SMB Support
Spring Integration provides support for file transfer operations with SMB.spring-doc.cn
The Server Message Block (SMB) is a simple network protocol that lets you transfer files to a shared file server.spring-doc.cn
You need to include this dependency into your project:spring-doc.cn
Maven
<dependency>
    <groupId>org.springframework.integration</groupId>
    <artifactId>spring-integration-smb</artifactId>
    <version>6.1.9</version>
</dependency>
Gradle
compile "org.springframework.integration:spring-integration-smb:6.1.9"
Overview
The Java CIFS Client Library has been chosen as a Java implementation for the CIFS/SMB networking protocol. Its SmbFile abstraction is simply wrapped to the Spring Integration "Remote File" foundations like SmbSession, SmbRemoteFileTemplate, etc.spring-doc.cn
The SMB Channel Adapters and support classes implementations are fully similar to existing components for (S)FTP or AWS S3 protocols. So, if you familiar with those components it is pretty straightforward to use.spring-doc.cn
Spring Integration supports sending and receiving files over SMB by providing three client-side endpoints: inbound channel adapter, outbound channel adapter, and outbound gateway. It also provides convenient namespace-based configuration options for defining these client components.spring-doc.cn
To use the SMB namespace, add the following to the header of your XML file:spring-doc.cn
xmlns:int-smb="http://www.springframework.org/schema/integration/smb"
xsi:schemaLocation="http://www.springframework.org/schema/integration/smb
    https://www.springframework.org/schema/integration/smb/spring-integration-smb.xsd"
SMB Session Factory
Before configuring the SMB adapter, you must configure an SMB session factory. You can configure the SMB session factory with a regular bean definition, as the following examples show:spring-doc.cn
The SmbSessionFactory exposes options to set the SMB protocol with Min/Max versions. For example, supporting a minimum version of SMB 2.1 and a maximum version of the SMB 3.1.1:spring-doc.cn
public SmbSessionFactory smbSessionFactory() {
    SmbSessionFactory smbSession = new SmbSessionFactory();
    smbSession.setHost("myHost");
    smbSession.setPort(445);
    smbSession.setDomain("myDomain");
    smbSession.setUsername("myUser");
    smbSession.setPassword("myPassword");
    smbSession.setShareAndDir("myShareAndDir");
    smbSession.setSmbMinVersion(DialectVersion.SMB210);
    smbSession.setSmbMaxVersion(DialectVersion.SMB311);
    return smbSession;
The SmbSessionFactory can be initialized with a custom jcifs.CIFSContext.spring-doc.cn
Setting of the SMB protocol Min/Max versions must be done in your implementation of jcifs.CIFSContext.
    SmbSessionFactory smbSession = new SmbSessionFactory(new MyCIFSContext());
    return smbSession;
SMB Inbound Channel Adapter
To download SMB files locally the SmbInboundFileSynchronizingMessageSource is provided. It is simple extension of the AbstractInboundFileSynchronizingMessageSource which requires SmbInboundFileSynchronizer injection. For filtering remote files you still can use any existing FileListFilter implementations, but particular SmbRegexPatternFileListFilter and SmbSimplePatternFileListFilter are provided.spring-doc.cn
public SmbInboundFileSynchronizer smbInboundFileSynchronizer() {
    SmbInboundFileSynchronizer fileSynchronizer =
        new SmbInboundFileSynchronizer(smbSessionFactory());
    fileSynchronizer.setFilter(compositeFileListFilter());
    fileSynchronizer.setRemoteDirectory("mySharedDirectoryPath");
    fileSynchronizer.setDeleteRemoteFiles(true);
    return fileSynchronizer;
public CompositeFileListFilter<SmbFile> compositeFileListFilter() {
    CompositeFileListFilter<SmbFile> filters = new CompositeFileListFilter<>();
    filters.addFilter(new SmbRegexPatternFileListFilter("^(?i).+((\\.txt))$"));
    return filters;
public MessageChannel smbFileInputChannel() {
    return new DirectChannel();
@InboundChannelAdapter(value = "smbFileInputChannel",
                       poller = @Poller(fixedDelay = "2000"))
public MessageSource<File> smbMessageSource() {
    SmbInboundFileSynchronizingMessageSource messageSource =
        new SmbInboundFileSynchronizingMessageSource(smbInboundFileSynchronizer());
    messageSource.setLocalDirectory(new File("myLocalDirectoryPath"));
    messageSource.setAutoCreateLocalDirectory(true);
    return messageSource;
For XML configuration the <int-smb:inbound-channel-adapter> component is provided.spring-doc.cn
Configuring with the Java DSL
The following Spring Boot application shows an example of how to configure the inbound adapter with the Java DSL:spring-doc.cn
@SpringBootApplication
public class SmbJavaApplication {
        new SpringApplicationBuilder(SmbJavaApplication.class)
            .web(false)
            .run(args);
        return smbSession;
    public IntegrationFlow smbInboundFlow() {
        return IntegrationFlow
            .from(Smb.inboundAdapter(smbSessionFactory())
                    .preserveTimestamp(true)
                    .remoteDirectory("smbSource")
                    .regexFilter(".*\\.txt$")
                    .localFilename(f -> f.toUpperCase() + ".a")
                    .localDirectory(new File("d:\\smb_files")),
                        e -> e.id("smbInboundAdapter")
                    .autoStartup(true)
                    .poller(Pollers.fixedDelay(5000)))
            .handle(m -> System.out.println(m.getPayload()))
            .get();
SMB Streaming Inbound Channel Adapter
This adapter produces message with payloads of type InputStream, letting files be fetched without writing to the local file system. Since the session remains open, the consuming application is responsible for closing the session when the file has been consumed. The session is provided in the closeableResource header (IntegrationMessageHeaderAccessor.CLOSEABLE_RESOURCE). Standard framework components, such as the FileSplitter and StreamTransformer, automatically close the session. See File Splitter and Stream Transformer for more information about these components. The following example shows how to configure an inbound-streaming-channel-adapter:spring-doc.cn
<int-smb:inbound-streaming-channel-adapter id="smbInbound"
            channel="smbChannel"
            session-factory="sessionFactory"
            filename-pattern="*.txt"
            filename-regex=".*\.txt"
            filter="filter"
            filter-expression="@myFilterBean.check(#root)"
            remote-file-separator="/"
            comparator="comparator"
            max-fetch-size="1"
            remote-directory-expression="'foo/bar'">
        <int:poller fixed-rate="1000" />
</int-smb:inbound-streaming-channel-adapter>
Only one of filename-pattern, filename-regex, filter, or filter-expression is allowed.spring-doc.cn
The SmbStreamingMessageSource adapter prevents duplicates for remote files with SmbPersistentAcceptOnceFileListFilter based on the in-memory SimpleMetadataStore. By default, this filter is also applied with the filename pattern (or regex). If you need to allow duplicates, you can use AcceptAllFileListFilter. Any other use cases can be handled by CompositeFileListFilter (or ChainFileListFilter). The Java configuration (later in the document) shows one technique to remove the remote file after processing to avoid duplicates.spring-doc.cn
For more information about the SmbPersistentAcceptOnceFileListFilter, and how it is used, see Remote Persistent File List Filters.spring-doc.cn
Use the max-fetch-size attribute to limit the number of files fetched on each poll when a fetch is necessary. Set it to 1 and use a persistent filter when running in a clustered environment. See Inbound Channel Adapters: Controlling Remote File Fetching for more information.spring-doc.cn
The adapter puts the remote directory and file name in the FileHeaders.REMOTE_DIRECTORY and FileHeaders.REMOTE_FILE headers, respectively. The FileHeaders.REMOTE_FILE_INFO header provides additional remote file information (represented in JSON by default). If you set the fileInfoJson property on the SmbStreamingMessageSource to false, the header contains an SmbFileInfo object.spring-doc.cn
Configuring with Java Configuration
The following Spring Boot application shows an example of how to configure the inbound adapter with Java configuration:spring-doc.cn
            .web(false)
            .run(args);
    @InboundChannelAdapter(channel = "stream")
    public MessageSource<InputStream> smbMessageSource() {
        SmbStreamingMessageSource messageSource = new SmbStreamingMessageSource(template());
        messageSource.setRemoteDirectory("smbSource/");
        messageSource.setFilter(new AcceptAllFileListFilter<>());
        messageSource.setMaxFetchSize(1);
    @Transformer(inputChannel = "stream", outputChannel = "data")
    public org.springframework.integration.transformer.Transformer transformer() {
        return new StreamTransformer("UTF-8");
    public SmbRemoteFileTemplate template() {
        return new SmbRemoteFileTemplate(smbSessionFactory());
    @ServiceActivator(inputChannel = "data", adviceChain = "after")
    public MessageHandler handle() {
        return System.out::println;
    public ExpressionEvaluatingRequestHandlerAdvice after() {
        ExpressionEvaluatingRequestHandlerAdvice advice = new ExpressionEvaluatingRequestHandlerAdvice();
        advice.setOnSuccessExpression(
                "@template.remove(headers['file_remoteDirectory'] + headers['file_remoteFile'])");
        advice.setPropagateEvaluationFailures(true);
        return advice;
Notice that, in this example, the message handler downstream of the transformer has an advice that removes the remote file after processing.spring-doc.cn
There are two properties that you should consider when you configure inbound channel adapters. max-messages-per-poll, as with all pollers, can be used to limit the number of messages emitted on each poll (if more than the configured value are ready). max-fetch-size can limit the number of files retrieved from the remote server at one time.spring-doc.cn
The following scenarios assume the starting state is an empty local directory:spring-doc.cn
  • max-messages-per-poll=2 and max-fetch-size=1: The adapter fetches one file, emits it, fetches the next file, emits it, and then sleeps until the next poll.spring-doc.cn
  • max-messages-per-poll=2 and max-fetch-size=2): The adapter fetches both files and then emits each one.spring-doc.cn
  • max-messages-per-poll=2 and max-fetch-size=4: The adapter fetches up to four files (if available) and emits the first two (if there are at least two). The next two files are emitted on the next poll.spring-doc.cn
  • max-messages-per-poll=2 and max-fetch-size not specified: The adapter fetches all remote files and emits the first two (if there are at least two). The subsequent files are emitted on subsequent polls (two at a time). When all files are consumed, the remote fetch is attempted again, to pick up any new files.spring-doc.cn
When you deploy multiple instances of an application, we recommend a small max-fetch-size, to avoid one instance “grabbing” all the files and starving other instances.
Another use for max-fetch-size is if you want to stop fetching remote files but continue to process files that have already been fetched. Setting the maxFetchSize property on the MessageSource (programmatically, with JMX, or with a control bus) effectively stops the adapter from fetching more files but lets the poller continue to emit messages for files that have previously been fetched. If the poller is active when the property is changed, the change takes effect on the next poll.spring-doc.cn
The synchronizer can be provided with a Comparator<SmbFile>. This is useful when restricting the number of files fetched with maxFetchSize.spring-doc.cn
SMB Outbound Channel Adapter
For writing files to an SMB share, and for XML <int-smb:outbound-channel-adapter> component we use the SmbMessageHandler. In case of Java configuration a SmbMessageHandler should be supplied with the SmbSessionFactory (or SmbRemoteFileTemplate).spring-doc.cn
@ServiceActivator(inputChannel = "storeToSmbShare")
public MessageHandler smbMessageHandler(SmbSessionFactory smbSessionFactory) {
    SmbMessageHandler handler = new SmbMessageHandler(smbSessionFactory);
    handler.setRemoteDirectoryExpression(
        new LiteralExpression("remote-target-dir"));
    handler.setFileNameGenerator(m ->
        m.getHeaders().get(FileHeaders.FILENAME, String.class) + ".test");
    handler.setAutoCreateDirectory(true);
    return handler;
The following Spring Boot application shows an example of how to configure the outbound adapter using the Java DSL:spring-doc.cn
@IntegrationComponentScan
        ConfigurableApplicationContext context =
                .web(false)
                .run(args);
        MyGateway gateway = context.getBean(MyGateway.class);
        gateway.sendToSmb(new File("/foo/bar.txt"));
        return smbSession;
    public IntegrationFlow smbOutboundFlow() {
        return IntegrationFlow.from("toSmbChannel")
                .handle(Smb.outboundAdapter(smbSessionFactory(), FileExistsMode.REPLACE)
                        .useTemporaryFileName(false)
                        .fileNameExpression("headers['" + FileHeaders.FILENAME + "']")
                        .remoteDirectory("smbTarget")
                ).get();
    @MessagingGateway
    public interface MyGateway {
         @Gateway(requestChannel = "toSmbChannel")
         void sendToSmb(File file);
SMB Outbound Gateway
The SMB outbound gateway provides a limited set of commands to interact with a remote SMB server. The supported commands are:spring-doc.cn
Using the ls Command
ls lists remote files and supports the following options:spring-doc.cn
  • -1: Retrieve a list of filenames. The default is to retrieve a list of FileInfo objectsspring-doc.cn
  • -a: Include all files (including those starting with '.')spring-doc.cn
  • -f: Do not sort the listspring-doc.cn
  • -dirs: Include directories (excluded by default)spring-doc.cn
  • -links: Include symbolic links (excluded by default)spring-doc.cn
  • -R: List the remote directory recursivelyspring-doc.cn
In addition, filename filtering is provided in the same manner as the inbound-channel-adapter.spring-doc.cn
The message payload resulting from an ls operation is a list of file names or a list of FileInfo objects (depending on whether you usr the -1 switch). These objects provide information such as modified time, permissions, and others.spring-doc.cn
The remote directory that the ls command acted on is provided in the file_remoteDirectory header.spring-doc.cn
When using the recursive option (-R), the fileName includes any subdirectory elements and represents the relative path to the file (relative to the remote directory). If you use the -dirs option, each recursive directory is also returned as an element in the list. In this case, we recommend that you not use the -1 option, because you would not be able to distinguish files from directories, which you can do when you use FileInfo objects.spring-doc.cn
Using nlst Command
nlst lists remote file names and supports only one option:spring-doc.cn
The message payload resulting from an nlst operation is a list of file names.spring-doc.cn
The file_remoteDirectory header holds the remote directory on which the nlst command acted.spring-doc.cn
Using the get Command
get retrieves a remote file and supports the following options:spring-doc.cn
  • -P: Preserve the timestamp of the remote file.spring-doc.cn
  • -stream: Retrieve the remote file as a stream.spring-doc.cn
  • -D: Delete the remote file after successful transfer. The remote file is not deleted if the transfer is ignored, because the FileExistsMode is IGNORE and the local file already exists.spring-doc.cn
The file_remoteDirectory header holds the remote directory, and the file_remoteFile header holds the filename.spring-doc.cn
The message payload resulting from a get operation is a File object representing the retrieved file. If you use the -stream option, the payload is an InputStream rather than a File. For text files, a common use case is to combine this operation with a file splitter or a stream transformer. When consuming remote files as streams, you are responsible for closing the Session after the stream is consumed. For convenience, the Session is provided in the closeableResource header, and IntegrationMessageHeaderAccessor offers convenience method:spring-doc.cn
Closeable closeable = new IntegrationMessageHeaderAccessor(message).getCloseableResource();
if (closeable != null) {
    closeable.close();
Framework components, such as the File Splitter and Stream Transformer, automatically close the session after the data is transferred.spring-doc.cn
The following example shows how to consume a file as a stream:spring-doc.cn
<int-smb:outbound-gateway session-factory="smbSessionFactory"
                            request-channel="inboundGetStream"
                            command="get"
                            command-options="-stream"
                            expression="payload"
                            remote-directory="smbTarget"
                            reply-channel="stream" />
<int-file:splitter input-channel="stream" output-channel="lines" />
If you consume the input stream in a custom component, you must close the Session. You can either do that in your custom code or route a copy of the message to a service-activator and use SpEL, as the following example shows:
<int:service-activator input-channel="closeSession"
    expression="headers['closeableResource'].close()" />
Using the mget Command
mget retrieves multiple remote files based on a pattern and supports the following options:spring-doc.cn
  • -P: Preserve the timestamps of the remote files.spring-doc.cn
  • -R: Retrieve the entire directory tree recursively.spring-doc.cn
  • -x: Throw an exception if no files match the pattern (otherwise, an empty list is returned).spring-doc.cn
  • -D: Delete each remote file after successful transfer. If the transfer is ignored, the remote file is not deleted, because the FileExistsMode is IGNORE and the local file already exists.spring-doc.cn
The message payload resulting from an mget operation is a List<File> object (that is, a List of File objects, each representing a retrieved file).spring-doc.cn
If the FileExistsMode is IGNORE, the payload of the output message no longer contain files that were not fetched due to the file already existing. Previously, the array contained all files, including those that already existed.
The expression you use determine the remote path should produce a result that ends with for example myfiles/ fetches the complete tree under myfiles.spring-doc.cn
You can use a recursive MGET, combined with the FileExistsMode.REPLACE_IF_MODIFIED mode, to periodically synchronize an entire remote directory tree locally. This mode sets the local file’s last modified timestamp to the remote file’s timestamp, regardless of the -P (preserve timestamp) option.spring-doc.cn
Notes for when using recursion (-R)
The pattern is ignored and * is assumed. By default, the entire remote tree is retrieved. However, you can filter files in the tree by providing a FileListFilter. You can also filter directories in the tree this way. A FileListFilter can be provided by reference or by filename-pattern or filename-regex attributes. For example, filename-regex="(subDir|.*1.txt)" retrieves all files ending with 1.txt in the remote directory and the subdirectory subDir. However, we describe an alternative available after this note.spring-doc.cn
If you filter a subdirectory, no additional traversal of that subdirectory is performed.spring-doc.cn
The -dirs option is not allowed (the recursive mget uses the recursive ls to obtain the directory tree and the directories themselves cannot be included in the list).spring-doc.cn
Typically, you would use the #remoteDirectory variable in the local-directory-expression so that the remote directory structure is retained locally.spring-doc.cn
The persistent file list filters now have a boolean property forRecursion. Setting this property to true, also sets alwaysAcceptDirectories, which means that the recursive operation on the outbound gateways (ls and mget) will now always traverse the full directory tree each time. This is to solve a problem where changes deep in the directory tree were not detected. In addition, forRecursion=true causes the full path to files to be used as the metadata store keys; this solves a problem where the filter did not work properly if a file with the same name appears multiple times in different directories. IMPORTANT: This means that existing keys in a persistent metadata store will not be found for files beneath the top level directory. For this reason, the property is false by default; this may change in a future release.spring-doc.cn
You can configure the SmbSimplePatternFileListFilter and SmbRegexPatternFileListFilter to always pass directories by setting the alwaysAcceptDirectorties to true. Doing so allows recursion for a simple pattern, as the following examples show:spring-doc.cn
<bean id="starDotTxtFilter"
            class="org.springframework.integration.smb.filters.SmbSimplePatternFileListFilter">
    <constructor-arg value="*.txt" />
    <property name="alwaysAcceptDirectories" value="true" />
</bean>
<bean id="dotStarDotTxtFilter"
            class="org.springframework.integration.smb.filters.SmbRegexPatternFileListFilter">
    <constructor-arg value="^.*\.txt$" />
</bean>
You can provide one of these filters by using the filter property on the gateway.spring-doc.cn
Using the put Command
put sends a file to the remote server. The payload of the message can be a java.io.File, a byte[], or a String. A remote-filename-generator (or expression) is used to name the remote file. Other available attributes include remote-directory, temporary-remote-directory and their *-expression equivalents: use-temporary-file-name and auto-create-directory. See the schema documentation for more information.spring-doc.cn
The message payload resulting from a put operation is a String that contains the full path of the file on the server after transfer.spring-doc.cn
Using the mput Command
mput sends multiple files to the server and supports the following option:spring-doc.cn
  • -R: Recursive — send all files (possibly filtered) in the directory and subdirectoriesspring-doc.cn
The message payload must be a java.io.File (or String) that represents a local directory. A collection of File or String is also supported.spring-doc.cn
The same attributes as the put command are supported. In addition, you can filter files in the local directory with one of mput-pattern, mput-regex, mput-filter, or mput-filter-expression. The filter works with recursion, as long as the subdirectories themselves pass the filter. Subdirectories that do not pass the filter are not recursed.spring-doc.cn
The message payload resulting from an mput operation is a List<String> object (that is, a List of remote file paths resulting from the transfer).spring-doc.cn
Using the rm Command
The rm command has no options.spring-doc.cn
If the remove operation was successful, the resulting message payload is Boolean.TRUE. Otherwise, the message payload is Boolean.FALSE. The file_remoteDirectory header holds the remote directory, and the file_remoteFile header holds the file name.spring-doc.cn
Using the mv Command
The mv command has no options.spring-doc.cn
The expression attribute defines the “from” path, and the rename-expression attribute defines the “to” path. By default, the rename-expression is headers['file_renameTo']. This expression must not evaluate to null or an empty String. If necessary, any remote directories needed are created. The payload of the result message is Boolean.TRUE. The file_remoteDirectory header holds the original remote directory, and the file_remoteFile header holds the filename. The file_renameTo header holds the new path.spring-doc.cn
The remoteDirectoryExpression can be used in the mv command for convenience. If the “from” file is not a full file path, the result of remoteDirectoryExpression is used as the remote directory. The same applies for the “to” file, for example, if the task is just to rename a remote file in some directory.spring-doc.cn
Additional Command Information
The get and mget commands support the local-filename-generator-expression attribute. It defines a SpEL expression to generate the names of local files during the transfer. The root object of the evaluation context is the request message. The remoteFileName variable is also available. It is particularly useful for mget (for example: local-filename-generator-expression="#remoteFileName.toUpperCase() + headers.foo").spring-doc.cn
The get and mget commands support the local-directory-expression attribute. It defines a SpEL expression to generate the names of local directories during the transfer. The root object of the evaluation context is the request message. The remoteDirectory variable is also available. It is particularly useful for mget (for example: local-directory-expression="'/tmp/local/' + #remoteDirectory.toUpperCase() + headers.myheader"). This attribute is mutually exclusive with the local-directory attribute.spring-doc.cn
For all commands, the 'expression' property of the gateway holds the path on which the command acts. For the mget command, the expression might evaluate to , meaning to retrieve all files, somedirectory/, and other values that end with *.spring-doc.cn
The following example shows a gateway configured for an ls command:spring-doc.cn
<int-smb:outbound-gateway id="gateway1"
        request-channel="inbound1"
        command="ls"
        command-options="-1"
        reply-channel="toSplitter"/>
The payload of the message sent to the toSplitter channel is a list of String objects, each of which contains the name of a file. If you omitted command-options="-1", the payload would be a list of FileInfo objects. You can provide options as a space-delimited list (for example, command-options="-1 -dirs -links").spring-doc.cn
The GET, MGET, PUT, and MPUT commands support a FileExistsMode property (mode when using the namespace support). This affects the behavior when the local file exists (GET and MGET) or the remote file exists (PUT and MPUT). The supported modes are REPLACE, APPEND, FAIL, and IGNORE. For backwards compatibility, the default mode for PUT and MPUT operations is REPLACE. For GET and MGET operations, the default is FAIL.spring-doc.cn
The following Spring Boot application shows an example of how to configure the outbound gateway with Java configuration:spring-doc.cn
            .web(false)
            .run(args);
        return smbSession;
    @ServiceActivator(inputChannel = "smbChannel")
    public MessageHandler handler() {
        SmbOutboundGateway smbOutboundGateway =
            new SmbOutboundGateway(smbSessionFactory(), "'my_remote_dir/'");
        smbOutboundGateway.setOutputChannelName("replyChannel");
        return smbOutboundGateway;
The following Spring Boot application shows an example of how to configure the outbound gateway with the Java DSL:spring-doc.cn
            .web(false)
            .run(args);
        return smbSession;
    public SmbOutboundGatewaySpec smbOutboundGateway() {
        return Smb.outboundGateway(smbSessionFactory(),
            AbstractRemoteFileOutboundGateway.Command.MGET, "payload")
            .options(AbstractRemoteFileOutboundGateway.Option.RECURSIVE)
            .regexFileNameFilter("(subSmbSource|.*.txt)")
            .localDirectoryExpression("'localDirectory/' + #remoteDirectory")
            .localFilenameExpression("#remoteFileName.replaceFirst('smbSource', 'localTarget')");
    public IntegrationFlow smbFlow(AbstractRemoteFileOutboundGateway<SmbFile> smbOutboundGateway) {
        return f -> f
            .handle(smbOutboundGateway)
            .channel(c -> c.queue("remoteFileOutputChannel"));
Outbound Gateway Partial Success (mget and mput)
When performing operations on multiple files (by using mget and mput) an exception can occur some time after one or more files have been transferred. In this case a PartialSuccessException is thrown. As well as the usual MessagingException properties (failedMessage and cause), this exception has two additional properties:spring-doc.cn
  • partialResults: The successful transfer results.spring-doc.cn
  • derivedInput: The list of files generated from the request message (such as local files to transfer for an mput).spring-doc.cn
These attributes let you determine which files were successfully transferred and which were not.spring-doc.cn
In the case of a recursive mput, the PartialSuccessException may have nested PartialSuccessException instances.spring-doc.cn
Consider the following directory structure:spring-doc.cn
root/
|- file1.txt
|- subdir/
   | - file2.txt
   | - file3.txt
|- zoo.txt
If the exception occurs on file3.txt, the PartialSuccessException thrown by the gateway has derivedInput of file1.txt, subdir, and zoo.txt and partialResults of file1.txt. Its cause is another PartialSuccessException with derivedInput of file2.txt and file3.txt and partialResults of file2.txt.spring-doc.cn
Remote File Information
The SmbStreamingMessageSource (SMB Streaming Inbound Channel Adapter), SmbInboundFileSynchronizingMessageSource (SMB Inbound Channel Adapter) and "read"-commands of the SmbOutboundGateway (SMB Outbound Gateway) provide additional headers in the message to produce with an information about the remote file:spring-doc.cn
  • FileHeaders.REMOTE_HOST_PORT - the host:port pair the remote session has been connected to during file transfer operation;spring-doc.cn
  • FileHeaders.REMOTE_DIRECTORY - the remote directory the operation has been performed;spring-doc.cn
  • FileHeaders.REMOTE_FILE - the remote file name; applicable only for single file operations.spring-doc.cn
Since the SmbInboundFileSynchronizingMessageSource doesn’t produce messages against remote files, but using a local copy, the AbstractInboundFileSynchronizer stores an information about remote file in the MetadataStore (which can be configured externally) in the URI style (protocol://host:port/remoteDirectory#remoteFileName) during synchronization operation. This metadata is retrieved by the SmbInboundFileSynchronizingMessageSource when local file is polled. When local file is deleted, it is recommended to remove its metadata entry. The AbstractInboundFileSynchronizer provides a removeRemoteFileMetadata() callback for this purpose. In addition, there is a setMetadataStorePrefix() to be used in the metadata keys. It is recommended to have this prefix be different from the one used in the MetadataStore-based FileListFilter implementations, when the same MetadataStore instance is shared between these components, to avoid entry overriding because both filter and AbstractInboundFileSynchronizer use the same local file name for the metadata entry key.spring-doc.cn
