HTTP Support
HTTP Support
Spring Integration’s HTTP support allows for the running of HTTP requests and the processing of inbound HTTP requests.
The HTTP support consists of the following gateway implementations: HttpInboundEndpoint
and HttpRequestExecutingMessageHandler
See also WebFlux Support.
You need to include this dependency into your project:
<dependency>
<groupId>org.springframework.integration</groupId>
<artifactId>spring-integration-http</artifactId>
<version>6.0.9</version>
</dependency>
compile "org.springframework.integration:spring-integration-http:6.0.9"
The jakarta.servlet:jakarta.servlet-api
dependency must be provided on the target Servlet container.
Http Inbound Components
To receive messages over HTTP, you need to use an HTTP inbound channel adapter or an HTTP inbound gateway.
To support the HTTP inbound adapters, they need to be deployed within a servlet container such as Apache Tomcat or Jetty.
The easiest way to do this is to use Spring’s HttpRequestHandlerServlet
, by providing the following servlet definition in the web.xml
file:
<servlet>
<servlet-name>inboundGateway</servlet-name>
<servlet-class>o.s.web.context.support.HttpRequestHandlerServlet</servlet-class>
</servlet>
Notice that the servlet name matches the bean name.
For more information on using the HttpRequestHandlerServlet
, see Remoting and web services using Spring, which is part of the Spring Framework Reference documentation.
If you are running within a Spring MVC application, then the aforementioned explicit servlet definition is not necessary. In that case, the bean name for your gateway can be matched against the URL path as you would for a Spring MVC Controller bean. For more information, see Web MVC framework, which is part of the Spring Framework Reference documentation.
For a sample application and the corresponding configuration, see the Spring Integration Samples repository. It contains the HTTP sample application, which demonstrates Spring Integration’s HTTP support. |
The following example bean defines an HTTP inbound endpoint:
<bean id="httpInbound"
class="org.springframework.integration.http.inbound.HttpRequestHandlingMessagingGateway">
<property name="requestChannel" ref="httpRequestChannel" />
<property name="replyChannel" ref="httpReplyChannel" />
</bean>
The HttpRequestHandlingMessagingGateway
accepts a list of HttpMessageConverter
instances or else relies on a default list.
The converters allow customization of the mapping from HttpServletRequest
to Message
The default converters encapsulate simple strategies, which (for example) create a String
message for a POST
request where the content type starts with text
See the Javadoc for full details.
An additional flag (mergeWithDefaultConverters
) can be set along with the list of custom HttpMessageConverter
to add the default converters after the custom converters.
By default, this flag is set to false
, meaning that the custom converters replace the default list.
The message conversion process uses the (optional) requestPayloadType
property and the incoming Content-Type
header.
Starting with version 4.3, if a request has no content type header, application/octet-stream
is assumed, as recommended by RFC 2616
Previously, the body of such messages was ignored.
Spring Integration 2.0 implemented multipart file support.
If the request has been wrapped as a MultipartHttpServletRequest
, when you use the default converters, that request is converted to a Message
payload that is a MultiValueMap
containing values that may be byte arrays, strings, or instances of Spring’s MultipartFile
, depending on the content type of the individual parts.
The HTTP inbound endpoint locates a MultipartResolver in the context if one has a bean name of multipartResolver (the same name expected by Spring’s DispatcherServlet ).
If it does locate that bean, the support for multipart files is enabled on the inbound request mapper.
Otherwise, it fails when it tries to map a multipart file request to a Spring Integration Message .
For more on Spring’s support for MultipartResolver , see the Spring Reference Manual.
If you wish to proxy a
When you send a response to the client, you have a number of ways to customize the behavior of the gateway.
By default, the gateway acknowledges that the request was received by sending a 200
status code back.
It is possible to customize this response by providing a 'viewName' to be resolved by the Spring MVC ViewResolver
If the gateway should expect a reply to the Message
, you can set the expectReply
flag (constructor argument) to cause the gateway to wait for a reply Message
before creating an HTTP response.
The following example configures a gateway to serve as a Spring MVC Controller with a view name:
class="org.springframework.integration.http.inbound.HttpRequestHandlingController">
<constructor-arg value="true" /> <!-- indicates that a reply is expected -->
<property name="viewName" value="jsonView" />
<property name="supportedMethodNames" >
<list>
<value>GET</value>
<value>DELETE</value>
</list>
</property>
</bean>
Because of the constructor-arg
value of true
, it waits for a reply.
The preceding example also shows how to customize the HTTP methods accepted by the gateway, which are POST
and GET
by default.
The reply message is available in the model map. By default, the key for that map entry is 'reply', but you can override this default by setting the 'replyKey' property on the endpoint’s configuration.
Payload Validation
Starting with version 5.2, the HTTP inbound endpoints can be supplied with a Validator
to check a payload before sending into the channel.
This payload is already a result of conversion and extraction after payloadExpression
to narrow a validation scope in regards to the valuable data.
The validation failure handling is fully the same what we have in Spring MVC Error Handling.
HTTP Outbound Components
This section describes Spring Integration’s HTTP outbound components.
Using HttpRequestExecutingMessageHandler
To configure the HttpRequestExecutingMessageHandler
, write a bean definition similar to the following:
<bean id="httpOutbound"
class="org.springframework.integration.http.outbound.HttpRequestExecutingMessageHandler">
<constructor-arg value="http://localhost:8080/example" />
<property name="outputChannel" ref="responseChannel" />
</bean>
This bean definition runs HTTP requests by delegating to a RestTemplate
That template, in turn, delegates to a list of HttpMessageConverter
instances to generate the HTTP request body from the Message
payload.
You can configure those converters as well as the ClientHttpRequestFactory
instance to use, as the following example shows:
<property name="messageConverters" ref="messageConverterList" />
<property name="requestFactory" ref="customRequestFactory" />
</bean>
By default, the HTTP request is generated by using an instance of SimpleClientHttpRequestFactory
, which uses the JDK HttpURLConnection
Use of the Apache Commons HTTP Client is also supported through CommonsClientHttpRequestFactory
, which you can inject (as shown earlier).
For the outbound gateway, the reply message produced by the gateway contains all the message headers that are present in the request message. |
Using Cookies
Basic cookie support is provided by the transfer-cookies
attribute on the outbound gateway.
When set to true
(the default is false
), a Set-Cookie
header received from the server in a response is converted to Cookie
in the reply message.
This header is then used on subsequent sends.
This enables simple stateful interactions, such as the following:
…→logonGateway→…→doWorkGateway→…→logoffGateway→…
If transfer-cookies
is false
, any Set-Cookie
header received remains as Set-Cookie
in the reply message and is dropped on subsequent sends.
Empty Response Bodies
HTTP is a request-response protocol.
However, the response may not have a body, only headers.
In this case, the |
expected-response-type
Further to the preceding note about empty response bodies, if a response does contain a body, you must provide an appropriate |
Starting with version 5.5, the HttpRequestExecutingMessageHandler
exposes an extractResponseBody
flag (which is true
by default) to return just the response body, or to return the whole ResponseEntity
as the reply message payload, independently of the provided expectedResponseType
If a body is not present in the ResponseEntity
, this flag is ignored and the whole ResponseEntity
is returned.
HTTP Namespace Support
Spring Integration provides an http
namespace and the corresponding schema definition.
To include it in your configuration, provide the following namespace declaration in your application context configuration file:
xmlns:int="http://www.springframework.org/schema/integration"
xmlns:int-http="http://www.springframework.org/schema/integration/http"
xsi:schemaLocation="
https://www.springframework.org/schema/integration/spring-integration.xsd
https://www.springframework.org/schema/integration/http/spring-integration-http.xsd">
</beans>
Inbound
The XML namespace provides two components for handling HTTP inbound requests: inbound-channel-adapter
and inbound-gateway
In order to process requests without returning a dedicated response, use the inbound-channel-adapter
The following example shows how to configure one:
<int-http:inbound-channel-adapter id="httpChannelAdapter" channel="requests"
supported-methods="PUT, DELETE"/>
To process requests that do expect a response, use an inbound-gateway
<int-http:inbound-gateway id="inboundGateway"
request-channel="requests"
reply-channel="responses"/>
Request Mapping Support
Spring Integration 3.0 improved the REST support by introducing the IntegrationRequestMappingHandlerMapping .
The implementation relies on the enhanced REST support provided by Spring Framework 3.1 or higher.
The parsing of the HTTP inbound gateway or the HTTP inbound channel adapter registers an integrationRequestMappingHandlerMapping
bean of type IntegrationRequestMappingHandlerMapping
, in case one is not yet registered.
This particular implementation of the HandlerMapping
delegates its logic to RequestMappingInfoHandlerMapping
The implementation provides functionality similar to the org.springframework.web.bind.annotation.RequestMapping
annotation in Spring MVC.
For more information, see Mapping Requests With @RequestMapping .
For this purpose, Spring Integration 3.0 introduces the <request-mapping>
element.
You can add this optional element to <http:inbound-channel-adapter>
and <http:inbound-gateway>
It works in conjunction with the path
and supported-methods
attributes.
The following example shows how to configure it on an inbound gateway:
<inbound-gateway id="inboundController"
path="/foo/{fooId}"
supported-methods="GET"
view-name="foo"
error-code="oops">
<request-mapping headers="User-Agent"
params="myParam=myValue"
consumes="application/json"
produces="!text/plain"/>
</inbound-gateway>
Based on the preceding configuration, the namespace parser creates an instance of the IntegrationRequestMappingHandlerMapping
(if none exists) and an HttpRequestHandlingController
bean and associates with it an instance of RequestMapping
This RequestMapping
instance is, in turn, converted to the Spring MVC RequestMappingInfo
The <request-mapping>
element provides the following attributes:
headers
params
consumes
produces
With the path
attributes of the <http:inbound-channel-adapter>
or the <http:inbound-gateway>
, <request-mapping>
attributes translate directly into the respective options provided by the org.springframework.web.bind.annotation.RequestMapping
element lets you configure several Spring Integration HTTP inbound endpoints to the same path
(or even the same supported-methods
) and lets you provide different downstream message flows based on incoming HTTP requests.
Alternatively, you can also declare only one HTTP inbound endpoint and apply routing and filtering logic within the Spring Integration flow to achieve the same result.
This lets you get the Message
into the flow as early as possibly.
The following example shows how to do so:
<int-http:inbound-gateway request-channel="httpMethodRouter"
supported-methods="GET,DELETE"
path="/process/{entId}"
payload-expression="#pathVariables.entId"/>
<int:router input-channel="httpMethodRouter" expression="headers.http_requestMethod">
<int:mapping value="GET" channel="in1"/>
<int:mapping value="DELETE" channel="in2"/>
</int:router>
<int:service-activator input-channel="in1" ref="service" method="getEntity"/>
<int:service-activator input-channel="in2" ref="service" method="delete"/>
For more information regarding handler mappings, see the Spring Framework Web Servlet documentation or the Spring Framework Web Reactive documentation.
The IntegrationRequestMappingHandlerMapping extends the Spring MVC RequestMappingHandlerMapping class, inheriting most of its logic, especially handleNoMatch(Set, String, HttpServletRequest) , which throws a specific 4xx error for the HTTP response, when mapping doesn’t match for some reason, preventing calls to any remaining mapping handlers in the application context.
For this reason, configuring the same path for both Spring Integration and Spring MVC request mappings (e.g. POST in one and GET in the other) is not supported; the MVC mapping will not be found..
Cross-origin Resource Sharing (CORS) Support
Starting with version 4.2, you can configure the <http:inbound-channel-adapter>
with a <cross-origin>
element.
It represents the same options as Spring MVC’s @CrossOrigin
for @Controller
annotations and allows the configuration of cross-origin resource sharing (CORS) for Spring Integration HTTP endpoints:
origin
: List of allowed origins. The*
means that all origins are allowed. These values are placed in theAccess-Control-Allow-Origin
header of both the pre-flight and actual responses. The default value is*
allowed-headers
: Indicates which request headers can be used during the actual request. The*
means that all headers requested by the client are allowed. This property controls the value of the pre-flight response’sAccess-Control-Allow-Headers
header. The default value is*
exposed-headers
: List of response headers that the user-agent lets the client access. This property controls the value of the actual response’sAccess-Control-Expose-Headers
header. -
method
: The HTTP request methods to allow:GET
,POST
,HEAD
,OPTIONS
,PUT
,PATCH
,DELETE
,TRACE
. Methods specified here overrides those insupported-methods
allow-credentials
: Set totrue
if the browser should include any cookies associated to the domain of the request orfalse
if it should not. An empty string ("") means undefined. Iftrue
, the pre-flight response includes theAccess-Control-Allow-Credentials=true
header. The default value istrue
max-age
: Controls the cache duration for pre-flight responses. Setting this to a reasonable value can reduce the number of pre-flight request-response interactions required by the browser. This property controls the value of theAccess-Control-Max-Age
header in the pre-flight response. A value of-1
means undefined. The default value is 1800 seconds (30 minutes).
The CORS Java Configuration is represented by the org.springframework.integration.http.inbound.CrossOrigin
class, instances of which can be injected into the HttpRequestHandlingEndpointSupport
beans.
Response Status Code
Starting with version 4.1, you can configure the <http:inbound-channel-adapter>
with a status-code-expression
to override the default 200 OK
status.
The expression must return an object that can be converted to an org.springframework.http.HttpStatus
enum value.
The evaluationContext
has a BeanResolver
and, starting with version 5.1, is supplied with the RequestEntity<?>
as root object.
An example might be to resolve, at runtime, some scoped bean that returns a status code value.
However, most likely, it is set to a fixed value such as status-code=expression="204"
(No Content), or status-code-expression="T(org.springframework.http.HttpStatus).NO_CONTENT"
By default, status-code-expression
is null, meaning that the normal '200 OK' response status is returned.
Using the RequestEntity<?>
as root object, the status code can be conditional e.g. on the request method, some header, URI content or even request body.
The following example shows how to set the status code to ACCEPTED
<http:inbound-channel-adapter id="inboundController"
channel="requests" view-name="foo" error-code="oops"
status-code-expression="T(org.springframework.http.HttpStatus).ACCEPTED">
<request-mapping headers="BAR"/>
</http:inbound-channel-adapter>
The <http:inbound-gateway>
resolves the 'status code' from the http_statusCode
header of the reply Message
Starting with version 4.2, the default response status code when no reply is received within the reply-timeout
is 500 Internal Server Error
There are two ways to modify this behavior:
Add a
reply-timeout-status-code-expression
. This has the same semantics as thestatus-code-expression
on the inbound adapter. -
Add an
error-channel
and return an appropriate message with an HTTP status code header, as the following example shows:<int:chain input-channel="errors"> <int:header-enricher> <int:header name="http_statusCode" value="504" /> </int:header-enricher> <int:transformer expression="payload.failedMessage" /> </int:chain>
The payload of the ErrorMessage
is a MessageTimeoutException
It must be transformed to something that can be converted by the gateway, such as a String
A good candidate is the exception’s message property, which is the value used when you use the expression
technique.
If the error flow times out after a main flow timeout, 500 Internal Server Error
is returned, or, if the reply-timeout-status-code-expression
is present, it is evaluated.
Previously, the default status code for a timeout was 200 OK .
To restore that behavior, set reply-timeout-status-code-expression="200" .
Also starting with version 5.4, an error that is encountered while preparing the request message is sent to the error channel (if provided).
A decision about throwing an appropriate exception should be done in the error flow by examining the exception.
Previously, any exceptions were simply thrown, causing an HTTP 500 server error response status, but in some cases the problem can be caused by incorrect request params, so a ResponseStatusException
with a 4xx client error status should be thrown instead.
See ResponseStatusException
for more information.
The ErrorMessage
sent to this error channel contains the original exception as the payload for analysis.
==== URI Template Variables and Expressions
By using the path
attribute in conjunction with the payload-expression
attribute and the header
element, you have a high degree of flexibility for mapping inbound request data.
In the following example configuration, an inbound channel adapter is configured to accept requests using the following URI:
/first-name/{firstName}/last-name/{lastName}
When you use the payload-expression
attribute, the {firstName}
URI template variable maps to be the Message
payload, while the {lastName}
URI template variable maps to the lname
message header, as defined in the following example:
<int-http:inbound-channel-adapter id="inboundAdapterWithExpressions"
path="/first-name/{firstName}/last-name/{lastName}"
channel="requests"
payload-expression="#pathVariables.firstName">
<int-http:header name="lname" expression="#pathVariables.lastName"/>
</int-http:inbound-channel-adapter>
For more information about URI template variables, see uri template patterns in the Spring Reference Manual.
Since Spring Integration 3.0, in addition to the existing #pathVariables
and #requestParams
variables being available in payload and header expressions, we added other useful expression variables:
#requestParams
: TheMultiValueMap
from theServletRequest
parameterMap
#pathVariables
: TheMap
from URI Template placeholders and their values. -
#matrixVariables
: TheMap
ofMultiValueMap
according to the Spring MVC Specification. Note that#matrixVariables
requires Spring MVC 3.2 or higher. -
#requestAttributes
: Theorg.springframework.web.context.request.RequestAttributes
associated with the current request. -
#requestHeaders
: Theorg.springframework.http.HttpHeaders
object from the current request. -
#cookies
: TheMultiValueMap<String, Cookie>
ofjakarta.servlet.http.Cookie
instances from the current request.
Note that all these values (and others) can be accessed within expressions in the downstream message flow through the ThreadLocal
variable, if that message flow is single-threaded and lives within the request thread.
The following example configures a transformer that uses an expression
attribute:
<int-:transformer
expression="T(org.springframework.web.context.request.RequestContextHolder).
requestAttributes.request.queryString"/>
Outbound
To configure the outbound gateway, you can use the namespace support. The following code snippet shows the available configuration options for an outbound HTTP gateway:
<int-http:outbound-gateway id="example"
url="http://localhost/test"
http-method="POST"
extract-request-payload="false"
expected-response-type="java.lang.String"
charset="UTF-8"
request-factory="requestFactory"
reply-timeout="1234"
reply-channel="replies"/>
Most importantly, notice that the 'http-method' and 'expected-response-type' attributes are provided.
Those are two of the most commonly configured values.
The default http-method
is POST
, and the default response type is null.
With a null response type, the payload of the reply Message
contains the ResponseEntity
, as long as its HTTP status is a success (non-successful status codes throw exceptions).
If you expect a different type, such as a String
, provide that as a fully-qualified class name (java.lang.String
in the preceding example).
See also the note about empty response bodies in HTTP Outbound Components.
Beginning with Spring Integration 2.1, the request-timeout attribute of the HTTP outbound gateway was renamed to reply-timeout to better reflect its intent.
Since Spring Integration 2.2, Java serialization over HTTP is no longer enabled by default.
Previously, when setting the However, because this could cause incompatibility with existing applications, it was decided to no longer automatically add this converter to the HTTP endpoints.
If you wish to use Java serialization, you can add the |
Beginning with Spring Integration 2.2, you can also determine the HTTP method dynamically by using SpEL and the http-method-expression
attribute.
Note that this attribute is mutually exclusive with http-method
You can also use the expected-response-type-expression
attribute instead of expected-response-type
and provide any valid SpEL expression that determines the type of the response.
The following configuration example uses expected-response-type-expression
http-method-expression="headers.httpMethod"
expected-response-type-expression="payload"
charset="UTF-8"
If your outbound adapter is to be used in a unidirectional way, you can use an outbound-channel-adapter
instead.
This means that a successful response executes without sending any messages to a reply channel.
In the case of any non-successful response status code, it throws an exception.
The configuration looks very similar to the gateway, as the following example shows:
<int-http:outbound-channel-adapter id="example"
url="http://localhost/example"
http-method="GET"
channel="requests"
charset="UTF-8"
extract-payload="false"
request-factory="someRequestFactory"
order="3"
auto-startup="false"/>
To specify the URL, you can use either the 'url' attribute or the 'url-expression' attribute.
The 'url' attribute takes a simple string (with placeholders for URI variables, as described below).
The 'url-expression' is a SpEL expression, with the In previous releases, some users used the place holders to replace the entire URL with a URI variable. Changes in Spring 3.1 can cause some issues with escaped characters, such as '?'. For this reason, we recommend that, if you wish to generate the URL entirely at runtime, you use the 'url-expression' attribute. |
Mapping URI Variables
If your URL contains URI variables, you can map them by using the uri-variable
element.
This element is available for the HTTP outbound gateway and the HTTP outbound channel adapter.
The following example maps the zipCode
URI variable to an expression:
<int-http:outbound-gateway id="trafficGateway"
url="https://local.yahooapis.com/trafficData?appid=YdnDemo&zip={zipCode}"
request-channel="trafficChannel"
http-method="GET"
expected-response-type="java.lang.String">
<int-http:uri-variable name="zipCode" expression="payload.getZip()"/>
</int-http:outbound-gateway>
The uri-variable
element defines two attributes: name
and expression
The name
attribute identifies the name of the URI variable, while the expression
attribute is used to set the actual value.
By using the expression
attribute, you can leverage the full power of the Spring Expression Language (SpEL), which gives you full dynamic access to the message payload and the message headers.
For example, in the preceding configuration, the getZip()
method is invoked on the payload object of the Message
and the result of that method is used as the value of the URI variable named 'zipCode'.
Since Spring Integration 3.0, HTTP outbound endpoints support the uri-variables-expression
attribute to specify an expression
that should be evaluated, resulting in a Map
of all URI variable placeholders within the URL template.
It provides a mechanism whereby you can use different variable expressions, based on the outbound message.
This attribute is mutually exclusive with the <uri-variable/>
element.
The following example shows how to use the uri-variables-expression
attribute:
url="https://foo.host/{foo}/bars/{bar}"
http-method="GET"
uri-variables-expression="@uriVariablesBean.populate(payload)"
expected-response-type="java.lang.String"/>
uriVariablesBean
might be defined as follows:
public class UriVariablesBean {
private static final ExpressionParser EXPRESSION_PARSER = new SpelExpressionParser();
public Map<String, ?> populate(Object payload) {
Map<String, Object> variables = new HashMap<String, Object>();
if (payload instanceOf String.class)) {
variables.put("foo", "foo"));
else {
variables.put("foo", EXPRESSION_PARSER.parseExpression("headers.bar"));
return variables;
The uri-variables-expression must evaluate to a Map .
The values of the Map must be instances of String or Expression .
This Map is provided to an ExpressionEvalMap for further resolution of URI variable placeholders by using those expressions in the context of the outbound Message .
IMPORTANT
The uriVariablesExpression
property provides a very powerful mechanism for evaluating URI variables.
We anticipate that people mostly use simple expressions, such as the preceding example.
However, you can also configure something such as "@uriVariablesBean.populate(#root)"
with an expression in the returned map being variables.put("thing1", EXPRESSION_PARSER.parseExpression(message.getHeaders().get("thing2", String.class)));
, where the expression is dynamically provided in the message header named thing2
Since the header may come from an untrusted source, the HTTP outbound endpoints use SimpleEvaluationContext
when evaluating these expressions.
The SimpleEvaluationContext
uses only a subset of SpEL features.
If you trust your message sources and wish to use the restricted SpEL constructs, set the trustedSpel
property of the outbound endpoint to true
You can achieve scenarios that need to supply a dynamic set of URI variables on a per-message basis by using a custom url-expression
and some utilities for building and encoding URL parameters.
url-expression="T(org.springframework.web.util.UriComponentsBuilder)
.fromHttpUrl('https://HOST:PORT/PATH')
.queryParams(payload)
.build()
.toUri()"
The queryParams()
method expects a MultiValueMap<String, String>
as an argument, so you can build a real set of URL query parameters in advance, before performing the request.
The whole queryString
can also be presented as a uri-variable
<int-http:outbound-gateway id="proxyGateway" request-channel="testChannel"
url="http://testServer/test?{queryString}">
<int-http:uri-variable name="queryString" expression="'a=A&b=B'"/>
In this case, you must manually provide the URL encoding.
For example, you can use the org.apache.http.client.utils.URLEncodedUtils#format()
for this purpose.
As mentioned earlier, a manually built MultiValueMap<String, String>
can be converted to the List<NameValuePair>
format()
method argument by using the following Java Streams snippet:
List<NameValuePair> nameValuePairs =
params.entrySet()
.stream()
.flatMap(e -> e
.getValue()
.stream()
.map(v -> new BasicNameValuePair(e.getKey(), v)))
.collect(Collectors.toList());
Controlling URI Encoding
By default, the URL string is encoded (see UriComponentsBuilder
) to the URI object before sending the request.
In some scenarios with a non-standard URI (such as the RabbitMQ REST API), it is undesirable to perform the encoding.
The <http:outbound-gateway/>
and <http:outbound-channel-adapter/>
provide an encoding-mode
attribute.
To disable encoding the URL, set this attribute to NONE
(by default, it is TEMPLATE_AND_VALUES
If you wish to partially encode some part of the URL, use an expression
within a <uri-variable/>
<http:outbound-gateway url="https://somehost/%2f/fooApps?bar={param}" encoding-mode="NONE">
<http:uri-variable name="param"
expression="T(org.apache.commons.httpclient.util.URIUtil)
.encodeWithinQuery('Hello World!')"/>
</http:outbound-gateway>
With Java DSL this option can be controlled by the BaseHttpMessageHandlerSpec.encodingMode()
option.
The same configuration applies for similar outbound components in the WebFlux module and Web Services module.
For much sophisticated scenarios it is recommended to configure an UriTemplateHandler
on the externally provided RestTemplate
; or in case of WebFlux - WebClient
with it UriBuilderFactory
Configuring HTTP Endpoints with Java
The following example shows how to configure an inbound gateway with Java:
public HttpRequestHandlingMessagingGateway inbound() {
HttpRequestHandlingMessagingGateway gateway =
new HttpRequestHandlingMessagingGateway(true);
gateway.setRequestMapping(mapping());
gateway.setRequestPayloadType(String.class);
gateway.setRequestChannelName("httpRequest");
return gateway;
public RequestMapping mapping() {
RequestMapping requestMapping = new RequestMapping();
requestMapping.setPathPatterns("/foo");
requestMapping.setMethods(HttpMethod.POST);
return requestMapping;
The following example shows how to configure an inbound gateway with the Java DSL:
public IntegrationFlow inbound() {
return IntegrationFlow.from(Http.inboundGateway("/foo")
.requestMapping(m -> m.methods(HttpMethod.POST))
.requestPayloadType(String.class))
.channel("httpRequest")
.get();
The following example shows how to configure an outbound gateway with Java:
@ServiceActivator(inputChannel = "httpOutRequest")
public HttpRequestExecutingMessageHandler outbound() {
HttpRequestExecutingMessageHandler handler =
new HttpRequestExecutingMessageHandler("http://localhost:8080/foo");
handler.setHttpMethod(HttpMethod.POST);
handler.setExpectedResponseType(String.class);
return handler;
The following example shows how to configure an outbound gateway with the Java DSL:
public IntegrationFlow outbound() {
return IntegrationFlow.from("httpOutRequest")
.handle(Http.outboundGateway("http://localhost:8080/foo")
.httpMethod(HttpMethod.POST)
.expectedResponseType(String.class))
.get();
Timeout Handling
In the context of HTTP components, there are two timing areas that have to be considered:
Timeouts when interacting with Spring Integration Channels
Timeouts when interacting with a remote HTTP server
The components interact with message channels, for which timeouts can be specified. For example, an HTTP Inbound Gateway forwards messages received from connected HTTP Clients to a message channel (which uses a request timeout) and consequently the HTTP Inbound Gateway receives a reply message from the reply channel (which uses a reply timeout) that is used to generate the HTTP Response. The following illustration offers a visual explanation:
For outbound endpoints, we need to consider how timing works while interacting with the remote server. The following image shows this scenario:
You may want to configure the HTTP related timeout behavior, when making active HTTP requests by using the HTTP outbound gateway or the HTTP outbound channel adapter.
In those instances, these two components use Spring’s RestTemplate
support to execute HTTP requests.
To configure timeouts for the HTTP outbound gateway and the HTTP outbound channel adapter, you can either reference a RestTemplate
bean directly (by using the rest-template
attribute) or you can provide a reference to a ClientHttpRequestFactory
bean (by using the request-factory
attribute).
Spring provides the following implementations of the ClientHttpRequestFactory
interface:
: Uses standard J2SE facilities for making HTTP Requests -
HttpComponentsClientHttpRequestFactory
: Uses Apache HttpComponents HttpClient (since Spring 3.1)
If you do not explicitly configure the request-factory
or rest-template
attribute, a default RestTemplate
(which uses a SimpleClientHttpRequestFactory
) is instantiated.
With some JVM implementations, the handling of timeouts by the For example, from the Java™ Platform, Standard Edition 6 API Specification on
Some non-standard implementation of this method may ignore the specified timeout.
To see the
If you have specific needs, you should test your timeouts.
Consider using the |
When you use the Apache HttpComponents HttpClient with a pooling connection manager, you should be aware that, by default, the connection manager creates no more than two concurrent connections per given route and no more than 20 connections in total. For many real-world applications, these limits may prove to be too constraining. See the Apache documentation for information about configuring this important component. |
The following example configures an HTTP outbound gateway by using a SimpleClientHttpRequestFactory
that is configured with connect and read timeouts of 5 seconds, respectively:
<int-http:outbound-gateway url="https://samples.openweathermap.org/data/2.5/weather?q={city}"
http-method="GET"
request-channel="requestChannel"
reply-channel="replyChannel">
<int-http:uri-variable name="city" expression="payload"/>
<bean id="requestFactory"
class="org.springframework.http.client.SimpleClientHttpRequestFactory">
<property name="connectTimeout" value="5000"/>
<property name="readTimeout" value="5000"/>
</bean>
HTTP Outbound Gateway
For the HTTP Outbound Gateway, the XML Schema defines only the reply-timeout.
The reply-timeout maps to the sendTimeout property of the org.springframework.integration.http.outbound.HttpRequestExecutingMessageHandler class.
More precisely, the property is set on the extended AbstractReplyProducingMessageHandler
class, which ultimately sets the property on the MessagingTemplate
The value of the sendTimeout property defaults to "-1" and will be applied to the connected MessageChannel
This means, that depending on the implementation, the Message Channel’s send method may block indefinitely.
Furthermore, the sendTimeout property is only used, when the actual MessageChannel implementation has a blocking send (such as 'full' bounded QueueChannel).
For the HTTP inbound gateway, the XML Schema defines the request-timeout
attribute, which is used to set the requestTimeout
property on the HttpRequestHandlingMessagingGateway
class (on the extended MessagingGatewaySupport
class).
You can also use the reply-timeout
attribute to map to the replyTimeout
property on the same class.
The default for both timeout properties is 1000ms
(one thousand milliseconds or one second).
Ultimately, the request-timeout
property is used to set the sendTimeout
instance.
The replyTimeout
property, on the other hand, is used to set the receiveTimeout
instance.
To simulate connection timeouts, you can connect to a non-routable IP address, such as 10.255.255.10. |
HTTP Proxy configuration
If you are behind a proxy and need to configure proxy settings for HTTP outbound adapters or gateways, you can apply one of two approaches. In most cases, you can rely on the standard Java system properties that control the proxy settings. Otherwise, you can explicitly configure a Spring bean for the HTTP client request factory instance.
Standard Java Proxy configuration
You can set three system properties to configure the proxy settings that are used by the HTTP protocol handler:
http.proxyHost
: The host name of the proxy server. -
http.proxyPort
: The port number (the default is80
http.nonProxyHosts
: A list of hosts that should be reached directly, bypassing the proxy. This is a list of patterns separated by|
. The patterns may start or end with a*
for wildcards. Any host that matches one of these patterns is reached through a direct connection instead of through a proxy.
For HTTPS, the following properties are available:
https.proxyHost
https.proxyPort
: The port number, the default value being 80.
For more information, see https://docs.oracle.com/javase/8/docs/technotes/guides/net/proxies.html
Spring’s SimpleClientHttpRequestFactory
If you need more explicit control over the proxy configuration, you can use Spring’s SimpleClientHttpRequestFactory
and configure its 'proxy' property, as the following example shows:
<property name="proxy">
<bean id="proxy" class="java.net.Proxy">
<constructor-arg>
<util:constant static-field="java.net.Proxy.Type.HTTP"/>
</constructor-arg>
<constructor-arg>
<bean class="java.net.InetSocketAddress">
<constructor-arg value="123.0.0.1"/>
<constructor-arg value="8080"/>
</bean>
</constructor-arg>
</bean>
</property>
</bean>
HTTP Header Mappings
Spring Integration provides support for HTTP header mapping for both HTTP Request and HTTP Responses.
By default, all standard HTTP headers are mapped from the message to HTTP request or response headers without further configuration.
However, if you do need further customization, you can provide additional configuration by taking advantage of the namespace support.
You can provide a comma-separated list of header names, and you can include simple patterns with the '*' character acting as a wildcard.
Provide such values overrides the default behavior.
Basically, it assumes you are in complete control at that point.
However, if you do want to include all the standard HTTP headers, you can use the shortcut patterns: HTTP_REQUEST_HEADERS
and HTTP_RESPONSE_HEADERS
The following listing shows two examples (the first of which uses a wildcard):
<int-http:outbound-gateway id="httpGateway"
url="http://localhost/test2"
mapped-request-headers="thing1, thing2"
mapped-response-headers="X-*, HTTP_RESPONSE_HEADERS"
channel="someChannel"/>
<int-http:outbound-channel-adapter id="httpAdapter"
mapped-request-headers="thing1, thing2, HTTP_REQUEST_HEADERS"
The adapters and gateways use the DefaultHttpHeaderMapper
, which now provides two static factory methods for inbound and outbound adapters so that the proper direction can be applied (mapping HTTP requests and responses either in or out, as appropriate).
If you need further customization, you can also configure a DefaultHttpHeaderMapper
independently and inject it into the adapter through the header-mapper
attribute.
Before version 5.0, the DefaultHttpHeaderMapper
the default prefix for user-defined, non-standard HTTP headers was X-
Version 5.0 changed the default prefix to an empty string.
According to RFC-6648, the use of such prefixes is now discouraged.
You can still customize this option by setting the DefaultHttpHeaderMapper.setUserDefinedHeaderPrefix()
property.
The following example configures a header mapper for an HTTP gateway:
header-mapper="headerMapper"
<bean id="headerMapper" class="o.s.i.http.support.DefaultHttpHeaderMapper">
<property name="inboundHeaderNames" value="thing1*, *thing2, thing3"/>
<property name="outboundHeaderNames" value="a*b, d"/>
</bean>
If you need to do something other than what the DefaultHttpHeaderMapper
supports, you can implement the HeaderMapper
strategy interface directly and provide a reference to your implementation.
Integration Graph Controller
Starting with version 4.3, the HTTP module provides an @EnableIntegrationGraphController
configuration class annotation and an <int-http:graph-controller/>
XML element to expose the IntegrationGraphServer
as a REST service.
See Integration Graph for more information.
HTTP Samples
This section wraps up our coverage of Spring Integration’s HTTP support with a few examples.
Multipart HTTP Request — RestTemplate (Client) and Http Inbound Gateway (Server)
This example shows how simple it is to send a multipart HTTP request with Spring’s RestTemplate
and receive it with a Spring Integration HTTP inbound adapter.
We create a MultiValueMap
and populate it with multipart data.
The RestTemplate
takes care of the rest (no pun intended) by converting it to a MultipartHttpServletRequest
This particular client sends a multipart HTTP Request that contains the name of the company and an image file (the company logo).
The following listing shows the example:
RestTemplate template = new RestTemplate();
String uri = "http://localhost:8080/multipart-http/inboundAdapter.htm";
Resource s2logo =
new ClassPathResource("org/springframework/samples/multipart/spring09_logo.png");
MultiValueMap map = new LinkedMultiValueMap();
map.add("company", "SpringSource");
map.add("company-logo", s2logo);
HttpHeaders headers = new HttpHeaders();
headers.setContentType(new MediaType("multipart", "form-data"));
HttpEntity request = new HttpEntity(map, headers);
ResponseEntity<?> httpResponse = template.exchange(uri, HttpMethod.POST, request, null);
That is all we need for the client.
On the server side, we have the following configuration:
<int-http:inbound-channel-adapter id="httpInboundAdapter"
channel="receiveChannel"
path="/inboundAdapter.htm"
supported-methods="GET, POST"/>
<int:channel id="receiveChannel"/>
<int:service-activator input-channel="receiveChannel">
<bean class="org.springframework.integration.samples.multipart.MultipartReceiver"/>
</int:service-activator>
<bean id="multipartResolver"
class="org.springframework.web.multipart.commons.CommonsMultipartResolver"/>
The 'httpInboundAdapter' receives the request and converts it to a Message
with a payload that is a LinkedMultiValueMap
We then parse that in the 'multipartReceiver' service-activator, as the following example shows:
public void receive(LinkedMultiValueMap<String, Object> multipartRequest){
System.out.println("### Successfully received multipart request ###");
for (String elementName : multipartRequest.keySet()) {
if (elementName.equals("company")){
System.out.println("\t" + elementName + " - " +
((String[]) multipartRequest.getFirst("company"))[0]);
else if (elementName.equals("company-logo")){
System.out.println("\t" + elementName + " - as UploadedMultipartFile: " +
((UploadedMultipartFile) multipartRequest
.getFirst("company-logo")).getOriginalFilename());
You should see the following output:
company - SpringSource
company-logo - as UploadedMultipartFile: spring09_logo.png
