For the latest stable version, please use Spring Integration 6.5.0! |
Inbound Gateway
The inbound gateway supports all the attributes on the inbound channel adapter (except that 'channel' is replaced by 'request-channel'), plus some additional attributes. The following listing shows the available attributes:
Java DSL
Java
XML
@Bean // return the upper cased payload
public IntegrationFlow amqpInboundGateway(ConnectionFactory connectionFactory) {
return IntegrationFlow.from(Amqp.inboundGateway(connectionFactory, "foo"))
.transform(String.class, String::toUpperCase)
.get();
public MessageChannel amqpInputChannel() {
return new DirectChannel();
public AmqpInboundGateway inbound(SimpleMessageListenerContainer listenerContainer,
@Qualifier("amqpInputChannel") MessageChannel channel) {
AmqpInboundGateway gateway = new AmqpInboundGateway(listenerContainer);
gateway.setRequestChannel(channel);
gateway.setDefaultReplyTo("bar");
return gateway;
public SimpleMessageListenerContainer container(ConnectionFactory connectionFactory) {
SimpleMessageListenerContainer container =
new SimpleMessageListenerContainer(connectionFactory);
container.setQueueNames("foo");
container.setConcurrentConsumers(2);
return container;
@ServiceActivator(inputChannel = "amqpInputChannel")
public MessageHandler handler() {
return new AbstractReplyProducingMessageHandler() {
protected Object handleRequestMessage(Message<?> requestMessage) {
return "reply to " + requestMessage.getPayload();
<int-amqp:inbound-gateway
id="inboundGateway" (1)
request-channel="myRequestChannel" (2)
header-mapper="" (3)
mapped-request-headers="" (4)
mapped-reply-headers="" (5)
reply-channel="myReplyChannel" (6)
reply-timeout="1000" (7)
amqp-template="" (8)
default-reply-to="" /> (9)
1 | The Unique ID for this adapter. Optional. |
2 | Message channel to which converted messages are sent. Required. |
3 | A reference to an AmqpHeaderMapper to use when receiving AMQP Messages.
Optional.
By default, only standard AMQP properties (such as contentType ) are copied to and from Spring Integration MessageHeaders .
Any user-defined headers within the AMQP MessageProperties are not copied to or from an AMQP message by the default DefaultAmqpHeaderMapper .
Not allowed if 'request-header-names' or 'reply-header-names' is provided. |
4 | Comma-separated list of names of AMQP Headers to be mapped from the AMQP request into the MessageHeaders .
This attribute can be provided only if the 'header-mapper' reference is not provided.
The values in this list can also be simple patterns to be matched against the header names (e.g. "*" or "thing1*, thing2" or "*thing1" ). |
5 | Comma-separated list of names of MessageHeaders to be mapped into the AMQP message properties of the AMQP reply message.
All standard Headers (such as contentType ) are mapped to AMQP Message Properties, while user-defined headers are mapped to the 'headers' property.
This attribute can only be provided if the 'header-mapper' reference is not provided.
The values in this list can also be simple patterns to be matched against the header names (for example, "*" or "foo*, bar" or "*foo" ). |
6 | Message Channel where reply Messages are expected. Optional. |
7 | Sets the receiveTimeout on the underlying o.s.i.core.MessagingTemplate for receiving messages from the reply channel.
If not specified, this property defaults to 1000 (1 second).
Only applies if the container thread hands off to another thread before the reply is sent. |
8 | The customized AmqpTemplate bean reference (to have more control over the reply messages to send).
You can provide an alternative implementation to the RabbitTemplate . |
9 | The replyTo o.s.amqp.core.Address to be used when the requestMessage does not have a replyTo
property.
If this option is not specified, no amqp-template is provided, no replyTo property exists in the request message, and
an IllegalStateException is thrown because the reply cannot be routed.
If this option is not specified and an external amqp-template is provided, no exception is thrown.
You must either specify this option or configure a default exchange and routingKey on that template,
if you anticipate cases when no replyTo property exists in the request message. |
See the note in Inbound Channel Adapter about configuring the listener-container
attribute.
Starting with version 5.5, the AmqpInboundChannelAdapter
can be configured with an org.springframework.amqp.rabbit.retry.MessageRecoverer
strategy which is used in the RecoveryCallback
when the retry operation is called internally.
See setMessageRecoverer()
JavaDocs for more information.
Batched Messages
See Batched Messages.
