This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Framework 6.2.6!spring-doc.cn
Resources
Introduction
Java’s standard java.net.URL class and standard handlers for various URL prefixes, unfortunately, are not quite adequate enough for all access to low-level resources. For example, there is no standardized URL implementation that may be used to access a resource that needs to be obtained from the classpath or relative to a ServletContext. While it is possible to register new handlers for specialized URL prefixes (similar to existing handlers for prefixes such as http:), this is generally quite complicated, and the URL interface still lacks some desirable functionality, such as a method to check for the existence of the resource being pointed to.spring-doc.cn
The Resource Interface
Spring’s Resource interface located in the org.springframework.core.io. package is meant to be a more capable interface for abstracting access to low-level resources. The following listing provides an overview of the Resource interface. See the Resource javadoc for further details.spring-doc.cn
public interface Resource extends InputStreamSource {
	boolean exists();
	boolean isReadable();
	boolean isOpen();
	boolean isFile();
	URL getURL() throws IOException;
	URI getURI() throws IOException;
	File getFile() throws IOException;
	ReadableByteChannel readableChannel() throws IOException;
	long contentLength() throws IOException;
	long lastModified() throws IOException;
	Resource createRelative(String relativePath) throws IOException;
	String getFilename();
	String getDescription();
As the definition of the Resource interface shows, it extends the InputStreamSource interface. The following listing shows the definition of the InputStreamSource interface:spring-doc.cn
public interface InputStreamSource {
	InputStream getInputStream() throws IOException;
Some of the most important methods from the Resource interface are:spring-doc.cn
  • getInputStream(): Locates and opens the resource, returning an InputStream for reading from the resource. It is expected that each invocation returns a fresh InputStream. It is the responsibility of the caller to close the stream.spring-doc.cn
  • exists(): Returns a boolean indicating whether this resource actually exists in physical form.spring-doc.cn
  • isOpen(): Returns a boolean indicating whether this resource represents a handle with an open stream. If true, the InputStream cannot be read multiple times and must be read once only and then closed to avoid resource leaks. Returns false for all usual resource implementations, with the exception of InputStreamResource.spring-doc.cn
  • getDescription(): Returns a description for this resource, to be used for error output when working with the resource. This is often the fully qualified file name or the actual URL of the resource.spring-doc.cn
Other methods let you obtain an actual URL or File object representing the resource (if the underlying implementation is compatible and supports that functionality).spring-doc.cn
Some implementations of the Resource interface also implement the extended WritableResource interface for a resource that supports writing to it.spring-doc.cn
Spring itself uses the Resource abstraction extensively, as an argument type in many method signatures when a resource is needed. Other methods in some Spring APIs (such as the constructors to various ApplicationContext implementations) take a String which in unadorned or simple form is used to create a Resource appropriate to that context implementation or, via special prefixes on the String path, let the caller specify that a specific Resource implementation must be created and used.spring-doc.cn
While the Resource interface is used a lot with Spring and by Spring, it is actually very convenient to use as a general utility class by itself in your own code, for access to resources, even when your code does not know or care about any other parts of Spring. While this couples your code to Spring, it really only couples it to this small set of utility classes, which serves as a more capable replacement for URL and can be considered equivalent to any other library you would use for this purpose.spring-doc.cn
The Resource abstraction does not replace functionality. It wraps it where possible. For example, a UrlResource wraps a URL and uses the wrapped URL to do its work.
Built-in Resource Implementations
Spring includes several built-in Resource implementations:spring-doc.cn
For a complete list of Resource implementations available in Spring, consult the "All Known Implementing Classes" section of the Resource javadoc.spring-doc.cn
UrlResource
UrlResource wraps a java.net.URL and can be used to access any object that is normally accessible with a URL, such as files, an HTTPS target, an FTP target, and others. All URLs have a standardized String representation, such that appropriate standardized prefixes are used to indicate one URL type from another. This includes file: for accessing filesystem paths, https: for accessing resources through the HTTPS protocol, ftp: for accessing resources through FTP, and others.spring-doc.cn
A UrlResource is created by Java code by explicitly using the UrlResource constructor but is often created implicitly when you call an API method that takes a String argument meant to represent a path. For the latter case, a JavaBeans PropertyEditor ultimately decides which type of Resource to create. If the path string contains a well-known (to property editor, that is) prefix (such as classpath:), it creates an appropriate specialized Resource for that prefix. However, if it does not recognize the prefix, it assumes the string is a standard URL string and creates a UrlResource.spring-doc.cn
ClassPathResource
This class represents a resource that should be obtained from the classpath. It uses either the thread context class loader, a given class loader, or a given class for loading resources.spring-doc.cn
This Resource implementation supports resolution as a java.io.File if the class path resource resides in the file system but not for classpath resources that reside in a jar and have not been expanded (by the servlet engine or whatever the environment is) to the filesystem. To address this, the various Resource implementations always support resolution as a java.net.URL.spring-doc.cn
A ClassPathResource is created by Java code by explicitly using the ClassPathResource constructor but is often created implicitly when you call an API method that takes a String argument meant to represent a path. For the latter case, a JavaBeans PropertyEditor recognizes the special prefix, classpath:, on the string path and creates a ClassPathResource in that case.spring-doc.cn
FileSystemResource
This is a Resource implementation for java.io.File handles. It also supports java.nio.file.Path handles, applying Spring’s standard String-based path transformations but performing all operations via the java.nio.file.Files API. For pure java.nio.path.Path based support use a PathResource instead. FileSystemResource supports resolution as a File and as a URL.spring-doc.cn
PathResource
This is a Resource implementation for java.nio.file.Path handles, performing all operations and transformations via the Path API. It supports resolution as a File and as a URL and also implements the extended WritableResource interface. PathResource is effectively a pure java.nio.path.Path based alternative to FileSystemResource with different createRelative behavior.spring-doc.cn
ServletContextResource
This is a Resource implementation for ServletContext resources that interprets relative paths within the relevant web application’s root directory.spring-doc.cn
It always supports stream access and URL access but allows java.io.File access only when the web application archive is expanded and the resource is physically on the filesystem. Whether or not it is expanded and on the filesystem or accessed directly from the JAR or somewhere else like a database (which is conceivable) is actually dependent on the Servlet container.spring-doc.cn
InputStreamResource
An InputStreamResource is a Resource implementation for a given InputStream. It should be used only if no specific Resource implementation is applicable. In particular, prefer ByteArrayResource or any of the file-based Resource implementations where possible.spring-doc.cn
In contrast to other Resource implementations, this is a descriptor for an already-opened resource. Therefore, it returns true from isOpen(). Do not use it if you need to keep the resource descriptor somewhere or if you need to read a stream multiple times.spring-doc.cn
ByteArrayResource
This is a Resource implementation for a given byte array. It creates a ByteArrayInputStream for the given byte array.spring-doc.cn
It is useful for loading content from any given byte array without having to resort to a single-use InputStreamResource.spring-doc.cn
The ResourceLoader Interface
The ResourceLoader interface is meant to be implemented by objects that can return (that is, load) Resource instances. The following listing shows the ResourceLoader interface definition:spring-doc.cn
public interface ResourceLoader {
	Resource getResource(String location);
	ClassLoader getClassLoader();
All application contexts implement the ResourceLoader interface. Therefore, all application contexts may be used to obtain Resource instances.spring-doc.cn
When you call getResource() on a specific application context, and the location path specified doesn’t have a specific prefix, you get back a Resource type that is appropriate to that particular application context. For example, assume the following snippet of code was run against a ClassPathXmlApplicationContext instance:spring-doc.cn
Resource template = ctx.getResource("some/resource/path/myTemplate.txt");
val template = ctx.getResource("some/resource/path/myTemplate.txt")
Against a ClassPathXmlApplicationContext, that code returns a ClassPathResource. If the same method were run against a FileSystemXmlApplicationContext instance, it would return a FileSystemResource. For a WebApplicationContext, it would return a ServletContextResource. It would similarly return appropriate objects for each context.spring-doc.cn
As a result, you can load resources in a fashion appropriate to the particular application context.spring-doc.cn
On the other hand, you may also force ClassPathResource to be used, regardless of the application context type, by specifying the special classpath: prefix, as the following example shows:spring-doc.cn
Resource template = ctx.getResource("classpath:some/resource/path/myTemplate.txt");
val template = ctx.getResource("classpath:some/resource/path/myTemplate.txt")
Similarly, you can force a UrlResource to be used by specifying any of the standard java.net.URL prefixes. The following examples use the file and https prefixes:spring-doc.cn
Resource template = ctx.getResource("file:///some/resource/path/myTemplate.txt");
val template = ctx.getResource("file:///some/resource/path/myTemplate.txt")
Resource template = ctx.getResource("https://myhost.com/resource/path/myTemplate.txt");
val template = ctx.getResource("https://myhost.com/resource/path/myTemplate.txt")
The following table summarizes the strategy for converting String objects to Resource objects:spring-doc.cn
Table 1. Resource strings
Prefix Example Explanation
classpath:spring-doc.cn
classpath:com/myapp/config.xmlspring-doc.cn
Loaded from the classpath.spring-doc.cn
file:spring-doc.cn
file:///data/config.xmlspring-doc.cn
Loaded as a URL from the filesystem. See also FileSystemResource Caveats.spring-doc.cn
https:spring-doc.cn
https://myserver/logo.pngspring-doc.cn
Loaded as a URL.spring-doc.cn
(none)spring-doc.cn
Depends on the underlying ApplicationContext.spring-doc.cn
The ResourcePatternResolver Interface
The ResourcePatternResolver interface is an extension to the ResourceLoader interface which defines a strategy for resolving a location pattern (for example, an Ant-style path pattern) into Resource objects.spring-doc.cn
public interface ResourcePatternResolver extends ResourceLoader {
	String CLASSPATH_ALL_URL_PREFIX = "classpath*:";
	Resource[] getResources(String locationPattern) throws IOException;
As can be seen above, this interface also defines a special classpath*: resource prefix for all matching resources from the class path. Note that the resource location is expected to be a path without placeholders in this case — for example, classpath*:/config/beans.xml. JAR files or different directories in the class path can contain multiple files with the same path and the same name. See Wildcards in Application Context Constructor Resource Paths and its subsections for further details on wildcard support with the classpath*: resource prefix.spring-doc.cn
A passed-in ResourceLoader (for example, one supplied via ResourceLoaderAware semantics) can be checked whether it implements this extended interface too.spring-doc.cn
PathMatchingResourcePatternResolver is a standalone implementation that is usable outside an ApplicationContext and is also used by ResourceArrayPropertyEditor for populating Resource[] bean properties. PathMatchingResourcePatternResolver is able to resolve a specified resource location path into one or more matching Resource objects. The source path may be a simple path which has a one-to-one mapping to a target Resource, or alternatively may contain the special classpath*: prefix and/or internal Ant-style regular expressions (matched using Spring’s org.springframework.util.AntPathMatcher utility). Both of the latter are effectively wildcards.spring-doc.cn
The default ResourceLoader in any standard ApplicationContext is in fact an instance of PathMatchingResourcePatternResolver which implements the ResourcePatternResolver interface. The same is true for the ApplicationContext instance itself which also implements the ResourcePatternResolver interface and delegates to the default PathMatchingResourcePatternResolver.spring-doc.cn
The ResourceLoaderAware Interface
The ResourceLoaderAware interface is a special callback interface which identifies components that expect to be provided a ResourceLoader reference. The following listing shows the definition of the ResourceLoaderAware interface:spring-doc.cn
public interface ResourceLoaderAware {
	void setResourceLoader(ResourceLoader resourceLoader);
When a class implements ResourceLoaderAware and is deployed into an application context (as a Spring-managed bean), it is recognized as ResourceLoaderAware by the application context. The application context then invokes setResourceLoader(ResourceLoader), supplying itself as the argument (remember, all application contexts in Spring implement the ResourceLoader interface).spring-doc.cn
Since an ApplicationContext is a ResourceLoader, the bean could also implement the ApplicationContextAware interface and use the supplied application context directly to load resources. However, in general, it is better to use the specialized ResourceLoader interface if that is all you need. The code would be coupled only to the resource loading interface (which can be considered a utility interface) and not to the whole Spring ApplicationContext interface.spring-doc.cn
In application components, you may also rely upon autowiring of the ResourceLoader as an alternative to implementing the ResourceLoaderAware interface. The traditional constructor and byType autowiring modes (as described in Autowiring Collaborators) are capable of providing a ResourceLoader for either a constructor argument or a setter method parameter, respectively. For more flexibility (including the ability to autowire fields and multiple parameter methods), consider using the annotation-based autowiring features. In that case, the ResourceLoader is autowired into a field, constructor argument, or method parameter that expects the ResourceLoader type as long as the field, constructor, or method in question carries the @Autowired annotation. For more information, see Using @Autowired.spring-doc.cn
To load one or more Resource objects for a resource path that contains wildcards or makes use of the special classpath*: resource prefix, consider having an instance of ResourcePatternResolver autowired into your application components instead of ResourceLoader.
Resources as Dependencies
If the bean itself is going to determine and supply the resource path through some sort of dynamic process, it probably makes sense for the bean to use the ResourceLoader or ResourcePatternResolver interface to load resources. For example, consider the loading of a template of some sort, where the specific resource that is needed depends on the role of the user. If the resources are static, it makes sense to eliminate the use of the ResourceLoader interface (or ResourcePatternResolver interface) completely, have the bean expose the Resource properties it needs, and expect them to be injected into it.spring-doc.cn
What makes it trivial to then inject these properties is that all application contexts register and use a special JavaBeans PropertyEditor, which can convert String paths to Resource objects. For example, the following MyBean class has a template property of type Resource.spring-doc.cn
public class MyBean {
	private Resource template;
	public setTemplate(Resource template) {
		this.template = template;
class MyBean(var template: Resource)
In an XML configuration file, the template property can be configured with a simple string for that resource, as the following example shows:spring-doc.cn
<bean id="myBean" class="example.MyBean">
	<property name="template" value="some/resource/path/myTemplate.txt"/>
</bean>
Note that the resource path has no prefix. Consequently, because the application context itself is going to be used as the ResourceLoader, the resource is loaded through a ClassPathResource, a FileSystemResource, or a ServletContextResource, depending on the exact type of the application context.spring-doc.cn
If you need to force a specific Resource type to be used, you can use a prefix. The following two examples show how to force a ClassPathResource and a UrlResource (the latter being used to access a file in the filesystem):spring-doc.cn
<property name="template" value="classpath:some/resource/path/myTemplate.txt">
<property name="template" value="file:///some/resource/path/myTemplate.txt"/>
If the MyBean class is refactored for use with annotation-driven configuration, the path to myTemplate.txt can be stored under a key named template.path — for example, in a properties file made available to the Spring Environment (see Environment Abstraction). The template path can then be referenced via the @Value annotation using a property placeholder (see Using @Value). Spring will retrieve the value of the template path as a string, and a special PropertyEditor will convert the string to a Resource object to be injected into the MyBean constructor. The following example demonstrates how to achieve this.spring-doc.cn
@Component
	private final Resource template;
	public MyBean(@Value("${template.path}") Resource template) {
@Component
class MyBean(@Value("\${template.path}") private val template: Resource)
If we want to support multiple templates discovered under the same path in multiple locations in the classpath — for example, in multiple jars in the classpath — we can use the special classpath*: prefix and wildcarding to define a templates.path key as classpath*:/config/templates/*.txt. If we redefine the MyBean class as follows, Spring will convert the template path pattern into an array of Resource objects that can be injected into the MyBean constructor.spring-doc.cn
@Component
	private final Resource[] templates;
	public MyBean(@Value("${templates.path}") Resource[] templates) {
		this.templates = templates;
@Component
class MyBean(@Value("\${templates.path}") private val templates: Resource[])
Application Contexts and Resource Paths
This section covers how to create application contexts with resources, including shortcuts that work with XML, how to use wildcards, and other details.spring-doc.cn
Constructing Application Contexts
An application context constructor (for a specific application context type) generally takes a string or array of strings as the location paths of the resources, such as XML files that make up the definition of the context.spring-doc.cn
When such a location path does not have a prefix, the specific Resource type built from that path and used to load the bean definitions depends on and is appropriate to the specific application context. For example, consider the following example, which creates a ClassPathXmlApplicationContext:spring-doc.cn
ApplicationContext ctx = new ClassPathXmlApplicationContext("conf/appContext.xml");
val ctx = ClassPathXmlApplicationContext("conf/appContext.xml")
The bean definitions are loaded from the classpath, because a ClassPathResource is used. However, consider the following example, which creates a FileSystemXmlApplicationContext:spring-doc.cn
	new FileSystemXmlApplicationContext("conf/appContext.xml");
val ctx = FileSystemXmlApplicationContext("conf/appContext.xml")
Now the bean definitions are loaded from a filesystem location (in this case, relative to the current working directory).spring-doc.cn
Note that the use of the special classpath prefix or a standard URL prefix on the location path overrides the default type of Resource created to load the bean definitions. Consider the following example:spring-doc.cn
	new FileSystemXmlApplicationContext("classpath:conf/appContext.xml");
val ctx = FileSystemXmlApplicationContext("classpath:conf/appContext.xml")
Using FileSystemXmlApplicationContext loads the bean definitions from the classpath. However, it is still a FileSystemXmlApplicationContext. If it is subsequently used as a ResourceLoader, any unprefixed paths are still treated as filesystem paths.spring-doc.cn
Constructing ClassPathXmlApplicationContext Instances — Shortcuts
The ClassPathXmlApplicationContext exposes a number of constructors to enable convenient instantiation. The basic idea is that you can supply merely a string array that contains only the filenames of the XML files themselves (without the leading path information) and also supply a Class. The ClassPathXmlApplicationContext then derives the path information from the supplied class.spring-doc.cn
Consider the following directory layout:spring-doc.cn
com/
  example/
    services.xml
    repositories.xml
    MessengerService.class
The following example shows how a ClassPathXmlApplicationContext instance composed of the beans defined in files named services.xml and repositories.xml (which are on the classpath) can be instantiated:spring-doc.cn
	new String[] {"services.xml", "repositories.xml"}, MessengerService.class);
val ctx = ClassPathXmlApplicationContext(arrayOf("services.xml", "repositories.xml"), MessengerService::class.java)
See the ClassPathXmlApplicationContext javadoc for details on the various constructors.spring-doc.cn
The resource paths in application context constructor values may be simple paths (as shown earlier), each of which has a one-to-one mapping to a target Resource or, alternately, may contain the special classpath*: prefix or internal Ant-style patterns (matched by using Spring’s PathMatcher utility). Both of the latter are effectively wildcards.spring-doc.cn
One use for this mechanism is when you need to do component-style application assembly. All components can publish context definition fragments to a well-known location path, and, when the final application context is created using the same path prefixed with classpath*:, all component fragments are automatically picked up.spring-doc.cn
Note that this wildcarding is specific to the use of resource paths in application context constructors (or when you use the PathMatcher utility class hierarchy directly) and is resolved at construction time. It has nothing to do with the Resource type itself. You cannot use the classpath*: prefix to construct an actual Resource, as a resource points to just one resource at a time.spring-doc.cn
Ant-style Patterns
Path locations can contain Ant-style patterns, as the following example shows:spring-doc.cn
/WEB-INF/*-context.xml
com/mycompany/**/applicationContext.xml
file:C:/some/path/*-context.xml
classpath:com/mycompany/**/applicationContext.xml
When the path location contains an Ant-style pattern, the resolver follows a more complex procedure to try to resolve the wildcard. It produces a Resource for the path up to the last non-wildcard segment and obtains a URL from it. If this URL is not a jar: URL or container-specific variant (such as zip: in WebLogic, wsjar in WebSphere, and so on), a java.io.File is obtained from it and used to resolve the wildcard by traversing the filesystem. In the case of a jar URL, the resolver either gets a java.net.JarURLConnection from it or manually parses the jar URL and then traverses the contents of the jar file to resolve the wildcards.spring-doc.cn
Implications on Portability
If the specified path is already a file URL (either implicitly because the base ResourceLoader is a filesystem one or explicitly), wildcarding is guaranteed to work in a completely portable fashion.spring-doc.cn
If the specified path is a classpath location, the resolver must obtain the last non-wildcard path segment URL by making a Classloader.getResource() call. Since this is just a node of the path (not the file at the end), it is actually undefined (in the ClassLoader javadoc) exactly what sort of a URL is returned in this case. In practice, it is always a java.io.File representing the directory (where the classpath resource resolves to a filesystem location) or a jar URL of some sort (where the classpath resource resolves to a jar location). Still, there is a portability concern on this operation.spring-doc.cn
If a jar URL is obtained for the last non-wildcard segment, the resolver must be able to get a java.net.JarURLConnection from it or manually parse the jar URL, to be able to walk the contents of the jar and resolve the wildcard. This does work in most environments but fails in others, and we strongly recommend that the wildcard resolution of resources coming from jars be thoroughly tested in your specific environment before you rely on it.spring-doc.cn
The classpath*: Prefix
When constructing an XML-based application context, a location string may use the special classpath*: prefix, as the following example shows:spring-doc.cn
	new ClassPathXmlApplicationContext("classpath*:conf/appContext.xml");
val ctx = ClassPathXmlApplicationContext("classpath*:conf/appContext.xml")
This special prefix specifies that all classpath resources that match the given name must be obtained (internally, this essentially happens through a call to ClassLoader.getResources(…​)) and then merged to form the final application context definition.spring-doc.cn
The wildcard classpath relies on the getResources() method of the underlying ClassLoader. As most application servers nowadays supply their own ClassLoader implementation, the behavior might differ, especially when dealing with jar files. A simple test to check if classpath* works is to use the ClassLoader to load a file from within a jar on the classpath: getClass().getClassLoader().getResources("<someFileInsideTheJar>"). Try this test with files that have the same name but reside in two different locations — for example, files with the same name and same path but in different jars on the classpath. In case an inappropriate result is returned, check the application server documentation for settings that might affect the ClassLoader behavior.
You can also combine the classpath*: prefix with a PathMatcher pattern in the rest of the location path (for example, classpath*:META-INF/*-beans.xml). In this case, the resolution strategy is fairly simple: A ClassLoader.getResources() call is used on the last non-wildcard path segment to get all the matching resources in the class loader hierarchy and then, off each resource, the same PathMatcher resolution strategy described earlier is used for the wildcard subpath.spring-doc.cn
Other Notes Relating to Wildcards
Note that classpath*:, when combined with Ant-style patterns, only works reliably with at least one root directory before the pattern starts, unless the actual target files reside in the file system. This means that a pattern such as classpath*:*.xml might not retrieve files from the root of jar files but rather only from the root of expanded directories.spring-doc.cn
Spring’s ability to retrieve classpath entries originates from the JDK’s ClassLoader.getResources() method, which only returns file system locations for an empty string (indicating potential roots to search). Spring evaluates URLClassLoader runtime configuration and the java.class.path manifest in jar files as well, but this is not guaranteed to lead to portable behavior.spring-doc.cn
The scanning of classpath packages requires the presence of corresponding directory entries in the classpath. When you build JARs with Ant, do not activate the files-only switch of the JAR task. Also, classpath directories may not get exposed based on security policies in some environments — for example, stand-alone applications on JDK 1.7.0_45 and higher (which requires 'Trusted-Library' to be set up in your manifests. See stackoverflow.com/questions/19394570/java-jre-7u45-breaks-classloader-getresources).spring-doc.cn
On JDK 9’s module path (Jigsaw), Spring’s classpath scanning generally works as expected. Putting resources into a dedicated directory is highly recommendable here as well, avoiding the aforementioned portability problems with searching the jar file root level.spring-doc.cn
Ant-style patterns with classpath: resources are not guaranteed to find matching resources if the root package to search is available in multiple classpath locations. Consider the following example of a resource location:spring-doc.cn
com/mycompany/package1/service-context.xml
Now consider an Ant-style path that someone might use to try to find that file:spring-doc.cn
classpath:com/mycompany/**/service-context.xml
Such a resource may exist in only one location in the classpath, but when a path such as the preceding example is used to try to resolve it, the resolver works off the (first) URL returned by getResource("com/mycompany");. If this base package node exists in multiple ClassLoader locations, the desired resource may not exist in the first location found. Therefore, in such cases you should prefer using classpath*: with the same Ant-style pattern, which searches all classpath locations that contain the com.mycompany base package: classpath*:com/mycompany/**/service-context.xml.spring-doc.cn
A FileSystemResource that is not attached to a FileSystemApplicationContext (that is, when a FileSystemApplicationContext is not the actual ResourceLoader) treats absolute and relative paths as you would expect. Relative paths are relative to the current working directory, while absolute paths are relative to the root of the filesystem.spring-doc.cn
For backwards compatibility (historical) reasons however, this changes when the FileSystemApplicationContext is the ResourceLoader. The FileSystemApplicationContext forces all attached FileSystemResource instances to treat all location paths as relative, whether they start with a leading slash or not. In practice, this means the following examples are equivalent:spring-doc.cn
	new FileSystemXmlApplicationContext("conf/context.xml");
val ctx = FileSystemXmlApplicationContext("conf/context.xml")
	new FileSystemXmlApplicationContext("/conf/context.xml");
val ctx = FileSystemXmlApplicationContext("/conf/context.xml")
The following examples are also equivalent (even though it would make sense for them to be different, as one case is relative and the other absolute):spring-doc.cn
FileSystemXmlApplicationContext ctx = ...;
val ctx: FileSystemXmlApplicationContext = ...
ctx.getResource("/some/resource/path/myTemplate.txt");
In practice, if you need true absolute filesystem paths, you should avoid using absolute paths with FileSystemResource or FileSystemXmlApplicationContext and force the use of a UrlResource by using the file: URL prefix. The following examples show how to do so:spring-doc.cn
// actual context type doesn't matter, the Resource will always be UrlResource
// force this FileSystemXmlApplicationContext to load its definition via a UrlResource
	new FileSystemXmlApplicationContext("file:///conf/context.xml");
val ctx = FileSystemXmlApplicationContext("file:///conf/context.xml")
