此版本仍在开发中,尚未被视为稳定版本。对于最新的稳定版本,请使用 Spring Integration 6.3.1
Spring Integration 原生提供专用路由器类型,包括:
  • HeaderValueRouter
  • PayloadTypeRouter
  • ExceptionTypeRouter
  • RecipientListRouter
  • XPathRouter
与许多其他 DSL EIP 方法一样,该方法可以应用任何实现,或者为了方便起见,可以应用 a 作为 SpEL 表达式或 - 对。 此外,您可以使用 lambda 进行配置,并将 lambda 用于 . Fluent API 还提供了诸如对之类的选项,如以下示例所示:IntegrationFlowBuilderroute()AbstractMessageRouterStringrefmethodroute()Consumer<RouterSpec<MethodInvokingRouter>>AbstractMappingMessageRouterchannelMapping(String key, String channelName)
public IntegrationFlow routeFlowByLambda() {
    return IntegrationFlow.from("routerInput")
            .<Integer, Boolean>route(p -> p % 2 == 0,
                    m -> m.suffix("Channel")
                            .channelMapping(true, "even")
                            .channelMapping(false, "odd")
            .get();
以下示例显示了一个简单的基于表达式的路由器:
public IntegrationFlow routeFlowByExpression() {
            .route("headers['destChannel']")
            .get();
该方法采用 ,如以下示例所示:routeToRecipients()Consumer<RecipientListRouterSpec>
public IntegrationFlow recipientListFlow() {
    return IntegrationFlow.from("recipientListInput")
            .<String, String>transform(p -> p.replaceFirst("Payload", ""))
            .routeToRecipients(r -> r
                    .recipient("thing1-channel", "'thing1' == payload")
                    .recipientMessageSelector("thing2-channel", m ->
                            m.getHeaders().containsKey("recipient")
                                    && (boolean) m.getHeaders().get("recipient"))
                    .recipientFlow("'thing1' == payload or 'thing2' == payload or 'thing3' == payload",
                            f -> f.<String, String>transform(String::toUpperCase)
                                    .channel(c -> c.queue("recipientListSubFlow1Result")))
                    .recipientFlow((String p) -> p.startsWith("thing3"),
                            f -> f.transform("Hello "::concat)
                                    .channel(c -> c.queue("recipientListSubFlow2Result")))
                    .recipientFlow(new FunctionExpression<Message<?>>(m ->
                                    "thing3".equals(m.getPayload())),
                            f -> f.channel(c -> c.queue("recipientListSubFlow3Result")))
                    .defaultOutputToParentFlow())
            .get();
该定义允许您将路由器设置为网关,以继续处理主流中不匹配的消息。.defaultOutputToParentFlow().routeToRecipients()defaultOutput
