Topic Resolution
A destination topic is needed when producing or consuming messages. The framework looks in the following ordered locations to determine a topic (stopping at the first find):
User specified
Message type default
Global default
When a topic is found via one of the default mechanisms, there is no need to specify the topic on the produce or consume API.
When a topic is not found, the API will throw an exception accordingly.
1. User specified
A topic passed into the API being used has the highest precedence (eg. PulsarTemplate.send("my-topic", myMessage)
or @PulsarListener(topics = "my-topic"
2. Message type default
When no topic is passed into the API, the system looks for a message type to topic mapping configured for the type of the message being produced or consumed.
Mappings can be configured with the spring.pulsar.defaults.type-mappings
property.
The following example uses application.yml
to configure default topics to use when consuming or producing Foo
or Bar
spring:
pulsar:
defaults:
type-mappings:
- message-type: com.acme.Foo
topic-name: foo-topic
- message-type: com.acme.Bar
topic-name: bar-topic
The message-type is the fully-qualified name of the message class.
If the message (or the first message of a Publisher input) is null , the framework won’t be able to determine the topic from it. Another method shall be used to specify the topic if your application is likely to send null messages.
2.1. Specified via annotation
When no topic is passed into the API and there are no custom topic mappings configured, the system looks for a @PulsarMessage
annotation on the class of the message being produced or consumed.
The default topic can be specified via the topic
attribute on the annotation.
The following example configures the default topic to use when producing or consuming messages of type Foo
@PulsarMessage(topic = "foo-topic")
record Foo(String value) {
Property placeholders and SpEL expressions are supported in the @PulsarMessage
annotation,
for example:
@PulsarMessage(topic = "${app.topics.foo}")
@PulsarMessage(topic = "#{someBean.getTopic()}")
record Bar(String value) {
2.2. Custom topic resolver
The preferred method of adding mappings is via the property mentioned above. However, if more control is needed you can replace the default resolver by proving your own implementation, for example:
public MyTopicResolver topicResolver() {
return new MyTopicResolver();
3. Producer global default
The final location consulted (when producing) is the system-wide producer default topic.
It is configured via the spring.pulsar.producer.topic-name
property when using the imperative API and the spring.pulsar.reactive.sender.topic-name
property when using the reactive API.
4. Consumer global default
The final location consulted (when consuming) is the system-wide consumer default topic.
It is configured via the spring.pulsar.consumer.topics
or spring.pulsar.consumer.topics-pattern
property when using the imperative API and one of the spring.pulsar.reactive.consumer.topics
or spring.pulsar.reactive.consumer.topics-pattern
