For the latest stable version, please use Spring Security 6.4.3!spring-doc.cn
Observability
Spring Security integrates with Spring Observability out-of-the-box for tracing; though it’s also quite simple to configure for gathering metrics.spring-doc.cn
Tracing
When an ObservationRegistry bean is present, Spring Security creates traces for:spring-doc.cn
Boot Integration
For example, consider a simple Boot application:spring-doc.cn
@SpringBootApplication
public class MyApplication {
	public UserDetailsService userDetailsService() {
		return new InMemoryUserDetailsManager(
				User.withDefaultPasswordEncoder()
						.username("user")
						.password("password")
						.authorities("app")
						.build()
	ObservationRegistryCustomizer<ObservationRegistry> addTextHandler() {
		return (registry) -> registry.observationConfig().observationHandler(new ObservationTextPublisher());
		SpringApplication.run(ListenerSamplesApplication.class, args);
	fun userDetailsService(): UserDetailsService {
						.username("user")
						.authorities("app")
						.build()
	fun addTextHandler(): ObservationRegistryCustomizer<ObservationRegistry> {
		return registry: ObservationRegistry -> registry.observationConfig()
				.observationHandler(ObservationTextPublisher());
	fun main(args: Array<String>) {
		runApplication<MyApplication>(*args)
And a corresponding request:spring-doc.cn
?> http -a user:password :8080
Will produce the following output (indentation added for clarity):spring-doc.cn
START - name='http.server.requests', contextualName='null', error='null', lowCardinalityKeyValues=[], highCardinalityKeyValues=[], map=[class io.micrometer.core.instrument.Timer$Sample='io.micrometer.core.instrument.Timer$Sample@687e16d1', class io.micrometer.core.instrument.LongTaskTimer$Sample='SampleImpl{duration(seconds)=0.001779024, duration(nanos)=1779024.0, startTimeNanos=91695917264958}']
	START - name='spring.security.http.chains', contextualName='spring.security.http.chains.before', error='null', lowCardinalityKeyValues=[chain.position='0', chain.size='17', filter.section='before'], highCardinalityKeyValues=[request.line='GET /'], map=[class io.micrometer.core.instrument.Timer$Sample='io.micrometer.core.instrument.Timer$Sample@79f554a5', class io.micrometer.core.instrument.LongTaskTimer$Sample='SampleImpl{duration(seconds)=7.42147E-4, duration(nanos)=742147.0, startTimeNanos=91695947182029}']
	... skipped for brevity ...
	STOP - name='spring.security.http.chains', contextualName='spring.security.http.chains.before', error='null', lowCardinalityKeyValues=[chain.position='0', chain.size='17', filter.section='before'], highCardinalityKeyValues=[request.line='GET /'], map=[class io.micrometer.core.instrument.Timer$Sample='io.micrometer.core.instrument.Timer$Sample@79f554a5', class io.micrometer.core.instrument.LongTaskTimer$Sample='SampleImpl{duration(seconds)=0.014771848, duration(nanos)=1.4771848E7, startTimeNanos=91695947182029}']
		START - name='spring.security.authentications', contextualName='null', error='null', lowCardinalityKeyValues=[authentication.failure.type='Optional', authentication.method='ProviderManager', authentication.request.type='UsernamePasswordAuthenticationToken'], highCardinalityKeyValues=[], map=[class io.micrometer.core.instrument.Timer$Sample='io.micrometer.core.instrument.Timer$Sample@4d4b2b56', class io.micrometer.core.instrument.LongTaskTimer$Sample='SampleImpl{duration(seconds)=7.09759E-4, duration(nanos)=709759.0, startTimeNanos=91696094477504}']
		STOP - name='spring.security.authentications', contextualName='null', error='null', lowCardinalityKeyValues=[authentication.failure.type='Optional', authentication.method='ProviderManager', authentication.request.type='UsernamePasswordAuthenticationToken', authentication.result.type='UsernamePasswordAuthenticationToken'], highCardinalityKeyValues=[], map=[class io.micrometer.core.instrument.Timer$Sample='io.micrometer.core.instrument.Timer$Sample@4d4b2b56', class io.micrometer.core.instrument.LongTaskTimer$Sample='SampleImpl{duration(seconds)=0.895141386, duration(nanos)=8.95141386E8, startTimeNanos=91696094477504}']
		START - name='spring.security.authorizations', contextualName='null', error='null', lowCardinalityKeyValues=[object.type='Servlet3SecurityContextHolderAwareRequestWrapper'], highCardinalityKeyValues=[], map=[class io.micrometer.core.instrument.Timer$Sample='io.micrometer.core.instrument.Timer$Sample@6d834cc7', class io.micrometer.core.instrument.LongTaskTimer$Sample='SampleImpl{duration(seconds)=3.0965E-4, duration(nanos)=309650.0, startTimeNanos=91697034893983}']
		STOP - name='spring.security.authorizations', contextualName='null', error='null', lowCardinalityKeyValues=[authorization.decision='true', object.type='Servlet3SecurityContextHolderAwareRequestWrapper'], highCardinalityKeyValues=[authentication.authorities='[app]', authorization.decision.details='AuthorizationDecision [granted=true]'], map=[class io.micrometer.core.instrument.Timer$Sample='io.micrometer.core.instrument.Timer$Sample@6d834cc7', class io.micrometer.core.instrument.LongTaskTimer$Sample='SampleImpl{duration(seconds)=0.02084809, duration(nanos)=2.084809E7, startTimeNanos=91697034893983}']
		START - name='spring.security.http.secured.requests', contextualName='null', error='null', lowCardinalityKeyValues=[], highCardinalityKeyValues=[], map=[class io.micrometer.core.instrument.Timer$Sample='io.micrometer.core.instrument.Timer$Sample@649c5ec3', class io.micrometer.core.instrument.LongTaskTimer$Sample='SampleImpl{duration(seconds)=2.67878E-4, duration(nanos)=267878.0, startTimeNanos=91697059819304}']
		STOP - name='spring.security.http.secured.requests', contextualName='null', error='null', lowCardinalityKeyValues=[], highCardinalityKeyValues=[], map=[class io.micrometer.core.instrument.Timer$Sample='io.micrometer.core.instrument.Timer$Sample@649c5ec3', class io.micrometer.core.instrument.LongTaskTimer$Sample='SampleImpl{duration(seconds)=0.090753322, duration(nanos)=9.0753322E7, startTimeNanos=91697059819304}']
	START - name='spring.security.http.chains', contextualName='spring.security.http.chains.after', error='null', lowCardinalityKeyValues=[chain.position='0', chain.size='17', filter.section='after'], highCardinalityKeyValues=[request.line='GET /'], map=[class io.micrometer.core.instrument.Timer$Sample='io.micrometer.core.instrument.Timer$Sample@47af8207', class io.micrometer.core.instrument.LongTaskTimer$Sample='SampleImpl{duration(seconds)=5.31832E-4, duration(nanos)=531832.0, startTimeNanos=91697152857268}']
	STOP - name='spring.security.http.chains', contextualName='spring.security.http.chains.after', error='null', lowCardinalityKeyValues=[chain.position='17', chain.size='17', current.filter.name='DisableEncodeUrlFilter', filter.section='after'], highCardinalityKeyValues=[request.line='GET /'], map=[class io.micrometer.core.instrument.Timer$Sample='io.micrometer.core.instrument.Timer$Sample@47af8207', class io.micrometer.core.instrument.LongTaskTimer$Sample='SampleImpl{duration(seconds)=0.007689382, duration(nanos)=7689382.0, startTimeNanos=91697152857268}']
STOP - name='http.server.requests', contextualName='null', error='null', lowCardinalityKeyValues=[], highCardinalityKeyValues=[request.line='GET /'], map=[class io.micrometer.core.instrument.Timer$Sample='io.micrometer.core.instrument.Timer$Sample@687e16d1', class io.micrometer.core.instrument.LongTaskTimer$Sample='SampleImpl{duration(seconds)=1.245858319, duration(nanos)=1.245858319E9, startTimeNanos=91695917264958}']
Manual Configuration
For a non-Spring Boot application, or to override the existing Boot configuration, you can publish your own ObservationRegistry and Spring Security will still pick it up.spring-doc.cn
						.username("user")
						.authorities("app")
						.build()
	ObservationRegistry<ObservationRegistry> observationRegistry() {
		ObservationRegistry registry = ObservationRegistry.create();
		return registry;
						.username("user")
						.authorities("app")
						.build()
	fun observationRegistry(): ObservationRegistry<ObservationRegistry> {
		registry.observationConfig().observationHandler(ObservationTextPublisher())
		return registry
<sec:http auto-config="true" observation-registry-ref="ref">
	<sec:intercept-url pattern="/**" access="authenticated"/>
</sec:http>
<!-- define and configure ObservationRegistry bean -->
Disabling Observability
If you don’t want any Spring Security observations, in a Spring Boot application you can publish a ObservationRegistry.NOOP @Bean. However, this may turn off observations for more than just Spring Security.spring-doc.cn
Instead, you can alter the provided ObservationRegistry with an ObservationPredicate like the following:spring-doc.cn
ObservationRegistryCustomizer<ObservationRegistry> noSpringSecurityObservations() {
	ObservationPredicate predicate = (name, context) -> !name.startsWith("spring.security.");
	return (registry) -> registry.observationConfig().observationPredicate(predicate);
fun noSpringSecurityObservations(): ObservationRegistryCustomizer<ObservationRegistry> {
	ObservationPredicate predicate = (name: String, context: Observation.Context) -> !name.startsWith("spring.security.")
	(registry: ObservationRegistry) -> registry.observationConfig().observationPredicate(predicate)
There is no facility for disabling observations with XML support. Instead, simply do not set the observation-registry-ref attribute.
Trace Listing
Spring Security tracks the following spans on each request:spring-doc.cn
  1. spring.security.http.requests - a span that wraps the entire filter chain, including the requestspring-doc.cn
  2. spring.security.http.chains.before - a span that wraps the receiving part of the security filtersspring-doc.cn
  3. spring.security.http.chains.after - a span that wraps the returning part of the security filtersspring-doc.cn
  4. spring.security.http.secured.requests - a span that wraps the now-secured application requestspring-doc.cn
  5. spring.security.http.unsecured.requests - a span that wraps requests that Spring Security does not securespring-doc.cn
  6. spring.security.authentications - a span that wraps authentication attemptsspring-doc.cn
  7. spring.security.authorizations - a span that wraps authorization attemptsspring-doc.cn
spring.security.http.chains.before + spring.security.http.secured.requests + spring.security.http.chains.after = spring.security.http.requests spring.security.http.chains.before + spring.security.http.chains.after = Spring Security’s part of the request
