For the latest stable version, please use Spring Security 6.4.3!spring-doc.cn
Security HTTP Response Headers
You can use Security HTTP Response Headers to increase the security of web applications. This section is dedicated to servlet-based support for Security HTTP Response Headers.spring-doc.cn
Default Security Headers
Spring Security provides a default set of Security HTTP Response Headers to provide secure defaults. While each of these headers are considered best practice, it should be noted that not all clients use the headers, so additional testing is encouraged.spring-doc.cn
You can customize specific headers. For example, assume that you want the defaults but you wish to specify SAMEORIGIN for X-Frame-Options.spring-doc.cn
You can do so with the following configuration:spring-doc.cn
Customize Default Security Headers
@EnableWebSecurity
public class WebSecurityConfig {
		http
			.headers(headers -> headers
				.frameOptions(frameOptions -> frameOptions
					.sameOrigin()
		return http.build();
<http>
	<headers>
		<frame-options policy="SAMEORIGIN" />
	</headers>
</http>
@EnableWebSecurity
class SecurityConfig {
        http {
            headers {
                frameOptions {
                    sameOrigin = true
        return http.build()
If you do not want the defaults to be added and want explicit control over what should be used, you can disable the defaults. The next code listing shows how to do so.spring-doc.cn
If you use Spring Security’s configuration, the following adds only Cache Control:spring-doc.cn
Customize Cache Control Headers
@EnableWebSecurity
		http
				// do not use any default headers unless explicitly listed
				.defaultsDisabled()
				.cacheControl(withDefaults())
<http>
	<headers defaults-disabled="true">
		<cache-control/>
	</headers>
</http>
@EnableWebSecurity
        http {
            headers {
                defaultsDisabled = true
                cacheControl {
        return http.build()
If necessary, you can disable all of the HTTP Security response headers with the following configuration:spring-doc.cn
Disable All HTTP Security Headers
@EnableWebSecurity
		http
			.headers(headers -> headers.disable());
<http>
	<headers disabled="true" />
</http>
@EnableWebSecurity
        http {
            headers {
                disable()
        return http.build()
Cache Control
Spring Security includes Cache Control headers by default.spring-doc.cn
However, if you actually want to cache specific responses, your application can selectively invoke HttpServletResponse.setHeader(String,String) to override the header set by Spring Security. You can use this to ensure that content (such as CSS, JavaScript, and images) is properly cached.spring-doc.cn
When you use Spring Web MVC, this is typically done within your configuration. You can find details on how to do this in the Static Resources portion of the Spring Reference documentationspring-doc.cn
If necessary, you can also disable Spring Security’s cache control HTTP response headers.spring-doc.cn
Cache Control Disabled
@EnableWebSecurity
		http
				.cacheControl(cache -> cache.disable())
<http>
	<headers>
		<cache-control disabled="true"/>
	</headers>
</http>
@EnableWebSecurity
       http {
            headers {
                cacheControl {
                    disable()
        return http.build()
Content Type Options
Spring Security includes Content-Type headers by default. However, you can disable it:spring-doc.cn
Content Type Options Disabled
@EnableWebSecurity
		http
				.contentTypeOptions(contentTypeOptions -> contentTypeOptions.disable())
<http>
	<headers>
		<content-type-options disabled="true"/>
	</headers>
</http>
@EnableWebSecurity
       http {
            headers {
                contentTypeOptions {
                    disable()
        return http.build()
HTTP Strict Transport Security (HSTS)
By default, Spring Security provides the Strict Transport Security header. However, you can explicitly customize the results. The following example explicitly provides HSTS:spring-doc.cn
@EnableWebSecurity
		http
				.httpStrictTransportSecurity(hsts -> hsts
					.includeSubDomains(true)
					.preload(true)
					.maxAgeInSeconds(31536000)
<http>
	<headers>
		<hsts
			include-subdomains="true"
			max-age-seconds="31536000"
			preload="true" />
	</headers>
</http>
@EnableWebSecurity
        http {
            headers {
                httpStrictTransportSecurity {
                    includeSubDomains = true
                    preload = true
                    maxAgeInSeconds = 31536000
        return http.build()
HTTP Public Key Pinning (HPKP)
Spring Security provides servlet support for HTTP Public Key Pinning, but it is no longer recommended.spring-doc.cn
You can enable HPKP headers with the following configuration:spring-doc.cn
@EnableWebSecurity
		http
				.httpPublicKeyPinning(hpkp -> hpkp
					.reportUri("https://example.net/pkp-report")
					.addSha256Pins("d6qzRu9zOECb90Uez27xWltNsj0e1Md7GkYYkVoZWmM=", "E9CZ9INDbd+2eRQozYqqbQ2yXLVKB9+xcprMF+44U1g=")
<http>
	<headers>
		<hpkp
			report-uri="https://example.net/pkp-report">
			<pins>
				<pin algorithm="sha256">d6qzRu9zOECb90Uez27xWltNsj0e1Md7GkYYkVoZWmM=</pin>
				<pin algorithm="sha256">E9CZ9INDbd+2eRQozYqqbQ2yXLVKB9+xcprMF+44U1g=</pin>
			</pins>
		</hpkp>
	</headers>
</http>
@EnableWebSecurity
        http {
            headers {
                httpPublicKeyPinning {
                    reportUri = "https://example.net/pkp-report"
                    pins = mapOf("d6qzRu9zOECb90Uez27xWltNsj0e1Md7GkYYkVoZWmM=" to "sha256",
                            "E9CZ9INDbd+2eRQozYqqbQ2yXLVKB9+xcprMF+44U1g=" to "sha256")
        return http.build()
X-Frame-Options
By default, Spring Security instructs browsers to block reflected XSS attacks by using the X-Frame-Options.spring-doc.cn
For example, the following configuration specifies that Spring Security should no longer instruct browsers to block the content:spring-doc.cn
X-Frame-Options: SAMEORIGIN
@EnableWebSecurity
		http
					.sameOrigin()
<http>
	<headers>
		<frame-options
	</headers>
</http>
@EnableWebSecurity
        http {
            headers {
                frameOptions {
                    sameOrigin = true
        return http.build()
X-XSS-Protection
By default, Spring Security instructs browsers to disable the XSS Auditor by using <<headers-xss-protection,X-XSS-Protection header>. However, you can change this default. For example, the following configuration specifies that Spring Security instruct compatible browsers to enable filtering, and block the content:spring-doc.cn
X-XSS-Protection Customization
@EnableWebSecurity
		http
				.xssProtection(xss -> xss
					.headerValue(XXssProtectionHeaderWriter.HeaderValue.ENABLED_MODE_BLOCK)
<http>
	<headers>
		<xss-protection headerValue="1; mode=block"/>
	</headers>
</http>
@EnableWebSecurity
        http {
            headers {
                xssProtection {
                    headerValue = XXssProtectionHeaderWriter.HeaderValue.ENABLED_MODE_BLOCK
        return http.build()
Content Security Policy (CSP)
Spring Security does not add Content Security Policy by default, because a reasonable default is impossible to know without knowing the context of the application. The web application author must declare the security policy (or policies) to enforce or monitor for the protected resources.spring-doc.cn
Consider the following security policy:spring-doc.cn
Content Security Policy Example
Content-Security-Policy: script-src 'self' https://trustedscripts.example.com; object-src https://trustedplugins.example.com; report-uri /csp-report-endpoint/
Given the preceding security policy, you can enable the CSP header:spring-doc.cn
@EnableWebSecurity
		http
				.contentSecurityPolicy(csp -> csp
					.policyDirectives("script-src 'self' https://trustedscripts.example.com; object-src https://trustedplugins.example.com; report-uri /csp-report-endpoint/")
<http>
	<headers>
		<content-security-policy
			policy-directives="script-src 'self' https://trustedscripts.example.com; object-src https://trustedplugins.example.com; report-uri /csp-report-endpoint/" />
	</headers>
</http>
@EnableWebSecurity
        http {
            headers {
                contentSecurityPolicy {
                    policyDirectives = "script-src 'self' https://trustedscripts.example.com; object-src https://trustedplugins.example.com; report-uri /csp-report-endpoint/"
        return http.build()
To enable the CSP report-only header, provide the following configuration:spring-doc.cn
Content Security Policy Report Only
@EnableWebSecurity
		http
					.reportOnly()
<http>
	<headers>
			report-only="true" />
	</headers>
</http>
@EnableWebSecurity
        http {
            headers {
                    reportOnly = true
        return http.build()
Referrer Policy
Spring Security does not add Referrer Policy headers by default. You can enable the Referrer Policy header by using the configuration:spring-doc.cn
Referrer Policy
@EnableWebSecurity
		http
				.referrerPolicy(referrer -> referrer
					.policy(ReferrerPolicy.SAME_ORIGIN)
<http>
	<headers>
		<referrer-policy policy="same-origin" />
	</headers>
</http>
@EnableWebSecurity
        http {
            headers {
                referrerPolicy {
                    policy = ReferrerPolicy.SAME_ORIGIN
        return http.build()
Feature Policy
Spring Security does not add Feature Policy headers by default. Consider the following Feature-Policy header:spring-doc.cn
Feature-Policy Example
Feature-Policy: geolocation 'self'
You can enable the preceding feature policy header by using the following configuration:spring-doc.cn
Feature-Policy
@EnableWebSecurity
		http
				.featurePolicy("geolocation 'self'")
<http>
	<headers>
		<feature-policy policy-directives="geolocation 'self'" />
	</headers>
</http>
@EnableWebSecurity
        http {
            headers {
        return http.build()
Permissions Policy
Spring Security does not add Permissions Policy headers by default. Consider the following Permissions-Policy header:spring-doc.cn
Permissions-Policy Example
Permissions-Policy: geolocation=(self)
You can enable the preceding permissions policy header using the following configuration:spring-doc.cn
Permissions-Policy
@EnableWebSecurity
		http
				.permissionsPolicy(permissions -> permissions
					.policy("geolocation=(self)")
<http>
	<headers>
		<permissions-policy policy="geolocation=(self)" />
	</headers>
</http>
@EnableWebSecurity
        http {
            headers {
                permissionPolicy {
                    policy = "geolocation=(self)"
        return http.build()
Clear Site Data
Spring Security does not add Clear-Site-Data headers by default. Consider the following Clear-Site-Data header:spring-doc.cn
Clear-Site-Data Example
Clear-Site-Data: "cache", "cookies"
You can send the preceding header on log out with the following configuration:spring-doc.cn
Clear-Site-Data
@EnableWebSecurity
		http
			.logout((logout) -> logout
                .addLogoutHandler(new HeaderWriterLogoutHandler(new ClearSiteDataHeaderWriter(CACHE, COOKIES)))
@EnableWebSecurity
        http {
            logout {
                addLogoutHandler(HeaderWriterLogoutHandler(ClearSiteDataHeaderWriter(CACHE, COOKIES)))
        return http.build()
Custom Headers
Spring Security has mechanisms to make it convenient to add the more common security headers to your application. However, it also provides hooks to enable adding custom headers.spring-doc.cn
Static Headers
There may be times when you wish to inject custom security headers that are not supported out of the box into your application. Consider the following custom security header:spring-doc.cn
X-Custom-Security-Header: header-value
Given the preceding header, you could add the headers to the response by using the following configuration:spring-doc.cn
StaticHeadersWriter
@EnableWebSecurity
		http
				.addHeaderWriter(new StaticHeadersWriter("X-Custom-Security-Header","header-value"))
<http>
	<headers>
		<header name="X-Custom-Security-Header" value="header-value"/>
	</headers>
</http>
@EnableWebSecurity
        http {
            headers {
                addHeaderWriter(StaticHeadersWriter("X-Custom-Security-Header","header-value"))
        return http.build()
Headers Writer
When the namespace or Java configuration does not support the headers you want, you can create a custom HeadersWriter instance or even provide a custom implementation of the HeadersWriter.spring-doc.cn
The next example use a custom instance of XFrameOptionsHeaderWriter. If you wanted to explicitly configure X-Frame-Options, you could do so with the following configuration:spring-doc.cn
Headers Writer
@EnableWebSecurity
		http
				.addHeaderWriter(new XFrameOptionsHeaderWriter(XFrameOptionsMode.SAMEORIGIN))
<http>
	<headers>
		<header ref="frameOptionsWriter"/>
	</headers>
</http>
<!-- Requires the c-namespace.
See https://docs.spring.io/spring/docs/current/spring-framework-reference/htmlsingle/#beans-c-namespace
<beans:bean id="frameOptionsWriter"
	class="org.springframework.security.web.header.writers.frameoptions.XFrameOptionsHeaderWriter"
	c:frameOptionsMode="SAMEORIGIN"/>
@EnableWebSecurity
        http {
            headers {
                addHeaderWriter(XFrameOptionsHeaderWriter(XFrameOptionsMode.SAMEORIGIN))
        return http.build()
DelegatingRequestMatcherHeaderWriter
At times, you may want to write a header only for certain requests. For example, perhaps you want to protect only your login page from being framed. You could use the DelegatingRequestMatcherHeaderWriter to do so.spring-doc.cn
The following configuration example uses DelegatingRequestMatcherHeaderWriter:spring-doc.cn
DelegatingRequestMatcherHeaderWriter Java Configuration
@EnableWebSecurity
		RequestMatcher matcher = new AntPathRequestMatcher("/login");
		DelegatingRequestMatcherHeaderWriter headerWriter =
			new DelegatingRequestMatcherHeaderWriter(matcher,new XFrameOptionsHeaderWriter());
		http
				.frameOptions(frameOptions -> frameOptions.disable())
				.addHeaderWriter(headerWriter)
<http>
	<headers>
		<frame-options disabled="true"/>
		<header ref="headerWriter"/>
	</headers>
</http>
<beans:bean id="headerWriter"
	class="org.springframework.security.web.header.writers.DelegatingRequestMatcherHeaderWriter">
	<beans:constructor-arg>
		<bean class="org.springframework.security.web.util.matcher.AntPathRequestMatcher"
			c:pattern="/login"/>
	</beans:constructor-arg>
		<beans:bean
			class="org.springframework.security.web.header.writers.frameoptions.XFrameOptionsHeaderWriter"/>
</beans:bean>
@EnableWebSecurity
        val matcher: RequestMatcher = AntPathRequestMatcher("/login")
        val headerWriter = DelegatingRequestMatcherHeaderWriter(matcher, XFrameOptionsHeaderWriter())
       http {
            headers {
                frameOptions {
                    disable()
        return http.build()
