附录 A:覆盖 Spring Boot 依赖项
在 Spring Boot 应用程序中使用 Spring for Apache Kafka 时,Apache Kafka 依赖项版本由 Spring Boot 的依赖项管理确定。 如果您希望使用其他版本的kafka-clientskafka-streams,并使用嵌入式 Kafka broker 进行测试,则需要覆盖 Spring Boot 依赖管理使用的版本,并添加两个testartifacts。spring-doc.cadn.net.cn
Maven 系列
<properties>
    <kafka.version>3.1.0</kafka.version>
</properties>
<dependency>
    <groupId>org.springframework.kafka</groupId>
    <artifactId>spring-kafka</artifactId>
</dependency>
<!-- optional - only needed when using kafka-streams -->
<dependency>
    <groupId>org.apache.kafka</groupId>
    <artifactId>kafka-streams</artifactId>
</dependency>
<dependency>
    <artifactId>spring-kafka-test</artifactId>
    <scope>test</scope>
</dependency>
<dependency>
    <artifactId>kafka-clients</artifactId>
    <classifier>test</classifier>
    <scope>test</scope>
    <version>${kafka.version}</version>
</dependency>
<dependency>
    <artifactId>kafka_2.13</artifactId>
    <scope>test</scope>
</dependency>
Gradle
ext['kafka.version'] = '2.8.1'
dependencies {
    implementation 'org.springframework.kafka:spring-kafka'
    implementation "org.apache.kafka:kafka-streams" // optional - only needed when using kafka-streams
    testImplementation ('org.springframework.kafka:spring-kafka-test') {
            // needed if downgrading to Apache Kafka 2.8.1
            exclude group: 'org.apache.zookeeper', module: 'zookeeper'
    testImplementation "org.apache.kafka:kafka-clients:${kafka.version}:test"
    testImplementation "org.apache.kafka:kafka_2.13:${kafka.version}:test"
仅当在测试中使用嵌入式 Kafka 代理时,才需要测试范围依赖项。spring-doc.cadn.net.cn
