Quick Tour
We will take a quick tour of the Reactive support in Spring for Apache Pulsar by showing a sample Spring Boot application that produces and consumes in a Reactive fashion.
This is a complete application and does not require any additional configuration, as long as you have a Pulsar cluster running on the default location - localhost:6650
1. Dependencies
Spring Boot applications need only the spring-boot-starter-pulsar-reactive
dependency. The following listings show how to define the dependency for Maven and Gradle, respectively:
Maven
Gradle
<dependencies>
<dependency>
<artifactId>spring-boot-starter-pulsar-reactive</artifactId>
<version>3.3.7-SNAPSHOT</version>
</dependency>
</dependencies>
dependencies {
implementation 'org.springframework.boot:spring-boot-starter-pulsar-reactive:3.3.7-SNAPSHOT'
2. Application Code
Here is the application source code:
@SpringBootApplication
public class ReactiveSpringPulsarHelloWorld {
SpringApplication.run(ReactiveSpringPulsarHelloWorld.class, args);
ApplicationRunner runner(ReactivePulsarTemplate<String> pulsarTemplate) {
return (args) -> pulsarTemplate.send("hello-pulsar-topic", "Hello Reactive Pulsar World!").subscribe();
@ReactivePulsarListener(subscriptionName = "hello-pulsar-sub", topics = "hello-pulsar-topic")
Mono<Void> listen(String message) {
System.out.println("Reactive listener received: " + message);
return Mono.empty();
That is it, with just a few lines of code we have a working Spring Boot app that is producing and consuming messages from a Pulsar topic in a Reactive fashion.
Once started, the application uses a ReactivePulsarTemplate
to send messages to the hello-pulsar-topic
It then consumes from the hello-pulsar-topic
using a @ReactivePulsarListener
One of the key ingredients to the simplicity is the Spring Boot starter which auto-configures and provides the required components to the application |
