This version is still in development and is not considered stable yet. For the latest stable version, please use Spring for Apache Kafka 3.3.6!spring-doc.cn
Micrometer Observation Documentation
Observability - Metrics
Below you can find a list of all metrics declared by this project.spring-doc.cn
Listener Observation
Observation for Apache Kafka listeners.spring-doc.cn
Metric name spring.kafka.listener (defined by convention class KafkaListenerObservation$DefaultKafkaListenerObservationConvention). Type timer.spring-doc.cn
Metric name spring.kafka.listener.active (defined by convention class KafkaListenerObservation$DefaultKafkaListenerObservationConvention). Type long task timer.spring-doc.cn
KeyValues that are added after starting the Observation might be missing from the *.active metrics.
Micrometer internally uses nanoseconds for the baseunit. However, each backend determines the actual baseunit. (i.e. Prometheus uses seconds)
Name of the enclosing class KafkaListenerObservation.spring-doc.cn
Table 1. Low cardinality Keys
Descriptionspring-doc.cn
messaging.kafka.consumer.group (required)spring-doc.cn
Messaging the consumer group.spring-doc.cn
messaging.operation (required)spring-doc.cn
Messaging operation.spring-doc.cn
messaging.source.kind (required)spring-doc.cn
Messaging source kind.spring-doc.cn
messaging.source.name (required)spring-doc.cn
Messaging source name.spring-doc.cn
messaging.system (required)spring-doc.cn
Messaging system.spring-doc.cn
spring.kafka.listener.id (required)spring-doc.cn
Listener id (or listener container bean name).spring-doc.cn
Template Observation
Observation for KafkaTemplates.spring-doc.cn
Metric name spring.kafka.template (defined by convention class KafkaTemplateObservation$DefaultKafkaTemplateObservationConvention). Type timer.spring-doc.cn
Metric name spring.kafka.template.active (defined by convention class KafkaTemplateObservation$DefaultKafkaTemplateObservationConvention). Type long task timer.spring-doc.cn
Name of the enclosing class KafkaTemplateObservation.spring-doc.cn
Table 2. Low cardinality Keys
messaging.destination.kind (required)spring-doc.cn
Messaging destination kind.spring-doc.cn
messaging.destination.name (required)spring-doc.cn
Messaging destination name.spring-doc.cn
spring.kafka.template.name (required)spring-doc.cn
Bean name of the template.spring-doc.cn
Observability - Spans
Below you can find a list of all spans declared by this project.spring-doc.cn
Listener Observation Span
Span name spring.kafka.listener (defined by convention class KafkaListenerObservation$DefaultKafkaListenerObservationConvention).spring-doc.cn
Table 3. Tag Keys
Namespring-doc.cn
messaging.consumer.id (required)spring-doc.cn
Messaging consumer id (consumer group and client id).spring-doc.cn
messaging.kafka.client_id (required)spring-doc.cn
Messaging client id.spring-doc.cn
messaging.kafka.message.offset (required)spring-doc.cn
Messaging message offset.spring-doc.cn
messaging.kafka.source.partition (required)spring-doc.cn
Messaging partition.spring-doc.cn
Template Observation Span
Span name spring.kafka.template (defined by convention class KafkaTemplateObservation$DefaultKafkaTemplateObservationConvention).spring-doc.cn
Table 4. Tag Keys
Namespring-doc.cn
Observability - Conventions
Below you can find a list of all GlobalObservationConvention and ObservationConvention declared by this project.spring-doc.cn
Table 5. ObservationConvention implementations
ObservationConvention Class Namespring-doc.cn
Applicable ObservationContext Class Namespring-doc.cn
KafkaListenerObservationspring-doc.cn
KafkaRecordReceiverContextspring-doc.cn
KafkaListenerObservation.DefaultKafkaListenerObservationConventionspring-doc.cn
KafkaTemplateObservationspring-doc.cn
KafkaRecordSenderContextspring-doc.cn
KafkaTemplateObservation.DefaultKafkaTemplateObservationConventionspring-doc.cn
