For the latest stable version, please use Spring Integration 6.5.0! |
Reactive Advice
Starting with version 5.3, a ReactiveRequestHandlerAdvice
can be used for request message handlers producing a Mono
replies.
A BiFunction<Message<?>, Mono<?>, Publisher<?>>
has to be provided for this advice and it is called from the Mono.transform()
operator on a reply produced by the intercepted handleRequestMessage()
method implementation.
Typically, such a Mono
customization is necessary when we would like to control network fluctuations via timeout()
, retry()
and similar support operators.
For example when we can an HTTP request over WebFlux client, we could use below configuration to not wait for response more than 5 seconds:
.handle(WebFlux.outboundGateway("https://somehost/"),
e -> e.customizeMonoReply((message, mono) -> mono.timeout(Duration.ofSeconds(5))));
The message
argument is the request message for the message handler and can be used to determine request-scope attributes.
The mono
argument is the result of this message handler’s handleRequestMessage()
A nested Mono.transform()
can also be called from this function to apply, for example, a Reactive Circuit Breaker.
