This version is still in development and is not considered stable yet. For the latest stable version, please use Spring for Apache Kafka 3.3.6!spring-doc.cn
Topic/Partition Initial Offset
There are several ways to set the initial offset for a partition.spring-doc.cn
When manually assigning partitions, you can set the initial offset (if desired) in the configured TopicPartitionOffset arguments (see Message Listener Containers). You can also seek to a specific offset at any time.spring-doc.cn
When you use group management where the broker assigns partitions:spring-doc.cn
  • For a new group.id, the initial offset is determined by the auto.offset.reset consumer property (earliest or latest).spring-doc.cn
  • For an existing group ID, the initial offset is the current offset for that group ID. You can, however, seek to a specific offset during initialization (or at any time thereafter).spring-doc.cn
