Web Reactive
1. Spring WebFlux
The original web framework included in the Spring Framework, Spring Web MVC, was purpose-built for the Servlet API and Servlet containers. The reactive-stack web framework, Spring WebFlux, was added later in version 5.0. It is fully non-blocking, supports Reactive Streams back pressure, and runs on such servers as Netty, Undertow, and Servlet 3.1+ containers.
Both web frameworks mirror the names of their source modules
(spring-webmvc and
spring-webflux) and co-exist side by side in the
Spring Framework. Each module is optional. Applications can use one or the other module or,
in some cases, both — for example, Spring MVC controllers with the reactive WebClient
1.1. Overview
Why was Spring WebFlux created?
Part of the answer is the need for a non-blocking web stack to handle concurrency with a
small number of threads and scale with fewer hardware resources. Servlet 3.1 did provide
an API for non-blocking I/O. However, using it leads away from the rest of the Servlet API,
where contracts are synchronous (Filter
, Servlet
) or blocking (getParameter
getPart
). This was the motivation for a new common API to serve as a foundation across
any non-blocking runtime. That is important because of servers (such as Netty) that are
well-established in the async, non-blocking space.
The other part of the answer is functional programming. Much as the addition of annotations
in Java 5 created opportunities (such as annotated REST controllers or unit tests), the addition
of lambda expressions in Java 8 created opportunities for functional APIs in Java.
This is a boon for non-blocking applications and continuation-style APIs (as popularized
by CompletableFuture
and ReactiveX) that allow declarative
composition of asynchronous logic. At the programming-model level, Java 8 enabled Spring
WebFlux to offer functional web endpoints alongside annotated controllers.
1.1.1. Define “Reactive”
We touched on “non-blocking” and “functional” but what does reactive mean?
The term, “reactive,” refers to programming models that are built around reacting to change — network components reacting to I/O events, UI controllers reacting to mouse events, and others. In that sense, non-blocking is reactive, because, instead of being blocked, we are now in the mode of reacting to notifications as operations complete or data becomes available.
There is also another important mechanism that we on the Spring team associate with “reactive” and that is non-blocking back pressure. In synchronous, imperative code, blocking calls serve as a natural form of back pressure that forces the caller to wait. In non-blocking code, it becomes important to control the rate of events so that a fast producer does not overwhelm its destination.
Reactive Streams is a small spec (also adopted in Java 9) that defines the interaction between asynchronous components with back pressure. For example a data repository (acting as Publisher) can produce data that an HTTP server (acting as Subscriber) can then write to the response. The main purpose of Reactive Streams is to let the subscriber control how quickly or how slowly the publisher produces data.
Common question: what if a publisher cannot slow down? The purpose of Reactive Streams is only to establish the mechanism and a boundary. If a publisher cannot slow down, it has to decide whether to buffer, drop, or fail. |
1.1.2. Reactive API
Reactive Streams plays an important role for interoperability. It is of interest to libraries
and infrastructure components but less useful as an application API, because it is too
low-level. Applications need a higher-level and richer, functional API to
compose async logic — similar to the Java 8 Stream
API but not only for collections.
This is the role that reactive libraries play.
Reactor is the reactive library of choice for
Spring WebFlux. It provides the
Mono
and
Flux
API types
to work on data sequences of 0..1 (Mono
) and 0..N (Flux
) through a rich set of operators aligned with the
ReactiveX vocabulary of operators.
Reactor is a Reactive Streams library and, therefore, all of its operators support non-blocking back pressure.
Reactor has a strong focus on server-side Java. It is developed in close collaboration
with Spring.
WebFlux requires Reactor as a core dependency but it is interoperable with other reactive
libraries via Reactive Streams. As a general rule, a WebFlux API accepts a plain Publisher
as input, adapts it to a Reactor type internally, uses that, and returns either a
Flux
or a Mono
as output. So, you can pass any Publisher
as input and you can apply
operations on the output, but you need to adapt the output for use with another reactive library.
Whenever feasible (for example, annotated controllers), WebFlux adapts transparently to the use
of RxJava or another reactive library. See Reactive Libraries for more details.
In addition to Reactive APIs, WebFlux can also be used with Coroutines APIs in Kotlin which provides a more imperative style of programming. The following Kotlin code samples will be provided with Coroutines APIs. |
1.1.3. Programming Models
The spring-web
module contains the reactive foundation that underlies Spring WebFlux,
including HTTP abstractions, Reactive Streams adapters for supported
servers, codecs, and a core WebHandler
API comparable to
the Servlet API but with non-blocking contracts.
On that foundation, Spring WebFlux provides a choice of two programming models:
Annotated Controllers: Consistent with Spring MVC and based on the same annotations from the
spring-web
module. Both Spring MVC and WebFlux controllers support reactive (Reactor and RxJava) return types, and, as a result, it is not easy to tell them apart. One notable difference is that WebFlux also supports reactive@RequestBody
arguments. -
Functional Endpoints: Lambda-based, lightweight, and functional programming model. You can think of this as a small library or a set of utilities that an application can use to route and handle requests. The big difference with annotated controllers is that the application is in charge of request handling from start to finish versus declaring intent through annotations and being called back.
1.1.4. Applicability
Spring MVC or WebFlux?
A natural question to ask but one that sets up an unsound dichotomy. Actually, both work together to expand the range of available options. The two are designed for continuity and consistency with each other, they are available side by side, and feedback from each side benefits both sides. The following diagram shows how the two relate, what they have in common, and what each supports uniquely:
We suggest that you consider the following specific points:
If you have a Spring MVC application that works fine, there is no need to change. Imperative programming is the easiest way to write, understand, and debug code. You have maximum choice of libraries, since, historically, most are blocking.
If you are already shopping for a non-blocking web stack, Spring WebFlux offers the same execution model benefits as others in this space and also provides a choice of servers (Netty, Tomcat, Jetty, Undertow, and Servlet 3.1+ containers), a choice of programming models (annotated controllers and functional web endpoints), and a choice of reactive libraries (Reactor, RxJava, or other).
If you are interested in a lightweight, functional web framework for use with Java 8 lambdas or Kotlin, you can use the Spring WebFlux functional web endpoints. That can also be a good choice for smaller applications or microservices with less complex requirements that can benefit from greater transparency and control.
In a microservice architecture, you can have a mix of applications with either Spring MVC or Spring WebFlux controllers or with Spring WebFlux functional endpoints. Having support for the same annotation-based programming model in both frameworks makes it easier to re-use knowledge while also selecting the right tool for the right job.
A simple way to evaluate an application is to check its dependencies. If you have blocking persistence APIs (JPA, JDBC) or networking APIs to use, Spring MVC is the best choice for common architectures at least. It is technically feasible with both Reactor and RxJava to perform blocking calls on a separate thread but you would not be making the most of a non-blocking web stack.
If you have a Spring MVC application with calls to remote services, try the reactive
WebClient
. You can return reactive types (Reactor, RxJava, or other) directly from Spring MVC controller methods. The greater the latency per call or the interdependency among calls, the more dramatic the benefits. Spring MVC controllers can call other reactive components too. -
If you have a large team, keep in mind the steep learning curve in the shift to non-blocking, functional, and declarative programming. A practical way to start without a full switch is to use the reactive
WebClient
. Beyond that, start small and measure the benefits. We expect that, for a wide range of applications, the shift is unnecessary. If you are unsure what benefits to look for, start by learning about how non-blocking I/O works (for example, concurrency on single-threaded Node.js) and its effects.
1.1.5. Servers
Spring WebFlux is supported on Tomcat, Jetty, Servlet 3.1+ containers, as well as on non-Servlet runtimes such as Netty and Undertow. All servers are adapted to a low-level, common API so that higher-level programming models can be supported across servers.
Spring WebFlux does not have built-in support to start or stop a server. However, it is easy to assemble an application from Spring configuration and WebFlux infrastructure and run it with a few lines of code.
Spring Boot has a WebFlux starter that automates these steps. By default, the starter uses Netty, but it is easy to switch to Tomcat, Jetty, or Undertow by changing your Maven or Gradle dependencies. Spring Boot defaults to Netty, because it is more widely used in the asynchronous, non-blocking space and lets a client and a server share resources.
Tomcat and Jetty can be used with both Spring MVC and WebFlux. Keep in mind, however, that the way they are used is very different. Spring MVC relies on Servlet blocking I/O and lets applications use the Servlet API directly if they need to. Spring WebFlux relies on Servlet 3.1 non-blocking I/O and uses the Servlet API behind a low-level adapter. It is not exposed for direct use.
For Undertow, Spring WebFlux uses Undertow APIs directly without the Servlet API.
1.1.6. Performance
Performance has many characteristics and meanings. Reactive and non-blocking generally
do not make applications run faster. They can, in some cases, (for example, if using the
WebClient
to run remote calls in parallel). On the whole, it requires more work to do
things the non-blocking way and that can slightly increase the required processing time.
The key expected benefit of reactive and non-blocking is the ability to scale with a small, fixed number of threads and less memory. That makes applications more resilient under load, because they scale in a more predictable way. In order to observe those benefits, however, you need to have some latency (including a mix of slow and unpredictable network I/O). That is where the reactive stack begins to show its strengths, and the differences can be dramatic.
1.1.7. Concurrency Model
Both Spring MVC and Spring WebFlux support annotated controllers, but there is a key difference in the concurrency model and the default assumptions for blocking and threads.
In Spring MVC (and servlet applications in general), it is assumed that applications can block the current thread, (for example, for remote calls). For this reason, servlet containers use a large thread pool to absorb potential blocking during request handling.
In Spring WebFlux (and non-blocking servers in general), it is assumed that applications do not block. Therefore, non-blocking servers use a small, fixed-size thread pool (event loop workers) to handle requests.
“To scale” and “small number of threads” may sound contradictory but to never block the current thread (and rely on callbacks instead) means that you do not need extra threads, as there are no blocking calls to absorb. |
What if you do need to use a blocking library? Both Reactor and RxJava provide the
publishOn
operator to continue processing on a different thread. That means there is an
easy escape hatch. Keep in mind, however, that blocking APIs are not a good fit for
this concurrency model.
In Reactor and RxJava, you declare logic through operators. At runtime, a reactive pipeline is formed where data is processed sequentially, in distinct stages. A key benefit of this is that it frees applications from having to protect mutable state because application code within that pipeline is never invoked concurrently.
What threads should you expect to see on a server running with Spring WebFlux?
On a “vanilla” Spring WebFlux server (for example, no data access nor other optional dependencies), you can expect one thread for the server and several others for request processing (typically as many as the number of CPU cores). Servlet containers, however, may start with more threads (for example, 10 on Tomcat), in support of both servlet (blocking) I/O and servlet 3.1 (non-blocking) I/O usage.
The reactive
WebClient
operates in event loop style. So you can see a small, fixed number of processing threads related to that (for example,reactor-http-nio-
with the Reactor Netty connector). However, if Reactor Netty is used for both client and server, the two share event loop resources by default. -
Reactor and RxJava provide thread pool abstractions, called schedulers, to use with the
publishOn
operator that is used to switch processing to a different thread pool. The schedulers have names that suggest a specific concurrency strategy — for example, “parallel” (for CPU-bound work with a limited number of threads) or “elastic” (for I/O-bound work with a large number of threads). If you see such threads, it means some code is using a specific thread poolScheduler
strategy. -
Data access libraries and other third party dependencies can also create and use threads of their own.
The Spring Framework does not provide support for starting and stopping
servers. To configure the threading model for a server,
you need to use server-specific configuration APIs, or, if you use Spring Boot,
check the Spring Boot configuration options for each server. You can
configure the WebClient
directly.
For all other libraries, see their respective documentation.
1.2. Reactive Core
The spring-web
module contains the following foundational support for reactive web
applications:
For server request processing there are two levels of support.
HttpHandler: Basic contract for HTTP request handling with non-blocking I/O and Reactive Streams back pressure, along with adapters for Reactor Netty, Undertow, Tomcat, Jetty, and any Servlet 3.1+ container.
WebHandler
API: Slightly higher level, general-purpose web API for request handling, on top of which concrete programming models such as annotated controllers and functional endpoints are built.
For the client side, there is a basic
ClientHttpConnector
contract to perform HTTP requests with non-blocking I/O and Reactive Streams back pressure, along with adapters for Reactor Netty, reactive Jetty HttpClient and Apache HttpComponents. The higher level WebClient used in applications builds on this basic contract. -
For client and server, codecs for serialization and deserialization of HTTP request and response content.
1.2.1. HttpHandler
HttpHandler is a simple contract with a single method to handle a request and a response. It is intentionally minimal, and its main and only purpose is to be a minimal abstraction over different HTTP server APIs.
The following table describes the supported server APIs:
Server name | Server API used | Reactive Streams support |
Netty |
Netty API |
Undertow |
Undertow API |
spring-web: Undertow to Reactive Streams bridge |
Tomcat |
Servlet 3.1 non-blocking I/O; Tomcat API to read and write ByteBuffers vs byte[] |
spring-web: Servlet 3.1 non-blocking I/O to Reactive Streams bridge |
Jetty |
Servlet 3.1 non-blocking I/O; Jetty API to write ByteBuffers vs byte[] |
Servlet 3.1 container |
Servlet 3.1 non-blocking I/O |
The following table describes server dependencies (also see supported versions):
Server name | Group id | Artifact name |
Reactor Netty |
io.projectreactor.netty |
reactor-netty |
Undertow |
io.undertow |
undertow-core |
Tomcat |
org.apache.tomcat.embed |
tomcat-embed-core |
Jetty |
org.eclipse.jetty |
jetty-server, jetty-servlet |
The code snippets below show using the HttpHandler
adapters with each server API:
Reactor Netty
HttpHandler handler = ...
ReactorHttpHandlerAdapter adapter = new ReactorHttpHandlerAdapter(handler);
HttpServer.create().host(host).port(port).handle(adapter).bind().block();
val handler: HttpHandler = ...
val adapter = ReactorHttpHandlerAdapter(handler)
Undertow
UndertowHttpHandlerAdapter adapter = new UndertowHttpHandlerAdapter(handler);
Undertow server = Undertow.builder().addHttpListener(port, host).setHandler(adapter).build();
server.start();
val adapter = UndertowHttpHandlerAdapter(handler)
val server = Undertow.builder().addHttpListener(port, host).setHandler(adapter).build()
server.start()
Tomcat
Servlet servlet = new TomcatHttpHandlerAdapter(handler);
Tomcat server = new Tomcat();
File base = new File(System.getProperty("java.io.tmpdir"));
Context rootContext = server.addContext("", base.getAbsolutePath());
Tomcat.addServlet(rootContext, "main", servlet);
rootContext.addServletMappingDecoded("/", "main");
server.setHost(host);
server.setPort(port);
server.start();
val servlet = TomcatHttpHandlerAdapter(handler)
val server = Tomcat()
val base = File(System.getProperty("java.io.tmpdir"))
val rootContext = server.addContext("", base.absolutePath)
server.host = host
server.start()
Jetty
Servlet servlet = new JettyHttpHandlerAdapter(handler);
Server server = new Server();
ServletContextHandler contextHandler = new ServletContextHandler(server, "");
contextHandler.addServlet(new ServletHolder(servlet), "/");
contextHandler.start();
ServerConnector connector = new ServerConnector(server);
connector.setHost(host);
connector.setPort(port);
server.addConnector(connector);
server.start();
val servlet = JettyHttpHandlerAdapter(handler)
val server = Server()
val contextHandler = ServletContextHandler(server, "")
contextHandler.addServlet(ServletHolder(servlet), "/")
val connector = ServerConnector(server)
connector.host = host
connector.port = port
server.start()
Servlet 3.1+ Container
To deploy as a WAR to any Servlet 3.1+ container, you can extend and include
AbstractReactiveWebInitializer
in the WAR. That class wraps an HttpHandler
with ServletHttpHandlerAdapter
and registers
that as a Servlet
1.2.2. WebHandler
API
The org.springframework.web.server
package builds on the HttpHandler
contract
to provide a general-purpose web API for processing requests through a chain of multiple
WebExceptionHandler
, multiple
WebFilter
, and a single
WebHandler
component. The chain can
be put together with WebHttpHandlerBuilder
by simply pointing to a Spring
ApplicationContext
where components are
auto-detected, and/or by registering components
with the builder.
While HttpHandler
has a simple goal to abstract the use of different HTTP servers, the
WebHandler
API aims to provide a broader set of features commonly used in web applications
such as:
User session with attributes.
Request attributes.
Resolved
Locale
orPrincipal
for the request. -
Access to parsed and cached form data.
Abstractions for multipart data.
and more..
Special bean types
The table below lists the components that WebHttpHandlerBuilder
can auto-detect in a
Spring ApplicationContext, or that can be registered directly with it:
Bean name | Bean type | Count | Description |
<any> |
0..N |
Provide handling for exceptions from the chain of |
<any> |
0..N |
Apply interception style logic to before and after the rest of the filter chain and
the target |
1 |
The handler for the request. |
0..1 |
The manager for |
0..1 |
For access to |
0..1 |
The resolver for |
0..1 |
For processing forwarded type headers, either by extracting and removing them or by removing them only. Not used by default. |
Form Data
ServerWebExchange
exposes the following method for accessing form data:
Mono<MultiValueMap<String, String>> getFormData();
suspend fun getFormData(): MultiValueMap<String, String>
The DefaultServerWebExchange
uses the configured HttpMessageReader
to parse form data
(application/x-www-form-urlencoded
) into a MultiValueMap
. By default,
FormHttpMessageReader
is configured for use by the ServerCodecConfigurer
bean
(see the Web Handler API).
Multipart Data
ServerWebExchange
exposes the following method for accessing multipart data:
Mono<MultiValueMap<String, Part>> getMultipartData();
suspend fun getMultipartData(): MultiValueMap<String, Part>
uses the configured
HttpMessageReader<MultiValueMap<String, Part>>
to parse multipart/form-data
content
By default, this is the DefaultPartHttpMessageReader
, which does not have any third-party
dependencies.
Alternatively, the SynchronossPartHttpMessageReader
can be used, which is based on the
Synchronoss NIO Multipart library.
Both are configured through the ServerCodecConfigurer
bean
To parse multipart data in streaming fashion, you can use the Flux<Part>
returned from an
HttpMessageReader<Part>
instead. For example, in an annotated controller, use of
@RequestPart
implies Map
-like access to individual parts by name and, hence, requires
parsing multipart data in full. By contrast, you can use @RequestBody
to decode the
content to Flux<Part>
without collecting to a MultiValueMap
Forwarded Headers
As a request goes through proxies (such as load balancers), the host, port, and scheme may change. That makes it a challenge, from a client perspective, to create links that point to the correct host, port, and scheme.
RFC 7239 defines the Forwarded
HTTP header
that proxies can use to provide information about the original request. There are other
non-standard headers, too, including X-Forwarded-Host
, X-Forwarded-Port
X-Forwarded-Proto
, X-Forwarded-Ssl
, and X-Forwarded-Prefix
ForwardedHeaderTransformer
is a component that modifies the host, port, and scheme of
the request, based on forwarded headers, and then removes those headers. If you declare
it as a bean with the name forwardedHeaderTransformer
, it will be
detected and used.
There are security considerations for forwarded headers, since an application cannot know
if the headers were added by a proxy, as intended, or by a malicious client. This is why
a proxy at the boundary of trust should be configured to remove untrusted forwarded traffic coming
from the outside. You can also configure the ForwardedHeaderTransformer
with
removeOnly=true
, in which case it removes but does not use the headers.
In 5.1 ForwardedHeaderFilter was deprecated and superseded by
ForwardedHeaderTransformer so forwarded headers can be processed earlier, before the
exchange is created. If the filter is configured anyway, it is taken out of the list of
filters, and ForwardedHeaderTransformer is used instead.
1.2.3. Filters
In the WebHandler
API, you can use a WebFilter
to apply interception-style
logic before and after the rest of the processing chain of filters and the target
WebHandler
. When using the WebFlux Config, registering a WebFilter
is as simple
as declaring it as a Spring bean and (optionally) expressing precedence by using @Order
on
the bean declaration or by implementing Ordered
CORS
Spring WebFlux provides fine-grained support for CORS configuration through annotations on
controllers. However, when you use it with Spring Security, we advise relying on the built-in
CorsFilter
, which must be ordered ahead of Spring Security’s chain of filters.
See the section on CORS and the CORS WebFilter
for more details.
1.2.4. Exceptions
In the WebHandler
API, you can use a WebExceptionHandler
to handle
exceptions from the chain of WebFilter
instances and the target WebHandler
. When using the
WebFlux Config, registering a WebExceptionHandler
is as simple as declaring it as a
on the bean declaration or
The following table describes the available WebExceptionHandler
implementations:
Exception Handler | Description |
Provides handling for exceptions of type
Extension of This handler is declared in the WebFlux Config. |
1.2.5. Codecs
The spring-web
and spring-core
modules provide support for serializing and
deserializing byte content to and from higher level objects through non-blocking I/O with
Reactive Streams back pressure. The following describes this support:
Encoder
andDecoder
are low level contracts to encode and decode content independent of HTTP. -
HttpMessageReader
andHttpMessageWriter
are contracts to encode and decode HTTP message content. -
An
Encoder
can be wrapped withEncoderHttpMessageWriter
to adapt it for use in a web application, while aDecoder
can be wrapped withDecoderHttpMessageReader
DataBuffer
abstracts different byte buffer representations (e.g. NettyByteBuf
,java.nio.ByteBuffer
, etc.) and is what all codecs work on. See Data Buffers and Codecs in the "Spring Core" section for more on this topic.
The spring-core
module provides byte[]
, ByteBuffer
, DataBuffer
, Resource
, and
String
encoder and decoder implementations. The spring-web
module provides Jackson
JSON, Jackson Smile, JAXB2, Protocol Buffers and other encoders and decoders along with
web-only HTTP message reader and writer implementations for form data, multipart content,
server-sent events, and others.
ClientCodecConfigurer
and ServerCodecConfigurer
are typically used to configure and
customize the codecs to use in an application. See the section on configuring
HTTP message codecs.
Jackson JSON
JSON and binary JSON (Smile) are both supported when the Jackson library is present.
The Jackson2Decoder
works as follows:
Jackson’s asynchronous, non-blocking parser is used to aggregate a stream of byte chunks into
TokenBuffer
's each representing a JSON object. -
Each
TokenBuffer
is passed to Jackson’sObjectMapper
to create a higher level object. -
When decoding to a single-value publisher (e.g.
Mono
), there is oneTokenBuffer
When decoding to a multi-value publisher (e.g.
Flux
), eachTokenBuffer
is passed to theObjectMapper
as soon as enough bytes are received for a fully formed object. The input content can be a JSON array, or any line-delimited JSON format such as NDJSON, JSON Lines, or JSON Text Sequences.
The Jackson2Encoder
works as follows:
For a single value publisher (e.g.
Mono
), simply serialize it through theObjectMapper
For a multi-value publisher with
application/json
, by default collect the values withFlux#collectToList()
and then serialize the resulting collection. -
For a multi-value publisher with a streaming media type such as
application/x-ndjson
orapplication/stream+x-jackson-smile
, encode, write, and flush each value individually using a line-delimited JSON format. Other streaming media types may be registered with the encoder. -
For SSE the
Jackson2Encoder
is invoked per event and the output is flushed to ensure delivery without delay.
By default both |
Form Data
and FormHttpMessageWriter
support decoding and encoding
content.
On the server side where form content often needs to be accessed from multiple places,
ServerWebExchange
provides a dedicated getFormData()
method that parses the content
through FormHttpMessageReader
and then caches the result for repeated access.
See Form Data in the WebHandler
API section.
Once getFormData()
is used, the original raw content can no longer be read from the
request body. For this reason, applications are expected to go through ServerWebExchange
consistently for access to the cached form data versus reading from the raw request body.
Multipart
MultipartHttpMessageReader
and MultipartHttpMessageWriter
encoding "multipart/form-data" content. In turn MultipartHttpMessageReader
delegates to
another HttpMessageReader
for the actual parsing to a Flux<Part>
and then simply
collects the parts into a MultiValueMap
By default, the DefaultPartHttpMessageReader
is used, but this can be changed through the
For more information about the DefaultPartHttpMessageReader
, refer to to the
javadoc of DefaultPartHttpMessageReader
On the server side where multipart form content may need to be accessed from multiple
places, ServerWebExchange
provides a dedicated getMultipartData()
method that parses
the content through MultipartHttpMessageReader
See Multipart Data in the WebHandler
API section.
Once getMultipartData()
request body. For this reason applications have to consistently use getMultipartData()
for repeated, map-like access to parts, or otherwise rely on the
for a one-time access to Flux<Part>
Limits
Decoder
and HttpMessageReader
implementations that buffer some or all of the input
stream can be configured with a limit on the maximum number of bytes to buffer in memory.
In some cases buffering occurs because input is aggregated and represented as a single
object — for example, a controller method with @RequestBody byte[]
data, and so on. Buffering can also occur with streaming, when
splitting the input stream — for example, delimited text, a stream of JSON objects, and
so on. For those streaming cases, the limit applies to the number of bytes associated
with one object in the stream.
To configure buffer sizes, you can check if a given Decoder
or HttpMessageReader
exposes a maxInMemorySize
property and if so the Javadoc will have details about default
values. On the server side, ServerCodecConfigurer
provides a single place from where to
set all codecs, see HTTP message codecs. On the client side, the limit for
all codecs can be changed in
WebClient.Builder.
For Multipart parsing the maxInMemorySize
property limits
the size of non-file parts. For file parts, it determines the threshold at which the part
is written to disk. For file parts written to disk, there is an additional
maxDiskUsagePerPart
property to limit the amount of disk space per part. There is also
a maxParts
property to limit the overall number of parts in a multipart request.
To configure all three in WebFlux, you’ll need to supply a pre-configured instance of
to ServerCodecConfigurer
Streaming
When streaming to the HTTP response (for example, text/event-stream
), it is important to send data periodically, in order to
reliably detect a disconnected client sooner rather than later. Such a send could be a
comment-only, empty SSE event or any other "no-op" data that would effectively serve as
a heartbeat.
DataBuffer
DataBuffer
is the representation for a byte buffer in WebFlux. The Spring Core part of
this reference has more on that in the section on
Data Buffers and Codecs. The key point to understand is that on some
servers like Netty, byte buffers are pooled and reference counted, and must be released
when consumed to avoid memory leaks.
WebFlux applications generally do not need to be concerned with such issues, unless they consume or produce data buffers directly, as opposed to relying on codecs to convert to and from higher level objects, or unless they choose to create custom codecs. For such cases please review the information in Data Buffers and Codecs, especially the section on Using DataBuffer.
1.2.6. Logging
DEBUG
level logging in Spring WebFlux is designed to be compact, minimal, and
human-friendly. It focuses on high value bits of information that are useful over and
over again vs others that are useful only when debugging a specific issue.
TRACE
level logging generally follows the same principles as DEBUG
(and for example also
should not be a firehose) but can be used for debugging any issue. In addition, some log
messages may show a different level of detail at TRACE
vs DEBUG
Good logging comes from the experience of using the logs. If you spot anything that does not meet the stated goals, please let us know.
Log Id
In WebFlux, a single request can be run over multiple threads and the thread ID is not useful for correlating log messages that belong to a specific request. This is why WebFlux log messages are prefixed with a request-specific ID by default.
On the server side, the log ID is stored in the ServerWebExchange
attribute
(LOG_ID_ATTRIBUTE
while a fully formatted prefix based on that ID is available from
ServerWebExchange#getLogPrefix()
. On the WebClient
ClientRequest
attribute
(LOG_ID_ATTRIBUTE
,while a fully formatted prefix is available from ClientRequest#logPrefix()
Sensitive Data
DEBUG
and TRACE
logging can log sensitive information. This is why form parameters and
headers are masked by default and you must explicitly enable their logging in full.
The following example shows how to do so for server-side requests:
@EnableWebFlux
class MyConfig implements WebFluxConfigurer {
public void configureHttpMessageCodecs(ServerCodecConfigurer configurer) {
configurer.defaultCodecs().enableLoggingRequestDetails(true);
@EnableWebFlux
class MyConfig : WebFluxConfigurer {
override fun configureHttpMessageCodecs(configurer: ServerCodecConfigurer) {
The following example shows how to do so for client-side requests:
Consumer<ClientCodecConfigurer> consumer = configurer ->
WebClient webClient = WebClient.builder()
.exchangeStrategies(strategies -> strategies.codecs(consumer))
val consumer: (ClientCodecConfigurer) -> Unit = { configurer -> configurer.defaultCodecs().enableLoggingRequestDetails(true) }
val webClient = WebClient.builder()
.exchangeStrategies({ strategies -> strategies.codecs(consumer) })
.build()
Appenders
Logging libraries such as SLF4J and Log4J 2 provide asynchronous loggers that avoid blocking. While those have their own drawbacks such as potentially dropping messages that could not be queued for logging, they are the best available options currently for use in a reactive, non-blocking application.
Custom codecs
Applications can register custom codecs for supporting additional media types, or specific behaviors that are not supported by the default codecs.
Some configuration options expressed by developers are enforced on default codecs. Custom codecs might want to get a chance to align with those preferences, like enforcing buffering limits or logging sensitive data.
.codecs(configurer -> {
CustomDecoder decoder = new CustomDecoder();
configurer.customCodecs().registerWithDefaultConfig(decoder);
.codecs({ configurer ->
val decoder = CustomDecoder()
.build()
1.3. DispatcherHandler
Spring WebFlux, similarly to Spring MVC, is designed around the front controller pattern,
where a central WebHandler
, the DispatcherHandler
, provides a shared algorithm for
request processing, while actual work is performed by configurable, delegate components.
This model is flexible and supports diverse workflows.
DispatcherHandler
discovers the delegate components it needs from Spring configuration.
It is also designed to be a Spring bean itself and implements ApplicationContextAware
for access to the context in which it runs. If DispatcherHandler
is declared with a bean
name of webHandler
, it is, in turn, discovered by
which puts together a request-processing chain, as described in WebHandler
API.
Spring configuration in a WebFlux application typically contains:
DispatcherHandler
with the bean namewebHandler
WebFilter
andWebExceptionHandler
beans -
Others
The configuration is given to WebHttpHandlerBuilder
to build the processing chain,
as the following example shows:
ApplicationContext context = ...
HttpHandler handler = WebHttpHandlerBuilder.applicationContext(context).build();
val context: ApplicationContext = ...
val handler = WebHttpHandlerBuilder.applicationContext(context).build()
The resulting HttpHandler
is ready for use with a server adapter.
1.3.1. Special Bean Types
The DispatcherHandler
delegates to special beans to process requests and render the
appropriate responses. By “special beans,” we mean Spring-managed Object
instances that
implement WebFlux framework contracts. Those usually come with built-in contracts, but
you can customize their properties, extend them, or replace them.
The following table lists the special beans detected by the DispatcherHandler
. Note that
there are also some other beans detected at a lower level (see
Special bean types in the Web Handler API).
Bean type | Explanation |
Map a request to a handler. The mapping is based on some criteria, the details of
which vary by The main |
Help the |
Process the result from the handler invocation and finalize the response. See Result Handling. |
1.3.2. WebFlux Config
Applications can declare the infrastructure beans (listed under
Web Handler API and
DispatcherHandler
) that are required to process requests.
However, in most cases, the WebFlux Config is the best starting point. It declares the
required beans and provides a higher-level configuration callback API to customize it.
Spring Boot relies on the WebFlux config to configure Spring WebFlux and also provides many extra convenient options. |
1.3.3. Processing
DispatcherHandler
processes requests as follows:
Each
HandlerMapping
is asked to find a matching handler, and the first match is used. -
If a handler is found, it is run through an appropriate
HandlerAdapter
, which exposes the return value from the execution asHandlerResult
The
HandlerResult
is given to an appropriateHandlerResultHandler
to complete processing by writing to the response directly or by using a view to render.
1.3.4. Result Handling
The return value from the invocation of a handler, through a HandlerAdapter
, is wrapped
as a HandlerResult
, along with some additional context, and passed to the first
that claims support for it. The following table shows the available
implementations, all of which are declared in the WebFlux Config:
Result Handler Type | Return Values | Default Order |
0 |
0 |
Handle return values from |
100 |
See also View Resolution. |
1.3.5. Exceptions
The HandlerResult
returned from a HandlerAdapter
can expose a function for error
handling based on some handler-specific mechanism. This error function is called if:
The handler (for example,
@Controller
) invocation fails. -
The handling of the handler return value through a
fails.
The error function can change the response (for example, to an error status), as long as an error signal occurs before the reactive type returned from the handler produces any data items.
This is how @ExceptionHandler
methods in @Controller
classes are supported.
By contrast, support for the same in Spring MVC is built on a HandlerExceptionResolver
This generally should not matter. However, keep in mind that, in WebFlux, you cannot use a
@ControllerAdvice
to handle exceptions that occur before a handler is chosen.
See also Managing Exceptions in the “Annotated Controller” section or Exceptions in the WebHandler API section.
1.3.6. View Resolution
View resolution enables rendering to a browser with an HTML template and a model without
tying you to a specific view technology. In Spring WebFlux, view resolution is
supported through a dedicated HandlerResultHandler that uses
ViewResolver
instances to map a String (representing a logical view name) to a View
instance. The View
is then used to render the response.
Handling
The HandlerResult
passed into ViewResolutionResultHandler
contains the return value
from the handler and the model that contains attributes added during request
handling. The return value is processed as one of the following:
String
,CharSequence
: A logical view name to be resolved to aView
through the list of configuredViewResolver
implementations. -
void
: Select a default view name based on the request path, minus the leading and trailing slash, and resolve it to aView
. The same also happens when a view name was not provided (for example, model attribute was returned) or an async return value (for example,Mono
completed empty). -
Rendering: API for view resolution scenarios. Explore the options in your IDE with code completion.
Model
,Map
: Extra model attributes to be added to the model for the request. -
Any other: Any other return value (except for simple types, as determined by BeanUtils#isSimpleProperty) is treated as a model attribute to be added to the model. The attribute name is derived from the class name by using conventions, unless a handler method
@ModelAttribute
annotation is present.
The model can contain asynchronous, reactive types (for example, from Reactor or RxJava). Prior
to rendering, AbstractView
resolves such model attributes into concrete values
and updates the model. Single-value reactive types are resolved to a single
value or no value (if empty), while multi-value reactive types (for example, Flux<T>
) are
collected and resolved to List<T>
To configure view resolution is as simple as adding a ViewResolutionResultHandler
bean
to your Spring configuration. WebFlux Config provides a
dedicated configuration API for view resolution.
See View Technologies for more on the view technologies integrated with Spring WebFlux.
Redirecting
The special redirect:
prefix in a view name lets you perform a redirect. The
UrlBasedViewResolver
(and sub-classes) recognize this as an instruction that a
redirect is needed. The rest of the view name is the redirect URL.
The net effect is the same as if the controller had returned a RedirectView
or
Rendering.redirectTo("abc").build()
, but now the controller itself can
operate in terms of logical view names. A view name such as
redirect:/some/resource
is relative to the current application, while a view name such as
redirect:https://example.com/arbitrary/path
redirects to an absolute URL.
Content Negotiation
supports content negotiation. It compares the request
media types with the media types supported by each selected View
. The first View
that supports the requested media type(s) is used.
In order to support media types such as JSON and XML, Spring WebFlux provides
HttpMessageWriterView
, which is a special View
that renders through an
HttpMessageWriter. Typically, you would configure these as default
views through the WebFlux Configuration. Default views are
always selected and used if they match the requested media type.
1.4. Annotated Controllers
Spring WebFlux provides an annotation-based programming model, where @Controller
and
@RestController
components use annotations to express request mappings, request input,
handle exceptions, and more. Annotated controllers have flexible method signatures and
do not have to extend base classes nor implement specific interfaces.
The following listing shows a basic example:
@RestController
public class HelloController {
@GetMapping("/hello")
public String handle() {
return "Hello WebFlux";
@RestController
fun handle() = "Hello WebFlux"
In the preceding example, the method returns a String
to be written to the response body.
1.4.1. @Controller
You can define controller beans by using a standard Spring bean definition.
The @Controller
stereotype allows for auto-detection and is aligned with Spring general support
for detecting @Component
classes in the classpath and auto-registering bean definitions
for them. It also acts as a stereotype for the annotated class, indicating its role as
a web component.
To enable auto-detection of such @Controller
beans, you can add component scanning to
your Java configuration, as the following example shows:
@ComponentScan("org.example.web") (1)
public class WebConfig {
1 | Scan the org.example.web package. |
class WebConfig {
@RestController
is a composed annotation that is
itself meta-annotated with @Controller
and @ResponseBody
, indicating a controller whose
every method inherits the type-level @ResponseBody
annotation and, therefore, writes
directly to the response body versus view resolution and rendering with an HTML template.
1.4.2. Request Mapping
The @RequestMapping
annotation is used to map requests to controllers methods. It has
various attributes to match by URL, HTTP method, request parameters, headers, and media
types. You can use it at the class level to express shared mappings or at the method level
to narrow down to a specific endpoint mapping.
There are also HTTP method specific shortcut variants of @RequestMapping
@GetMapping
@PostMapping
@PutMapping
@DeleteMapping
@PatchMapping
The preceding annotations are Custom Annotations that are provided
because, arguably, most controller methods should be mapped to a specific HTTP method versus
using @RequestMapping
, which, by default, matches to all HTTP methods. At the same time, a
@RequestMapping
is still needed at the class level to express shared mappings.
The following example uses type and method level mappings:
@RestController
@RequestMapping("/persons")
class PersonController {
@GetMapping("/{id}")
public Person getPerson(@PathVariable Long id) {
@PostMapping
@ResponseStatus(HttpStatus.CREATED)
public void add(@RequestBody Person person) {
@RestController
fun getPerson(@PathVariable id: Long): Person {
@PostMapping
fun add(@RequestBody person: Person) {
URI Patterns
You can map requests by using glob patterns and wildcards:
Pattern | Description | Example |
Matches one character |
Matches zero or more characters within a path segment |
Matches zero or more path segments until the end of the path |
Matches a path segment and captures it as a variable named "name" |
Matches the regexp |
Matches zero or more path segments until the end of the path and captures it as a variable named "path" |
Captured URI variables can be accessed with @PathVariable
@GetMapping("/owners/{ownerId}/pets/{petId}")
public Pet findPet(@PathVariable Long ownerId, @PathVariable Long petId) {
fun findPet(@PathVariable ownerId: Long, @PathVariable petId: Long): Pet {
You can declare URI variables at the class and method levels, as the following example shows:
@Controller
@RequestMapping("/owners/{ownerId}") (1)
public class OwnerController {
@GetMapping("/pets/{petId}") (2)
1 | Class-level URI mapping. |
2 | Method-level URI mapping. |
@Controller
URI variables are automatically converted to the appropriate type or a TypeMismatchException
is raised. Simple types (int
, long
, Date
, and so on) are supported by default and you can
register support for any other data type.
See Type Conversion and DataBinder
URI variables can be named explicitly (for example, @PathVariable("customId")
), but you can
leave that detail out if the names are the same and you compile your code with debugging
information or with the -parameters
compiler flag on Java 8.
The syntax {*varName}
declares a URI variable that matches zero or more remaining path
segments. For example /resources/{*path}
matches all files under /resources/
, and the
"path"
variable captures the complete path under /resources
The syntax {varName:regex}
declares a URI variable with a regular expression that has the
syntax: {varName:regex}
. For example, given a URL of /spring-web-3.0.5.jar
, the following method
extracts the name, version, and file extension:
@GetMapping("/{name:[a-z-]+}-{version:\\d\\.\\d\\.\\d}{ext:\\.[a-z]+}")
public void handle(@PathVariable String version, @PathVariable String ext) {
fun handle(@PathVariable version: String, @PathVariable ext: String) {
URI path patterns can also have embedded ${…}
placeholders that are resolved on startup
through PropertySourcesPlaceholderConfigurer
against local, system, environment, and
other property sources. You can use this to, for example, parameterize a base URL based on
some external configuration.
Spring WebFlux uses PathPattern and the PathPatternParser for URI path matching support.
Both classes are located in spring-web and are expressly designed for use with HTTP URL
paths in web applications where a large number of URI path patterns are matched at runtime.
Spring WebFlux does not support suffix pattern matching — unlike Spring MVC, where a
mapping such as /person
also matches to /person.*
. For URL-based content
negotiation, if needed, we recommend using a query parameter, which is simpler, more
explicit, and less vulnerable to URL path based exploits.
Pattern Comparison
When multiple patterns match a URL, they must be compared to find the best match. This is done
with PathPattern.SPECIFICITY_COMPARATOR
, which looks for patterns that are more specific.
For every pattern, a score is computed, based on the number of URI variables and wildcards, where a URI variable scores lower than a wildcard. A pattern with a lower total score wins. If two patterns have the same score, the longer is chosen.
Catch-all patterns (for example, **
, {*varName}
) are excluded from the scoring and are always
sorted last instead. If two patterns are both catch-all, the longer is chosen.
Consumable Media Types
You can narrow the request mapping based on the Content-Type
of the request,
@PostMapping(path = "/pets", consumes = "application/json")
public void addPet(@RequestBody Pet pet) {
@PostMapping("/pets", consumes = ["application/json"])
fun addPet(@RequestBody pet: Pet) {
The consumes attribute also supports negation expressions — for example, !text/plain
means any
content type other than text/plain
You can declare a shared consumes
attribute at the class level. Unlike most other request
mapping attributes, however, when used at the class level, a method-level consumes
attribute
overrides rather than extends the class-level declaration.
MediaType provides constants for commonly used media types — for example,
APPLICATION_JSON_VALUE and APPLICATION_XML_VALUE .
Producible Media Types
You can narrow the request mapping based on the Accept
request header and the list of
content types that a controller method produces, as the following example shows:
@GetMapping(path = "/pets/{petId}", produces = "application/json")
@ResponseBody
public Pet getPet(@PathVariable String petId) {
@GetMapping("/pets/{petId}", produces = ["application/json"])
@ResponseBody
fun getPet(@PathVariable petId: String): Pet {
The media type can specify a character set. Negated expressions are supported — for example,
!text/plain
means any content type other than text/plain
You can declare a shared produces
mapping attributes, however, when used at the class level, a method-level produces
attribute
overrides rather than extend the class level declaration.
MediaType provides constants for commonly used media types — e.g.
APPLICATION_JSON_VALUE , APPLICATION_XML_VALUE .
Parameters and Headers
You can narrow request mappings based on query parameter conditions. You can test for the
presence of a query parameter (myParam
), for its absence (!myParam
), or for a
specific value (myParam=myValue
). The following examples tests for a parameter with a value:
@GetMapping(path = "/pets/{petId}", params = "myParam=myValue") (1)
public void findPet(@PathVariable String petId) {
1 | Check that myParam equals myValue . |
@GetMapping("/pets/{petId}", params = ["myParam=myValue"]) (1)
fun findPet(@PathVariable petId: String) {
You can also use the same with request header conditions, as the following example shows:
@GetMapping(path = "/pets/{petId}", headers = "myHeader=myValue") (1)
1 | Check that myHeader equals myValue . |
@GetMapping("/pets/{petId}", headers = ["myHeader=myValue"]) (1)
HTTP HEAD, OPTIONS
@GetMapping
and @RequestMapping(method=HttpMethod.GET)
support HTTP HEAD
transparently for request mapping purposes. Controller methods need not change.
A response wrapper, applied in the HttpHandler
server adapter, ensures a Content-Length
header is set to the number of bytes written without actually writing to the response.
By default, HTTP OPTIONS is handled by setting the Allow
response header to the list of HTTP
methods listed in all @RequestMapping
methods with matching URL patterns.
For a @RequestMapping
without HTTP method declarations, the Allow
header is set to
GET,HEAD,POST,PUT,PATCH,DELETE,OPTIONS
. Controller methods should always declare the
supported HTTP methods (for example, by using the HTTP method specific variants — @GetMapping
, @PostMapping
, and others).
You can explicitly map a @RequestMapping
method to HTTP HEAD and HTTP OPTIONS, but that
is not necessary in the common case.
Custom Annotations
Spring WebFlux supports the use of composed annotations
for request mapping. Those are annotations that are themselves meta-annotated with
@RequestMapping
and composed to redeclare a subset (or all) of the @RequestMapping
attributes with a narrower, more specific purpose.
@GetMapping
, @PostMapping
, @PutMapping
, @DeleteMapping
, and @PatchMapping
are
examples of composed annotations. They are provided, because, arguably, most
controller methods should be mapped to a specific HTTP method versus using @RequestMapping
which, by default, matches to all HTTP methods. If you need an example of composed
annotations, look at how those are declared.
Spring WebFlux also supports custom request mapping attributes with custom request matching
logic. This is a more advanced option that requires sub-classing
RequestMappingHandlerMapping
and overriding the getCustomMethodCondition
method, where
you can check the custom attribute and return your own RequestCondition
Explicit Registrations
You can programmatically register Handler methods, which can be used for dynamic registrations or for advanced cases, such as different instances of the same handler under different URLs. The following example shows how to do so:
public class MyConfig {
@Autowired
public void setHandlerMapping(RequestMappingHandlerMapping mapping, UserHandler handler) (1)
throws NoSuchMethodException {
RequestMappingInfo info = RequestMappingInfo
.paths("/user/{id}").methods(RequestMethod.GET).build(); (2)
Method method = UserHandler.class.getMethod("getUser", Long.class); (3)
mapping.registerMapping(info, handler, method); (4)
1 | Inject target handlers and the handler mapping for controllers. |
2 | Prepare the request mapping metadata. |
3 | Get the handler method. |
4 | Add the registration. |
class MyConfig {
@Autowired
fun setHandlerMapping(mapping: RequestMappingHandlerMapping, handler: UserHandler) { (1)
val info = RequestMappingInfo.paths("/user/{id}").methods(RequestMethod.GET).build() (2)
val method = UserHandler::class.java.getMethod("getUser", Long::class.java) (3)
mapping.registerMapping(info, handler, method) (4)
1.4.3. Handler Methods
@RequestMapping
handler methods have a flexible signature and can choose from a range of
supported controller method arguments and return values.
Method Arguments
The following table shows the supported controller method arguments.
Reactive types (Reactor, RxJava, or other) are supported on arguments that require blocking I/O (for example, reading the request body) to be resolved. This is marked in the Description column. Reactive types are not expected on arguments that do not require blocking.
JDK 1.8’s java.util.Optional
is supported as a method argument in combination with
annotations that have a required
attribute (for example, @RequestParam
, @RequestHeader
and others) and is equivalent to required=false
Controller method argument | Description |
Access to the full |
Access to the HTTP request or response. |
Access to the session. This does not force the start of a new session unless attributes are added. Supports reactive types. |
The currently authenticated user — possibly a specific |
The HTTP method of the request. |
The current request locale, determined by the most specific |
The time zone associated with the current request, as determined by a |
For access to URI template variables. See URI Patterns. |
For access to name-value pairs in URI path segments. See Matrix Variables. |
For access to query parameters. Parameter values are converted to the declared method argument
type. See Note that use of |
For access to request headers. Header values are converted to the declared method argument
type. See |
For access to cookies. Cookie values are converted to the declared method argument type.
See |
For access to the HTTP request body. Body content is converted to the declared method
argument type by using |
For access to request headers and body. The body is converted with |
For access to a part in a |
For access to the model that is used in HTML controllers and is exposed to templates as part of view rendering. |
For access to an existing attribute in the model (instantiated if not present) with
data binding and validation applied. See Note that use of |
For access to errors from validation and data binding for a command object, i.e. a
For marking form processing complete, which triggers cleanup of session attributes
declared through a class-level |
For preparing a URL relative to the current request’s host, port, scheme, and context path. See URI Links. |
For access to any session attribute — in contrast to model attributes stored in the session
as a result of a class-level |
For access to request attributes. See |
Any other argument |
If a method argument is not matched to any of the above, it is, by default, resolved as
a |
Return Values
The following table shows the supported controller method return values. Note that reactive types from libraries such as Reactor, RxJava, or other are generally supported for all return values.
Controller method return value | Description |
The return value is encoded through |
The return value specifies the full response, including HTTP headers, and the body is encoded
through |
For returning a response with headers and no body. |
A view name to be resolved with |
A |
Attributes to be added to the implicit model, with the view name implicitly determined based on the request path. |
An attribute to be added to the model, with the view name implicitly determined based on the request path. Note that |
An API for model and view rendering scenarios. |
A method with a If none of the above is true, a |
Emit server-sent events. The |
Other return values |
If a return value remains unresolved in any other way, it is treated as a model attribute, unless it is a simple type as determined by BeanUtils#isSimpleProperty, in which case it remains unresolved. |
Type Conversion
Some annotated controller method arguments that represent String-based request input (for example,
@RequestParam
, @RequestHeader
, @PathVariable
, @MatrixVariable
, and @CookieValue
can require type conversion if the argument is declared as something other than String
For such cases, type conversion is automatically applied based on the configured converters.
By default, simple types (such as int
, long
, Date
, and others) are supported. Type conversion
can be customized through a WebDataBinder
(see DataBinder
) or by registering
Formatters
with the FormattingConversionService
(see Spring Field Formatting).
A practical issue in type conversion is the treatment of an empty String source value.
Such a value is treated as missing if it becomes null
as a result of type conversion.
This can be the case for Long
, UUID
, and other target types. If you want to allow null
to be injected, either use the required
flag on the argument annotation, or declare the
argument as @Nullable
Matrix Variables
RFC 3986 discusses name-value pairs in path segments. In Spring WebFlux, we refer to those as “matrix variables” based on an “old post” by Tim Berners-Lee, but they can be also be referred to as URI path parameters.
Matrix variables can appear in any path segment, with each variable separated by a semicolon and
multiple values separated by commas — for example, "/cars;color=red,green;year=2012"
. Multiple
values can also be specified through repeated variable names — for example,
"color=red;color=green;color=blue"
Unlike Spring MVC, in WebFlux, the presence or absence of matrix variables in a URL does not affect request mappings. In other words, you are not required to use a URI variable to mask variable content. That said, if you want to access matrix variables from a controller method, you need to add a URI variable to the path segment where matrix variables are expected. The following example shows how to do so:
// GET /pets/42;q=11;r=22
public void findPet(@PathVariable String petId, @MatrixVariable int q) {
// petId == 42
// q == 11
fun findPet(@PathVariable petId: String, @MatrixVariable q: Int) {
// petId == 42
// q == 11
Given that all path segments can contain matrix variables, you may sometimes need to disambiguate which path variable the matrix variable is expected to be in, as the following example shows:
// GET /owners/42;q=11/pets/21;q=22
@MatrixVariable(name="q", pathVar="ownerId") int q1,
@MatrixVariable(name="q", pathVar="petId") int q2) {
// q1 == 11
// q2 == 22
fun findPet(
@MatrixVariable(name = "q", pathVar = "ownerId") q1: Int,
@MatrixVariable(name = "q", pathVar = "petId") q2: Int) {
// q1 == 11
// q2 == 22
You can define a matrix variable may be defined as optional and specify a default value as the following example shows:
// GET /pets/42
public void findPet(@MatrixVariable(required=false, defaultValue="1") int q) {
// q == 1
// GET /pets/42
fun findPet(@MatrixVariable(required = false, defaultValue = "1") q: Int) {
// q == 1
To get all matrix variables, use a MultiValueMap
// GET /owners/42;q=11;r=12/pets/21;q=22;s=23
@MatrixVariable MultiValueMap<String, String> matrixVars,
@MatrixVariable(pathVar="petId") MultiValueMap<String, String> petMatrixVars) {
// matrixVars: ["q" : [11,22], "r" : 12, "s" : 23]
// petMatrixVars: ["q" : 22, "s" : 23]
fun findPet(
@MatrixVariable matrixVars: MultiValueMap<String, String>,
@MatrixVariable(pathVar="petId") petMatrixVars: MultiValueMap<String, String>) {
@RequestParam
You can use the @RequestParam
annotation to bind query parameters to a method argument in a
controller. The following code snippet shows the usage:
@Controller
@RequestMapping("/pets")
public class EditPetForm {
@GetMapping
public String setupForm(@RequestParam("petId") int petId, Model model) { (1)
Pet pet = this.clinic.loadPet(petId);
model.addAttribute("pet", pet);
return "petForm";
1 | Using @RequestParam . |
import org.springframework.ui.set
@Controller
class EditPetForm {
@GetMapping
fun setupForm(@RequestParam("petId") petId: Int, model: Model): String { (1)
val pet = clinic.loadPet(petId)
model["pet"] = pet
return "petForm"
The Servlet API “request parameter” concept conflates query parameters, form
data, and multiparts into one. However, in WebFlux, each is accessed individually through
ServerWebExchange . While @RequestParam binds to query parameters only, you can use
data binding to apply query parameters, form data, and multiparts to a
command object.
Method parameters that use the @RequestParam
annotation are required by default, but
you can specify that a method parameter is optional by setting the required flag of a @RequestParam
to false
or by declaring the argument with a java.util.Optional
wrapper.
Type conversion is applied automatically if the target method parameter type is not
String
. See Type Conversion.
When a @RequestParam
annotation is declared on a Map<String, String>
or
argument, the map is populated with all query parameters.
Note that use of @RequestParam
is optional — for example, to set its attributes. By
default, any argument that is a simple value type (as determined by
and is not resolved by any other argument resolver is treated as if it were annotated
with @RequestParam
@RequestHeader
You can use the @RequestHeader
annotation to bind a request header to a method argument in a
controller.
The following example shows a request with headers:
Host localhost:8080 Accept text/html,application/xhtml+xml,application/xml;q=0.9 Accept-Language fr,en-gb;q=0.7,en;q=0.3 Accept-Encoding gzip,deflate Accept-Charset ISO-8859-1,utf-8;q=0.7,*;q=0.7 Keep-Alive 300
The following example gets the value of the Accept-Encoding
and Keep-Alive
headers:
@GetMapping("/demo")
public void handle(
@RequestHeader("Accept-Encoding") String encoding, (1)
@RequestHeader("Keep-Alive") long keepAlive) { (2)
1 | Get the value of the Accept-Encoding header. |
2 | Get the value of the Keep-Alive header. |
fun handle(
@RequestHeader("Accept-Encoding") encoding: String, (1)
@RequestHeader("Keep-Alive") keepAlive: Long) { (2)
String
When a @RequestHeader
annotation is used on a Map<String, String>
, or HttpHeaders
with all header values.
Built-in support is available for converting a comma-separated string into an
array or collection of strings or other types known to the type conversion system. For
example, a method parameter annotated with @RequestHeader("Accept") may be of type
String but also of String[] or List<String> .
@CookieValue
You can use the @CookieValue
annotation to bind the value of an HTTP cookie to a method argument
in a controller.
The following example shows a request with a cookie:
JSESSIONID=415A4AC178C59DACE0B2C9CA727CDD84
The following code sample demonstrates how to get the cookie value:
public void handle(@CookieValue("JSESSIONID") String cookie) { (1)
1 | Get the cookie value. |
fun handle(@CookieValue("JSESSIONID") cookie: String) { (1)
String
@ModelAttribute
You can use the @ModelAttribute
annotation on a method argument to access an attribute from the
model or have it instantiated if not present. The model attribute is also overlaid with
the values of query parameters and form fields whose names match to field names. This is
referred to as data binding, and it saves you from having to deal with parsing and
converting individual query parameters and form fields. The following example binds an instance of Pet
@PostMapping("/owners/{ownerId}/pets/{petId}/edit")
public String processSubmit(@ModelAttribute Pet pet) { } (1)
1 | Bind an instance of Pet . |
fun processSubmit(@ModelAttribute pet: Pet): String { } (1)
The Pet
instance in the preceding example is resolved as follows:
From the model if already added through
Model
From the HTTP session through
@SessionAttributes
From the invocation of a default constructor.
From the invocation of a “primary constructor” with arguments that match query parameters or form fields. Argument names are determined through JavaBeans
@ConstructorProperties
or through runtime-retained parameter names in the bytecode.
After the model attribute instance is obtained, data binding is applied. The
WebExchangeDataBinder
class matches names of query parameters and form fields to field
names on the target Object
. Matching fields are populated after type conversion is applied
where necessary. For more on data binding (and validation), see
Validation. For more on customizing data binding, see
DataBinder
Data binding can result in errors. By default, a WebExchangeBindException
is raised, but,
to check for such errors in the controller method, you can add a BindingResult
argument
immediately next to the @ModelAttribute
public String processSubmit(@ModelAttribute("pet") Pet pet, BindingResult result) { (1)
if (result.hasErrors()) {
return "petForm";
1 | Adding a BindingResult . |
fun processSubmit(@ModelAttribute("pet") pet: Pet, result: BindingResult): String { (1)
return "petForm"
You can automatically apply validation after data binding by adding the
javax.validation.Valid
annotation or Spring’s @Validated
annotation (see also
Bean Validation and
Spring validation). The following example uses the @Valid
annotation:
public String processSubmit(@Valid @ModelAttribute("pet") Pet pet, BindingResult result) { (1)
return "petForm";
1 | Using @Valid on a model attribute argument. |
fun processSubmit(@Valid @ModelAttribute("pet") pet: Pet, result: BindingResult): String { (1)
return "petForm"
Spring WebFlux, unlike Spring MVC, supports reactive types in the model — for example,
Mono<Account>
or io.reactivex.Single<Account>
. You can declare a @ModelAttribute
argument
with or without a reactive type wrapper, and it will be resolved accordingly,
to the actual value if necessary. However, note that, to use a BindingResult
argument, you must declare the @ModelAttribute
argument before it without a reactive
type wrapper, as shown earlier. Alternatively, you can handle any errors through the
reactive type, as the following example shows:
public Mono<String> processSubmit(@Valid @ModelAttribute("pet") Mono<Pet> petMono) {
return petMono
.flatMap(pet -> {
.onErrorResume(ex -> {
fun processSubmit(@Valid @ModelAttribute("pet") petMono: Mono<Pet>): Mono<String> {
return petMono
.flatMap { pet ->
.onErrorResume{ ex ->
Note that use of @ModelAttribute
By default, any argument that is not a simple value type (as determined by
with @ModelAttribute
@SessionAttributes
@SessionAttributes
is used to store model attributes in the WebSession
between
requests. It is a type-level annotation that declares session attributes used by a
specific controller. This typically lists the names of model attributes or types of
model attributes that should be transparently stored in the session for subsequent
requests to access.
Consider the following example:
@Controller
@SessionAttributes("pet") (1)
1 | Using the @SessionAttributes annotation. |
@Controller
class EditPetForm {
On the first request, when a model attribute with the name, pet
, is added to the model,
it is automatically promoted to and saved in the WebSession
. It remains there until
another controller method uses a SessionStatus
method argument to clear the storage,
@Controller
@PostMapping("/pets/{id}")
public String handle(Pet pet, BindingResult errors, SessionStatus status) { (2)
if (errors.hasErrors()) {
status.setComplete();
2 | Using a SessionStatus variable. |
@Controller
class EditPetForm {
fun handle(pet: Pet, errors: BindingResult, status: SessionStatus): String { (2)
@SessionAttribute
If you need access to pre-existing session attributes that are managed globally
(that is, outside the controller — for example, by a filter) and may or may not be present,
you can use the @SessionAttribute
annotation on a method parameter, as the following example shows:
@GetMapping("/")
public String handle(@SessionAttribute User user) { (1)
1 | Using @SessionAttribute . |
@GetMapping("/")
fun handle(@SessionAttribute user: User): String { (1)
For use cases that require adding or removing session attributes, consider injecting
WebSession
into the controller method.
For temporary storage of model attributes in the session as part of a controller
workflow, consider using SessionAttributes
, as described in
@SessionAttributes
@RequestAttribute
Similarly to @SessionAttribute
, you can use the @RequestAttribute
annotation to
access pre-existing request attributes created earlier (for example, by a WebFilter
@GetMapping("/")
public String handle(@RequestAttribute Client client) { (1)
1 | Using @RequestAttribute . |
@GetMapping("/")
fun handle(@RequestAttribute client: Client): String { (1)
Multipart Content
As explained in Multipart Data, ServerWebExchange
provides access to multipart
content. The best way to handle a file upload form (for example, from a browser) in a controller
is through data binding to a command object,
class MyForm {
private String name;
private MultipartFile file;
@Controller
public class FileUploadController {
@PostMapping("/form")
public String handleFormUpload(MyForm form, BindingResult errors) {
class MyForm(
val name: String,
val file: MultipartFile)
@Controller
fun handleFormUpload(form: MyForm, errors: BindingResult): String {
You can also submit multipart requests from non-browser clients in a RESTful service scenario. The following example uses a file along with JSON:
POST /someUrl Content-Type: multipart/mixed --edt7Tfrdusa7r3lNQc79vXuhIIMlatb7PQg7Vp Content-Disposition: form-data; name="meta-data" Content-Type: application/json; charset=UTF-8 Content-Transfer-Encoding: 8bit { "name": "value" } --edt7Tfrdusa7r3lNQc79vXuhIIMlatb7PQg7Vp Content-Disposition: form-data; name="file-data"; filename="file.properties" Content-Type: text/xml Content-Transfer-Encoding: 8bit ... File Data ...
You can access individual parts with @RequestPart
@PostMapping("/")
public String handle(@RequestPart("meta-data") Part metadata, (1)
@RequestPart("file-data") FilePart file) { (2)
1 | Using @RequestPart to get the metadata. |
2 | Using @RequestPart to get the file. |
@PostMapping("/")
fun handle(@RequestPart("meta-data") Part metadata, (1)
@RequestPart("file-data") FilePart file): String { (2)
To deserialize the raw part content (for example, to JSON — similar to @RequestBody
you can declare a concrete target Object
, instead of Part
@PostMapping("/")
public String handle(@RequestPart("meta-data") MetaData metadata) { (1)
@PostMapping("/")
fun handle(@RequestPart("meta-data") metadata: MetaData): String { (1)
You can use @RequestPart
in combination with javax.validation.Valid
or Spring’s
@Validated
annotation, which causes Standard Bean Validation to be applied. Validation
errors lead to a WebExchangeBindException
that results in a 400 (BAD_REQUEST) response.
The exception contains a BindingResult
with the error details and can also be handled
in the controller method by declaring the argument with an async wrapper and then using
error related operators:
@PostMapping("/")
public String handle(@Valid @RequestPart("meta-data") Mono<MetaData> metadata) {
// use one of the onError* operators...
@PostMapping("/")
fun handle(@Valid @RequestPart("meta-data") metadata: MetaData): String {
To access all multipart data as a MultiValueMap
@PostMapping("/")
public String handle(@RequestBody Mono<MultiValueMap<String, Part>> parts) { (1)
1 | Using @RequestBody . |
@PostMapping("/")
fun handle(@RequestBody parts: MultiValueMap<String, Part>): String { (1)
To access multipart data sequentially, in streaming fashion, you can use @RequestBody
with
Flux<Part>
(or Flow<Part>
in Kotlin) instead, as the following example shows:
@PostMapping("/")
public String handle(@RequestBody Flux<Part> parts) { (1)
@PostMapping("/")
fun handle(@RequestBody parts: Flow<Part>): String { (1)
@RequestBody
You can use the @RequestBody
annotation to have the request body read and deserialized into an
Object
through an HttpMessageReader.
The following example uses a @RequestBody
argument:
@PostMapping("/accounts")
public void handle(@RequestBody Account account) {
fun handle(@RequestBody account: Account) {
Unlike Spring MVC, in WebFlux, the @RequestBody
method argument supports reactive types
and fully non-blocking reading and (client-to-server) streaming.
public void handle(@RequestBody Mono<Account> account) {
fun handle(@RequestBody accounts: Flow<Account>) {
You can use the HTTP message codecs option of the WebFlux Config to configure or customize message readers.
You can use @RequestBody
or Spring’s
@Validated
errors cause a WebExchangeBindException
, which results in a 400 (BAD_REQUEST) response.
with error details and can be handled in the
controller method by declaring the argument with an async wrapper and then using error
related operators:
public void handle(@Valid @RequestBody Mono<Account> account) {
fun handle(@Valid @RequestBody account: Mono<Account>) {
HttpEntity
HttpEntity
is more or less identical to using @RequestBody
but is based on a
container object that exposes request headers and the body. The following example uses an
HttpEntity
public void handle(HttpEntity<Account> entity) {
fun handle(entity: HttpEntity<Account>) {
@ResponseBody
You can use the @ResponseBody
annotation on a method to have the return serialized
to the response body through an HttpMessageWriter. The following
@GetMapping("/accounts/{id}")
@ResponseBody
public Account handle() {
@ResponseBody
fun handle(): Account {
@ResponseBody
is also supported at the class level, in which case it is inherited by
all controller methods. This is the effect of @RestController
, which is nothing more
than a meta-annotation marked with @Controller
and @ResponseBody
@ResponseBody
supports reactive types, which means you can return Reactor or RxJava
types and have the asynchronous values they produce rendered to the response.
For additional details, see Streaming and
JSON rendering.
You can combine @ResponseBody
methods with JSON serialization views.
See Jackson JSON for details.
You can use the HTTP message codecs option of the WebFlux Config to configure or customize message writing.
ResponseEntity
ResponseEntity
is like @ResponseBody
but with status and headers. For example:
@GetMapping("/something")
public ResponseEntity<String> handle() {
String body = ... ;
String etag = ... ;
return ResponseEntity.ok().eTag(etag).body(body);
fun handle(): ResponseEntity<String> {
val body: String = ...
val etag: String = ...
return ResponseEntity.ok().eTag(etag).build(body)
WebFlux supports using a single value reactive type to
produce the ResponseEntity
asynchronously, and/or single and multi-value reactive types
for the body. This allows a variety of async responses with ResponseEntity
as follows:
ResponseEntity<Mono<T>>
orResponseEntity<Flux<T>>
make the response status and headers known immediately while the body is provided asynchronously at a later point. UseMono
if the body consists of 0..1 values orFlux
if it can produce multiple values. -
Mono<ResponseEntity<T>>
provides all three — response status, headers, and body, asynchronously at a later point. This allows the response status and headers to vary depending on the outcome of asynchronous request handling. -
Mono<ResponseEntity<Mono<T>>>
orMono<ResponseEntity<Flux<T>>>
are yet another possible, albeit less common alternative. They provide the response status and headers asynchronously first and then the response body, also asynchronously, second.
Jackson JSON
Spring offers support for the Jackson JSON library.
JSON Views
Spring WebFlux provides built-in support for
Jackson’s Serialization Views,
which allows rendering only a subset of all fields in an Object
. To use it with
@ResponseBody
or ResponseEntity
controller methods, you can use Jackson’s
@JsonView
annotation to activate a serialization view class, as the following example shows:
@RestController
public class UserController {
@GetMapping("/user")
@JsonView(User.WithoutPasswordView.class)
public User getUser() {
return new User("eric", "7!jd#h23");
public class User {
public interface WithoutPasswordView {};
public interface WithPasswordView extends WithoutPasswordView {};
private String username;
private String password;
public User() {
public User(String username, String password) {
this.username = username;
this.password = password;
@JsonView(WithoutPasswordView.class)
public String getUsername() {
return this.username;
@JsonView(WithPasswordView.class)
public String getPassword() {
return this.password;
@RestController
@JsonView(User.WithoutPasswordView::class)
fun getUser(): User {
return User("eric", "7!jd#h23")
class User(
@JsonView(WithoutPasswordView::class) val username: String,
@JsonView(WithPasswordView::class) val password: String
interface WithPasswordView : WithoutPasswordView
@JsonView allows an array of view classes but you can only specify only one per
controller method. Use a composite interface if you need to activate multiple views.
1.4.4. Model
annotation:
On a method argument in
@RequestMapping
methods to create or access an Object from the model and to bind it to the request through aWebDataBinder
As a method-level annotation in
@Controller
or@ControllerAdvice
classes, helping to initialize the model prior to any@RequestMapping
method invocation. -
On a
@RequestMapping
method to mark its return value as a model attribute.
This section discusses @ModelAttribute
methods, or the second item from the preceding list.
A controller can have any number of @ModelAttribute
methods. All such methods are
invoked before @RequestMapping
methods in the same controller. A @ModelAttribute
method can also be shared across controllers through @ControllerAdvice
Controller Advice for more details.
@ModelAttribute
methods have flexible method signatures. They support many of the same
arguments as @RequestMapping
methods (except for @ModelAttribute
itself and anything
related to the request body).
The following example uses a @ModelAttribute
method:
@ModelAttribute
public void populateModel(@RequestParam String number, Model model) {
model.addAttribute(accountRepository.findAccount(number));
// add more ...
@ModelAttribute
fun populateModel(@RequestParam number: String, model: Model) {
// add more ...
The following example adds one attribute only:
@ModelAttribute
public Account addAccount(@RequestParam String number) {
return accountRepository.findAccount(number);
@ModelAttribute
fun addAccount(@RequestParam number: String): Account {
When a name is not explicitly specified, a default name is chosen based on the type,
as explained in the javadoc for Conventions .
You can always assign an explicit name by using the overloaded addAttribute method or
through the name attribute on @ModelAttribute (for a return value).
Spring WebFlux, unlike Spring MVC, explicitly supports reactive types in the model
(for example, Mono<Account>
). Such asynchronous model
attributes can be transparently resolved (and the model updated) to their actual values
at the time of @RequestMapping
invocation, provided a @ModelAttribute
argument is
declared without a wrapper, as the following example shows:
@ModelAttribute
public void addAccount(@RequestParam String number) {
Mono<Account> accountMono = accountRepository.findAccount(number);
model.addAttribute("account", accountMono);
public String handle(@ModelAttribute Account account, BindingResult errors) {
@ModelAttribute
fun addAccount(@RequestParam number: String) {
val accountMono: Mono<Account> = accountRepository.findAccount(number)
model["account"] = accountMono
fun handle(@ModelAttribute account: Account, errors: BindingResult): String {
In addition, any model attributes that have a reactive type wrapper are resolved to their actual values (and the model updated) just prior to view rendering.
You can also use @ModelAttribute
as a method-level annotation on @RequestMapping
methods, in which case the return value of the @RequestMapping
method is interpreted as a
model attribute. This is typically not required, as it is the default behavior in HTML
controllers, unless the return value is a String
that would otherwise be interpreted
as a view name. @ModelAttribute
can also help to customize the model attribute name,
@ModelAttribute("myAccount")
return account;
return account
1.4.5. DataBinder
@Controller
or @ControllerAdvice
classes can have @InitBinder
methods, to
initialize instances of WebDataBinder
. Those, in turn, are used to:
Bind request parameters (that is, form data or query) to a model object.
Convert
String
-based request values (such as request parameters, path variables, headers, cookies, and others) to the target type of controller method arguments. -
Format model object values as
String
values when rendering HTML forms.
@InitBinder
methods can register controller-specific java.beans.PropertyEditor
or
Spring Converter
and Formatter
components. In addition, you can use the
WebFlux Java configuration to register Converter
and
Formatter
types in a globally shared FormattingConversionService
@InitBinder
methods support many of the same arguments that @RequestMapping
methods
do, except for @ModelAttribute
(command object) arguments. Typically, they are declared
with a WebDataBinder
argument, for registrations, and a void
return value.
The following example uses the @InitBinder
annotation:
@Controller
public class FormController {
@InitBinder (1)
public void initBinder(WebDataBinder binder) {
SimpleDateFormat dateFormat = new SimpleDateFormat("yyyy-MM-dd");
dateFormat.setLenient(false);
binder.registerCustomEditor(Date.class, new CustomDateEditor(dateFormat, false));
1 | Using the @InitBinder annotation. |
@Controller
@InitBinder (1)
fun initBinder(binder: WebDataBinder) {
val dateFormat = SimpleDateFormat("yyyy-MM-dd")
dateFormat.isLenient = false
binder.registerCustomEditor(Date::class.java, CustomDateEditor(dateFormat, false))
Alternatively, when using a Formatter
-based setup through a shared
, you could re-use the same approach and register
controller-specific Formatter
instances, as the following example shows:
@Controller
@InitBinder
protected void initBinder(WebDataBinder binder) {
binder.addCustomFormatter(new DateFormatter("yyyy-MM-dd")); (1)
1 | Adding a custom formatter (a DateFormatter , in this case). |
@Controller
@InitBinder
binder.addCustomFormatter(DateFormatter("yyyy-MM-dd")) (1)
Model Design
In the context of web applications, data binding involves the binding of HTTP request parameters (that is, form data or query parameters) to properties in a model object and its nested objects.
Only public
properties following the
JavaBeans naming conventions
are exposed for data binding — for example, public String getFirstName()
and
public void setFirstName(String)
methods for a firstName
property.
The model object, and its nested object graph, is also sometimes referred to as a command object, form-backing object, or POJO (Plain Old Java Object). |
By default, Spring permits binding to all public properties in the model object graph. This means you need to carefully consider what public properties the model has, since a client could target any public property path, even some that are not expected to be targeted for a given use case.
For example, given an HTTP form data endpoint, a malicious client could supply values for properties that exist in the model object graph but are not part of the HTML form presented in the browser. This could lead to data being set on the model object and any of its nested objects, that is not expected to be updated.
The recommended approach is to use a dedicated model object that exposes only
properties that are relevant for the form submission. For example, on a form for changing
a user’s email address, the model object should declare a minimum set of properties such
as in the following ChangeEmailForm
public class ChangeEmailForm {
private String oldEmailAddress;
private String newEmailAddress;
public void setOldEmailAddress(String oldEmailAddress) {
this.oldEmailAddress = oldEmailAddress;
public String getOldEmailAddress() {
return this.oldEmailAddress;
public void setNewEmailAddress(String newEmailAddress) {
this.newEmailAddress = newEmailAddress;
public String getNewEmailAddress() {
return this.newEmailAddress;
If you cannot or do not want to use a dedicated model object for each data
binding use case, you must limit the properties that are allowed for data binding.
Ideally, you can achieve this by registering allowed field patterns via the
setAllowedFields()
method on WebDataBinder
For example, to register allowed field patterns in your application, you can implement an
@InitBinder
method in a @Controller
component as shown below:
@Controller
public class ChangeEmailController {
@InitBinder
binder.setAllowedFields("oldEmailAddress", "newEmailAddress");
// @RequestMapping methods, etc.
In addition to registering allowed patterns, it is also possible to register disallowed
field patterns via the setDisallowedFields()
method in DataBinder
and its subclasses.
Please note, however, that an "allow list" is safer than a "deny list". Consequently,
setAllowedFields()
should be favored over setDisallowedFields()
Note that matching against allowed field patterns is case-sensitive; whereas, matching against disallowed field patterns is case-insensitive. In addition, a field matching a disallowed pattern will not be accepted even if it also happens to match a pattern in the allowed list.
It is extremely important to properly configure allowed and disallowed field patterns when exposing your domain model directly for data binding purposes. Otherwise, it is a big security risk. Furthermore, it is strongly recommended that you do not use types from your domain model such as JPA or Hibernate entities as the model object in data binding scenarios. |
1.4.6. Managing Exceptions
@Controller
and @ControllerAdvice classes can have
@ExceptionHandler
methods to handle exceptions from controller methods. The following
example includes such a handler method:
@Controller
public class SimpleController {
@ExceptionHandler (1)
public ResponseEntity<String> handle(IOException ex) {
1 | Declaring an @ExceptionHandler . |
@Controller
fun handle(ex: IOException): ResponseEntity<String> {
The exception can match against a top-level exception being propagated (that is, a direct
IOException
being thrown) or against the immediate cause within a top-level wrapper
exception (for example, an IOException
wrapped inside an IllegalStateException
For matching exception types, preferably declare the target exception as a method argument,
as shown in the preceding example. Alternatively, the annotation declaration can narrow the
exception types to match. We generally recommend being as specific as possible in the
argument signature and to declare your primary root exception mappings on a
@ControllerAdvice
prioritized with a corresponding order.
See the MVC section for details.
An @ExceptionHandler method in WebFlux supports the same method arguments and
return values as a @RequestMapping method, with the exception of request body-
and @ModelAttribute -related method arguments.
Support for @ExceptionHandler
methods in Spring WebFlux is provided by the
HandlerAdapter
for @RequestMapping
methods. See DispatcherHandler
for more detail.
REST API exceptions
A common requirement for REST services is to include error details in the body of the
response. The Spring Framework does not automatically do so, because the representation
of error details in the response body is application-specific. However, a
@RestController
can use @ExceptionHandler
methods with a ResponseEntity
return
value to set the status and the body of the response. Such methods can also be declared
in @ControllerAdvice
classes to apply them globally.
Note that Spring WebFlux does not have an equivalent for the Spring MVC
ResponseEntityExceptionHandler , because WebFlux raises only ResponseStatusException
(or subclasses thereof), and those do not need to be translated to
an HTTP status code.
1.4.7. Controller Advice
Typically, the @ExceptionHandler
, @InitBinder
, and @ModelAttribute
methods apply
within the @Controller
class (or class hierarchy) in which they are declared. If you
want such methods to apply more globally (across controllers), you can declare them in a
class annotated with @ControllerAdvice
or @RestControllerAdvice
@ControllerAdvice
is annotated with @Component
, which means that such classes can be
registered as Spring beans through component scanning. @RestControllerAdvice
is a composed annotation that is annotated
with both @ControllerAdvice
and @ResponseBody
, which essentially means
@ExceptionHandler
methods are rendered to the response body through message conversion
(versus view resolution or template rendering).
On startup, the infrastructure classes for @RequestMapping
and @ExceptionHandler
methods detect Spring beans annotated with @ControllerAdvice
and then apply their
methods at runtime. Global @ExceptionHandler
methods (from a @ControllerAdvice
) are
applied after local ones (from the @Controller
). By contrast, global @ModelAttribute
and @InitBinder
methods are applied before local ones.
By default, @ControllerAdvice
methods apply to every request (that is, all controllers),
but you can narrow that down to a subset of controllers by using attributes on the
annotation, as the following example shows:
// Target all Controllers annotated with @RestController
@ControllerAdvice(annotations = RestController.class)
public class ExampleAdvice1 {}
// Target all Controllers within specific packages
@ControllerAdvice("org.example.controllers")
public class ExampleAdvice2 {}
// Target all Controllers assignable to specific classes
@ControllerAdvice(assignableTypes = {ControllerInterface.class, AbstractController.class})
public class ExampleAdvice3 {}
@ControllerAdvice(annotations = [RestController::class])
@ControllerAdvice(assignableTypes = [ControllerInterface::class, AbstractController::class])
The selectors in the preceding example are evaluated at runtime and may negatively impact
performance if used extensively. See the
@ControllerAdvice
javadoc for more details.
1.5. Functional Endpoints
Spring WebFlux includes WebFlux.fn, a lightweight functional programming model in which functions are used to route and handle requests and contracts are designed for immutability. It is an alternative to the annotation-based programming model but otherwise runs on the same Reactive Core foundation.
1.5.1. Overview
In WebFlux.fn, an HTTP request is handled with a HandlerFunction
: a function that takes
ServerRequest
and returns a delayed ServerResponse
(i.e. Mono<ServerResponse>
Both the request and the response object have immutable contracts that offer JDK 8-friendly
access to the HTTP request and response.
HandlerFunction
is the equivalent of the body of a @RequestMapping
method in the
annotation-based programming model.
Incoming requests are routed to a handler function with a RouterFunction
: a function that
takes ServerRequest
and returns a delayed HandlerFunction
(i.e. Mono<HandlerFunction>
When the router function matches, a handler function is returned; otherwise an empty Mono.
RouterFunction
is the equivalent of a @RequestMapping
annotation, but with the major
difference that router functions provide not just data, but also behavior.
RouterFunctions.route()
provides a router builder that facilitates the creation of routers,
import static org.springframework.http.MediaType.APPLICATION_JSON;
import static org.springframework.web.reactive.function.server.RequestPredicates.*;
import static org.springframework.web.reactive.function.server.RouterFunctions.route;
PersonRepository repository = ...
PersonHandler handler = new PersonHandler(repository);
RouterFunction<ServerResponse> route = route()
.GET("/person/{id}", accept(APPLICATION_JSON), handler::getPerson)
.GET("/person", accept(APPLICATION_JSON), handler::listPeople)
.POST("/person", handler::createPerson)
public class PersonHandler {
public Mono<ServerResponse> listPeople(ServerRequest request) {
public Mono<ServerResponse> createPerson(ServerRequest request) {
public Mono<ServerResponse> getPerson(ServerRequest request) {
val repository: PersonRepository = ...
val handler = PersonHandler(repository)
val route = coRouter { (1)
accept(APPLICATION_JSON).nest {
GET("/person/{id}", handler::getPerson)
GET("/person", handler::listPeople)
class PersonHandler(private val repository: PersonRepository) {
suspend fun listPeople(request: ServerRequest): ServerResponse {
suspend fun createPerson(request: ServerRequest): ServerResponse {
suspend fun getPerson(request: ServerRequest): ServerResponse {
1 | Create router using Coroutines router DSL, a Reactive alternative is also available via router { } . |
One way to run a RouterFunction
is to turn it into an HttpHandler
and install it
through one of the built-in server adapters:
RouterFunctions.toHttpHandler(RouterFunction)
RouterFunctions.toHttpHandler(RouterFunction, HandlerStrategies)
Most applications can run through the WebFlux Java configuration, see Running a Server.
1.5.2. HandlerFunction
ServerRequest
and ServerResponse
are immutable interfaces that offer JDK 8-friendly
Both request and response provide Reactive Streams back pressure
against the body streams.
The request body is represented with a Reactor Flux
or Mono
The response body is represented with any Reactive Streams Publisher
, including Flux
and Mono
For more on that, see Reactive Libraries.
ServerRequest
ServerRequest
provides access to the HTTP method, URI, headers, and query parameters,
while access to the body is provided through the body
methods.
The following example extracts the request body to a Mono<String>
Mono<String> string = request.bodyToMono(String.class);
val string = request.awaitBody<String>()
The following example extracts the body to a Flux<Person>
(or a Flow<Person>
in Kotlin),
where Person
objects are decoded from some serialized form, such as JSON or XML:
Flux<Person> people = request.bodyToFlux(Person.class);
val people = request.bodyToFlow<Person>()
The preceding examples are shortcuts that use the more general ServerRequest.body(BodyExtractor)
which accepts the BodyExtractor
functional strategy interface. The utility class
BodyExtractors
provides access to a number of instances. For example, the preceding examples can
also be written as follows:
Mono<String> string = request.body(BodyExtractors.toMono(String.class));
Flux<Person> people = request.body(BodyExtractors.toFlux(Person.class));
val string = request.body(BodyExtractors.toMono(String::class.java)).awaitSingle()
val people = request.body(BodyExtractors.toFlux(Person::class.java)).asFlow()
The following example shows how to access form data:
Mono<MultiValueMap<String, String>> map = request.formData();
val map = request.awaitFormData()
The following example shows how to access multipart data as a map:
Mono<MultiValueMap<String, Part>> map = request.multipartData();
val map = request.awaitMultipartData()
The following example shows how to access multiparts, one at a time, in streaming fashion:
Flux<Part> parts = request.body(BodyExtractors.toParts());
val parts = request.body(BodyExtractors.toParts()).asFlow()
ServerResponse
ServerResponse
provides access to the HTTP response and, since it is immutable, you can use
a build
method to create it. You can use the builder to set the response status, to add response
headers, or to provide a body. The following example creates a 200 (OK) response with JSON
content:
Mono<Person> person = ...
ServerResponse.ok().contentType(MediaType.APPLICATION_JSON).body(person, Person.class);
val person: Person = ...
ServerResponse.ok().contentType(MediaType.APPLICATION_JSON).bodyValue(person)
The following example shows how to build a 201 (CREATED) response with a Location
header and no body:
URI location = ...
ServerResponse.created(location).build();
val location: URI = ...
Depending on the codec used, it is possible to pass hint parameters to customize how the body is serialized or deserialized. For example, to specify a Jackson JSON view:
ServerResponse.ok().hint(Jackson2CodecSupport.JSON_VIEW_HINT, MyJacksonView.class).body(...);
ServerResponse.ok().hint(Jackson2CodecSupport.JSON_VIEW_HINT, MyJacksonView::class.java).body(...)
Handler Classes
We can write a handler function as a lambda, as the following example shows:
HandlerFunction<ServerResponse> helloWorld =
request -> ServerResponse.ok().bodyValue("Hello World");
val helloWorld = HandlerFunction<ServerResponse> { ServerResponse.ok().bodyValue("Hello World") }
That is convenient, but in an application we need multiple functions, and multiple inline
lambda’s can get messy.
Therefore, it is useful to group related handler functions together into a handler class, which
has a similar role as @Controller
in an annotation-based application.
For example, the following class exposes a reactive Person
repository:
import static org.springframework.web.reactive.function.server.ServerResponse.ok;
private final PersonRepository repository;
public PersonHandler(PersonRepository repository) {
this.repository = repository;
public Mono<ServerResponse> listPeople(ServerRequest request) { (1)
Flux<Person> people = repository.allPeople();
return ok().contentType(APPLICATION_JSON).body(people, Person.class);
public Mono<ServerResponse> createPerson(ServerRequest request) { (2)
Mono<Person> person = request.bodyToMono(Person.class);
return ok().build(repository.savePerson(person));
public Mono<ServerResponse> getPerson(ServerRequest request) { (3)
int personId = Integer.valueOf(request.pathVariable("id"));
return repository.getPerson(personId)
.flatMap(person -> ok().contentType(APPLICATION_JSON).bodyValue(person))
.switchIfEmpty(ServerResponse.notFound().build());
1 | listPeople is a handler function that returns all Person objects found in the repository as
JSON. |
2 | createPerson is a handler function that stores a new Person contained in the request body.
Note that PersonRepository.savePerson(Person) returns Mono<Void> : an empty Mono that emits
a completion signal when the person has been read from the request and stored. So we use the
build(Publisher<Void>) method to send a response when that completion signal is received (that is,
when the Person has been saved). |
3 | getPerson is a handler function that returns a single person, identified by the id path
variable. We retrieve that Person from the repository and create a JSON response, if it is
found. If it is not found, we use switchIfEmpty(Mono<T>) to return a 404 Not Found response. |
suspend fun listPeople(request: ServerRequest): ServerResponse { (1)
val people: Flow<Person> = repository.allPeople()
return ok().contentType(APPLICATION_JSON).bodyAndAwait(people);
suspend fun createPerson(request: ServerRequest): ServerResponse { (2)
val person = request.awaitBody<Person>()
return ok().buildAndAwait()
suspend fun getPerson(request: ServerRequest): ServerResponse { (3)
val personId = request.pathVariable("id").toInt()
return repository.getPerson(personId)?.let { ok().contentType(APPLICATION_JSON).bodyValueAndAwait(it) }
?: ServerResponse.notFound().buildAndAwait()
JSON. |
Note that PersonRepository.savePerson(Person) is a suspending function with no return type. |
found. If it is not found, we return a 404 Not Found response. |
Validation
A functional endpoint can use Spring’s validation facilities to
apply validation to the request body. For example, given a custom Spring
Validator implementation for a Person
private final Validator validator = new PersonValidator(); (1)
Mono<Person> person = request.bodyToMono(Person.class).doOnNext(this::validate); (2)
private void validate(Person person) {
Errors errors = new BeanPropertyBindingResult(person, "person");
validator.validate(person, errors);
throw new ServerWebInputException(errors.toString()); (3)
1 | Create Validator instance. |
2 | Apply validation. |
3 | Raise exception for a 400 response. |
private val validator = PersonValidator() (1)
validate(person) (2)
private fun validate(person: Person) {
val errors: Errors = BeanPropertyBindingResult(person, "person");
throw ServerWebInputException(errors.toString()) (3)
Handlers can also use the standard bean validation API (JSR-303) by creating and injecting
a global Validator
instance based on LocalValidatorFactoryBean
See Spring Validation.
1.5.3. RouterFunction
Router functions are used to route the requests to the corresponding HandlerFunction
Typically, you do not write router functions yourself, but rather use a method on the
RouterFunctions
utility class to create one.
(no parameters) provides you with a fluent builder for creating a router
function, whereas RouterFunctions.route(RequestPredicate, HandlerFunction)
offers a direct way
to create a router.
Generally, it is recommended to use the route()
builder, as it provides
convenient short-cuts for typical mapping scenarios without requiring hard-to-discover
static imports.
For instance, the router function builder offers the method GET(String, HandlerFunction)
to create a mapping for GET requests; and POST(String, HandlerFunction)
for POSTs.
Besides HTTP method-based mapping, the route builder offers a way to introduce additional
predicates when mapping to requests.
For each HTTP method there is an overloaded variant that takes a RequestPredicate
as a
parameter, though which additional constraints can be expressed.
Predicates
You can write your own RequestPredicate
, but the RequestPredicates
utility class
offers commonly used implementations, based on the request path, HTTP method, content-type,
and so on.
The following example uses a request predicate to create a constraint based on the Accept
header:
RouterFunction<ServerResponse> route = RouterFunctions.route()
.GET("/hello-world", accept(MediaType.TEXT_PLAIN),
request -> ServerResponse.ok().bodyValue("Hello World")).build();
GET("/hello-world", accept(TEXT_PLAIN)) {
ServerResponse.ok().bodyValueAndAwait("Hello World")
You can compose multiple request predicates together by using:
RequestPredicate.and(RequestPredicate)
— both must match. -
RequestPredicate.or(RequestPredicate)
— either can match.
Many of the predicates from RequestPredicates
are composed.
For example, RequestPredicates.GET(String)
is composed from RequestPredicates.method(HttpMethod)
and RequestPredicates.path(String)
The example shown above also uses two request predicates, as the builder uses
internally, and composes that with the accept
predicate.
Routes
Router functions are evaluated in order: if the first route does not match, the second is evaluated, and so on. Therefore, it makes sense to declare more specific routes before general ones. This is also important when registering router functions as Spring beans, as will be described later. Note that this behavior is different from the annotation-based programming model, where the "most specific" controller method is picked automatically.
When using the router function builder, all defined routes are composed into one
RouterFunction
that is returned from build()
There are also other ways to compose multiple router functions together:
add(RouterFunction)
on theRouterFunctions.route()
builder -
RouterFunction.and(RouterFunction)
RouterFunction.andRoute(RequestPredicate, HandlerFunction)
— shortcut forRouterFunction.and()
with nestedRouterFunctions.route()
The following example shows the composition of four routes:
RouterFunction<ServerResponse> otherRoute = ...
.GET("/person/{id}", accept(APPLICATION_JSON), handler::getPerson) (1)
.GET("/person", accept(APPLICATION_JSON), handler::listPeople) (2)
.POST("/person", handler::createPerson) (3)
.add(otherRoute) (4)
1 | GET /person/{id} with an Accept header that matches JSON is routed to
PersonHandler.getPerson |
2 | GET /person with an Accept header that matches JSON is routed to
PersonHandler.listPeople |
3 | POST /person with no additional predicates is mapped to
PersonHandler.createPerson , and |
4 | otherRoute is a router function that is created elsewhere, and added to the route built. |
import org.springframework.http.MediaType.APPLICATION_JSON
val handler = PersonHandler(repository);
val otherRoute: RouterFunction<ServerResponse> = coRouter { }
}.and(otherRoute) (4)
Nested Routes
It is common for a group of router functions to have a shared predicate, for instance a
shared path. In the example above, the shared predicate would be a path predicate that
matches /person
, used by three of the routes. When using annotations, you would remove
this duplication by using a type-level @RequestMapping
annotation that maps to
/person
. In WebFlux.fn, path predicates can be shared through the path
method on the
router function builder. For instance, the last few lines of the example above can be
improved in the following way by using nested routes:
.path("/person", builder -> builder (1)
.GET("/{id}", accept(APPLICATION_JSON), handler::getPerson)
.GET(accept(APPLICATION_JSON), handler::listPeople)
.POST(handler::createPerson))
1 | Note that second parameter of path is a consumer that takes the router builder. |
"/person".nest {
Though path-based nesting is the most common, you can nest on any kind of predicate by using
the nest
method on the builder.
The above still contains some duplication in the form of the shared Accept
-header predicate.
We can further improve by using the nest
method together with accept
.path("/person", b1 -> b1
.nest(accept(APPLICATION_JSON), b2 -> b2
.GET("/{id}", handler::getPerson)
.GET(handler::listPeople))
"/person".nest {
1.5.4. Running a Server
How do you run a router function in an HTTP server? A simple option is to convert a router
function to an HttpHandler
by using one of the following:
You can then use the returned HttpHandler
with a number of server adapters by following
HttpHandler for server-specific instructions.
A more typical option, also used by Spring Boot, is to run with a
DispatcherHandler
-based setup through the
WebFlux Config, which uses Spring configuration to declare the
components required to process requests. The WebFlux Java configuration declares the following
infrastructure components to support functional endpoints:
RouterFunctionMapping
: Detects one or moreRouterFunction<?>
beans in the Spring configuration, orders them, combines them throughRouterFunction.andOther
, and routes requests to the resulting composedRouterFunction
HandlerFunctionAdapter
: Simple adapter that letsDispatcherHandler
invoke aHandlerFunction
that was mapped to a request. -
ServerResponseResultHandler
: Handles the result from the invocation of aHandlerFunction
by invoking thewriteTo
method of theServerResponse
The preceding components let functional endpoints fit within the DispatcherHandler
request
processing lifecycle and also (potentially) run side by side with annotated controllers, if
any are declared. It is also how functional endpoints are enabled by the Spring Boot WebFlux
starter.
The following example shows a WebFlux Java configuration (see DispatcherHandler for how to run it):
@EnableWebFlux
public class WebConfig implements WebFluxConfigurer {
public RouterFunction<?> routerFunctionA() {
public RouterFunction<?> routerFunctionB() {
public void configureHttpMessageCodecs(ServerCodecConfigurer configurer) {
// configure message conversion...
public void addCorsMappings(CorsRegistry registry) {
// configure CORS...
public void configureViewResolvers(ViewResolverRegistry registry) {
// configure view resolution for HTML rendering...
@EnableWebFlux
class WebConfig : WebFluxConfigurer {
fun routerFunctionA(): RouterFunction<*> {
fun routerFunctionB(): RouterFunction<*> {
override fun configureHttpMessageCodecs(configurer: ServerCodecConfigurer) {
override fun addCorsMappings(registry: CorsRegistry) {
override fun configureViewResolvers(registry: ViewResolverRegistry) {
1.5.5. Filtering Handler Functions
You can filter handler functions by using the before
, after
, or filter
methods on the routing
function builder.
With annotations, you can achieve similar functionality by using @ControllerAdvice
, a ServletFilter
, or both.
The filter will apply to all routes that are built by the builder.
This means that filters defined in nested routes do not apply to "top-level" routes.
For instance, consider the following example:
.before(request -> ServerRequest.from(request) (1)
.header("X-RequestHeader", "Value")
.build()))
.after((request, response) -> logResponse(response)) (2)
1 | The before filter that adds a custom request header is only applied to the two GET routes. |
2 | The after filter that logs the response is applied to all routes, including the nested ones. |
val route = router {
"/person".nest {
GET("", handler::listPeople)
before { (1)
ServerRequest.from(it)
.header("X-RequestHeader", "Value").build()
after { _, response -> (2)
The filter
method on the router builder takes a HandlerFilterFunction
: a
function that takes a ServerRequest
and HandlerFunction
and returns a ServerResponse
The handler function parameter represents the next element in the chain.
This is typically the handler that is routed to, but it can also be another
filter if multiple are applied.
Now we can add a simple security filter to our route, assuming that we have a SecurityManager
that
can determine whether a particular path is allowed.
SecurityManager securityManager = ...
.filter((request, next) -> {
if (securityManager.allowAccessTo(request.path())) {
return next.handle(request);
else {
return ServerResponse.status(UNAUTHORIZED).build();
val securityManager: SecurityManager = ...
("/person" and accept(APPLICATION_JSON)).nest {
filter { request, next ->
next(request)
else {
The preceding example demonstrates that invoking the next.handle(ServerRequest)
is optional.
We only let the handler function be run when access is allowed.
Besides using the filter
method on the router function builder, it is possible to apply a
filter to an existing router function via RouterFunction.filter(HandlerFilterFunction)
CORS support for functional endpoints is provided through a dedicated
CorsWebFilter .
1.6. URI Links
This section describes various options available in the Spring Framework to prepare URIs.
1.6.1. UriComponents
Spring MVC and Spring WebFlux
UriComponentsBuilder
helps to build URI’s from URI templates with variables, as the following example shows:
UriComponents uriComponents = UriComponentsBuilder
.fromUriString("https://example.com/hotels/{hotel}") (1)
.queryParam("q", "{q}") (2)
.encode() (3)
.build(); (4)
URI uri = uriComponents.expand("Westin", "123").toUri(); (5)
1 | Static factory method with a URI template. |
2 | Add or replace URI components. |
3 | Request to have the URI template and URI variables encoded. |
4 | Build a UriComponents . |
5 | Expand variables and obtain the URI . |
val uriComponents = UriComponentsBuilder
.encode() (3)
.build() (4)
val uri = uriComponents.expand("Westin", "123").toUri() (5)
The preceding example can be consolidated into one chain and shortened with buildAndExpand
URI uri = UriComponentsBuilder
.encode()
.buildAndExpand("Westin", "123")
.toUri();
val uri = UriComponentsBuilder
.encode()
.toUri()
You can shorten it further by going directly to a URI (which implies encoding), as the following example shows:
.build("Westin", "123");
You can shorten it further still with a full URI template, as the following example shows:
.fromUriString("https://example.com/hotels/{hotel}?q={q}")
1.6.2. UriBuilder
implements UriBuilder
. You can create a
UriBuilder
, in turn, with a UriBuilderFactory
. Together, UriBuilderFactory
and
UriBuilder
provide a pluggable mechanism to build URIs from URI templates, based on
shared configuration, such as a base URL, encoding preferences, and other details.
You can configure RestTemplate
and WebClient
to customize the preparation of URIs. DefaultUriBuilderFactory
is a default
implementation of UriBuilderFactory
that uses UriComponentsBuilder
internally and
exposes shared configuration options.
The following example shows how to configure a RestTemplate
// import org.springframework.web.util.DefaultUriBuilderFactory.EncodingMode;
String baseUrl = "https://example.org";
DefaultUriBuilderFactory factory = new DefaultUriBuilderFactory(baseUrl);
factory.setEncodingMode(EncodingMode.TEMPLATE_AND_VALUES);
RestTemplate restTemplate = new RestTemplate();
restTemplate.setUriTemplateHandler(factory);
val baseUrl = "https://example.org"
val factory = DefaultUriBuilderFactory(baseUrl)
factory.encodingMode = EncodingMode.TEMPLATE_AND_VALUES
val restTemplate = RestTemplate()
restTemplate.uriTemplateHandler = factory
The following example configures a WebClient
WebClient client = WebClient.builder().uriBuilderFactory(factory).build();
val client = WebClient.builder().uriBuilderFactory(factory).build()
In addition, you can also use DefaultUriBuilderFactory
directly. It is similar to using
but, instead of static factory methods, it is an actual instance
that holds configuration and preferences, as the following example shows:
String baseUrl = "https://example.com";
DefaultUriBuilderFactory uriBuilderFactory = new DefaultUriBuilderFactory(baseUrl);
URI uri = uriBuilderFactory.uriString("/hotels/{hotel}")
val baseUrl = "https://example.com"
val uriBuilderFactory = DefaultUriBuilderFactory(baseUrl)
val uri = uriBuilderFactory.uriString("/hotels/{hotel}")
1.6.3. URI Encoding
exposes encoding options at two levels:
UriComponentsBuilder#encode(): Pre-encodes the URI template first and then strictly encodes URI variables when expanded.
UriComponents#encode(): Encodes URI components after URI variables are expanded.
Both options replace non-ASCII and illegal characters with escaped octets. However, the first option also replaces characters with reserved meaning that appear in URI variables.
Consider ";", which is legal in a path but has reserved meaning. The first option replaces ";" with "%3B" in URI variables but not in the URI template. By contrast, the second option never replaces ";", since it is a legal character in a path. |
For most cases, the first option is likely to give the expected result, because it treats URI variables as opaque data to be fully encoded, while the second option is useful if URI variables do intentionally contain reserved characters. The second option is also useful when not expanding URI variables at all since that will also encode anything that incidentally looks like a URI variable.
The following example uses the first option:
URI uri = UriComponentsBuilder.fromPath("/hotel list/{city}")
.encode()
.buildAndExpand("New York", "foo+bar")
.toUri();
// Result is "/hotel%20list/New%20York?q=foo%2Bbar"
val uri = UriComponentsBuilder.fromPath("/hotel list/{city}")
.encode()
.toUri()
You can shorten the preceding example by going directly to the URI (which implies encoding), as the following example shows:
.build("New York", "foo+bar");
URI uri = UriComponentsBuilder.fromUriString("/hotel list/{city}?q={q}")
val uri = UriComponentsBuilder.fromUriString("/hotel list/{city}?q={q}")
The WebClient
and the RestTemplate
expand and encode URI templates internally through
the UriBuilderFactory
strategy. Both can be configured with a custom strategy,
// Customize the RestTemplate..
// Customize the WebClient..
val factory = DefaultUriBuilderFactory(baseUrl).apply {
val restTemplate = RestTemplate().apply {
The DefaultUriBuilderFactory
implementation uses UriComponentsBuilder
internally to
expand and encode URI templates. As a factory, it provides a single place to configure
the approach to encoding, based on one of the below encoding modes:
TEMPLATE_AND_VALUES
: UsesUriComponentsBuilder#encode()
, corresponding to the first option in the earlier list, to pre-encode the URI template and strictly encode URI variables when expanded. -
VALUES_ONLY
: Does not encode the URI template and, instead, applies strict encoding to URI variables throughUriUtils#encodeUriVariables
prior to expanding them into the template. -
URI_COMPONENT
: UsesUriComponents#encode()
, corresponding to the second option in the earlier list, to encode URI component value after URI variables are expanded. -
NONE
: No encoding is applied.
The RestTemplate
is set to EncodingMode.URI_COMPONENT
for historic
reasons and for backwards compatibility. The WebClient
relies on the default value
in DefaultUriBuilderFactory
, which was changed from EncodingMode.URI_COMPONENT
in
5.0.x to EncodingMode.TEMPLATE_AND_VALUES
in 5.1.
1.7. CORS
Spring WebFlux lets you handle CORS (Cross-Origin Resource Sharing). This section describes how to do so.
1.7.1. Introduction
For security reasons, browsers prohibit AJAX calls to resources outside the current origin. For example, you could have your bank account in one tab and evil.com in another. Scripts from evil.com should not be able to make AJAX requests to your bank API with your credentials — for example, withdrawing money from your account!
Cross-Origin Resource Sharing (CORS) is a W3C specification implemented by most browsers that lets you specify what kind of cross-domain requests are authorized, rather than using less secure and less powerful workarounds based on IFRAME or JSONP.
1.7.2. Processing
The CORS specification distinguishes between preflight, simple, and actual requests. To learn how CORS works, you can read this article, among many others, or see the specification for more details.
Spring WebFlux HandlerMapping
implementations provide built-in support for CORS. After successfully
mapping a request to a handler, a HandlerMapping
checks the CORS configuration for the
given request and handler and takes further actions. Preflight requests are handled
directly, while simple and actual CORS requests are intercepted, validated, and have the
required CORS response headers set.
In order to enable cross-origin requests (that is, the Origin
header is present and
differs from the host of the request), you need to have some explicitly declared CORS
configuration. If no matching CORS configuration is found, preflight requests are
rejected. No CORS headers are added to the responses of simple and actual CORS requests
and, consequently, browsers reject them.
Each HandlerMapping
can be
configured
individually with URL pattern-based CorsConfiguration
mappings. In most cases, applications
use the WebFlux Java configuration to declare such mappings, which results in a single,
global map passed to all HandlerMapping
implementations.
You can combine global CORS configuration at the HandlerMapping
level with more
fine-grained, handler-level CORS configuration. For example, annotated controllers can use
class- or method-level @CrossOrigin
annotations (other handlers can implement
CorsConfigurationSource
The rules for combining global and local configuration are generally additive — for example,
all global and all local origins. For those attributes where only a single value can be
accepted, such as allowCredentials
and maxAge
, the local overrides the global value. See
CorsConfiguration#combine(CorsConfiguration)
for more details.
To learn more from the source or to make advanced customizations, see:
1.7.3. Credentialed Requests
Using CORS with credentialed requests requires enabling allowedCredentials
. Be aware that
this option establishes a high level of trust with the configured domains and also increases
the surface of attack of the web application by exposing sensitive user-specific information
such as cookies and CSRF tokens.
Enabling credentials also impacts how the configured "*"
CORS wildcards are processed:
Wildcards are not authorized in
allowOrigins
, but alternatively theallowOriginPatterns
property may be used to match to a dynamic set of origins. -
When set on
allowedHeaders
orallowedMethods
, theAccess-Control-Allow-Headers
andAccess-Control-Allow-Methods
response headers are handled by copying the related headers and method specified in the CORS preflight request. -
When set on
exposedHeaders
,Access-Control-Expose-Headers
response header is set either to the configured list of headers or to the wildcard character. While the CORS spec does not allow the wildcard character whenAccess-Control-Allow-Credentials
is set totrue
, most browsers support it and the response headers are not all available during the CORS processing, so as a consequence the wildcard character is the header value used when specified regardless of the value of theallowCredentials
property.
While such wildcard configuration can be handy, it is recommended when possible to configure a finite set of values instead to provide a higher level of security. |
1.7.4. @CrossOrigin
The @CrossOrigin
annotation enables cross-origin requests on annotated controller methods, as the
@RestController
@RequestMapping("/account")
public class AccountController {
@CrossOrigin
@GetMapping("/{id}")
public Mono<Account> retrieve(@PathVariable Long id) {
@DeleteMapping("/{id}")
public Mono<Void> remove(@PathVariable Long id) {
@RestController
@CrossOrigin
suspend fun retrieve(@PathVariable id: Long): Account {
suspend fun remove(@PathVariable id: Long) {
By default, @CrossOrigin
allows:
All origins.
All headers.
All HTTP methods to which the controller method is mapped.
allowCredentials
is not enabled by default, since that establishes a trust level
that exposes sensitive user-specific information (such as cookies and CSRF tokens) and
should be used only where appropriate. When it is enabled either allowOrigins
must be
set to one or more specific domain (but not the special value "*"
) or alternatively
the allowOriginPatterns
maxAge
is set to 30 minutes.
@CrossOrigin
is supported at the class level, too, and inherited by all methods.
The following example specifies a certain domain and sets maxAge
to an hour:
@CrossOrigin(origins = "https://domain2.com", maxAge = 3600)
@RestController
@CrossOrigin("https://domain2.com", maxAge = 3600)
@RestController
You can use @CrossOrigin
at both the class and the method level,
@CrossOrigin(maxAge = 3600) (1)
@RestController
@CrossOrigin("https://domain2.com") (2)
1 | Using @CrossOrigin at the class level. |
2 | Using @CrossOrigin at the method level. |
@RestController
1.7.5. Global Configuration
In addition to fine-grained, controller method-level configuration, you probably want to
define some global CORS configuration, too. You can set URL-based CorsConfiguration
mappings individually on any HandlerMapping
. Most applications, however, use the
WebFlux Java configuration to do that.
By default global configuration enables the following:
All origins.
All headers.
GET
,HEAD
, andPOST
methods.
allowedCredentials
must be
) or alternatively
maxAge
To enable CORS in the WebFlux Java configuration, you can use the CorsRegistry
callback,
@EnableWebFlux
registry.addMapping("/api/**")
.allowedOrigins("https://domain2.com")
.allowedMethods("PUT", "DELETE")
.allowedHeaders("header1", "header2", "header3")
.exposedHeaders("header1", "header2")
.allowCredentials(true).maxAge(3600);
// Add more mappings...
@EnableWebFlux
1.7.6. CORS WebFilter
You can apply CORS support through the built-in
CorsWebFilter
, which is a
good fit with functional endpoints.
If you try to use the CorsFilter with Spring Security, keep in mind that Spring
Security has built-in support for
CORS.
To configure the filter, you can declare a CorsWebFilter
bean and pass a
to its constructor, as the following example shows:
CorsWebFilter corsFilter() {
CorsConfiguration config = new CorsConfiguration();
// Possibly...
// config.applyPermitDefaultValues()
config.setAllowCredentials(true);
config.addAllowedOrigin("https://domain1.com");
config.addAllowedHeader("*");
config.addAllowedMethod("*");
UrlBasedCorsConfigurationSource source = new UrlBasedCorsConfigurationSource();
source.registerCorsConfiguration("/**", config);
return new CorsWebFilter(source);
fun corsFilter(): CorsWebFilter {
val config = CorsConfiguration()
// Possibly...
config.allowCredentials = true
val source = UrlBasedCorsConfigurationSource().apply {
return CorsWebFilter(source)
1.8. Web Security
The Spring Security project provides support for protecting web applications from malicious exploits. See the Spring Security reference documentation, including:
1.9. View Technologies
The use of view technologies in Spring WebFlux is pluggable. Whether you decide to use Thymeleaf, FreeMarker, or some other view technology is primarily a matter of a configuration change. This chapter covers the view technologies integrated with Spring WebFlux. We assume you are already familiar with View Resolution.
1.9.1. Thymeleaf
Thymeleaf is a modern server-side Java template engine that emphasizes natural HTML templates that can be previewed in a browser by double-clicking, which is very helpful for independent work on UI templates (for example, by a designer) without the need for a running server. Thymeleaf offers an extensive set of features, and it is actively developed and maintained. For a more complete introduction, see the Thymeleaf project home page.
The Thymeleaf integration with Spring WebFlux is managed by the Thymeleaf project. The
configuration involves a few bean declarations, such as
SpringResourceTemplateResolver
, SpringWebFluxTemplateEngine
, and
ThymeleafReactiveViewResolver
. For more details, see
Thymeleaf+Spring and the WebFlux integration
announcement.
1.9.2. FreeMarker
Apache FreeMarker is a template engine for generating any kind of text output from HTML to email and others. The Spring Framework has built-in integration for using Spring WebFlux with FreeMarker templates.
View Configuration
The following example shows how to configure FreeMarker as a view technology:
@EnableWebFlux
registry.freeMarker();
// Configure FreeMarker...
public FreeMarkerConfigurer freeMarkerConfigurer() {
FreeMarkerConfigurer configurer = new FreeMarkerConfigurer();
configurer.setTemplateLoaderPath("classpath:/templates/freemarker");
return configurer;
@EnableWebFlux
fun freeMarkerConfigurer() = FreeMarkerConfigurer().apply {
Your templates need to be stored in the directory specified by the FreeMarkerConfigurer
shown in the preceding example. Given the preceding configuration, if your controller
returns the view name, welcome
, the resolver looks for the
classpath:/templates/freemarker/welcome.ftl
template.
FreeMarker Configuration
You can pass FreeMarker 'Settings' and 'SharedVariables' directly to the FreeMarker
Configuration
object (which is managed by Spring) by setting the appropriate bean
properties on the FreeMarkerConfigurer
bean. The freemarkerSettings
property requires
a java.util.Properties
object, and the freemarkerVariables
property requires a
java.util.Map
. The following example shows how to use a FreeMarkerConfigurer
@EnableWebFlux
Map<String, Object> variables = new HashMap<>();
variables.put("xml_escape", new XmlEscape());
configurer.setTemplateLoaderPath("classpath:/templates");
configurer.setFreemarkerVariables(variables);
return configurer;
@EnableWebFlux
setFreemarkerVariables(mapOf("xml_escape" to XmlEscape()))
See the FreeMarker documentation for details of settings and variables as they apply to
the Configuration
object.
Form Handling
Spring provides a tag library for use in JSPs that contains, among others, a
<spring:bind/>
element. This element primarily lets forms display values from
form-backing objects and show the results of failed validations from a Validator
in the
web or business tier. Spring also has support for the same functionality in FreeMarker,
with additional convenience macros for generating form input elements themselves.
The Bind Macros
A standard set of macros are maintained within the spring-webflux.jar
file for
FreeMarker, so they are always available to a suitably configured application.
Some of the macros defined in the Spring templating libraries are considered internal
(private), but no such scoping exists in the macro definitions, making all macros visible
to calling code and user templates. The following sections concentrate only on the macros
you need to directly call from within your templates. If you wish to view the macro code
directly, the file is called spring.ftl
and is in the
org.springframework.web.reactive.result.view.freemarker
package.
For additional details on binding support, see Simple Binding for Spring MVC.
1.9.3. Script Views
The Spring Framework has a built-in integration for using Spring WebFlux with any templating library that can run on top of the JSR-223 Java scripting engine. The following table shows the templating libraries that we have tested on different script engines:
Scripting Library | Scripting Engine |
The basic rule for integrating any other script engine is that it must implement the
ScriptEngine and Invocable interfaces.
Requirements
You need to have the script engine on your classpath, the details of which vary by script engine:
The Nashorn JavaScript engine is provided with Java 8+. Using the latest update release available is highly recommended.
JRuby should be added as a dependency for Ruby support.
Jython should be added as a dependency for Python support.
org.jetbrains.kotlin:kotlin-script-util
dependency and aMETA-INF/services/javax.script.ScriptEngineFactory
file containing aorg.jetbrains.kotlin.script.jsr223.KotlinJsr223JvmLocalScriptEngineFactory
line should be added for Kotlin script support. See this example for more detail.
You need to have the script templating library. One way to do that for JavaScript is through WebJars.
Script Templates
You can declare a ScriptTemplateConfigurer
bean to specify the script engine to use,
the script files to load, what function to call to render templates, and so on.
The following example uses Mustache templates and the Nashorn JavaScript engine:
@EnableWebFlux
registry.scriptTemplate();
public ScriptTemplateConfigurer configurer() {
ScriptTemplateConfigurer configurer = new ScriptTemplateConfigurer();
configurer.setEngineName("nashorn");
configurer.setScripts("mustache.js");
configurer.setRenderObject("Mustache");
configurer.setRenderFunction("render");
return configurer;
@EnableWebFlux
fun configurer() = ScriptTemplateConfigurer().apply {
engineName = "nashorn"
renderObject = "Mustache"
renderFunction = "render"
The render
function is called with the following parameters:
String template
: The template content -
Map model
: The view model -
RenderingContext renderingContext
: TheRenderingContext
that gives access to the application context, the locale, the template loader, and the URL (since 5.0)
Mustache.render()
is natively compatible with this signature, so you can call it directly.
If your templating technology requires some customization, you can provide a script that implements a custom render function. For example, Handlerbars needs to compile templates before using them and requires a polyfill in order to emulate some browser facilities not available in the server-side script engine. The following example shows how to set a custom render function:
@EnableWebFlux
configurer.setScripts("polyfill.js", "handlebars.js", "render.js");
configurer.setSharedEngine(false);
return configurer;
@EnableWebFlux
isSharedEngine = false
Setting the sharedEngine property to false is required when using non-thread-safe
script engines with templating libraries not designed for concurrency, such as Handlebars or
React running on Nashorn. In that case, Java SE 8 update 60 is required, due to
this bug, but it is generally
recommended to use a recent Java SE patch release in any case.
polyfill.js
defines only the window
object needed by Handlebars to run properly,
as the following snippet shows:
var window = {};
This basic render.js
implementation compiles the template before using it. A production
ready implementation should also store and reused cached templates or pre-compiled templates.
This can be done on the script side, as well as any customization you need (managing
template engine configuration for example).
The following example shows how compile a template:
function render(template, model) {
var compiledTemplate = Handlebars.compile(template);
return compiledTemplate(model);
1.9.4. JSON and XML
For Content Negotiation purposes, it is useful to be able to alternate
between rendering a model with an HTML template or as other formats (such as JSON or XML),
depending on the content type requested by the client. To support doing so, Spring WebFlux
provides the HttpMessageWriterView
, which you can use to plug in any of the available
Codecs from spring-web
, such as Jackson2JsonEncoder
, Jackson2SmileEncoder
or Jaxb2XmlEncoder
Unlike other view technologies, HttpMessageWriterView
does not require a ViewResolver
but is instead configured as a default view. You can
configure one or more such default views, wrapping different HttpMessageWriter
instances
or Encoder
instances. The one that matches the requested content type is used at runtime.
In most cases, a model contains multiple attributes. To determine which one to serialize,
you can configure HttpMessageWriterView
with the name of the model attribute to use for
rendering. If the model contains only one attribute, that one is used.
1.10. HTTP Caching
HTTP caching can significantly improve the performance of a web application. HTTP caching
revolves around the Cache-Control
response header and subsequent conditional request
headers, such as Last-Modified
and ETag
. Cache-Control
advises private (for example, browser)
and public (for example, proxy) caches how to cache and re-use responses. An ETag
header is used
to make a conditional request that may result in a 304 (NOT_MODIFIED) without a body,
if the content has not changed. ETag
can be seen as a more sophisticated successor to
the Last-Modified
header.
This section describes the HTTP caching related options available in Spring WebFlux.
1.10.1. CacheControl
CacheControl
configuring settings related to the Cache-Control
header and is accepted as an argument
in a number of places:
While RFC 7234 describes all possible
directives for the Cache-Control
response header, the CacheControl
type takes a
use case-oriented approach that focuses on the common scenarios, as the following example shows:
// Cache for an hour - "Cache-Control: max-age=3600"
CacheControl ccCacheOneHour = CacheControl.maxAge(1, TimeUnit.HOURS);
// Prevent caching - "Cache-Control: no-store"
CacheControl ccNoStore = CacheControl.noStore();
// Cache for ten days in public and private caches,
// public caches should not transform the response
// "Cache-Control: max-age=864000, public, no-transform"
CacheControl ccCustom = CacheControl.maxAge(10, TimeUnit.DAYS).noTransform().cachePublic();
val ccCacheOneHour = CacheControl.maxAge(1, TimeUnit.HOURS)
val ccNoStore = CacheControl.noStore()
val ccCustom = CacheControl.maxAge(10, TimeUnit.DAYS).noTransform().cachePublic()
1.10.2. Controllers
Controllers can add explicit support for HTTP caching. We recommend doing so, since the
lastModified
or ETag
value for a resource needs to be calculated before it can be compared
against conditional request headers. A controller can add an ETag
and Cache-Control
settings to a ResponseEntity
@GetMapping("/book/{id}")
public ResponseEntity<Book> showBook(@PathVariable Long id) {
Book book = findBook(id);
String version = book.getVersion();
return ResponseEntity
.ok()
.cacheControl(CacheControl.maxAge(30, TimeUnit.DAYS))
.eTag(version) // lastModified is also available
.body(book);
fun showBook(@PathVariable id: Long): ResponseEntity<Book> {
val book = findBook(id)
val version = book.getVersion()
.ok()
.body(book)
The preceding example sends a 304 (NOT_MODIFIED) response with an empty body if the comparison
to the conditional request headers indicates the content has not changed. Otherwise, the
ETag
and Cache-Control
headers are added to the response.
You can also make the check against conditional request headers in the controller, as the following example shows:
@RequestMapping
public String myHandleMethod(ServerWebExchange exchange, Model model) {
long eTag = ... (1)
if (exchange.checkNotModified(eTag)) {
return null; (2)
model.addAttribute(...); (3)
return "myViewName";
1 | Application-specific calculation. |
2 | Response has been set to 304 (NOT_MODIFIED). No further processing. |
3 | Continue with request processing. |
@RequestMapping
fun myHandleMethod(exchange: ServerWebExchange, model: Model): String? {
val eTag: Long = ... (1)
return null(2)
model.addAttribute(...) (3)
return "myViewName"
There are three variants for checking conditional requests against eTag
values, lastModified
values, or both. For conditional GET
and HEAD
requests, you can set the response to
304 (NOT_MODIFIED). For conditional POST
, PUT
, and DELETE
, you can instead set the response
to 412 (PRECONDITION_FAILED) to prevent concurrent modification.
1.10.3. Static Resources
You should serve static resources with a Cache-Control
and conditional response headers
for optimal performance. See the section on configuring Static Resources.
1.11. WebFlux Config
The WebFlux Java configuration declares the components that are required to process
requests with annotated controllers or functional endpoints, and it offers an API to
customize the configuration. That means you do not need to understand the underlying
beans created by the Java configuration. However, if you want to understand them,
you can see them in WebFluxConfigurationSupport
or read more about what they are
in Special Bean Types.
For more advanced customizations, not available in the configuration API, you can gain full control over the configuration through the Advanced Configuration Mode.
1.11.1. Enabling WebFlux Config
You can use the @EnableWebFlux
annotation in your Java config, as the following example shows:
@EnableWebFlux
public class WebConfig {
@EnableWebFlux
class WebConfig
The preceding example registers a number of Spring WebFlux infrastructure beans and adapts to dependencies available on the classpath — for JSON, XML, and others.
1.11.2. WebFlux config API
In your Java configuration, you can implement the WebFluxConfigurer
interface,
@EnableWebFlux
// Implement configuration methods...
@EnableWebFlux
1.11.3. Conversion, formatting
By default, formatters for various number and date types are installed, along with support
for customization via @NumberFormat
and @DateTimeFormat
on fields.
To register custom formatters and converters in Java config, use the following:
@EnableWebFlux
public void addFormatters(FormatterRegistry registry) {
@EnableWebFlux
override fun addFormatters(registry: FormatterRegistry) {
By default Spring WebFlux considers the request Locale when parsing and formatting date values. This works for forms where dates are represented as Strings with "input" form fields. For "date" and "time" form fields, however, browsers use a fixed format defined in the HTML spec. For such cases date and time formatting can be customized as follows:
@EnableWebFlux
DateTimeFormatterRegistrar registrar = new DateTimeFormatterRegistrar();
registrar.setUseIsoFormat(true);
registrar.registerFormatters(registry);
@EnableWebFlux
val registrar = DateTimeFormatterRegistrar()
See FormatterRegistrar SPI
and the FormattingConversionServiceFactoryBean for more information on when to
use FormatterRegistrar implementations.
1.11.4. Validation
By default, if Bean Validation is present
on the classpath (for example, the Hibernate Validator), the LocalValidatorFactoryBean
is registered as a global validator for use with @Valid
and
@Validated
on @Controller
method arguments.
In your Java configuration, you can customize the global Validator
instance,
@EnableWebFlux
public Validator getValidator() {
@EnableWebFlux
override fun getValidator(): Validator {
Note that you can also register Validator
implementations locally,
@Controller
public class MyController {
@InitBinder
binder.addValidators(new FooValidator());
@Controller
@InitBinder
protected fun initBinder(binder: WebDataBinder) {
binder.addValidators(FooValidator())
If you need to have a LocalValidatorFactoryBean injected somewhere, create a bean and
mark it with @Primary in order to avoid conflict with the one declared in the MVC config.
1.11.5. Content Type Resolvers
You can configure how Spring WebFlux determines the requested media types for
@Controller
instances from the request. By default, only the Accept
header is checked,
but you can also enable a query parameter-based strategy.
The following example shows how to customize the requested content type resolution:
@EnableWebFlux
public void configureContentTypeResolver(RequestedContentTypeResolverBuilder builder) {
@EnableWebFlux
override fun configureContentTypeResolver(builder: RequestedContentTypeResolverBuilder) {
1.11.6. HTTP message codecs
The following example shows how to customize how the request and response body are read and written:
@EnableWebFlux
configurer.defaultCodecs().maxInMemorySize(512 * 1024);
@EnableWebFlux
provides a set of default readers and writers. You can use it to add
more readers and writers, customize the default ones, or replace the default ones completely.
For Jackson JSON and XML, consider using
Jackson2ObjectMapperBuilder
which customizes Jackson’s default properties with the following ones:
DeserializationFeature.FAIL_ON_UNKNOWN_PROPERTIES
is disabled. -
MapperFeature.DEFAULT_VIEW_INCLUSION
is disabled.
It also automatically registers the following well-known modules if they are detected on the classpath:
jackson-datatype-joda
: Support for Joda-Time types. -
jackson-datatype-jsr310
: Support for Java 8 Date and Time API types. -
jackson-datatype-jdk8
: Support for other Java 8 types, such asOptional
jackson-module-kotlin
: Support for Kotlin classes and data classes.
1.11.7. View Resolvers
The following example shows how to configure view resolution:
@EnableWebFlux
@EnableWebFlux
The ViewResolverRegistry
has shortcuts for view technologies with which the Spring Framework
integrates. The following example uses FreeMarker (which also requires configuring the
underlying FreeMarker view technology):
@EnableWebFlux
// Configure Freemarker...
return configurer;
@EnableWebFlux
You can also plug in any ViewResolver
implementation, as the following example shows:
@EnableWebFlux
ViewResolver resolver = ... ;
registry.viewResolver(resolver);
@EnableWebFlux
val resolver: ViewResolver = ...
To support Content Negotiation and rendering other formats
through view resolution (besides HTML), you can configure one or more default views based
on the HttpMessageWriterView
implementation, which accepts any of the available
. The following example shows how to do so:
@EnableWebFlux
Jackson2JsonEncoder encoder = new Jackson2JsonEncoder();
registry.defaultViews(new HttpMessageWriterView(encoder));
@EnableWebFlux
val encoder = Jackson2JsonEncoder()
registry.defaultViews(HttpMessageWriterView(encoder))
See View Technologies for more on the view technologies that are integrated with Spring WebFlux.
1.11.8. Static Resources
This option provides a convenient way to serve static resources from a list of
Resource
-based locations.
In the next example, given a request that starts with /resources
, the relative path is
used to find and serve static resources relative to /static
on the classpath. Resources
are served with a one-year future expiration to ensure maximum use of the browser cache
and a reduction in HTTP requests made by the browser. The Last-Modified
header is also
evaluated and, if present, a 304
status code is returned. The following listing shows
the example:
@EnableWebFlux
public void addResourceHandlers(ResourceHandlerRegistry registry) {
registry.addResourceHandler("/resources/**")
.addResourceLocations("/public", "classpath:/static/")
.setCacheControl(CacheControl.maxAge(365, TimeUnit.DAYS));
@EnableWebFlux
override fun addResourceHandlers(registry: ResourceHandlerRegistry) {
The resource handler also supports a chain of
ResourceResolver
implementations and
ResourceTransformer
implementations,
which can be used to create a toolchain for working with optimized resources.
You can use the VersionResourceResolver
for versioned resource URLs based on an MD5 hash
computed from the content, a fixed application version, or other information. A
ContentVersionStrategy
(MD5 hash) is a good choice with some notable exceptions (such as
JavaScript resources used with a module loader).
The following example shows how to use VersionResourceResolver
in your Java configuration:
@EnableWebFlux
.addResourceLocations("/public/")
.resourceChain(true)
.addResolver(new VersionResourceResolver().addContentVersionStrategy("/**"));
@EnableWebFlux
.addResolver(VersionResourceResolver().addContentVersionStrategy("/**"))
You can use ResourceUrlProvider
to rewrite URLs and apply the full chain of resolvers and
transformers (for example, to insert versions). The WebFlux configuration provides a ResourceUrlProvider
so that it can be injected into others.
Unlike Spring MVC, at present, in WebFlux, there is no way to transparently rewrite static
resource URLs, since there are no view technologies that can make use of a non-blocking chain
of resolvers and transformers. When serving only local resources, the workaround is to use
ResourceUrlProvider
directly (for example, through a custom element) and block.
Note that, when using both EncodedResourceResolver
(for example, Gzip, Brotli encoded) and
VersionedResourceResolver
, they must be registered in that order, to ensure content-based
versions are always computed reliably based on the unencoded file.
For WebJars, versioned URLs like
/webjars/jquery/1.2.0/jquery.min.js
are the recommended and most efficient way to use them.
The related resource location is configured out of the box with Spring Boot (or can be configured
manually via ResourceHandlerRegistry
) and does not require to add the
org.webjars:webjars-locator-core
dependency.
Version-less URLs like /webjars/jquery/jquery.min.js
are supported through the
WebJarsResourceResolver
which is automatically registered when the
library is present on the classpath, at the cost of a
classpath scanning that could slow down application startup. The resolver can re-write URLs to
include the version of the jar and can also match against incoming URLs without versions — for example, from /webjars/jquery/jquery.min.js
to /webjars/jquery/1.2.0/jquery.min.js
The Java configuration based on ResourceHandlerRegistry provides further options
for fine-grained control, e.g. last-modified behavior and optimized resource resolution.
1.11.9. Path Matching
You can customize options related to path matching. For details on the individual options, see the
PathMatchConfigurer
javadoc.
The following example shows how to use PathMatchConfigurer
@EnableWebFlux
public void configurePathMatch(PathMatchConfigurer configurer) {
configurer
.setUseCaseSensitiveMatch(true)
.setUseTrailingSlashMatch(false)
.addPathPrefix("/api",
HandlerTypePredicate.forAnnotation(RestController.class));
@EnableWebFlux
fun configurePathMatch(configurer: PathMatchConfigurer) {
configurer
HandlerTypePredicate.forAnnotation(RestController::class.java))
Spring WebFlux relies on a parsed representation of the request path called
Spring WebFlux also does not support suffix pattern matching, unlike in Spring MVC, where we are also recommend moving away from reliance on it. |
1.11.10. WebSocketService
The WebFlux Java config declares of a WebSocketHandlerAdapter
bean which provides
support for the invocation of WebSocket handlers. That means all that remains to do in
order to handle a WebSocket handshake request is to map a WebSocketHandler
to a URL
via SimpleUrlHandlerMapping
In some cases it may be necessary to create the WebSocketHandlerAdapter
bean with a
provided WebSocketService
service which allows configuring WebSocket server properties.
For example:
@EnableWebFlux
public WebSocketService getWebSocketService() {
TomcatRequestUpgradeStrategy strategy = new TomcatRequestUpgradeStrategy();
strategy.setMaxSessionIdleTimeout(0L);
return new HandshakeWebSocketService(strategy);
@EnableWebFlux
fun webSocketService(): WebSocketService {
val strategy = TomcatRequestUpgradeStrategy().apply {
return HandshakeWebSocketService(strategy)
1.11.11. Advanced Configuration Mode
@EnableWebFlux
imports DelegatingWebFluxConfiguration
that:
Provides default Spring configuration for WebFlux applications
detects and delegates to
WebFluxConfigurer
implementations to customize that configuration.
For advanced mode, you can remove @EnableWebFlux
and extend directly from
instead of implementing WebFluxConfigurer
public class WebConfig extends DelegatingWebFluxConfiguration {
class WebConfig : DelegatingWebFluxConfiguration {
You can keep existing methods in WebConfig
, but you can now also override bean declarations
from the base class and still have any number of other WebMvcConfigurer
implementations on
the classpath.
1.12. HTTP/2
HTTP/2 is supported with Reactor Netty, Tomcat, Jetty, and Undertow. However, there are considerations related to server configuration. For more details, see the HTTP/2 wiki page.
2. WebClient
Spring WebFlux includes a client to perform HTTP requests with. WebClient
has a
functional, fluent API based on Reactor, see Reactive Libraries,
which enables declarative composition of asynchronous logic without the need to deal with
threads or concurrency. It is fully non-blocking, it supports streaming, and relies on
the same codecs that are also used to encode and
decode request and response content on the server side.
WebClient
needs an HTTP client library to perform requests with. There is built-in
support for the following:
Others can be plugged via
ClientHttpConnector
2.1. Configuration
The simplest way to create a WebClient
is through one of the static factory methods:
WebClient.create()
WebClient.create(String baseUrl)
You can also use WebClient.builder()
with further options:
uriBuilderFactory
: CustomizedUriBuilderFactory
to use as a base URL. -
defaultUriVariables
: default values to use when expanding URI templates. -
defaultHeader
: Headers for every request. -
defaultCookie
: Cookies for every request. -
defaultRequest
:Consumer
to customize every request. -
filter
: Client filter for every request. -
exchangeStrategies
: HTTP message reader/writer customizations. -
clientConnector
: HTTP client library settings.
For example:
.codecs(configurer -> ... )
val webClient = WebClient.builder()
.codecs { configurer -> ... }
.build()
Once built, a WebClient
is immutable. However, you can clone it and build a
modified copy as follows:
WebClient client1 = WebClient.builder()
.filter(filterA).filter(filterB).build();
WebClient client2 = client1.mutate()
.filter(filterC).filter(filterD).build();
// client1 has filterA, filterB
// client2 has filterA, filterB, filterC, filterD
val client1 = WebClient.builder()
val client2 = client1.mutate()
2.1.1. MaxInMemorySize
Codecs have limits for buffering data in memory to avoid application memory issues. By default those are set to 256KB. If that’s not enough you’ll get the following error:
org.springframework.core.io.buffer.DataBufferLimitException: Exceeded limit on max bytes to buffer
To change the limit for default codecs, use the following:
WebClient webClient = WebClient.builder()
.codecs(configurer -> configurer.defaultCodecs().maxInMemorySize(2 * 1024 * 1024))
.codecs { configurer -> configurer.defaultCodecs().maxInMemorySize(2 * 1024 * 1024) }
.build()
2.1.2. Reactor Netty
To customize Reactor Netty settings, provide a pre-configured HttpClient
HttpClient httpClient = HttpClient.create().secure(sslSpec -> ...);
.clientConnector(new ReactorClientHttpConnector(httpClient))
val httpClient = HttpClient.create().secure { ... }
.clientConnector(ReactorClientHttpConnector(httpClient))
.build()
Resources
By default, HttpClient
participates in the global Reactor Netty resources held in
reactor.netty.http.HttpResources
, including event loop threads and a connection pool.
This is the recommended mode, since fixed, shared resources are preferred for event loop
concurrency. In this mode global resources remain active until the process exits.
If the server is timed with the process, there is typically no need for an explicit
shutdown. However, if the server can start or stop in-process (for example, a Spring MVC
application deployed as a WAR), you can declare a Spring-managed bean of type
ReactorResourceFactory
with globalResources=true
(the default) to ensure that the Reactor
Netty global resources are shut down when the Spring ApplicationContext
is closed,
public ReactorResourceFactory reactorResourceFactory() {
return new ReactorResourceFactory();
fun reactorResourceFactory() = ReactorResourceFactory()
You can also choose not to participate in the global Reactor Netty resources. However, in this mode, the burden is on you to ensure that all Reactor Netty client and server instances use shared resources, as the following example shows:
public ReactorResourceFactory resourceFactory() {
ReactorResourceFactory factory = new ReactorResourceFactory();
factory.setUseGlobalResources(false); (1)
return factory;
public WebClient webClient() {
Function<HttpClient, HttpClient> mapper = client -> {
// Further customizations...
ClientHttpConnector connector =
new ReactorClientHttpConnector(resourceFactory(), mapper); (2)
return WebClient.builder().clientConnector(connector).build(); (3)
1 | Create resources independent of global ones. |
2 | Use the ReactorClientHttpConnector constructor with resource factory. |
3 | Plug the connector into the WebClient.Builder . |
fun resourceFactory() = ReactorResourceFactory().apply {
isUseGlobalResources = false (1)
fun webClient(): WebClient {
val mapper: (HttpClient) -> HttpClient = {
val connector = ReactorClientHttpConnector(resourceFactory(), mapper) (2)
return WebClient.builder().clientConnector(connector).build() (3)
Timeouts
To configure a connection timeout:
import io.netty.channel.ChannelOption;
.option(ChannelOption.CONNECT_TIMEOUT_MILLIS, 10000);
To configure a read or write timeout:
import io.netty.handler.timeout.ReadTimeoutHandler;
import io.netty.handler.timeout.WriteTimeoutHandler;
.doOnConnected(conn -> conn
.addHandlerLast(new ReadTimeoutHandler(10))
.addHandlerLast(new WriteTimeoutHandler(10)));
// Create WebClient...
.doOnConnected { conn -> conn
.addHandlerLast(ReadTimeoutHandler(10))
.addHandlerLast(WriteTimeoutHandler(10))
To configure a response timeout for all requests:
.responseTimeout(Duration.ofSeconds(2));
To configure a response timeout for a specific request:
WebClient.create().get()
.uri("https://example.org/path")
.httpRequest(httpRequest -> {
HttpClientRequest reactorRequest = httpRequest.getNativeRequest();
reactorRequest.responseTimeout(Duration.ofSeconds(2));
.retrieve()
.bodyToMono(String.class);
.httpRequest { httpRequest: ClientHttpRequest ->
val reactorRequest = httpRequest.getNativeRequest<HttpClientRequest>()
.retrieve()
.bodyToMono(String::class.java)
2.1.3. Jetty
The following example shows how to customize Jetty HttpClient
settings:
HttpClient httpClient = new HttpClient();
httpClient.setCookieStore(...);
.clientConnector(new JettyClientHttpConnector(httpClient))
val httpClient = HttpClient()
httpClient.cookieStore = ...
.clientConnector(JettyClientHttpConnector(httpClient))
creates its own resources (Executor
, ByteBufferPool
, Scheduler
which remain active until the process exits or stop()
is called.
You can share resources between multiple instances of the Jetty client (and server) and
ensure that the resources are shut down when the Spring ApplicationContext
is closed by
declaring a Spring-managed bean of type JettyResourceFactory
shows:
public JettyResourceFactory resourceFactory() {
return new JettyResourceFactory();
new JettyClientHttpConnector(httpClient, resourceFactory()); (1)
return WebClient.builder().clientConnector(connector).build(); (2)
1 | Use the JettyClientHttpConnector constructor with resource factory. |
2 | Plug the connector into the WebClient.Builder . |
fun resourceFactory() = JettyResourceFactory()
val connector = JettyClientHttpConnector(httpClient, resourceFactory()) (1)
return WebClient.builder().clientConnector(connector).build() (2)
2.1.4. HttpComponents
The following example shows how to customize Apache HttpComponents HttpClient
settings:
HttpAsyncClientBuilder clientBuilder = HttpAsyncClients.custom();
clientBuilder.setDefaultRequestConfig(...);
CloseableHttpAsyncClient client = clientBuilder.build();
ClientHttpConnector connector = new HttpComponentsClientHttpConnector(client);
WebClient webClient = WebClient.builder().clientConnector(connector).build();
val client = HttpAsyncClients.custom().apply {
}.build()
val connector = HttpComponentsClientHttpConnector(client)
val webClient = WebClient.builder().clientConnector(connector).build()
2.2. retrieve()
The retrieve()
method can be used to declare how to extract the response. For example:
WebClient client = WebClient.create("https://example.org");
Mono<ResponseEntity<Person>> result = client.get()
.uri("/persons/{id}", id).accept(MediaType.APPLICATION_JSON)
.retrieve()
.toEntity(Person.class);
val client = WebClient.create("https://example.org")
val result = client.get()
.retrieve()
.toEntity<Person>().awaitSingle()
Or to get only the body:
Mono<Person> result = client.get()
.retrieve()
.bodyToMono(Person.class);
.retrieve()
To get a stream of decoded objects:
Flux<Quote> result = client.get()
.uri("/quotes").accept(MediaType.TEXT_EVENT_STREAM)
.retrieve()
.bodyToFlux(Quote.class);
.retrieve()
.bodyToFlow<Quote>()
By default, 4xx or 5xx responses result in an WebClientResponseException
, including
sub-classes for specific HTTP status codes. To customize the handling of error
responses, use onStatus
handlers as follows:
.retrieve()
.onStatus(HttpStatus::is4xxClientError, response -> ...)
.onStatus(HttpStatus::is5xxServerError, response -> ...)
.retrieve()
.onStatus(HttpStatus::is4xxClientError) { ... }
.onStatus(HttpStatus::is5xxServerError) { ... }
.awaitBody<Person>()
2.3. Exchange
The exchangeToMono()
and exchangeToFlux()
methods (or awaitExchange { }
and exchangeToFlow { }
in Kotlin)
are useful for more advanced cases that require more control, such as to decode the response differently
depending on the response status:
Mono<Person> entityMono = client.get()
.uri("/persons/1")
.exchangeToMono(response -> {
if (response.statusCode().equals(HttpStatus.OK)) {
return response.bodyToMono(Person.class);
else {
// Turn to error
return response.createException().flatMap(Mono::error);
val entity = client.get()
.uri("/persons/1")
.awaitExchange {
if (response.statusCode() == HttpStatus.OK) {
return response.awaitBody<Person>()
else {
throw response.createExceptionAndAwait()
When using the above, after the returned Mono
or Flux
completes, the response body
is checked and if not consumed it is released to prevent memory and connection leaks.
Therefore the response cannot be decoded further downstream. It is up to the provided
function to declare how to decode the response if needed.
2.4. Request Body
The request body can be encoded from any asynchronous type handled by ReactiveAdapterRegistry
like Mono
or Kotlin Coroutines Deferred
Mono<Person> personMono = ... ;
Mono<Void> result = client.post()
.contentType(MediaType.APPLICATION_JSON)
.body(personMono, Person.class)
.retrieve()
.bodyToMono(Void.class);
val personDeferred: Deferred<Person> = ...
client.post()
.body<Person>(personDeferred)
.retrieve()
.awaitBody<Unit>()
You can also have a stream of objects be encoded, as the following example shows:
Flux<Person> personFlux = ... ;
.contentType(MediaType.APPLICATION_STREAM_JSON)
.body(personFlux, Person.class)
.retrieve()
val people: Flow<Person> = ...
client.post()
.body(people)
.retrieve()
.awaitBody<Unit>()
Alternatively, if you have the actual value, you can use the bodyValue
shortcut method,
Person person = ... ;
.bodyValue(person)
.retrieve()
val person: Person = ...
client.post()
.bodyValue(person)
.retrieve()
.awaitBody<Unit>()
2.4.1. Form Data
To send form data, you can provide a MultiValueMap<String, String>
as the body. Note that the
content is automatically set to application/x-www-form-urlencoded
by the
FormHttpMessageWriter
. The following example shows how to use MultiValueMap<String, String>
MultiValueMap<String, String> formData = ... ;
.uri("/path", id)
.bodyValue(formData)
.retrieve()
val formData: MultiValueMap<String, String> = ...
client.post()
.uri("/path", id)
.retrieve()
.awaitBody<Unit>()
You can also supply form data in-line by using BodyInserters
import static org.springframework.web.reactive.function.BodyInserters.*;
.uri("/path", id)
.body(fromFormData("k1", "v1").with("k2", "v2"))
.retrieve()
import org.springframework.web.reactive.function.BodyInserters.*
client.post()
.uri("/path", id)
.retrieve()
.awaitBody<Unit>()
2.4.2. Multipart Data
To send multipart data, you need to provide a MultiValueMap<String, ?>
whose values are
either Object
instances that represent part content or HttpEntity
instances that represent the content and
headers for a part. MultipartBodyBuilder
provides a convenient API to prepare a
multipart request. The following example shows how to create a MultiValueMap<String, ?>
MultipartBodyBuilder builder = new MultipartBodyBuilder();
builder.part("fieldPart", "fieldValue");
builder.part("filePart1", new FileSystemResource("...logo.png"));
builder.part("jsonPart", new Person("Jason"));
builder.part("myPart", part); // Part from a server request
MultiValueMap<String, HttpEntity<?>> parts = builder.build();
val builder = MultipartBodyBuilder().apply {
part("filePart1", FileSystemResource("...logo.png"))
part("jsonPart", Person("Jason"))
part("myPart", part) // Part from a server request
val parts = builder.build()
In most cases, you do not have to specify the Content-Type
for each part. The content
type is determined automatically based on the HttpMessageWriter
chosen to serialize it
or, in the case of a Resource
, based on the file extension. If necessary, you can
explicitly provide the MediaType
to use for each part through one of the overloaded
builder part
methods.
Once a MultiValueMap
is prepared, the easiest way to pass it to the WebClient
is
through the body
method, as the following example shows:
MultipartBodyBuilder builder = ...;
.uri("/path", id)
.body(builder.build())
.retrieve()
val builder: MultipartBodyBuilder = ...
client.post()
.uri("/path", id)
.retrieve()
.awaitBody<Unit>()
If the MultiValueMap
contains at least one non-String
value, which could also
represent regular form data (that is, application/x-www-form-urlencoded
), you need not
set the Content-Type
to multipart/form-data
. This is always the case when using
, which ensures an HttpEntity
wrapper.
As an alternative to MultipartBodyBuilder
, you can also provide multipart content,
inline-style, through the built-in BodyInserters
.uri("/path", id)
.body(fromMultipartData("fieldPart", "value").with("filePart", resource))
.retrieve()
client.post()
.uri("/path", id)
.retrieve()
.awaitBody<Unit>()
2.5. Filters
You can register a client filter (ExchangeFilterFunction
) through the WebClient.Builder
in order to intercept and modify requests, as the following example shows:
ClientRequest filtered = ClientRequest.from(request)
.header("foo", "bar")
return next.exchange(filtered);
.filter { request, next ->
val filtered = ClientRequest.from(request)
.build()
.build()
This can be used for cross-cutting concerns, such as authentication. The following example uses a filter for basic authentication through a static factory method:
import static org.springframework.web.reactive.function.client.ExchangeFilterFunctions.basicAuthentication;
.filter(basicAuthentication("user", "password"))
import org.springframework.web.reactive.function.client.ExchangeFilterFunctions.basicAuthentication
.build()
Filters can be added or removed by mutating an existing WebClient
instance, resulting
in a new WebClient
instance that does not affect the original one. For example:
WebClient client = webClient.mutate()
.filters(filterList -> {
filterList.add(0, basicAuthentication("user", "password"));
val client = webClient.mutate()
.filters { it.add(0, basicAuthentication("user", "password")) }
.build()
WebClient
is a thin facade around the chain of filters followed by an
ExchangeFunction
. It provides a workflow to make requests, to encode to and from higher
level objects, and it helps to ensure that response content is always consumed.
When filters handle the response in some way, extra care must be taken to always consume
its content or to otherwise propagate it downstream to the WebClient
which will ensure
the same. Below is a filter that handles the UNAUTHORIZED
status code but ensures that
any response content, whether expected or not, is released:
public ExchangeFilterFunction renewTokenFilter() {
return (request, next) -> next.exchange(request).flatMap(response -> {
if (response.statusCode().value() == HttpStatus.UNAUTHORIZED.value()) {
return response.releaseBody()
.then(renewToken())
.flatMap(token -> {
ClientRequest newRequest = ClientRequest.from(request).build();
return next.exchange(newRequest);
} else {
return Mono.just(response);
fun renewTokenFilter(): ExchangeFilterFunction? {
return ExchangeFilterFunction { request: ClientRequest?, next: ExchangeFunction ->
next.exchange(request!!).flatMap { response: ClientResponse ->
return@flatMap response.releaseBody()
.then(renewToken())
.flatMap { token: String? ->
val newRequest = ClientRequest.from(request).build()
} else {
return@flatMap Mono.just(response)
2.6. Attributes
You can add attributes to a request. This is convenient if you want to pass information through the filter chain and influence the behavior of filters for a given request. For example:
Optional<Object> usr = request.attribute("myAttribute");
client.get().uri("https://example.org/")
.attribute("myAttribute", "...")
.retrieve()
.filter { request, _ ->
val usr = request.attributes()["myAttribute"];
.build()
.retrieve()
.awaitBody<Unit>()
Note that you can configure a defaultRequest
callback globally at the
WebClient.Builder
level which lets you insert attributes into all requests,
which could be used for example in a Spring MVC application to populate
request attributes based on ThreadLocal
data.
2.7. Context
Attributes provide a convenient way to pass information to the filter
chain but they only influence the current request. If you want to pass information that
propagates to additional requests that are nested, e.g. via flatMap
, or executed after,
e.g. via concatMap
, then you’ll need to use the Reactor Context
The Reactor Context
needs to be populated at the end of a reactive chain in order to
apply to all operations. For example:
Mono.deferContextual(contextView -> {
String value = contextView.get("foo");
.retrieve()
.flatMap(body -> {
// perform nested request (context propagates automatically)...
.contextWrite(context -> context.put("foo", ...));
2.8. Synchronous Use
WebClient
can be used in synchronous style by blocking at the end for the result:
Person person = client.get().uri("/person/{id}", i).retrieve()
.block();
List<Person> persons = client.get().uri("/persons").retrieve()
.bodyToFlux(Person.class)
.collectList()
.block();
val person = runBlocking {
val persons = runBlocking {
.bodyToFlow<Person>()
.toList()
However if multiple calls need to be made, it’s more efficient to avoid blocking on each response individually, and instead wait for the combined result:
Mono<Person> personMono = client.get().uri("/person/{id}", personId)
.retrieve().bodyToMono(Person.class);
Mono<List<Hobby>> hobbiesMono = client.get().uri("/person/{id}/hobbies", personId)
.retrieve().bodyToFlux(Hobby.class).collectList();
Map<String, Object> data = Mono.zip(personMono, hobbiesMono, (person, hobbies) -> {
Map<String, String> map = new LinkedHashMap<>();
map.put("person", person);
map.put("hobbies", hobbies);
return map;
.block();
val data = runBlocking {
val personDeferred = async {
.retrieve().awaitBody<Person>()
val hobbiesDeferred = async {
.retrieve().bodyToFlow<Hobby>().toList()
mapOf("person" to personDeferred.await(), "hobbies" to hobbiesDeferred.await())
The above is merely one example. There are lots of other patterns and operators for putting together a reactive pipeline that makes many remote calls, potentially some nested, inter-dependent, without ever blocking until the end.
With |
2.9. Testing
To test code that uses the WebClient
, you can use a mock web server, such as the
OkHttp MockWebServer. To see an example
of its use, check out
WebClientIntegrationTests
in the Spring Framework test suite or the
static-server
sample in the OkHttp repository.
3. WebSockets
This part of the reference documentation covers support for reactive-stack WebSocket messaging.
3.1. Introduction to WebSocket
The WebSocket protocol, RFC 6455, provides a standardized way to establish a full-duplex, two-way communication channel between client and server over a single TCP connection. It is a different TCP protocol from HTTP but is designed to work over HTTP, using ports 80 and 443 and allowing re-use of existing firewall rules.
A WebSocket interaction begins with an HTTP request that uses the HTTP Upgrade
header
to upgrade or, in this case, to switch to the WebSocket protocol. The following example
shows such an interaction:
GET /spring-websocket-portfolio/portfolio HTTP/1.1
Host: localhost:8080
Upgrade: websocket (1)
Connection: Upgrade (2)
Sec-WebSocket-Key: Uc9l9TMkWGbHFD2qnFHltg==
Sec-WebSocket-Protocol: v10.stomp, v11.stomp
Sec-WebSocket-Version: 13
Origin: http://localhost:8080
1 | The Upgrade header. |
2 | Using the Upgrade connection. |
Instead of the usual 200 status code, a server with WebSocket support returns output similar to the following:
HTTP/1.1 101 Switching Protocols (1)
Upgrade: websocket
Connection: Upgrade
Sec-WebSocket-Accept: 1qVdfYHU9hPOl4JYYNXF623Gzn0=
1 | Protocol switch |
After a successful handshake, the TCP socket underlying the HTTP upgrade request remains open for both the client and the server to continue to send and receive messages.
A complete introduction of how WebSockets work is beyond the scope of this document. See RFC 6455, the WebSocket chapter of HTML5, or any of the many introductions and tutorials on the Web.
Note that, if a WebSocket server is running behind a web server (e.g. nginx), you likely need to configure it to pass WebSocket upgrade requests on to the WebSocket server. Likewise, if the application runs in a cloud environment, check the instructions of the cloud provider related to WebSocket support.
3.1.1. HTTP Versus WebSocket
Even though WebSocket is designed to be HTTP-compatible and starts with an HTTP request, it is important to understand that the two protocols lead to very different architectures and application programming models.
In HTTP and REST, an application is modeled as many URLs. To interact with the application, clients access those URLs, request-response style. Servers route requests to the appropriate handler based on the HTTP URL, method, and headers.
By contrast, in WebSockets, there is usually only one URL for the initial connect. Subsequently, all application messages flow on that same TCP connection. This points to an entirely different asynchronous, event-driven, messaging architecture.
WebSocket is also a low-level transport protocol, which, unlike HTTP, does not prescribe any semantics to the content of messages. That means that there is no way to route or process a message unless the client and the server agree on message semantics.
WebSocket clients and servers can negotiate the use of a higher-level, messaging protocol
(for example, STOMP), through the Sec-WebSocket-Protocol
header on the HTTP handshake request.
In the absence of that, they need to come up with their own conventions.
3.1.2. When to Use WebSockets
WebSockets can make a web page be dynamic and interactive. However, in many cases, a combination of Ajax and HTTP streaming or long polling can provide a simple and effective solution.
For example, news, mail, and social feeds need to update dynamically, but it may be perfectly okay to do so every few minutes. Collaboration, games, and financial apps, on the other hand, need to be much closer to real-time.
Latency alone is not a deciding factor. If the volume of messages is relatively low (for example, monitoring network failures) HTTP streaming or polling can provide an effective solution. It is the combination of low latency, high frequency, and high volume that make the best case for the use of WebSocket.
Keep in mind also that over the Internet, restrictive proxies that are outside of your control
may preclude WebSocket interactions, either because they are not configured to pass on the
Upgrade
header or because they close long-lived connections that appear idle. This
means that the use of WebSocket for internal applications within the firewall is a more
straightforward decision than it is for public facing applications.
3.2. WebSocket API
The Spring Framework provides a WebSocket API that you can use to write client- and server-side applications that handle WebSocket messages.
3.2.1. Server
To create a WebSocket server, you can first create a WebSocketHandler
import org.springframework.web.reactive.socket.WebSocketHandler;
import org.springframework.web.reactive.socket.WebSocketSession;
public class MyWebSocketHandler implements WebSocketHandler {
public Mono<Void> handle(WebSocketSession session) {
class MyWebSocketHandler : WebSocketHandler {
override fun handle(session: WebSocketSession): Mono<Void> {
Then you can map it to a URL:
class WebConfig {
public HandlerMapping handlerMapping() {
Map<String, WebSocketHandler> map = new HashMap<>();
map.put("/path", new MyWebSocketHandler());
int order = -1; // before annotated controllers
return new SimpleUrlHandlerMapping(map, order);
class WebConfig {
fun handlerMapping(): HandlerMapping {
val map = mapOf("/path" to MyWebSocketHandler())
val order = -1 // before annotated controllers
return SimpleUrlHandlerMapping(map, order)
If using the WebFlux Config there is nothing
further to do, or otherwise if not using the WebFlux config you’ll need to declare a
as shown below:
class WebConfig {
public WebSocketHandlerAdapter handlerAdapter() {
return new WebSocketHandlerAdapter();
class WebConfig {
fun handlerAdapter() = WebSocketHandlerAdapter()
3.2.2. WebSocketHandler
The handle
method of WebSocketHandler
takes WebSocketSession
and returns Mono<Void>
to indicate when application handling of the session is complete. The session is handled
through two streams, one for inbound and one for outbound messages. The following table
describes the two methods that handle the streams:
WebSocketSession method |
Description |
Provides access to the inbound message stream and completes when the connection is closed. |
Takes a source for outgoing messages, writes the messages, and returns a |
A WebSocketHandler
must compose the inbound and outbound streams into a unified flow and
return a Mono<Void>
that reflects the completion of that flow. Depending on application
requirements, the unified flow completes when:
Either the inbound or the outbound message stream completes.
The inbound stream completes (that is, the connection closed), while the outbound stream is infinite.
At a chosen point, through the
close
method ofWebSocketSession
When inbound and outbound message streams are composed together, there is no need to check if the connection is open, since Reactive Streams signals end activity. The inbound stream receives a completion or error signal, and the outbound stream receives a cancellation signal.
The most basic implementation of a handler is one that handles the inbound stream. The following example shows such an implementation:
class ExampleHandler implements WebSocketHandler {
return session.receive() (1)
.doOnNext(message -> {
// ... (2)
.concatMap(message -> {
// ... (3)
.then(); (4)
1 | Access the stream of inbound messages. |
2 | Do something with each message. |
3 | Perform nested asynchronous operations that use the message content. |
4 | Return a Mono<Void> that completes when receiving completes. |
class ExampleHandler : WebSocketHandler {
.doOnNext {
// ... (2)
.concatMap {
// ... (3)
.then() (4)
For nested, asynchronous operations, you may need to call message.retain() on underlying
servers that use pooled data buffers (for example, Netty). Otherwise, the data buffer may be
released before you have had a chance to read the data. For more background, see
Data Buffers and Codecs.
The following implementation combines the inbound and outbound streams:
Flux<WebSocketMessage> output = session.receive() (1)
.map(value -> session.textMessage("Echo " + value)); (2)
return session.send(output); (3)
1 | Handle the inbound message stream. |
2 | Create the outbound message, producing a combined flow. |
3 | Return a Mono<Void> that does not complete while we continue to receive. |
val output = session.receive() (1)
.doOnNext {
.concatMap {
.map { session.textMessage("Echo $it") } (2)
return session.send(output) (3)
Inbound and outbound streams can be independent and be joined only for completion, as the following example shows:
Mono<Void> input = session.receive() (1)
.then();
Flux<String> source = ... ;
Mono<Void> output = session.send(source.map(session::textMessage)); (2)
return Mono.zip(input, output).then(); (3)
1 | Handle inbound message stream. |
2 | Send outgoing messages. |
3 | Join the streams and return a Mono<Void> that completes when either stream ends. |
val input = session.receive() (1)
.doOnNext {
.concatMap {
.then()
val source: Flux<String> = ...
val output = session.send(source.map(session::textMessage)) (2)
return Mono.zip(input, output).then() (3)
3.2.3. DataBuffer
DataBuffer
is the representation for a byte buffer in WebFlux. The Spring Core part of
the reference has more on that in the section on
Data Buffers and Codecs. The key point to understand is that on some
servers like Netty, byte buffers are pooled and reference counted, and must be released
when consumed to avoid memory leaks.
When running on Netty, applications must use DataBufferUtils.retain(dataBuffer)
if they
wish to hold on input data buffers in order to ensure they are not released, and
subsequently use DataBufferUtils.release(dataBuffer)
when the buffers are consumed.
3.2.4. Handshake
delegates to a WebSocketService
. By default, that is an instance
of HandshakeWebSocketService
, which performs basic checks on the WebSocket request and
then uses RequestUpgradeStrategy
for the server in use. Currently, there is built-in
support for Reactor Netty, Tomcat, Jetty, and Undertow.
exposes a sessionAttributePredicate
property that allows
setting a Predicate<String>
to extract attributes from the WebSession
and insert them
into the attributes of the WebSocketSession
3.2.5. Server Configuration
The RequestUpgradeStrategy
for each server exposes configuration specific to the
underlying WebSocket server engine. When using the WebFlux Java config you can customize
such properties as shown in the corresponding section of the
WebFlux Config, or otherwise if
not using the WebFlux config, use the below:
class WebConfig {
return new WebSocketHandlerAdapter(webSocketService());
public WebSocketService webSocketService() {
class WebConfig {
Check the upgrade strategy for your server to see what options are available. Currently, only Tomcat and Jetty expose such options.
3.2.6. CORS
The easiest way to configure CORS and restrict access to a WebSocket endpoint is to
have your WebSocketHandler
implement CorsConfigurationSource
and return a
CorsConfiguration
with allowed origins, headers, and other details. If you cannot do
that, you can also set the corsConfigurations
property on the SimpleUrlHandler
to
specify CORS settings by URL pattern. If both are specified, they are combined by using the
combine
method on CorsConfiguration
3.2.7. Client
Spring WebFlux provides a WebSocketClient
abstraction with implementations for
Reactor Netty, Tomcat, Jetty, Undertow, and standard Java (that is, JSR-356).
The Tomcat client is effectively an extension of the standard Java one with some extra
functionality in the WebSocketSession handling to take advantage of the Tomcat-specific
API to suspend receiving messages for back pressure.
To start a WebSocket session, you can create an instance of the client and use its execute
methods:
WebSocketClient client = new ReactorNettyWebSocketClient();
URI url = new URI("ws://localhost:8080/path");
client.execute(url, session ->
session.receive()
.doOnNext(System.out::println)
.then());
val client = ReactorNettyWebSocketClient()
val url = URI("ws://localhost:8080/path")
client.execute(url) { session ->
session.receive()
.doOnNext(::println)
.then()
Some clients, such as Jetty, implement Lifecycle
and need to be stopped and started
before you can use them. All clients have constructor options related to configuration
of the underlying WebSocket client.
4. Testing
The spring-test
module provides mock implementations of ServerHttpRequest
ServerHttpResponse
, and ServerWebExchange
See Spring Web Reactive for a
discussion of mock objects.
WebTestClient
builds on these mock request and
response objects to provide support for testing WebFlux applications without an HTTP
server. You can use the WebTestClient
for end-to-end integration tests, too.
5. RSocket
This section describes Spring Framework’s support for the RSocket protocol.
5.1. Overview
RSocket is an application protocol for multiplexed, duplex communication over TCP, WebSocket, and other byte stream transports, using one of the following interaction models:
Request-Response
— send one message and receive one back. -
Request-Stream
— send one message and receive a stream of messages back. -
Channel
— send streams of messages in both directions. -
Fire-and-Forget
— send a one-way message.
Once the initial connection is made, the "client" vs "server" distinction is lost as both sides become symmetrical and each side can initiate one of the above interactions. This is why in the protocol calls the participating sides "requester" and "responder" while the above interactions are called "request streams" or simply "requests".
These are the key features and benefits of the RSocket protocol:
Reactive Streams semantics across network boundary — for streaming requests such as
Request-Stream
andChannel
, back pressure signals travel between requester and responder, allowing a requester to slow down a responder at the source, hence reducing reliance on network layer congestion control, and the need for buffering at the network level or at any level. -
Request throttling — this feature is named "Leasing" after the
LEASE
frame that can be sent from each end to limit the total number of requests allowed by other end for a given time. Leases are renewed periodically. -
Session resumption — this is designed for loss of connectivity and requires some state to be maintained. The state management is transparent for applications, and works well in combination with back pressure which can stop a producer when possible and reduce the amount of state required.
Fragmentation and re-assembly of large messages.
Keepalive (heartbeats).
RSocket has implementations in multiple languages. The Java library is built on Project Reactor, and Reactor Netty for the transport. That means signals from Reactive Streams Publishers in your application propagate transparently through RSocket across the network.
5.1.1. The Protocol
One of the benefits of RSocket is that it has well defined behavior on the wire and an easy to read specification along with some protocol extensions. Therefore it is a good idea to read the spec, independent of language implementations and higher level framework APIs. This section provides a succinct overview to establish some context.
Connecting
Initially a client connects to a server via some low level streaming transport such
as TCP or WebSocket and sends a SETUP
frame to the server to set parameters for the
connection.
The server may reject the SETUP
frame, but generally after it is sent (for the client)
and received (for the server), both sides can begin to make requests, unless SETUP
indicates use of leasing semantics to limit the number of requests, in which case
both sides must wait for a LEASE
frame from the other end to permit making requests.
Making Requests
Once a connection is established, both sides may initiate a request through one of the
frames REQUEST_RESPONSE
, REQUEST_STREAM
, REQUEST_CHANNEL
, or REQUEST_FNF
. Each of
those frames carries one message from the requester to the responder.
The responder may then return PAYLOAD
frames with response messages, and in the case
of REQUEST_CHANNEL
the requester may also send PAYLOAD
frames with more request
messages.
When a request involves a stream of messages such as Request-Stream
and Channel
the responder must respect demand signals from the requester. Demand is expressed as a
number of messages. Initial demand is specified in REQUEST_STREAM
and
REQUEST_CHANNEL
frames. Subsequent demand is signaled via REQUEST_N
frames.
Each side may also send metadata notifications, via the METADATA_PUSH
frame, that do not
pertain to any individual request but rather to the connection as a whole.
Message Format
RSocket messages contain data and metadata. Metadata can be used to send a route, a
security token, etc. Data and metadata can be formatted differently. Mime types for each
are declared in the SETUP
frame and apply to all requests on a given connection.
While all messages can have metadata, typically metadata such as a route are per-request
and therefore only included in the first message on a request, i.e. with one of the frames
REQUEST_RESPONSE
, REQUEST_STREAM
, REQUEST_CHANNEL
, or REQUEST_FNF
Protocol extensions define common metadata formats for use in applications:
Composite Metadata-- multiple, independently formatted metadata entries.
Routing — the route for a request.
5.1.2. Java Implementation
The Java implementation for RSocket is built on
Project Reactor. The transports for TCP and WebSocket are
built on Reactor Netty. As a Reactive Streams
library, Reactor simplifies the job of implementing the protocol. For applications it is
a natural fit to use Flux
and Mono
with declarative operators and transparent back
pressure support.
The API in RSocket Java is intentionally minimal and basic. It focuses on protocol features and leaves the application programming model (e.g. RPC codegen vs other) as a higher level, independent concern.
The main contract
io.rsocket.RSocket
models the four request interaction types with Mono
representing a promise for a
single message, Flux
a stream of messages, and io.rsocket.Payload
the actual
message with access to data and metadata as byte buffers. The RSocket
contract is used
symmetrically. For requesting, the application is given an RSocket
to perform
requests with. For responding, the application implements RSocket
to handle requests.
This is not meant to be a thorough introduction. For the most part, Spring applications will not have to use its API directly. However it may be important to see or experiment with RSocket independent of Spring. The RSocket Java repository contains a number of sample apps that demonstrate its API and protocol features.
5.1.3. Spring Support
The spring-messaging
module contains the following:
RSocketRequester — fluent API to make requests through an
io.rsocket.RSocket
with data and metadata encoding/decoding. -
Annotated Responders —
@MessageMapping
annotated handler methods for responding.
The spring-web
module contains Encoder
and Decoder
implementations such as Jackson
CBOR/JSON, and Protobuf that RSocket applications will likely need. It also contains the
PathPatternParser
that can be plugged in for efficient route matching.
Spring Boot 2.2 supports standing up an RSocket server over TCP or WebSocket, including
the option to expose RSocket over WebSocket in a WebFlux server. There is also client
support and auto-configuration for an RSocketRequester.Builder
and RSocketStrategies
See the
RSocket section
in the Spring Boot reference for more details.
Spring Security 5.2 provides RSocket support.
Spring Integration 5.2 provides inbound and outbound gateways to interact with RSocket clients and servers. See the Spring Integration Reference Manual for more details.
Spring Cloud Gateway supports RSocket connections.
5.2. RSocketRequester
RSocketRequester
provides a fluent API to perform RSocket requests, accepting and
returning objects for data and metadata instead of low level data buffers. It can be used
symmetrically, to make requests from clients and to make requests from servers.
5.2.1. Client Requester
To obtain an RSocketRequester
on the client side is to connect to a server which involves
sending an RSocket SETUP
frame with connection settings. RSocketRequester
provides a
builder that helps to prepare an io.rsocket.core.RSocketConnector
including connection
settings for the SETUP
frame.
This is the most basic way to connect with default settings:
RSocketRequester requester = RSocketRequester.builder().tcp("localhost", 7000);
URI url = URI.create("https://example.org:8080/rsocket");
RSocketRequester requester = RSocketRequester.builder().webSocket(url);
val requester = RSocketRequester.builder().tcp("localhost", 7000)
val requester = RSocketRequester.builder().webSocket(url)
The above does not connect immediately. When requests are made, a shared connection is established transparently and used.
Connection Setup
provides the following to customize the initial SETUP
frame:
dataMimeType(MimeType)
— set the mime type for data on the connection. -
metadataMimeType(MimeType)
— set the mime type for metadata on the connection. -
setupData(Object)
— data to include in theSETUP
setupRoute(String, Object…)
— route in the metadata to include in theSETUP
setupMetadata(Object, MimeType)
— other metadata to include in theSETUP
For data, the default mime type is derived from the first configured Decoder
. For
metadata, the default mime type is
composite metadata which allows multiple
metadata value and mime type pairs per request. Typically both don’t need to be changed.
Data and metadata in the SETUP
frame is optional. On the server side,
@ConnectMapping methods can be used to handle the start of a
connection and the content of the SETUP
frame. Metadata may be used for connection
level security.
Strategies
accepts RSocketStrategies
to configure the requester.
You’ll need to use this to provide encoders and decoders for (de)-serialization of data and
metadata values. By default only the basic codecs from spring-core
for String
byte[]
, and ByteBuffer
are registered. Adding spring-web
provides access to more that
can be registered as follows:
RSocketStrategies strategies = RSocketStrategies.builder()
.encoders(encoders -> encoders.add(new Jackson2CborEncoder()))
.decoders(decoders -> decoders.add(new Jackson2CborDecoder()))
.rsocketStrategies(strategies)
val strategies = RSocketStrategies.builder()
.encoders { it.add(Jackson2CborEncoder()) }
.decoders { it.add(Jackson2CborDecoder()) }
.build()
RSocketStrategies
is designed for re-use. In some scenarios, e.g. client and server in
the same application, it may be preferable to declare it in Spring configuration.
Client Responders
can be used to configure responders to requests from the
server.
You can use annotated handlers for client-side responding based on the same infrastructure that’s used on a server, but registered programmatically as follows:
.routeMatcher(new PathPatternRouteMatcher()) (1)
SocketAcceptor responder =
RSocketMessageHandler.responder(strategies, new ClientHandler()); (2)
.rsocketConnector(connector -> connector.acceptor(responder)) (3)
1 | Use PathPatternRouteMatcher , if spring-web is present, for efficient
route matching. |
2 | Create a responder from a class with @MessageMapping and/or @ConnectMapping methods. |
3 | Register the responder. |
.routeMatcher(PathPatternRouteMatcher()) (1)
.build()
val responder =
.rsocketConnector { it.acceptor(responder) } (3)
route matching. |
Note the above is only a shortcut designed for programmatic registration of client
responders. For alternative scenarios, where client responders are in Spring configuration,
you can still declare RSocketMessageHandler
as a Spring bean and then apply as follows:
ApplicationContext context = ... ;
RSocketMessageHandler handler = context.getBean(RSocketMessageHandler.class);
.rsocketConnector(connector -> connector.acceptor(handler.responder()))
import org.springframework.beans.factory.getBean
val context: ApplicationContext = ...
val handler = context.getBean<RSocketMessageHandler>()
.rsocketConnector { it.acceptor(handler.responder()) }
For the above you may also need to use setHandlerPredicate
in RSocketMessageHandler
to
switch to a different strategy for detecting client responders, e.g. based on a custom
annotation such as @RSocketClientResponder
vs the default @Controller
. This
is necessary in scenarios with client and server, or multiple clients in the same
application.
See also Annotated Responders, for more on the programming model.
Advanced
RSocketRequesterBuilder
provides a callback to expose the underlying
for further configuration options for keepalive
intervals, session resumption, interceptors, and more. You can configure options
at that level as follows:
.rsocketConnector(connector -> {
.rsocketConnector {
5.2.2. Server Requester
To make requests from a server to connected clients is a matter of obtaining the requester for the connected client from the server.
In Annotated Responders, @ConnectMapping
and @MessageMapping
methods support an
RSocketRequester
argument. Use it to access the requester for the connection. Keep in
mind that @ConnectMapping
methods are essentially handlers of the SETUP
frame which
must be handled before requests can begin. Therefore, requests at the very start must be
decoupled from handling. For example:
@ConnectMapping
Mono<Void> handle(RSocketRequester requester) {
requester.route("status").data("5")
.retrieveFlux(StatusReport.class)
.subscribe(bar -> { (1)
return ... (2)
1 | Start the request asynchronously, independent from handling. |
2 | Perform handling and return completion Mono<Void> . |
@ConnectMapping
suspend fun handle(requester: RSocketRequester) {
GlobalScope.launch {
requester.route("status").data("5").retrieveFlow<StatusReport>().collect { (1)
/// ... (2)
2 | Perform handling in the suspending function. |
5.2.3. Requests
ViewBox viewBox = ... ;
Flux<AirportLocation> locations = requester.route("locate.radars.within") (1)
.data(viewBox) (2)
.retrieveFlux(AirportLocation.class); (3)
1 | Specify a route to include in the metadata of the request message. |
2 | Provide data for the request message. |
3 | Declare the expected response. |
val viewBox: ViewBox = ...
val locations = requester.route("locate.radars.within") (1)
.data(viewBox) (2)
.retrieveFlow<AirportLocation>() (3)
The interaction type is determined implicitly from the cardinality of the input and
output. The above example is a Request-Stream
because one value is sent and a stream
of values is received. For the most part you don’t need to think about this as long as the
choice of input and output matches an RSocket interaction type and the types of input and
output expected by the responder. The only example of an invalid combination is many-to-one.
The data(Object)
method also accepts any Reactive Streams Publisher
, including
Flux
and Mono
, as well as any other producer of value(s) that is registered in the
. For a multi-value Publisher
such as Flux
which produces the
same types of values, consider using one of the overloaded data
methods to avoid having
type checks and Encoder
lookup on every element:
data(Object producer, Class<?> elementClass);
data(Object producer, ParameterizedTypeReference<?> elementTypeRef);
The data(Object)
step is optional. Skip it for requests that don’t send data:
Mono<AirportLocation> location = requester.route("find.radar.EWR"))
.retrieveMono(AirportLocation.class);
import org.springframework.messaging.rsocket.retrieveAndAwait
val location = requester.route("find.radar.EWR")
.retrieveAndAwait<AirportLocation>()
Extra metadata values can be added if using
composite metadata (the default) and if the
values are supported by a registered Encoder
. For example:
String securityToken = ... ;
MimeType mimeType = MimeType.valueOf("message/x.rsocket.authentication.bearer.v0");
.metadata(securityToken, mimeType)
.data(viewBox)
import org.springframework.messaging.rsocket.retrieveFlow
val requester: RSocketRequester = ...
val securityToken: String = ...
val mimeType = MimeType.valueOf("message/x.rsocket.authentication.bearer.v0")
.data(viewBox)
For Fire-and-Forget
use the send()
method that returns Mono<Void>
. Note that the Mono
indicates only that the message was successfully sent, and not that it was handled.
For Metadata-Push
use the sendMetadata()
method with a Mono<Void>
return value.
5.3. Annotated Responders
RSocket responders can be implemented as @MessageMapping
and @ConnectMapping
methods.
@MessageMapping
methods handle individual requests while @ConnectMapping
methods handle
connection-level events (setup and metadata push). Annotated responders are supported
symmetrically, for responding from the server side and for responding from the client side.
5.3.1. Server Responders
To use annotated responders on the server side, add RSocketMessageHandler
to your Spring
configuration to detect @Controller
beans with @MessageMapping
and @ConnectMapping
methods:
static class ServerConfig {
public RSocketMessageHandler rsocketMessageHandler() {
RSocketMessageHandler handler = new RSocketMessageHandler();
handler.routeMatcher(new PathPatternRouteMatcher());
return handler;
fun rsocketMessageHandler() = RSocketMessageHandler().apply {
routeMatcher = PathPatternRouteMatcher()
Then start an RSocket server through the Java RSocket API and plug the
for the responder as follows:
CloseableChannel server =
RSocketServer.create(handler.responder())
.bind(TcpServerTransport.create("localhost", 7000))
.block();
val server = RSocketServer.create(handler.responder())
.awaitSingle()
supports
composite and
routing metadata by default. You can set its
MetadataExtractor if you need to switch to a
different mime type or register additional metadata mime types.
You’ll need to set the Encoder
and Decoder
instances required for metadata and data
formats to support. You’ll likely need the spring-web
module for codec implementations.
By default SimpleRouteMatcher
is used for matching routes via AntPathMatcher
We recommend plugging in the PathPatternRouteMatcher
from spring-web
for
efficient route matching. RSocket routes can be hierarchical but are not URL paths.
Both route matchers are configured to use "." as separator by default and there is no URL
decoding as with HTTP URLs.
can be configured via RSocketStrategies
which may be useful if
you need to share configuration between a client and a server in the same process:
handler.setRSocketStrategies(rsocketStrategies());
return handler;
public RSocketStrategies rsocketStrategies() {
return RSocketStrategies.builder()
rSocketStrategies = rsocketStrategies()
fun rsocketStrategies() = RSocketStrategies.builder()
.build()
5.3.2. Client Responders
Annotated responders on the client side need to be configured in the
. For details, see
Client Responders.
5.3.3. @MessageMapping
Once server or
client responder configuration is in place,
@MessageMapping
methods can be used as follows:
@Controller
public class RadarsController {
@MessageMapping("locate.radars.within")
public Flux<AirportLocation> radars(MapRequest request) {
@Controller
fun radars(request: MapRequest): Flow<AirportLocation> {
The above @MessageMapping
method responds to a Request-Stream interaction having the
route "locate.radars.within". It supports a flexible method signature with the option to
use the following method arguments:
Method Argument | Description |
The payload of the request. This can be a concrete value of asynchronous types like
Note: Use of the annotation is optional. A method argument that is not a simple type and is not any of the other supported arguments, is assumed to be the expected payload. |
Requester for making requests to the remote end. |
Value extracted from the route based on variables in the mapping pattern, e.g.
Metadata value registered for extraction as described in MetadataExtractor. |
All metadata values registered for extraction as described in MetadataExtractor. |
The return value is expected to be one or more Objects to be serialized as response
payloads. That can be asynchronous types like Mono
or Flux
, a concrete value, or
either void
or a no-value asynchronous type such as Mono<Void>
The RSocket interaction type that an @MessageMapping
method supports is determined from
the cardinality of the input (i.e. @Payload
argument) and of the output, where
cardinality means the following:
Cardinality | Description |
1 |
Either an explicit value, or a single-value asynchronous type such as |
Many |
A multi-value asynchronous type such as |
0 |
For input this means the method does not have an For output this is |
The table below shows all input and output cardinality combinations and the corresponding interaction type(s):
Input Cardinality | Output Cardinality | Interaction Types |
0, 1 |
0 |
Fire-and-Forget, Request-Response |
0, 1 |
1 |
Request-Response |
0, 1 |
Many |
Request-Stream |
Many |
0, 1, Many |
Request-Channel |
5.3.4. @ConnectMapping
@ConnectMapping
handles the SETUP
frame at the start of an RSocket connection, and
any subsequent metadata push notifications through the METADATA_PUSH
frame, i.e.
metadataPush(Payload)
in io.rsocket.RSocket
@ConnectMapping
methods support the same arguments as
@MessageMapping but based on metadata and data from the SETUP
and
METADATA_PUSH
frames. @ConnectMapping
can have a pattern to narrow handling to
specific connections that have a route in the metadata, or if no patterns are declared
then all connections match.
@ConnectMapping
methods cannot return data and must be declared with void
or
Mono<Void>
as the return value. If handling returns an error for a new
connection then the connection is rejected. Handling must not be held up to make
requests to the RSocketRequester
for the connection. See
Server Requester for details.
5.4. MetadataExtractor
Responders must interpret metadata. Composite metadata allows independently formatted metadata values (e.g. for routing, security, tracing) each with its own mime type. Applications need a way to configure metadata mime types to support, and a way to access extracted values.
MetadataExtractor
is a contract to take serialized metadata and return decoded
name-value pairs that can then be accessed like headers by name, for example via @Header
in annotated handler methods.
DefaultMetadataExtractor
can be given Decoder
instances to decode metadata. Out of
the box it has built-in support for
"message/x.rsocket.routing.v0" which it decodes to
String
and saves under the "route" key. For any other mime type you’ll need to provide
a Decoder
and register the mime type as follows:
DefaultMetadataExtractor extractor = new DefaultMetadataExtractor(metadataDecoders);
extractor.metadataToExtract(fooMimeType, Foo.class, "foo");
import org.springframework.messaging.rsocket.metadataToExtract
val extractor = DefaultMetadataExtractor(metadataDecoders)
extractor.metadataToExtract<Foo>(fooMimeType, "foo")
Composite metadata works well to combine independent metadata values. However the
requester might not support composite metadata, or may choose not to use it. For this,
may needs custom logic to map the decoded value to the output
map. Here is an example where JSON is used for metadata:
MimeType.valueOf("application/vnd.myapp.metadata+json"),
new ParameterizedTypeReference<Map<String,String>>() {},
(jsonMap, outputMap) -> {
outputMap.putAll(jsonMap);
extractor.metadataToExtract<Map<String, String>>(MimeType.valueOf("application/vnd.myapp.metadata+json")) { jsonMap, outputMap ->
When configuring MetadataExtractor
through RSocketStrategies
, you can let
RSocketStrategies.Builder
create the extractor with the configured decoders, and
simply use a callback to customize registrations as follows:
.metadataExtractorRegistry(registry -> {
registry.metadataToExtract(fooMimeType, Foo.class, "foo");
.metadataExtractorRegistry { registry: MetadataExtractorRegistry ->
registry.metadataToExtract<Foo>(fooMimeType, "foo")
.build()
6. Reactive Libraries
spring-webflux
depends on reactor-core
and uses it internally to compose asynchronous
logic and to provide Reactive Streams support. Generally, WebFlux APIs return Flux
or
Mono
(since those are used internally) and leniently accept any Reactive Streams
Publisher
implementation as input. The use of Flux
versus Mono
is important, because
it helps to express cardinality — for example, whether a single or multiple asynchronous
values are expected, and that can be essential for making decisions (for example, when
encoding or decoding HTTP messages).
For annotated controllers, WebFlux transparently adapts to the reactive library chosen
by the application. This is done with the help of the
which provides pluggable support for reactive library and other asynchronous types.
The registry has built-in support for RxJava 3, Kotlin coroutines and SmallRye Mutiny,
but you can register other third-party adapters as well.
As of Spring Framework 5.3.11, support for RxJava 1 and 2 is deprecated, following RxJava’s own EOL advice and the upgrade recommendation towards RxJava 3. |
For functional APIs (such as Functional Endpoints, the WebClient
, and others), the general
rules for WebFlux APIs apply — Flux
and Mono
as return values and a Reactive Streams
Publisher
as input. When a Publisher
, whether custom or from another reactive library,
is provided, it can be treated only as a stream with unknown semantics (0..N). If, however,
the semantics are known, you can wrap it with Flux
or Mono.from(Publisher)
instead
of passing the raw Publisher
For example, given a Publisher
that is not a Mono
, the Jackson JSON message writer
expects multiple values. If the media type implies an infinite stream (for example,
application/json+stream
), values are written and flushed individually. Otherwise,
values are buffered into a list and rendered as a JSON array.
