This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Framework 6.2.6!spring-doc.cn
Validation
Spring MVC has built-in validation for @RequestMapping methods, including Java Bean Validation. Validation may be applied at one of two levels:spring-doc.cn
  1. @ModelAttribute, @RequestBody, and @RequestPart argument resolvers validate a method argument individually if the method parameter is annotated with Jakarta @Valid or Spring’s @Validated, AND there is no Errors or BindingResult parameter immediately after, AND method validation is not needed (to be discussed next). The exception raised in this case is MethodArgumentNotValidException.spring-doc.cn
  2. When @Constraint annotations such as @Min, @NotBlank and others are declared directly on method parameters, or on the method (for the return value), then method validation must be applied, and that supersedes validation at the method argument level because method validation covers both method parameter constraints and nested constraints via @Valid. The exception raised in this case is HandlerMethodValidationException.spring-doc.cn
Applications must handle both MethodArgumentNotValidException and HandlerMethodValidationException as either may be raised depending on the controller method signature. The two exceptions, however are designed to be very similar, and can be handled with almost identical code. The main difference is that the former is for a single object while the latter is for a list of method parameters.spring-doc.cn
@Valid is not a constraint annotation, but rather for nested constraints within an Object. Therefore, by itself @Valid does not lead to method validation. @NotNull on the other hand is a constraint, and adding it to an @Valid parameter leads to method validation. For nullability specifically, you may also use the required flag of @RequestBody or @ModelAttribute.
Method validation may be used in combination with Errors or BindingResult method parameters. However, the controller method is called only if all validation errors are on method parameters with an Errors immediately after. If there are validation errors on any other method parameter then HandlerMethodValidationException is raised.spring-doc.cn
You can configure a Validator globally through the WebMvc config, or locally through an @InitBinder method in an @Controller or @ControllerAdvice. You can also use multiple validators.spring-doc.cn
If a controller has a class level @Validated, then method validation is applied through an AOP proxy. In order to take advantage of the Spring MVC built-in support for method validation added in Spring Framework 6.1, you need to remove the class level @Validated annotation from the controller.
The Error Responses section provides further details on how MethodArgumentNotValidException and HandlerMethodValidationException are handled, and also how their rendering can be customized through a MessageSource and locale and language specific resource bundles.spring-doc.cn
For further custom handling of method validation errors, you can extend ResponseEntityExceptionHandler or use an @ExceptionHandler method in a controller or in a @ControllerAdvice, and handle HandlerMethodValidationException directly. The exception contains a list ofParameterValidationResults that group validation errors by method parameter. You can either iterate over those, or provide a visitor with callback methods by controller method parameter type:spring-doc.cn
HandlerMethodValidationException ex = ... ;
ex.visitResults(new HandlerMethodValidationException.Visitor() {
	public void requestHeader(RequestHeader requestHeader, ParameterValidationResult result) {
	public void requestParam(@Nullable RequestParam requestParam, ParameterValidationResult result) {
	public void modelAttribute(@Nullable ModelAttribute modelAttribute, ParameterErrors errors) {
	public void other(ParameterValidationResult result) {
// HandlerMethodValidationException
val ex
ex.visitResults(object : HandlerMethodValidationException.Visitor {
	override fun requestHeader(requestHeader: RequestHeader, result: ParameterValidationResult) {
	override fun requestParam(requestParam: RequestParam?, result: ParameterValidationResult) {
	override fun modelAttribute(modelAttribute: ModelAttribute?, errors: ParameterErrors) {
	override fun other(result: ParameterValidationResult) {
