Data Access
1. Transaction Management
Comprehensive transaction support is among the most compelling reasons to use the Spring Framework. The Spring Framework provides a consistent abstraction for transaction management that delivers the following benefits:
A consistent programming model across different transaction APIs, such as Java Transaction API (JTA), JDBC, Hibernate, and the Java Persistence API (JPA).
Support for declarative transaction management.
A simpler API for programmatic transaction management than complex transaction APIs, such as JTA.
Excellent integration with Spring’s data access abstractions.
The following sections describe the Spring Framework’s transaction features and technologies:
Advantages of the Spring Framework’s transaction support model describes why you would use the Spring Framework’s transaction abstraction instead of EJB Container-Managed Transactions (CMT) or choosing to drive local transactions through a proprietary API, such as Hibernate.
Understanding the Spring Framework transaction abstraction outlines the core classes and describes how to configure and obtain
DataSource
instances from a variety of sources. -
Synchronizing resources with transactions describes how the application code ensures that resources are created, reused, and cleaned up properly.
Declarative transaction management describes support for declarative transaction management.
Programmatic transaction management covers support for programmatic (that is, explicitly coded) transaction management.
Transaction bound event describes how you could use application events within a transaction.
The chapter also includes discussions of best practices, application server integration, and solutions to common problems.
1.1. Advantages of the Spring Framework’s Transaction Support Model
Traditionally, Java EE developers have had two choices for transaction management: global or local transactions, both of which have profound limitations. Global and local transaction management is reviewed in the next two sections, followed by a discussion of how the Spring Framework’s transaction management support addresses the limitations of the global and local transaction models.
1.1.1. Global Transactions
Global transactions let you work with multiple transactional resources, typically
relational databases and message queues. The application server manages global
transactions through the JTA, which is a cumbersome API (partly due to its
exception model). Furthermore, a JTA UserTransaction
normally needs to be sourced from
JNDI, meaning that you also need to use JNDI in order to use JTA. The use
of global transactions limits any potential reuse of application code, as JTA is
normally only available in an application server environment.
Previously, the preferred way to use global transactions was through EJB CMT (Container Managed Transaction). CMT is a form of declarative transaction management (as distinguished from programmatic transaction management). EJB CMT removes the need for transaction-related JNDI lookups, although the use of EJB itself necessitates the use of JNDI. It removes most but not all of the need to write Java code to control transactions. The significant downside is that CMT is tied to JTA and an application server environment. Also, it is only available if one chooses to implement business logic in EJBs (or at least behind a transactional EJB facade). The negatives of EJB in general are so great that this is not an attractive proposition, especially in the face of compelling alternatives for declarative transaction management.
1.1.2. Local Transactions
Local transactions are resource-specific, such as a transaction associated with a JDBC connection. Local transactions may be easier to use but have a significant disadvantage: They cannot work across multiple transactional resources. For example, code that manages transactions by using a JDBC connection cannot run within a global JTA transaction. Because the application server is not involved in transaction management, it cannot help ensure correctness across multiple resources. (It is worth noting that most applications use a single transaction resource.) Another downside is that local transactions are invasive to the programming model.
1.1.3. Spring Framework’s Consistent Programming Model
Spring resolves the disadvantages of global and local transactions. It lets application developers use a consistent programming model in any environment. You write your code once, and it can benefit from different transaction management strategies in different environments. The Spring Framework provides both declarative and programmatic transaction management. Most users prefer declarative transaction management, which we recommend in most cases.
With programmatic transaction management, developers work with the Spring Framework transaction abstraction, which can run over any underlying transaction infrastructure. With the preferred declarative model, developers typically write little or no code related to transaction management and, hence, do not depend on the Spring Framework transaction API or any other transaction API.
1.2. Understanding the Spring Framework Transaction Abstraction
The key to the Spring transaction abstraction is the notion of a transaction strategy. A
transaction strategy is defined by a TransactionManager
, specifically the
org.springframework.transaction.PlatformTransactionManager
interface for imperative
transaction management and the
org.springframework.transaction.ReactiveTransactionManager
interface for reactive
transaction management. The following listing shows the definition of the
API:
public interface PlatformTransactionManager extends TransactionManager {
TransactionStatus getTransaction(TransactionDefinition definition) throws TransactionException;
void commit(TransactionStatus status) throws TransactionException;
void rollback(TransactionStatus status) throws TransactionException;
This is primarily a service provider interface (SPI), although you can use it
programmatically from your application code. Because
is an interface, it can be easily mocked or stubbed as
necessary. It is not tied to a lookup strategy, such as JNDI.
implementations are defined like any other object (or bean)
in the Spring Framework IoC container. This benefit alone makes Spring Framework
transactions a worthwhile abstraction, even when you work with JTA. You can test
transactional code much more easily than if it used JTA directly.
Again, in keeping with Spring’s philosophy, the TransactionException
that can be thrown
by any of the PlatformTransactionManager
interface’s methods is unchecked (that
is, it extends the java.lang.RuntimeException
class). Transaction infrastructure
failures are almost invariably fatal. In rare cases where application code can actually
recover from a transaction failure, the application developer can still choose to catch
and handle TransactionException
. The salient point is that developers are not
forced to do so.
The getTransaction(..)
method returns a TransactionStatus
object, depending on a
parameter. The returned TransactionStatus
might represent a
new transaction or can represent an existing transaction, if a matching transaction
exists in the current call stack. The implication in this latter case is that, as with
Java EE transaction contexts, a TransactionStatus
is associated with a thread of
execution.
As of Spring Framework 5.2, Spring also provides a transaction management abstraction for
reactive applications that make use of reactive types or Kotlin Coroutines. The following
listing shows the transaction strategy defined by
public interface ReactiveTransactionManager extends TransactionManager {
Mono<ReactiveTransaction> getReactiveTransaction(TransactionDefinition definition) throws TransactionException;
Mono<Void> commit(ReactiveTransaction status) throws TransactionException;
Mono<Void> rollback(ReactiveTransaction status) throws TransactionException;
The reactive transaction manager is primarily a service provider interface (SPI),
although you can use it programmatically from your
application code. Because ReactiveTransactionManager
mocked or stubbed as necessary.
The TransactionDefinition
interface specifies:
Propagation: Typically, all code within a transaction scope runs in that transaction. However, you can specify the behavior if a transactional method is run when a transaction context already exists. For example, code can continue running in the existing transaction (the common case), or the existing transaction can be suspended and a new transaction created. Spring offers all of the transaction propagation options familiar from EJB CMT. To read about the semantics of transaction propagation in Spring, see Transaction Propagation.
Isolation: The degree to which this transaction is isolated from the work of other transactions. For example, can this transaction see uncommitted writes from other transactions?
Timeout: How long this transaction runs before timing out and being automatically rolled back by the underlying transaction infrastructure.
Read-only status: You can use a read-only transaction when your code reads but does not modify data. Read-only transactions can be a useful optimization in some cases, such as when you use Hibernate.
These settings reflect standard transactional concepts. If necessary, refer to resources that discuss transaction isolation levels and other core transaction concepts. Understanding these concepts is essential to using the Spring Framework or any transaction management solution.
The TransactionStatus
interface provides a simple way for transactional code to
control transaction execution and query transaction status. The concepts should be
familiar, as they are common to all transaction APIs. The following listing shows the
TransactionStatus
interface:
public interface TransactionStatus extends TransactionExecution, SavepointManager, Flushable {
boolean isNewTransaction();
boolean hasSavepoint();
void setRollbackOnly();
boolean isRollbackOnly();
void flush();
boolean isCompleted();
Regardless of whether you opt for declarative or programmatic transaction management in
Spring, defining the correct TransactionManager
implementation is absolutely essential.
You typically define this implementation through dependency injection.
TransactionManager
implementations normally require knowledge of the environment in
which they work: JDBC, JTA, Hibernate, and so on. The following examples show how you can
define a local PlatformTransactionManager
implementation (in this case, with plain
JDBC.)
You can define a JDBC DataSource
by creating a bean similar to the following:
<bean id="dataSource" class="org.apache.commons.dbcp.BasicDataSource" destroy-method="close">
<property name="driverClassName" value="${jdbc.driverClassName}" />
<property name="url" value="${jdbc.url}" />
<property name="username" value="${jdbc.username}" />
<property name="password" value="${jdbc.password}" />
</bean>
The related PlatformTransactionManager
bean definition then has a reference to the
DataSource
definition. It should resemble the following example:
<bean id="txManager" class="org.springframework.jdbc.datasource.DataSourceTransactionManager">
<property name="dataSource" ref="dataSource"/>
</bean>
If you use JTA in a Java EE container, then you use a container DataSource
, obtained
through JNDI, in conjunction with Spring’s JtaTransactionManager
shows what the JTA and JNDI lookup version would look like:
xmlns:jee="http://www.springframework.org/schema/jee"
xsi:schemaLocation="
https://www.springframework.org/schema/jee/spring-jee.xsd">
<jee:jndi-lookup id="dataSource" jndi-name="jdbc/jpetstore"/>
<bean id="txManager" class="org.springframework.transaction.jta.JtaTransactionManager" />
<!-- other <bean/> definitions here -->
</beans>
The JtaTransactionManager
does not need to know about the DataSource
(or any other
specific resources) because it uses the container’s global transaction management
infrastructure.
The preceding definition of the dataSource bean uses the <jndi-lookup/> tag
from the jee namespace. For more information see
The JEE Schema.
If you use JTA, your transaction manager definition should look the same, regardless of what data access technology you use, be it JDBC, Hibernate JPA, or any other supported technology. This is due to the fact that JTA transactions are global transactions, which can enlist any transactional resource. |
In all Spring transaction setups, application code does not need to change. You can change how transactions are managed merely by changing configuration, even if that change means moving from local to global transactions or vice versa.
1.2.1. Hibernate Transaction Setup
You can also easily use Hibernate local transactions, as shown in the following examples.
In this case, you need to define a Hibernate LocalSessionFactoryBean
, which your
application code can use to obtain Hibernate Session
instances.
The DataSource
bean definition is similar to the local JDBC example shown previously
and, thus, is not shown in the following example.
If the DataSource (used by any non-JTA transaction manager) is looked up through
JNDI and managed by a Java EE container, it should be non-transactional, because the
Spring Framework (rather than the Java EE container) manages the transactions.
The txManager
bean in this case is of the HibernateTransactionManager
type. In the
same way as the DataSourceTransactionManager
needs a reference to the DataSource
, the
needs a reference to the SessionFactory
. The following
example declares sessionFactory
and txManager
beans:
<bean id="sessionFactory" class="org.springframework.orm.hibernate5.LocalSessionFactoryBean">
<property name="mappingResources">
<list>
<value>org/springframework/samples/petclinic/hibernate/petclinic.hbm.xml</value>
</list>
</property>
<property name="hibernateProperties">
<value>
hibernate.dialect=${hibernate.dialect}
</value>
</property>
</bean>
<bean id="txManager" class="org.springframework.orm.hibernate5.HibernateTransactionManager">
<property name="sessionFactory" ref="sessionFactory"/>
</bean>
If you use Hibernate and Java EE container-managed JTA transactions, you should use the
same JtaTransactionManager
as in the previous JTA example for JDBC, as the following
example shows. Also, it is recommended to make Hibernate aware of JTA through its
transaction coordinator and possibly also its connection release mode configuration:
<list>
</list>
</property>
<value>
hibernate.transaction.coordinator_class=jta
hibernate.connection.handling_mode=DELAYED_ACQUISITION_AND_RELEASE_AFTER_STATEMENT
</value>
</property>
</bean>
<bean id="txManager" class="org.springframework.transaction.jta.JtaTransactionManager"/>
Or alternatively, you may pass the JtaTransactionManager
into your LocalSessionFactoryBean
for enforcing the same defaults:
<list>
</list>
</property>
<value>
</value>
</property>
<property name="jtaTransactionManager" ref="txManager"/>
</bean>
1.3. Synchronizing Resources with Transactions
How to create different transaction managers and how they are linked to related resources
that need to be synchronized to transactions (for example DataSourceTransactionManager
to a JDBC DataSource
, HibernateTransactionManager
to a Hibernate SessionFactory
and so forth) should now be clear. This section describes how the application code
(directly or indirectly, by using a persistence API such as JDBC, Hibernate, or JPA)
ensures that these resources are created, reused, and cleaned up properly. The section
also discusses how transaction synchronization is (optionally) triggered through the
relevant TransactionManager
1.3.1. High-level Synchronization Approach
The preferred approach is to use Spring’s highest-level template-based persistence
integration APIs or to use native ORM APIs with transaction-aware factory beans or
proxies for managing the native resource factories. These transaction-aware solutions
internally handle resource creation and reuse, cleanup, optional transaction
synchronization of the resources, and exception mapping. Thus, user data access code does
not have to address these tasks but can focus purely on non-boilerplate
persistence logic. Generally, you use the native ORM API or take a template approach
for JDBC access by using the JdbcTemplate
. These solutions are detailed in subsequent
sections of this reference documentation.
1.3.2. Low-level Synchronization Approach
Classes such as DataSourceUtils
(for JDBC), EntityManagerFactoryUtils
(for JPA),
SessionFactoryUtils
(for Hibernate), and so on exist at a lower level. When you want the
application code to deal directly with the resource types of the native persistence APIs,
you use these classes to ensure that proper Spring Framework-managed instances are obtained,
transactions are (optionally) synchronized, and exceptions that occur in the process are
properly mapped to a consistent API.
For example, in the case of JDBC, instead of the traditional JDBC approach of calling
the getConnection()
method on the DataSource
, you can instead use Spring’s
org.springframework.jdbc.datasource.DataSourceUtils
class, as follows:
Connection conn = DataSourceUtils.getConnection(dataSource);
If an existing transaction already has a connection synchronized (linked) to it, that
instance is returned. Otherwise, the method call triggers the creation of a new
connection, which is (optionally) synchronized to any existing transaction and made
available for subsequent reuse in that same transaction. As mentioned earlier, any
SQLException
is wrapped in a Spring Framework CannotGetJdbcConnectionException
, one
of the Spring Framework’s hierarchy of unchecked DataAccessException
types. This approach
gives you more information than can be obtained easily from the SQLException
and
ensures portability across databases and even across different persistence technologies.
This approach also works without Spring transaction management (transaction synchronization is optional), so you can use it whether or not you use Spring for transaction management.
Of course, once you have used Spring’s JDBC support, JPA support, or Hibernate support,
you generally prefer not to use DataSourceUtils
or the other helper classes,
because you are much happier working through the Spring abstraction than directly
with the relevant APIs. For example, if you use the Spring JdbcTemplate
or
jdbc.object
package to simplify your use of JDBC, correct connection retrieval occurs
behind the scenes and you need not write any special code.
1.3.3. TransactionAwareDataSourceProxy
At the very lowest level exists the TransactionAwareDataSourceProxy
class. This is a
proxy for a target DataSource
, which wraps the target DataSource
to add awareness of
Spring-managed transactions. In this respect, it is similar to a transactional JNDI
DataSource
, as provided by a Java EE server.
You should almost never need or want to use this class, except when existing
code must be called and passed a standard JDBC DataSource
interface implementation. In
that case, it is possible that this code is usable but is participating in Spring-managed
transactions. You can write your new code by using the higher-level
abstractions mentioned earlier.
1.4. Declarative Transaction Management
Most Spring Framework users choose declarative transaction management. This option has the least impact on application code and, hence, is most consistent with the ideals of a non-invasive lightweight container. |
The Spring Framework’s declarative transaction management is made possible with Spring aspect-oriented programming (AOP). However, as the transactional aspects code comes with the Spring Framework distribution and may be used in a boilerplate fashion, AOP concepts do not generally have to be understood to make effective use of this code.
The Spring Framework’s declarative transaction management is similar to EJB CMT, in that
you can specify transaction behavior (or lack of it) down to the individual method level.
You can make a setRollbackOnly()
call within a transaction context, if
necessary. The differences between the two types of transaction management are:
Unlike EJB CMT, which is tied to JTA, the Spring Framework’s declarative transaction management works in any environment. It can work with JTA transactions or local transactions by using JDBC, JPA, or Hibernate by adjusting the configuration files.
You can apply the Spring Framework declarative transaction management to any class, not merely special classes such as EJBs.
The Spring Framework offers declarative rollback rules, a feature with no EJB equivalent. Both programmatic and declarative support for rollback rules is provided.
The Spring Framework lets you customize transactional behavior by using AOP. For example, you can insert custom behavior in the case of transaction rollback. You can also add arbitrary advice, along with transactional advice. With EJB CMT, you cannot influence the container’s transaction management, except with
setRollbackOnly()
The Spring Framework does not support propagation of transaction contexts across remote calls, as high-end application servers do. If you need this feature, we recommend that you use EJB. However, consider carefully before using such a feature, because, normally, one does not want transactions to span remote calls.
The concept of rollback rules is important. They let you specify which exceptions
(and throwables) should cause automatic rollback. You can specify this declaratively, in
configuration, not in Java code. So, although you can still call setRollbackOnly()
on
the TransactionStatus
object to roll back the current transaction back, most often you
can specify a rule that MyApplicationException
must always result in rollback. The
significant advantage to this option is that business objects do not depend on the
transaction infrastructure. For example, they typically do not need to import Spring
transaction APIs or other Spring APIs.
Although EJB container default behavior automatically rolls back the transaction on a
system exception (usually a runtime exception), EJB CMT does not roll back the
transaction automatically on an application exception (that is, a checked exception
other than java.rmi.RemoteException
). While the Spring default behavior for
declarative transaction management follows EJB convention (roll back is automatic only
on unchecked exceptions), it is often useful to customize this behavior.
1.4.1. Understanding the Spring Framework’s Declarative Transaction Implementation
It is not sufficient merely to tell you to annotate your classes with the
@Transactional
annotation, add @EnableTransactionManagement
to your configuration,
and expect you to understand how it all works. To provide a deeper understanding, this
section explains the inner workings of the Spring Framework’s declarative transaction
infrastructure in the context of transaction-related issues.
The most important concepts to grasp with regard to the Spring Framework’s declarative
transaction support are that this support is enabled
via AOP proxies and that the transactional
advice is driven by metadata (currently XML- or annotation-based). The combination of AOP
with transactional metadata yields an AOP proxy that uses a TransactionInterceptor
in
conjunction with an appropriate TransactionManager
implementation to drive transactions
around method invocations.
Spring AOP is covered in the AOP section. |
Spring Framework’s TransactionInterceptor
provides transaction management for
imperative and reactive programming models. The interceptor detects the desired flavor of
transaction management by inspecting the method return type. Methods returning a reactive
type such as Publisher
or Kotlin Flow
(or a subtype of those) qualify for reactive
transaction management. All other return types including void
use the code path for
imperative transaction management.
Transaction management flavors impact which transaction manager is required. Imperative
transactions require a PlatformTransactionManager
, while reactive transactions use
implementations.
A reactive transaction managed by |
The following image shows a conceptual view of calling a method on a transactional proxy:
1.4.2. Example of Declarative Transaction Implementation
Consider the following interface and its attendant implementation. This example uses
Foo
and Bar
classes as placeholders so that you can concentrate on the transaction
usage without focusing on a particular domain model. For the purposes of this example,
the fact that the DefaultFooService
class throws UnsupportedOperationException
instances in the body of each implemented method is good. That behavior lets you see
transactions being created and then rolled back in response to the
instance. The following listing shows the FooService
interface:
// the service interface that we want to make transactional
package x.y.service;
public interface FooService {
Foo getFoo(String fooName);
Foo getFoo(String fooName, String barName);
void insertFoo(Foo foo);
void updateFoo(Foo foo);
package x.y.service
fun getFoo(fooName: String): Foo
fun getFoo(fooName: String, barName: String): Foo
fun insertFoo(foo: Foo)
fun updateFoo(foo: Foo)
The following example shows an implementation of the preceding interface:
public class DefaultFooService implements FooService {
public Foo getFoo(String fooName) {
public Foo getFoo(String fooName, String barName) {
public void insertFoo(Foo foo) {
public void updateFoo(Foo foo) {
package x.y.service
class DefaultFooService : FooService {
override fun getFoo(fooName: String): Foo {
override fun getFoo(fooName: String, barName: String): Foo {
override fun insertFoo(foo: Foo) {
override fun updateFoo(foo: Foo) {
Assume that the first two methods of the FooService
interface, getFoo(String)
and
getFoo(String, String)
, must run in the context of a transaction with read-only
semantics and that the other methods, insertFoo(Foo)
and updateFoo(Foo)
, must
run in the context of a transaction with read-write semantics. The following
configuration is explained in detail in the next few paragraphs:
<!-- from the file 'context.xml' -->
xmlns:aop="http://www.springframework.org/schema/aop"
xmlns:tx="http://www.springframework.org/schema/tx"
https://www.springframework.org/schema/tx/spring-tx.xsd
https://www.springframework.org/schema/aop/spring-aop.xsd">
<!-- this is the service object that we want to make transactional -->
<bean id="fooService" class="x.y.service.DefaultFooService"/>
<!-- the transactional advice (what 'happens'; see the <aop:advisor/> bean below) -->
<tx:advice id="txAdvice" transaction-manager="txManager">
<!-- the transactional semantics... -->
<tx:attributes>
<!-- all methods starting with 'get' are read-only -->
<tx:method name="get*" read-only="true"/>
<!-- other methods use the default transaction settings (see below) -->
<tx:method name="*"/>
</tx:attributes>
</tx:advice>
<!-- ensure that the above transactional advice runs for any execution
of an operation defined by the FooService interface -->
<aop:config>
<aop:pointcut id="fooServiceOperation" expression="execution(* x.y.service.FooService.*(..))"/>
<aop:advisor advice-ref="txAdvice" pointcut-ref="fooServiceOperation"/>
</aop:config>
<!-- don't forget the DataSource -->
<property name="driverClassName" value="oracle.jdbc.driver.OracleDriver"/>
<property name="url" value="jdbc:oracle:thin:@rj-t42:1521:elvis"/>
<property name="username" value="scott"/>
<property name="password" value="tiger"/>
</bean>
<!-- similarly, don't forget the TransactionManager -->
</bean>
</beans>
Examine the preceding configuration. It assumes that you want to make a service object,
the fooService
bean, transactional. The transaction semantics to apply are encapsulated
in the <tx:advice/>
definition. The <tx:advice/>
definition reads as "all methods
starting with get
are to run in the context of a read-only transaction, and all
other methods are to run with the default transaction semantics". The
transaction-manager
attribute of the <tx:advice/>
tag is set to the name of the
TransactionManager
bean that is going to drive the transactions (in this case, the
txManager
bean).
You can omit the transaction-manager attribute in the transactional advice
(<tx:advice/> ) if the bean name of the TransactionManager that you want to
wire in has the name transactionManager . If the TransactionManager bean that
you want to wire in has any other name, you must use the transaction-manager
attribute explicitly, as in the preceding example.
The <aop:config/>
definition ensures that the transactional advice defined by the
txAdvice
bean runs at the appropriate points in the program. First, you define a
pointcut that matches the execution of any operation defined in the FooService
interface
(fooServiceOperation
). Then you associate the pointcut with the txAdvice
by using an
advisor. The result indicates that, at the execution of a fooServiceOperation
the advice defined by txAdvice
is run.
The expression defined within the <aop:pointcut/>
element is an AspectJ pointcut
expression. See the AOP section for more details on pointcut
expressions in Spring.
A common requirement is to make an entire service layer transactional. The best way to do this is to change the pointcut expression to match any operation in your service layer. The following example shows how to do so:
<aop:config>
<aop:pointcut id="fooServiceMethods" expression="execution(* x.y.service.*.*(..))"/>
<aop:advisor advice-ref="txAdvice" pointcut-ref="fooServiceMethods"/>
</aop:config>
In the preceding example, it is assumed that all your service interfaces are defined
in the x.y.service package. See the AOP section for more details.
Now that we have analyzed the configuration, you may be asking yourself, "What does all this configuration actually do?"
The configuration shown earlier is used to create a transactional proxy around the object
that is created from the fooService
bean definition. The proxy is configured with
the transactional advice so that, when an appropriate method is invoked on the proxy,
a transaction is started, suspended, marked as read-only, and so on, depending on the
transaction configuration associated with that method. Consider the following program
that test drives the configuration shown earlier:
public final class Boot {
public static void main(final String[] args) throws Exception {
ApplicationContext ctx = new ClassPathXmlApplicationContext("context.xml");
FooService fooService = ctx.getBean(FooService.class);
fooService.insertFoo(new Foo());
import org.springframework.beans.factory.getBean
fun main() {
val ctx = ClassPathXmlApplicationContext("context.xml")
val fooService = ctx.getBean<FooService>("fooService")
fooService.insertFoo(Foo())
The output from running the preceding program should resemble the following (the Log4J
output and the stack trace from the UnsupportedOperationException
thrown by the
insertFoo(..)
method of the DefaultFooService
class have been truncated for clarity):
<!-- the Spring container is starting up... -->
[AspectJInvocationContextExposingAdvisorAutoProxyCreator] - Creating implicit proxy for bean 'fooService' with 0 common interceptors and 1 specific interceptors
<!-- the DefaultFooService is actually proxied -->
[JdkDynamicAopProxy] - Creating JDK dynamic proxy for [x.y.service.DefaultFooService]
<!-- ... the insertFoo(..) method is now being invoked on the proxy -->
[TransactionInterceptor] - Getting transaction for x.y.service.FooService.insertFoo
<!-- the transactional advice kicks in here... -->
[DataSourceTransactionManager] - Creating new transaction with name [x.y.service.FooService.insertFoo]
[DataSourceTransactionManager] - Acquired Connection [org.apache.commons.dbcp.PoolableConnection@a53de4] for JDBC transaction
<!-- the insertFoo(..) method from DefaultFooService throws an exception... -->
[RuleBasedTransactionAttribute] - Applying rules to determine whether transaction should rollback on java.lang.UnsupportedOperationException
[TransactionInterceptor] - Invoking rollback for transaction on x.y.service.FooService.insertFoo due to throwable [java.lang.UnsupportedOperationException]
<!-- and the transaction is rolled back (by default, RuntimeException instances cause rollback) -->
[DataSourceTransactionManager] - Rolling back JDBC transaction on Connection [org.apache.commons.dbcp.PoolableConnection@a53de4]
[DataSourceTransactionManager] - Releasing JDBC Connection after transaction
[DataSourceUtils] - Returning JDBC Connection to DataSource
Exception in thread "main" java.lang.UnsupportedOperationException at x.y.service.DefaultFooService.insertFoo(DefaultFooService.java:14)
<!-- AOP infrastructure stack trace elements removed for clarity -->
at $Proxy0.insertFoo(Unknown Source)
at Boot.main(Boot.java:11)
To use reactive transaction management the code has to use reactive types.
Spring Framework uses the ReactiveAdapterRegistry to determine whether a method
return type is reactive.
The following listing shows a modified version of the previously used FooService
, but
this time the code uses reactive types:
// the reactive service interface that we want to make transactional
Flux<Foo> getFoo(String fooName);
Publisher<Foo> getFoo(String fooName, String barName);
Mono<Void> insertFoo(Foo foo);
Mono<Void> updateFoo(Foo foo);
package x.y.service
fun getFoo(fooName: String): Flow<Foo>
fun getFoo(fooName: String, barName: String): Publisher<Foo>
fun insertFoo(foo: Foo) : Mono<Void>
fun updateFoo(foo: Foo) : Mono<Void>
public Flux<Foo> getFoo(String fooName) {
public Publisher<Foo> getFoo(String fooName, String barName) {
public Mono<Void> insertFoo(Foo foo) {
public Mono<Void> updateFoo(Foo foo) {
package x.y.service
override fun getFoo(fooName: String): Flow<Foo> {
override fun getFoo(fooName: String, barName: String): Publisher<Foo> {
override fun insertFoo(foo: Foo): Mono<Void> {
override fun updateFoo(foo: Foo): Mono<Void> {
Imperative and reactive transaction management share the same semantics for transaction
boundary and transaction attribute definitions. The main difference between imperative
and reactive transactions is the deferred nature of the latter. TransactionInterceptor
decorates the returned reactive type with a transactional operator to begin and clean up
the transaction. Therefore, calling a transactional reactive method defers the actual
transaction management to a subscription type that activates processing of the reactive
type.
Another aspect of reactive transaction management relates to data escaping which is a natural consequence of the programming model.
Method return values of imperative transactions are returned from transactional methods upon successful termination of a method so that partially computed results do not escape the method closure.
Reactive transaction methods return a reactive wrapper type which represents a computation sequence along with a promise to begin and complete the computation.
A Publisher
can emit data while a transaction is ongoing but not necessarily completed.
Therefore, methods that depend upon successful completion of an entire transaction need
to ensure completion and buffer results in the calling code.
1.4.3. Rolling Back a Declarative Transaction
The previous section outlined the basics of how to specify transactional settings for
classes, typically service layer classes, declaratively in your application. This section
describes how you can control the rollback of transactions in a simple, declarative
fashion in XML configuration. For details on controlling rollback semantics declaratively
with the @Transactional
annotation, see
@Transactional
Settings.
The recommended way to indicate to the Spring Framework’s transaction infrastructure
that a transaction’s work is to be rolled back is to throw an Exception
from code that
is currently executing in the context of a transaction. The Spring Framework’s
transaction infrastructure code catches any unhandled Exception
as it bubbles up
the call stack and makes a determination whether to mark the transaction for rollback.
In its default configuration, the Spring Framework’s transaction infrastructure code
marks a transaction for rollback only in the case of runtime, unchecked exceptions.
That is, when the thrown exception is an instance or subclass of RuntimeException
(Error
instances also, by default, result in a rollback). Checked exceptions that are
thrown from a transactional method do not result in rollback in the default
configuration.
You can configure exactly which Exception
types mark a transaction for rollback,
including checked exceptions by specifying rollback rules.
Rollback rules
Rollback rules determine if a transaction should be rolled back when a given exception is
thrown, and the rules are based on patterns. A pattern can be a fully qualified class
name or a substring of a fully qualified class name for an exception type (which must be
a subclass of Rollback rules may be configured in XML via the
The following XML snippet demonstrates how to configure rollback for a checked,
application-specific Exception
type by supplying an exception pattern via the
rollback-for
attribute:
<tx:attributes>
<tx:method name="get*" read-only="true" rollback-for="NoProductInStockException"/>
</tx:attributes>
</tx:advice>
If you do not want a transaction rolled back when an exception is thrown, you can also
specify 'no rollback' rules. The following example tells the Spring Framework’s
transaction infrastructure to commit the attendant transaction even in the face of an
unhandled InstrumentNotFoundException
<tx:advice id="txAdvice">
<tx:attributes>
<tx:method name="updateStock" no-rollback-for="InstrumentNotFoundException"/>
</tx:attributes>
</tx:advice>
When the Spring Framework’s transaction infrastructure catches an exception and consults
the configured rollback rules to determine whether to mark the transaction for rollback,
the strongest matching rule wins. So, in the case of the following configuration, any
exception other than an InstrumentNotFoundException
results in a rollback of the
attendant transaction:
<tx:attributes>
<tx:method name="*" rollback-for="Throwable" no-rollback-for="InstrumentNotFoundException"/>
</tx:attributes>
</tx:advice>
You can also indicate a required rollback programmatically. Although simple, this process is quite invasive and tightly couples your code to the Spring Framework’s transaction infrastructure. The following example shows how to programmatically indicate a required rollback:
public void resolvePosition() {
try {
// some business logic...
} catch (NoProductInStockException ex) {
// trigger rollback programmatically
TransactionAspectSupport.currentTransactionStatus().setRollbackOnly();
fun resolvePosition() {
try {
} catch (ex: NoProductInStockException) {
You are strongly encouraged to use the declarative approach to rollback, if at all possible. Programmatic rollback is available should you absolutely need it, but its usage flies in the face of achieving a clean POJO-based architecture.
1.4.4. Configuring Different Transactional Semantics for Different Beans
Consider the scenario where you have a number of service layer objects, and you want to
apply a totally different transactional configuration to each of them. You can do so
by defining distinct <aop:advisor/>
elements with differing pointcut
and
advice-ref
attribute values.
As a point of comparison, first assume that all of your service layer classes are
defined in a root x.y.service
package. To make all beans that are instances of classes
defined in that package (or in subpackages) and that have names ending in Service
have
the default transactional configuration, you could write the following:
<aop:config>
<aop:pointcut id="serviceOperation"
expression="execution(* x.y.service..*Service.*(..))"/>
<aop:advisor pointcut-ref="serviceOperation" advice-ref="txAdvice"/>
</aop:config>
<!-- these two beans will be transactional... -->
<bean id="barService" class="x.y.service.extras.SimpleBarService"/>
<!-- ... and these two beans won't -->
<bean id="anotherService" class="org.xyz.SomeService"/> <!-- (not in the right package) -->
<bean id="barManager" class="x.y.service.SimpleBarManager"/> <!-- (doesn't end in 'Service') -->
<tx:attributes>
</tx:attributes>
</tx:advice>
<!-- other transaction infrastructure beans such as a TransactionManager omitted... -->
</beans>
The following example shows how to configure two distinct beans with totally different transactional settings:
<aop:config>
<aop:pointcut id="defaultServiceOperation"
expression="execution(* x.y.service.*Service.*(..))"/>
<aop:pointcut id="noTxServiceOperation"
expression="execution(* x.y.service.ddl.DefaultDdlManager.*(..))"/>
<aop:advisor pointcut-ref="defaultServiceOperation" advice-ref="defaultTxAdvice"/>
<aop:advisor pointcut-ref="noTxServiceOperation" advice-ref="noTxAdvice"/>
</aop:config>
<!-- this bean will be transactional (see the 'defaultServiceOperation' pointcut) -->
<!-- this bean will also be transactional, but with totally different transactional settings -->
<bean id="anotherFooService" class="x.y.service.ddl.DefaultDdlManager"/>
<tx:advice id="defaultTxAdvice">
<tx:attributes>
</tx:attributes>
</tx:advice>
<tx:advice id="noTxAdvice">
<tx:attributes>
<tx:method name="*" propagation="NEVER"/>
</tx:attributes>
</tx:advice>
</beans>
1.4.5. <tx:advice/> Settings
This section summarizes the various transactional settings that you can specify by using
the <tx:advice/>
tag. The default <tx:advice/>
settings are:
The propagation setting is
REQUIRED.
The isolation level is
DEFAULT.
The transaction is read-write.
The transaction timeout defaults to the default timeout of the underlying transaction system or none if timeouts are not supported.
Any
RuntimeException
triggers rollback, and any checkedException
does not.
You can change these default settings. The following table summarizes the various attributes of the <tx:method/>
tags
that are nested within <tx:advice/>
and <tx:attributes/>
tags:
Attribute | Required? | Default | Description |
Yes |
Method names with which the transaction attributes are to be associated. The
wildcard (*) character can be used to associate the same transaction attribute
settings with a number of methods (for example, |
No |
Transaction propagation behavior. |
No |
Transaction isolation level. Only applicable to propagation settings of |
No |
-1 |
Transaction timeout (seconds). Only applicable to propagation |
No |
false |
Read-write versus read-only transaction. Applies only to |
No |
Comma-delimited list of |
No |
1.4.6. Using @Transactional
In addition to the XML-based declarative approach to transaction configuration, you can use an annotation-based approach. Declaring transaction semantics directly in the Java source code puts the declarations much closer to the affected code. There is not much danger of undue coupling, because code that is meant to be used transactionally is almost always deployed that way anyway.
The standard javax.transaction.Transactional annotation is also supported as a
drop-in replacement to Spring’s own annotation. Please refer to JTA 1.2 documentation
for more details.
The ease-of-use afforded by the use of the @Transactional
annotation is best
illustrated with an example, which is explained in the text that follows.
Consider the following class definition:
// the service class that we want to make transactional
@Transactional
@Transactional
Used at the class level as above, the annotation indicates a default for all methods of
the declaring class (as well as its subclasses). Alternatively, each method can be
annotated individually. See Method visibility and @Transactional
for
further details on which methods Spring considers transactional. Note that a class-level
annotation does not apply to ancestor classes up the class hierarchy; in such a scenario,
inherited methods need to be locally redeclared in order to participate in a
subclass-level annotation.
When a POJO class such as the one above is defined as a bean in a Spring context,
you can make the bean instance transactional through an @EnableTransactionManagement
annotation in a @Configuration
class. See the
javadoc
for full details.
In XML configuration, the <tx:annotation-driven/>
tag provides similar convenience:
<!-- enable the configuration of transactional behavior based on annotations -->
<!-- a TransactionManager is still required -->
<tx:annotation-driven transaction-manager="txManager"/> (1)
<!-- (this dependency is defined somewhere else) -->
</bean>
</beans>
1 | The line that makes the bean instance transactional. |
You can omit the transaction-manager attribute in the <tx:annotation-driven/>
tag if the bean name of the TransactionManager that you want to wire in has the name
transactionManager . If the TransactionManager bean that you want to dependency-inject
has any other name, you have to use the transaction-manager attribute, as in the
preceding example.
Reactive transactional methods use reactive return types in contrast to imperative programming arrangements as the following listing shows:
// the reactive service class that we want to make transactional
@Transactional
public Publisher<Foo> getFoo(String fooName) {
public Mono<Foo> getFoo(String fooName, String barName) {
@Transactional
override fun getFoo(fooName: String, barName: String): Mono<Foo> {
Note that there are special considerations for the returned Publisher
with regards to
Reactive Streams cancellation signals. See the Cancel Signals section under
"Using the TransactionalOperator" for more details.
@Transactional When you use transactional proxies with Spring’s standard configuration, you should apply
the When using
The Spring TestContext Framework supports non-private |
You can apply the @Transactional
annotation to an interface definition, a method
on an interface, a class definition, or a method on a class. However, the mere presence
annotation is not enough to activate the transactional behavior.
The @Transactional
annotation is merely metadata that can be consumed by corresponding
runtime infrastructure which uses that metadata to configure the appropriate beans with
transactional behavior. In the preceding example, the <tx:annotation-driven/>
element
switches on actual transaction management at runtime.
The Spring team recommends that you annotate methods of concrete classes with the
@Transactional annotation, rather than relying on annotated methods in interfaces,
even if the latter does work for interface-based and target-class proxies as of 5.0.
Since Java annotations are not inherited from interfaces, interface-declared annotations
are still not recognized by the weaving infrastructure when using AspectJ mode, so the
aspect does not get applied. As a consequence, your transaction annotations may be
silently ignored: Your code might appear to "work" until you test a rollback scenario.
In proxy mode (which is the default), only external method calls coming in through
the proxy are intercepted. This means that self-invocation (in effect, a method within
the target object calling another method of the target object) does not lead to an actual
transaction at runtime even if the invoked method is marked with @Transactional . Also,
the proxy must be fully initialized to provide the expected behavior, so you should not
rely on this feature in your initialization code — e.g. in a @PostConstruct method.
Consider using AspectJ mode (see the mode
attribute in the following table) if you
expect self-invocations to be wrapped with transactions as well. In this case, there is
no proxy in the first place. Instead, the target class is woven (that is, its byte code
is modified) to support @Transactional
runtime behavior on any kind of method.
XML Attribute | Annotation Attribute | Default | Description |
N/A (see |
Name of the transaction manager to use. Required only if the name of the transaction
manager is not |
The default mode ( |
Applies to |
Defines the order of the transaction advice that is applied to beans annotated with
The default advice mode for processing @Transactional annotations is proxy ,
which allows for interception of calls through the proxy only. Local calls within the
same class cannot get intercepted that way. For a more advanced mode of interception,
consider switching to aspectj mode in combination with compile-time or load-time weaving.
The proxy-target-class attribute controls what type of transactional proxies are
created for classes annotated with the @Transactional annotation. If
proxy-target-class is set to true , class-based proxies are created. If
proxy-target-class is false or if the attribute is omitted, standard JDK
interface-based proxies are created. (See Proxying Mechanisms
for a discussion of the different proxy types.)
@EnableTransactionManagement and <tx:annotation-driven/> look for
@Transactional only on beans in the same application context in which they are defined.
This means that, if you put annotation-driven configuration in a WebApplicationContext
for a DispatcherServlet , it checks for @Transactional beans only in your controllers
and not in your services. See MVC for more information.
The most derived location takes precedence when evaluating the transactional settings
for a method. In the case of the following example, the DefaultFooService
class is
annotated at the class level with the settings for a read-only transaction, but the
@Transactional
annotation on the updateFoo(Foo)
method in the same class takes
precedence over the transactional settings defined at the class level.
@Transactional(readOnly = true)
// these settings have precedence for this method
@Transactional(readOnly = false, propagation = Propagation.REQUIRES_NEW)
@Transactional
Settings
The @Transactional
annotation is metadata that specifies that an interface, class,
or method must have transactional semantics (for example, "start a brand new read-only
transaction when this method is invoked, suspending any existing transaction").
The default @Transactional
settings are as follows:
PROPAGATION_REQUIRED.
ISOLATION_DEFAULT.
The transaction timeout defaults to the default timeout of the underlying transaction system, or to none if timeouts are not supported.
Any
RuntimeException
orError
does not.
properties of the @Transactional
annotation:
Property | Type | Description |
Optional qualifier that specifies the transaction manager to be used. |
Alias for |
Array of |
Labels may be evaluated by transaction managers to associate implementation-specific behavior with the actual transaction. |
Optional propagation setting. |
Optional isolation level. Applies only to propagation values of |
Optional transaction timeout. Applies only to propagation values of |
Alternative for specifying the |
Read-write versus read-only transaction. Only applicable to values of |
Array of |
Optional array of exception types that must cause rollback. |
Array of exception name patterns. |
Optional array of exception name patterns that must cause rollback. |
Array of |
Optional array of exception types that must not cause rollback. |
Optional array of exception name patterns that must not cause rollback. |
See Rollback rules for further details on rollback rule semantics, patterns, and warnings regarding possible unintentional matches. |
Currently, you cannot have explicit control over the name of a transaction, where 'name'
means the transaction name that appears in a transaction monitor, if applicable
(for example, WebLogic’s transaction monitor), and in logging output. For declarative
transactions, the transaction name is always the fully-qualified class name + .
+ the method name of the transactionally advised class. For example, if the
handlePayment(..)
method of the BusinessService
class started a transaction, the
name of the transaction would be: com.example.BusinessService.handlePayment
Multiple Transaction Managers with @Transactional
Most Spring applications need only a single transaction manager, but there may be
situations where you want multiple independent transaction managers in a single
application. You can use the value
or transactionManager
attribute of the
@Transactional
annotation to optionally specify the identity of the
TransactionManager
to be used. This can either be the bean name or the qualifier value
of the transaction manager bean. For example, using the qualifier notation, you can
combine the following Java code with the following transaction manager bean declarations
in the application context:
public class TransactionalService {
@Transactional("order")
public void setSomething(String name) { ... }
@Transactional("account")
public void doSomething() { ... }
@Transactional("reactive-account")
public Mono<Void> doSomethingReactive() { ... }
fun setSomething(name: String) {
fun doSomething() {
fun doSomethingReactive(): Mono<Void> {
The following listing shows the bean declarations:
<bean id="transactionManager1" class="org.springframework.jdbc.support.JdbcTransactionManager">
<qualifier value="order"/>
</bean>
<bean id="transactionManager2" class="org.springframework.jdbc.support.JdbcTransactionManager">
<qualifier value="account"/>
</bean>
<bean id="transactionManager3" class="org.springframework.data.r2dbc.connection.R2dbcTransactionManager">
<qualifier value="reactive-account"/>
</bean>
In this case, the individual methods on TransactionalService
run under separate
transaction managers, differentiated by the order
, account
, and reactive-account
qualifiers. The default <tx:annotation-driven>
target bean name, transactionManager
is still used if no specifically qualified TransactionManager
bean is found.
Custom Composed Annotations
If you find you repeatedly use the same attributes with @Transactional
on many different
methods, Spring’s meta-annotation support lets you
define custom composed annotations for your specific use cases. For example, consider the
following annotation definitions:
@Target({ElementType.METHOD, ElementType.TYPE})
@Transactional(transactionManager = "order", label = "causal-consistency")
public @interface OrderTx {
@Transactional(transactionManager = "account", label = "retryable")
public @interface AccountTx {
@Target(AnnotationTarget.FUNCTION, AnnotationTarget.TYPE)
@Retention(AnnotationRetention.RUNTIME)
@Transactional(transactionManager = "order", label = ["causal-consistency"])
annotation class OrderTx
@Transactional(transactionManager = "account", label = ["retryable"])
annotation class AccountTx
The preceding annotations let us write the example from the previous section as follows:
@OrderTx
@AccountTx
@OrderTx
@AccountTx
fun doSomething() {
In the preceding example, we used the syntax to define the transaction manager qualifier and transactional labels, but we could also have included propagation behavior, rollback rules, timeouts, and other features.
1.4.7. Transaction Propagation
This section describes some semantics of transaction propagation in Spring. Note that this section is not a proper introduction to transaction propagation. Rather, it details some of the semantics regarding transaction propagation in Spring.
In Spring-managed transactions, be aware of the difference between physical and logical transactions, and how the propagation setting applies to this difference.
Understanding PROPAGATION_REQUIRED
enforces a physical transaction, either locally for the current
scope if no transaction exists yet or participating in an existing 'outer' transaction
defined for a larger scope. This is a fine default in common call stack arrangements
within the same thread (for example, a service facade that delegates to several repository methods
where all the underlying resources have to participate in the service-level transaction).
By default, a participating transaction joins the characteristics of the outer scope,
silently ignoring the local isolation level, timeout value, or read-only flag (if any).
Consider switching the validateExistingTransactions flag to true on your transaction
manager if you want isolation level declarations to be rejected when participating in
an existing transaction with a different isolation level. This non-lenient mode also
rejects read-only mismatches (that is, an inner read-write transaction that tries to participate
in a read-only outer scope).
When the propagation setting is PROPAGATION_REQUIRED
, a logical transaction scope
is created for each method upon which the setting is applied. Each such logical
transaction scope can determine rollback-only status individually, with an outer
transaction scope being logically independent from the inner transaction scope.
In the case of standard PROPAGATION_REQUIRED
behavior, all these scopes are
mapped to the same physical transaction. So a rollback-only marker set in the inner
transaction scope does affect the outer transaction’s chance to actually commit.
However, in the case where an inner transaction scope sets the rollback-only marker, the
outer transaction has not decided on the rollback itself, so the rollback (silently
triggered by the inner transaction scope) is unexpected. A corresponding
UnexpectedRollbackException
is thrown at that point. This is expected behavior so
that the caller of a transaction can never be misled to assume that a commit was
performed when it really was not. So, if an inner transaction (of which the outer caller
is not aware) silently marks a transaction as rollback-only, the outer caller still
calls commit. The outer caller needs to receive an UnexpectedRollbackException
to
indicate clearly that a rollback was performed instead.
Understanding PROPAGATION_REQUIRES_NEW
, in contrast to PROPAGATION_REQUIRED
, always uses an
independent physical transaction for each affected transaction scope, never
participating in an existing transaction for an outer scope. In such an arrangement,
the underlying resource transactions are different and, hence, can commit or roll back
independently, with an outer transaction not affected by an inner transaction’s rollback
status and with an inner transaction’s locks released immediately after its completion.
Such an independent inner transaction can also declare its own isolation level, timeout,
and read-only settings and not inherit an outer transaction’s characteristics.
The resources attached to the outer transaction will remain bound there while
the inner transaction acquires its own resources such as a new database connection.
This may lead to exhaustion of the connection pool and potentially to a deadlock if
several threads have an active outer transaction and wait to acquire a new connection
for their inner transaction, with the pool not being able to hand out any such inner
connection anymore. Do not use PROPAGATION_REQUIRES_NEW unless your connection pool
is appropriately sized, exceeding the number of concurrent threads by at least 1.
Understanding PROPAGATION_NESTED
PROPAGATION_NESTED
uses a single physical transaction with multiple savepoints
that it can roll back to. Such partial rollbacks let an inner transaction scope
trigger a rollback for its scope, with the outer transaction being able to continue
the physical transaction despite some operations having been rolled back. This setting
is typically mapped onto JDBC savepoints, so it works only with JDBC resource
transactions. See Spring’s DataSourceTransactionManager
1.4.8. Advising Transactional Operations
Suppose you want to run both transactional operations and some basic profiling advice.
How do you effect this in the context of <tx:annotation-driven/>
When you invoke the updateFoo(Foo)
method, you want to see the following actions:
The configured profiling aspect starts.
The transactional advice runs.
The method on the advised object runs.
The transaction commits.
The profiling aspect reports the exact duration of the whole transactional method invocation.
This chapter is not concerned with explaining AOP in any great detail (except as it applies to transactions). See AOP for detailed coverage of the AOP configuration and AOP in general. |
The following code shows the simple profiling aspect discussed earlier:
package x.y;
import org.aspectj.lang.ProceedingJoinPoint;
import org.springframework.util.StopWatch;
import org.springframework.core.Ordered;
public class SimpleProfiler implements Ordered {
private int order;
// allows us to control the ordering of advice
public int getOrder() {
return this.order;
public void setOrder(int order) {
this.order = order;
// this method is the around advice
public Object profile(ProceedingJoinPoint call) throws Throwable {
Object returnValue;
StopWatch clock = new StopWatch(getClass().getName());
try {
clock.start(call.toShortString());
returnValue = call.proceed();
} finally {
clock.stop();
System.out.println(clock.prettyPrint());
return returnValue;
class SimpleProfiler : Ordered {
private var order: Int = 0
override fun getOrder(): Int {
return this.order
fun setOrder(order: Int) {
this.order = order
fun profile(call: ProceedingJoinPoint): Any {
var returnValue: Any
val clock = StopWatch(javaClass.name)
try {
} finally {
clock.stop()
return returnValue
The ordering of advice
is controlled through the Ordered
interface. For full details on advice ordering, see
Advice ordering.
The following configuration creates a fooService
bean that has profiling and
transactional aspects applied to it in the desired order:
<!-- this is the aspect -->
<bean id="profiler" class="x.y.SimpleProfiler">
<!-- run before the transactional advice (hence the lower order number) -->
<property name="order" value="1"/>
</bean>
<tx:annotation-driven transaction-manager="txManager" order="200"/>
<aop:config>
<!-- this advice runs around the transactional advice -->
<aop:aspect id="profilingAspect" ref="profiler">
<aop:pointcut id="serviceMethodWithReturnValue"
expression="execution(!void x.y..*Service.*(..))"/>
<aop:around method="profile" pointcut-ref="serviceMethodWithReturnValue"/>
</aop:aspect>
</aop:config>
</bean>
</bean>
</beans>
You can configure any number of additional aspects in similar fashion.
The following example creates the same setup as the previous two examples but uses the purely XML declarative approach:
<!-- the profiling advice -->
</bean>
<aop:config>
<aop:pointcut id="entryPointMethod" expression="execution(* x.y..*Service.*(..))"/>
<!-- runs after the profiling advice (cf. the order attribute) -->
<aop:advisor advice-ref="txAdvice" pointcut-ref="entryPointMethod" order="2"/>
<!-- order value is higher than the profiling aspect -->
</aop:aspect>
</aop:config>
<tx:attributes>
</tx:attributes>
</tx:advice>
<!-- other <bean/> definitions such as a DataSource and a TransactionManager here -->
</beans>
The result of the preceding configuration is a fooService
transactional aspects applied to it in that order. If you want the profiling advice
to run after the transactional advice on the way in and before the
transactional advice on the way out, you can swap the value of the profiling
aspect bean’s order
property so that it is higher than the transactional advice’s
order value.
You can configure additional aspects in similar fashion.
1.4.9. Using @Transactional
with AspectJ
You can also use the Spring Framework’s @Transactional
support outside of a Spring
container by means of an AspectJ aspect. To do so, first annotate your classes
(and optionally your classes' methods) with the @Transactional
annotation,
and then link (weave) your application with the
org.springframework.transaction.aspectj.AnnotationTransactionAspect
defined in the
spring-aspects.jar
file. You must also configure the aspect with a transaction
manager. You can use the Spring Framework’s IoC container to take care of
dependency-injecting the aspect. The simplest way to configure the transaction
management aspect is to use the <tx:annotation-driven/>
element and specify the mode
attribute to aspectj
as described in Using @Transactional
. Because
we focus here on applications that run outside of a Spring container, we show
you how to do it programmatically.
Prior to continuing, you may want to read Using @Transactional and
AOP respectively.
The following example shows how to create a transaction manager and configure the
to use it:
// construct an appropriate transaction manager
DataSourceTransactionManager txManager = new DataSourceTransactionManager(getDataSource());
// configure the AnnotationTransactionAspect to use it; this must be done before executing any transactional methods
AnnotationTransactionAspect.aspectOf().setTransactionManager(txManager);
val txManager = DataSourceTransactionManager(getDataSource())
AnnotationTransactionAspect.aspectOf().transactionManager = txManager
When you use this aspect, you must annotate the implementation class (or the methods within that class or both), not the interface (if any) that the class implements. AspectJ follows Java’s rule that annotations on interfaces are not inherited. |
The @Transactional
annotation on a class specifies the default transaction semantics
for the execution of any public method in the class.
The @Transactional
annotation on a method within the class overrides the default
transaction semantics given by the class annotation (if present). You can annotate any method,
regardless of visibility.
To weave your applications with the AnnotationTransactionAspect
, you must either build
your application with AspectJ (see the
AspectJ Development
Guide) or use load-time weaving. See Load-time weaving with
AspectJ in the Spring Framework for a discussion of load-time weaving with AspectJ.
1.5. Programmatic Transaction Management
The Spring Framework provides two means of programmatic transaction management, by using:
The
TransactionTemplate
orTransactionalOperator
A
TransactionManager
implementation directly.
The Spring team generally recommends the TransactionTemplate
for programmatic
transaction management in imperative flows and TransactionalOperator
for reactive code.
The second approach is similar to using the JTA UserTransaction
API, although exception
handling is less cumbersome.
1.5.1. Using the TransactionTemplate
The TransactionTemplate
adopts the same approach as other Spring templates, such as
the JdbcTemplate
. It uses a callback approach (to free application code from having to
do the boilerplate acquisition and release transactional resources) and results in
code that is intention driven, in that your code focuses solely on what
you want to do.
As the examples that follow show, using the TransactionTemplate absolutely
couples you to Spring’s transaction infrastructure and APIs. Whether or not programmatic
transaction management is suitable for your development needs is a decision that you
have to make yourself.
Application code that must run in a transactional context and that explicitly uses the
TransactionTemplate
resembles the next example. You, as an application
developer, can write a TransactionCallback
implementation (typically expressed as an
anonymous inner class) that contains the code that you need to run in the context of
a transaction. You can then pass an instance of your custom TransactionCallback
to the
execute(..)
method exposed on the TransactionTemplate
public class SimpleService implements Service {
// single TransactionTemplate shared amongst all methods in this instance
private final TransactionTemplate transactionTemplate;
// use constructor-injection to supply the PlatformTransactionManager
public SimpleService(PlatformTransactionManager transactionManager) {
this.transactionTemplate = new TransactionTemplate(transactionManager);
public Object someServiceMethod() {
return transactionTemplate.execute(new TransactionCallback() {
// the code in this method runs in a transactional context
public Object doInTransaction(TransactionStatus status) {
updateOperation1();
return resultOfUpdateOperation2();
class SimpleService(transactionManager: PlatformTransactionManager) : Service {
private val transactionTemplate = TransactionTemplate(transactionManager)
fun someServiceMethod() = transactionTemplate.execute<Any?> {
updateOperation1()
If there is no return value, you can use the convenient TransactionCallbackWithoutResult
class
with an anonymous class, as follows:
transactionTemplate.execute(new TransactionCallbackWithoutResult() {
protected void doInTransactionWithoutResult(TransactionStatus status) {
updateOperation1();
updateOperation2();
transactionTemplate.execute(object : TransactionCallbackWithoutResult() {
override fun doInTransactionWithoutResult(status: TransactionStatus) {
updateOperation1()
updateOperation2()
Code within the callback can roll the transaction back by calling the
setRollbackOnly()
method on the supplied TransactionStatus
object, as follows:
try {
updateOperation1();
updateOperation2();
} catch (SomeBusinessException ex) {
status.setRollbackOnly();
try {
updateOperation1()
updateOperation2()
} catch (ex: SomeBusinessException) {
Specifying Transaction Settings
You can specify transaction settings (such as the propagation mode, the isolation level,
the timeout, and so forth) on the TransactionTemplate
either programmatically or in
configuration. By default, TransactionTemplate
instances have the
default transactional settings. The
following example shows the programmatic customization of the transactional settings for
a specific TransactionTemplate:
// the transaction settings can be set here explicitly if so desired
this.transactionTemplate.setIsolationLevel(TransactionDefinition.ISOLATION_READ_UNCOMMITTED);
this.transactionTemplate.setTimeout(30); // 30 seconds
// and so forth...
private val transactionTemplate = TransactionTemplate(transactionManager).apply {
isolationLevel = TransactionDefinition.ISOLATION_READ_UNCOMMITTED
timeout = 30 // 30 seconds
// and so forth...
The following example defines a TransactionTemplate
with some custom transactional
settings by using Spring XML configuration:
<bean id="sharedTransactionTemplate"
class="org.springframework.transaction.support.TransactionTemplate">
<property name="isolationLevelName" value="ISOLATION_READ_UNCOMMITTED"/>
<property name="timeout" value="30"/>
</bean>
You can then inject the sharedTransactionTemplate
into as many services as are required.
Finally, instances of the TransactionTemplate
class are thread-safe, in that instances
do not maintain any conversational state. TransactionTemplate
instances do, however,
maintain configuration state. So, while a number of classes may share a single instance
of a TransactionTemplate
, if a class needs to use a TransactionTemplate
with
different settings (for example, a different isolation level), you need to create
two distinct TransactionTemplate
instances.
1.5.2. Using the TransactionalOperator
The TransactionalOperator
follows an operator design that is similar to other reactive
operators. It uses a callback approach (to free application code from having to do the
boilerplate acquisition and release transactional resources) and results in code that is
intention driven, in that your code focuses solely on what you want to do.
As the examples that follow show, using the TransactionalOperator absolutely
transaction management is suitable for your development needs is a decision that you have
to make yourself.
resembles the next example:
// single TransactionalOperator shared amongst all methods in this instance
private final TransactionalOperator transactionalOperator;
// use constructor-injection to supply the ReactiveTransactionManager
public SimpleService(ReactiveTransactionManager transactionManager) {
this.transactionalOperator = TransactionalOperator.create(transactionManager);
public Mono<Object> someServiceMethod() {
Mono<Object> update = updateOperation1();
return update.then(resultOfUpdateOperation2).as(transactionalOperator::transactional);
class SimpleService(transactionManager: ReactiveTransactionManager) : Service {
private val transactionalOperator = TransactionalOperator.create(transactionManager)
suspend fun someServiceMethod() = transactionalOperator.executeAndAwait<Any?> {
updateOperation1()
can be used in two ways:
Operator-style using Project Reactor types (
mono.as(transactionalOperator::transactional)
Callback-style for every other case (
transactionalOperator.execute(TransactionCallback<T>)
Code within the callback can roll the transaction back by calling the setRollbackOnly()
method on the supplied ReactiveTransaction
object, as follows:
transactionalOperator.execute(new TransactionCallback<>() {
public Mono<Object> doInTransaction(ReactiveTransaction status) {
return updateOperation1().then(updateOperation2)
.doOnError(SomeBusinessException.class, e -> status.setRollbackOnly());
transactionalOperator.execute(object : TransactionCallback() {
override fun doInTransactionWithoutResult(status: ReactiveTransaction) {
Cancel Signals
In Reactive Streams, a Subscriber
can cancel its Subscription
and stop its
Publisher
. Operators in Project Reactor, as well as in other libraries, such as next()
take(long)
, timeout(Duration)
, and others can issue cancellations. There is no way to
know the reason for the cancellation, whether it is due to an error or a simply lack of
interest to consume further. Since version 5.3 cancel signals lead to a roll back.
As a result it is important to consider the operators used downstream from a transaction
Publisher
. In particular in the case of a Flux
or other multi-value Publisher
the full output must be consumed to allow the transaction to complete.
the timeout, and so forth) for the TransactionalOperator
. By default,
instances have
following example shows customization of the transactional settings for a specific
TransactionalOperator:
DefaultTransactionDefinition definition = new DefaultTransactionDefinition();
definition.setIsolationLevel(TransactionDefinition.ISOLATION_READ_UNCOMMITTED);
definition.setTimeout(30); // 30 seconds
// and so forth...
this.transactionalOperator = TransactionalOperator.create(transactionManager, definition);
private val definition = DefaultTransactionDefinition().apply {
// and so forth...
private val transactionalOperator = TransactionalOperator(transactionManager, definition)
1.5.3. Using the TransactionManager
The following sections explain programmatic usage of imperative and reactive transaction managers.
Using the PlatformTransactionManager
For imperative transactions, you can use a
org.springframework.transaction.PlatformTransactionManager
directly to manage your
transaction. To do so, pass the implementation of the PlatformTransactionManager
you
use to your bean through a bean reference. Then, by using the TransactionDefinition
and
TransactionStatus
objects, you can initiate transactions, roll back, and commit. The
DefaultTransactionDefinition def = new DefaultTransactionDefinition();
// explicitly setting the transaction name is something that can be done only programmatically
def.setName("SomeTxName");
def.setPropagationBehavior(TransactionDefinition.PROPAGATION_REQUIRED);
TransactionStatus status = txManager.getTransaction(def);
try {
// put your business logic here
} catch (MyException ex) {
txManager.rollback(status);
throw ex;
txManager.commit(status);
val def = DefaultTransactionDefinition()
def.propagationBehavior = TransactionDefinition.PROPAGATION_REQUIRED
val status = txManager.getTransaction(def)
try {
} catch (ex: MyException) {
throw ex
Using the ReactiveTransactionManager
When working with reactive transactions, you can use a
org.springframework.transaction.ReactiveTransactionManager
transaction. To do so, pass the implementation of the ReactiveTransactionManager
you
and
ReactiveTransaction
Mono<ReactiveTransaction> reactiveTx = txManager.getReactiveTransaction(def);
reactiveTx.flatMap(status -> {
Mono<Object> tx = ...; // put your business logic here
return tx.then(txManager.commit(status))
.onErrorResume(ex -> txManager.rollback(status).then(Mono.error(ex)));
val reactiveTx = txManager.getReactiveTransaction(def)
reactiveTx.flatMap { status ->
val tx = ... // put your business logic here
.onErrorResume { ex -> txManager.rollback(status).then(Mono.error(ex)) }
1.6. Choosing Between Programmatic and Declarative Transaction Management
Programmatic transaction management is usually a good idea only if you have a small
number of transactional operations. For example, if you have a web application that
requires transactions only for certain update operations, you may not want to set up
transactional proxies by using Spring or any other technology. In this case, using the
TransactionTemplate
may be a good approach. Being able to set the transaction name
explicitly is also something that can be done only by using the programmatic approach
to transaction management.
On the other hand, if your application has numerous transactional operations, declarative transaction management is usually worthwhile. It keeps transaction management out of business logic and is not difficult to configure. When using the Spring Framework, rather than EJB CMT, the configuration cost of declarative transaction management is greatly reduced.
1.7. Transaction-bound Events
As of Spring 4.2, the listener of an event can be bound to a phase of the transaction. The typical example is to handle the event when the transaction has completed successfully. Doing so lets events be used with more flexibility when the outcome of the current transaction actually matters to the listener.
You can register a regular event listener by using the @EventListener
annotation.
If you need to bind it to the transaction, use @TransactionalEventListener
When you do so, the listener is bound to the commit phase of the transaction by default.
The next example shows this concept. Assume that a component publishes an order-created event and that we want to define a listener that should only handle that event once the transaction in which it has been published has committed successfully. The following example sets up such an event listener:
@Component
public class MyComponent {
public void handleOrderCreatedEvent(CreationEvent<Order> creationEvent) {
@Component
class MyComponent {
fun handleOrderCreatedEvent(creationEvent: CreationEvent<Order>) {
The @TransactionalEventListener
annotation exposes a phase
attribute that lets you
customize the phase of the transaction to which the listener should be bound.
The valid phases are BEFORE_COMMIT
, AFTER_COMMIT
(default), AFTER_ROLLBACK
, as well as
AFTER_COMPLETION
which aggregates the transaction completion (be it a commit or a rollback).
If no transaction is running, the listener is not invoked at all, since we cannot honor the
required semantics. You can, however, override that behavior by setting the fallbackExecution
attribute of the annotation to true
1.8. Application server-specific integration
Spring’s transaction abstraction is generally application server-agnostic. Additionally,
Spring’s JtaTransactionManager
class (which can optionally perform a JNDI lookup for
and TransactionManager
objects) autodetects the location for
the latter object, which varies by application server. Having access to the JTA
TransactionManager
allows for enhanced transaction semantics — in particular,
supporting transaction suspension. See the
javadoc for details.
is the standard choice to run on Java EE application
servers and is known to work on all common servers. Advanced functionality, such as
transaction suspension, works on many servers as well (including GlassFish, JBoss and
Geronimo) without any special configuration required. However, for fully supported
transaction suspension and further advanced integration, Spring includes special adapters
for WebLogic Server and WebSphere. These adapters are discussed in the following
sections.
For standard scenarios, including WebLogic Server and WebSphere, consider using the
convenient <tx:jta-transaction-manager/>
configuration element. When configured,
this element automatically detects the underlying server and chooses the best
transaction manager available for the platform. This means that you need not explicitly
configure server-specific adapter classes (as discussed in the following sections).
Rather, they are chosen automatically, with the standard
as the default fallback.
1.8.1. IBM WebSphere
On WebSphere 6.1.0.9 and above, the recommended Spring JTA transaction manager to use is
WebSphereUowTransactionManager
. This special adapter uses IBM’s UOWManager
API,
which is available in WebSphere Application Server 6.1.0.9 and later. With this adapter,
Spring-driven transaction suspension (suspend and resume as initiated by
) is officially supported by IBM.
1.8.2. Oracle WebLogic Server
On WebLogic Server 9.0 or above, you would typically use the
WebLogicJtaTransactionManager
instead of the stock JtaTransactionManager
class. This
special WebLogic-specific subclass of the normal JtaTransactionManager
supports the
full power of Spring’s transaction definitions in a WebLogic-managed transaction
environment, beyond standard JTA semantics. Features include transaction names,
per-transaction isolation levels, and proper resuming of transactions in all cases.
1.9. Solutions to Common Problems
This section describes solutions to some common problems.
1.9.1. Using the Wrong Transaction Manager for a Specific DataSource
Use the correct PlatformTransactionManager
implementation based on your choice of
transactional technologies and requirements. Used properly, the Spring Framework merely
provides a straightforward and portable abstraction. If you use global
transactions, you must use the
org.springframework.transaction.jta.JtaTransactionManager
class (or an
application server-specific subclass of
it) for all your transactional operations. Otherwise, the transaction infrastructure
tries to perform local transactions on such resources as container DataSource
instances. Such local transactions do not make sense, and a good application server
treats them as errors.
1.10. Further Resources
For more information about the Spring Framework’s transaction support, see:
Distributed transactions in Spring, with and without XA is a JavaWorld presentation in which Spring’s David Syer guides you through seven patterns for distributed transactions in Spring applications, three of them with XA and four without.
Java Transaction Design Strategies is a book available from InfoQ that provides a well-paced introduction to transactions in Java. It also includes side-by-side examples of how to configure and use transactions with both the Spring Framework and EJB3.
2. DAO Support
The Data Access Object (DAO) support in Spring is aimed at making it easy to work with data access technologies (such as JDBC, Hibernate, or JPA) in a consistent way. This lets you switch between the aforementioned persistence technologies fairly easily, and it also lets you code without worrying about catching exceptions that are specific to each technology.
2.1. Consistent Exception Hierarchy
Spring provides a convenient translation from technology-specific exceptions, such as
SQLException
to its own exception class hierarchy, which has DataAccessException
as
the root exception. These exceptions wrap the original exception so that there is never
any risk that you might lose any information about what might have gone wrong.
In addition to JDBC exceptions, Spring can also wrap JPA- and Hibernate-specific exceptions, converting them to a set of focused runtime exceptions. This lets you handle most non-recoverable persistence exceptions in only the appropriate layers, without having annoying boilerplate catch-and-throw blocks and exception declarations in your DAOs. (You can still trap and handle exceptions anywhere you need to though.) As mentioned above, JDBC exceptions (including database-specific dialects) are also converted to the same hierarchy, meaning that you can perform some operations with JDBC within a consistent programming model.
The preceding discussion holds true for the various template classes in Spring’s support
for various ORM frameworks. If you use the interceptor-based classes, the application must
care about handling HibernateExceptions
and PersistenceExceptions
itself, preferably by
delegating to the convertHibernateAccessException(..)
or convertJpaAccessException(..)
methods, respectively, of SessionFactoryUtils
. These methods convert the exceptions
to exceptions that are compatible with the exceptions in the org.springframework.dao
exception hierarchy. As PersistenceExceptions
are unchecked, they can get thrown, too
(sacrificing generic DAO abstraction in terms of exceptions, though).
The following image shows the exception hierarchy that Spring provides.
(Note that the class hierarchy detailed in the image shows only a subset of the entire
DataAccessException
hierarchy.)
2.2. Annotations Used to Configure DAO or Repository Classes
The best way to guarantee that your Data Access Objects (DAOs) or repositories provide
exception translation is to use the @Repository
annotation. This annotation also
lets the component scanning support find and configure your DAOs and repositories
without having to provide XML configuration entries for them. The following example shows
how to use the @Repository
annotation:
@Repository (1)
public class SomeMovieFinder implements MovieFinder {
1 | The @Repository annotation. |
@Repository (1)
class SomeMovieFinder : MovieFinder {
Any DAO or repository implementation needs access to a persistence resource,
depending on the persistence technology used. For example, a JDBC-based repository
needs access to a JDBC DataSource
, and a JPA-based repository needs access to an
EntityManager
. The easiest way to accomplish this is to have this resource dependency
injected by using one of the @Autowired
, @Inject
, @Resource
or @PersistenceContext
annotations. The following example works for a JPA repository:
@Repository
public class JpaMovieFinder implements MovieFinder {
@PersistenceContext
private EntityManager entityManager;
@Repository
class JpaMovieFinder : MovieFinder {
@PersistenceContext
private lateinit var entityManager: EntityManager
If you use the classic Hibernate APIs, you can inject SessionFactory
, as the following
example shows:
@Repository
public class HibernateMovieFinder implements MovieFinder {
private SessionFactory sessionFactory;
@Autowired
public void setSessionFactory(SessionFactory sessionFactory) {
this.sessionFactory = sessionFactory;
@Repository
class HibernateMovieFinder(private val sessionFactory: SessionFactory) : MovieFinder {
The last example we show here is for typical JDBC support. You could have the DataSource
injected into an initialization method or a constructor, where you would create a JdbcTemplate
and other data access support classes (such as SimpleJdbcCall
and others) by using this
DataSource
. The following example autowires a DataSource
@Repository
public class JdbcMovieFinder implements MovieFinder {
private JdbcTemplate jdbcTemplate;
@Autowired
public void init(DataSource dataSource) {
this.jdbcTemplate = new JdbcTemplate(dataSource);
@Repository
class JdbcMovieFinder(dataSource: DataSource) : MovieFinder {
private val jdbcTemplate = JdbcTemplate(dataSource)
See the specific coverage of each persistence technology for details on how to configure the application context to take advantage of these annotations. |
3. Data Access with JDBC
The value provided by the Spring Framework JDBC abstraction is perhaps best shown by the sequence of actions outlined in the following table below. The table shows which actions Spring takes care of and which actions are your responsibility.
Action | Spring | You |
Define connection parameters. |
X |
Open the connection. |
X |
Specify the SQL statement. |
X |
Declare parameters and provide parameter values |
X |
Prepare and run the statement. |
X |
Set up the loop to iterate through the results (if any). |
X |
Do the work for each iteration. |
X |
Process any exception. |
X |
Handle transactions. |
X |
Close the connection, the statement, and the resultset. |
X |
The Spring Framework takes care of all the low-level details that can make JDBC such a tedious API.
3.1. Choosing an Approach for JDBC Database Access
You can choose among several approaches to form the basis for your JDBC database access.
In addition to three flavors of JdbcTemplate
, a new SimpleJdbcInsert
and
SimpleJdbcCall
approach optimizes database metadata, and the RDBMS Object style takes a
more object-oriented approach similar to that of JDO Query design. Once you start using
one of these approaches, you can still mix and match to include a feature from a
different approach. All approaches require a JDBC 2.0-compliant driver, and some
advanced features require a JDBC 3.0 driver.
JdbcTemplate
is the classic and most popular Spring JDBC approach. This “lowest-level” approach and all others use a JdbcTemplate under the covers. -
NamedParameterJdbcTemplate
wraps aJdbcTemplate
to provide named parameters instead of the traditional JDBC?
placeholders. This approach provides better documentation and ease of use when you have multiple parameters for an SQL statement. -
SimpleJdbcInsert
andSimpleJdbcCall
optimize database metadata to limit the amount of necessary configuration. This approach simplifies coding so that you need to provide only the name of the table or procedure and provide a map of parameters matching the column names. This works only if the database provides adequate metadata. If the database does not provide this metadata, you have to provide explicit configuration of the parameters. -
RDBMS objects — including
MappingSqlQuery
,SqlUpdate
, andStoredProcedure
— require you to create reusable and thread-safe objects during initialization of your data-access layer. This approach is modeled after JDO Query, wherein you define your query string, declare parameters, and compile the query. Once you do that,execute(…)
,update(…)
, andfindObject(…)
methods can be called multiple times with various parameter values.
3.2. Package Hierarchy
The Spring Framework’s JDBC abstraction framework consists of four different packages:
core
: Theorg.springframework.jdbc.core
package contains theJdbcTemplate
class and its various callback interfaces, plus a variety of related classes. A subpackage namedorg.springframework.jdbc.core.simple
contains theSimpleJdbcInsert
andSimpleJdbcCall
classes. Another subpackage namedorg.springframework.jdbc.core.namedparam
contains theNamedParameterJdbcTemplate
class and the related support classes. See Using the JDBC Core Classes to Control Basic JDBC Processing and Error Handling, JDBC Batch Operations, and Simplifying JDBC Operations with theSimpleJdbc
Classes. -
datasource
: Theorg.springframework.jdbc.datasource
package contains a utility class for easyDataSource
access and various simpleDataSource
implementations that you can use for testing and running unmodified JDBC code outside of a Java EE container. A subpackage namedorg.springframework.jdbc.datasource.embedded
provides support for creating embedded databases by using Java database engines, such as HSQL, H2, and Derby. See Controlling Database Connections and Embedded Database Support. -
object
: Theorg.springframework.jdbc.object
package contains classes that represent RDBMS queries, updates, and stored procedures as thread-safe, reusable objects. See Modeling JDBC Operations as Java Objects. This approach is modeled by JDO, although objects returned by queries are naturally disconnected from the database. This higher-level of JDBC abstraction depends on the lower-level abstraction in theorg.springframework.jdbc.core
package. -
support
: Theorg.springframework.jdbc.support
package providesSQLException
translation functionality and some utility classes. Exceptions thrown during JDBC processing are translated to exceptions defined in theorg.springframework.dao
package. This means that code using the Spring JDBC abstraction layer does not need to implement JDBC or RDBMS-specific error handling. All translated exceptions are unchecked, which gives you the option of catching the exceptions from which you can recover while letting other exceptions be propagated to the caller. See UsingSQLExceptionTranslator
3.3. Using the JDBC Core Classes to Control Basic JDBC Processing and Error Handling
This section covers how to use the JDBC core classes to control basic JDBC processing, including error handling. It includes the following topics:
3.3.1. Using JdbcTemplate
JdbcTemplate
is the central class in the JDBC core package. It handles the
creation and release of resources, which helps you avoid common errors, such as
forgetting to close the connection. It performs the basic tasks of the core JDBC
workflow (such as statement creation and execution), leaving application code to provide
SQL and extract results. The JdbcTemplate
class:
Runs SQL queries
Updates statements and stored procedure calls
Performs iteration over
ResultSet
instances and extraction of returned parameter values. -
Catches JDBC exceptions and translates them to the generic, more informative, exception hierarchy defined in the
package. (See Consistent Exception Hierarchy.)
When you use the JdbcTemplate
for your code, you need only to implement callback
interfaces, giving them a clearly defined contract. Given a Connection
provided by the
JdbcTemplate
class, the PreparedStatementCreator
callback interface creates a prepared
statement, providing SQL and any necessary parameters. The same is true for the
CallableStatementCreator
interface, which creates callable statements. The
RowCallbackHandler
interface extracts values from each row of a ResultSet
You can use JdbcTemplate
within a DAO implementation through direct instantiation
with a DataSource
reference, or you can configure it in a Spring IoC container and give it to
DAOs as a bean reference.
The DataSource should always be configured as a bean in the Spring IoC container. In
the first case the bean is given to the service directly; in the second case it is given
to the prepared template.
All SQL issued by this class is logged at the DEBUG
level under the category
corresponding to the fully qualified class name of the template instance (typically
JdbcTemplate
, but it may be different if you use a custom subclass of the
JdbcTemplate
class).
The following sections provide some examples of JdbcTemplate
usage. These examples
are not an exhaustive list of all of the functionality exposed by the JdbcTemplate
See the attendant javadoc for that.
Querying (SELECT
The following query gets the number of rows in a relation:
int rowCount = this.jdbcTemplate.queryForObject("select count(*) from t_actor", Integer.class);
val rowCount = jdbcTemplate.queryForObject<Int>("select count(*) from t_actor")!!
The following query uses a bind variable:
int countOfActorsNamedJoe = this.jdbcTemplate.queryForObject(
"select count(*) from t_actor where first_name = ?", Integer.class, "Joe");
val countOfActorsNamedJoe = jdbcTemplate.queryForObject<Int>(
"select count(*) from t_actor where first_name = ?", arrayOf("Joe"))!!
The following query looks for a String
String lastName = this.jdbcTemplate.queryForObject(
"select last_name from t_actor where id = ?",
String.class, 1212L);
val lastName = this.jdbcTemplate.queryForObject<String>(
arrayOf(1212L))!!
The following query finds and populates a single domain object:
Actor actor = jdbcTemplate.queryForObject(
"select first_name, last_name from t_actor where id = ?",
(resultSet, rowNum) -> {
Actor newActor = new Actor();
newActor.setFirstName(resultSet.getString("first_name"));
newActor.setLastName(resultSet.getString("last_name"));
return newActor;
1212L);
val actor = jdbcTemplate.queryForObject(
arrayOf(1212L)) { rs, _ ->
Actor(rs.getString("first_name"), rs.getString("last_name"))
The following query finds and populates a list of domain objects:
List<Actor> actors = this.jdbcTemplate.query(
"select first_name, last_name from t_actor",
Actor actor = new Actor();
actor.setFirstName(resultSet.getString("first_name"));
actor.setLastName(resultSet.getString("last_name"));
return actor;
val actors = jdbcTemplate.query("select first_name, last_name from t_actor") { rs, _ ->
If the last two snippets of code actually existed in the same application, it would make
sense to remove the duplication present in the two RowMapper
lambda expressions and
extract them out into a single field that could then be referenced by DAO methods as needed.
For example, it may be better to write the preceding code snippet as follows:
private final RowMapper<Actor> actorRowMapper = (resultSet, rowNum) -> {
return actor;
public List<Actor> findAllActors() {
return this.jdbcTemplate.query("select first_name, last_name from t_actor", actorRowMapper);
val actorMapper = RowMapper<Actor> { rs: ResultSet, rowNum: Int ->
fun findAllActors(): List<Actor> {
return jdbcTemplate.query("select first_name, last_name from t_actor", actorMapper)
Updating (INSERT
, UPDATE
, and DELETE
) with JdbcTemplate
You can use the update(..)
method to perform insert, update, and delete operations.
Parameter values are usually provided as variable arguments or, alternatively, as an object array.
The following example inserts a new entry:
this.jdbcTemplate.update(
"insert into t_actor (first_name, last_name) values (?, ?)",
"Leonor", "Watling");
The following example updates an existing entry:
"update t_actor set last_name = ? where id = ?",
"Banjo", 5276L);
"Banjo", 5276L)
The following example deletes an entry:
"delete from t_actor where id = ?",
Long.valueOf(actorId));
jdbcTemplate.update("delete from t_actor where id = ?", actorId.toLong())
Other JdbcTemplate
Operations
You can use the execute(..)
method to run any arbitrary SQL. Consequently, the
method is often used for DDL statements. It is heavily overloaded with variants that take
callback interfaces, binding variable arrays, and so on. The following example creates a
table:
this.jdbcTemplate.execute("create table mytable (id integer, name varchar(100))");
The following example invokes a stored procedure:
"call SUPPORT.REFRESH_ACTORS_SUMMARY(?)",
Long.valueOf(unionId));
unionId.toLong())
More sophisticated stored procedure support is covered later.
JdbcTemplate
Best Practices
Instances of the JdbcTemplate
class are thread-safe, once configured. This is
important because it means that you can configure a single instance of a JdbcTemplate
and then safely inject this shared reference into multiple DAOs (or repositories).
The JdbcTemplate
is stateful, in that it maintains a reference to a DataSource
, but
this state is not conversational state.
A common practice when using the JdbcTemplate
class (and the associated
class) is to
configure a DataSource
in your Spring configuration file and then dependency-inject
that shared DataSource
bean into your DAO classes. The JdbcTemplate
is created in
the setter for the DataSource
. This leads to DAOs that resemble the following:
public class JdbcCorporateEventDao implements CorporateEventDao {
public void setDataSource(DataSource dataSource) {
// JDBC-backed implementations of the methods on the CorporateEventDao follow...
class JdbcCorporateEventDao(dataSource: DataSource) : CorporateEventDao {
The following example shows the corresponding XML configuration:
xmlns:context="http://www.springframework.org/schema/context"
xsi:schemaLocation="
https://www.springframework.org/schema/context/spring-context.xsd">
<bean id="corporateEventDao" class="com.example.JdbcCorporateEventDao">
<property name="dataSource" ref="dataSource"/>
</bean>
<bean id="dataSource" class="org.apache.commons.dbcp.BasicDataSource" destroy-method="close">
<property name="driverClassName" value="${jdbc.driverClassName}"/>
<property name="url" value="${jdbc.url}"/>
<property name="username" value="${jdbc.username}"/>
<property name="password" value="${jdbc.password}"/>
</bean>
<context:property-placeholder location="jdbc.properties"/>
</beans>
An alternative to explicit configuration is to use component-scanning and annotation
support for dependency injection. In this case, you can annotate the class with @Repository
(which makes it a candidate for component-scanning) and annotate the DataSource
setter
method with @Autowired
. The following example shows how to do so:
@Repository (1)
@Autowired (2)
this.jdbcTemplate = new JdbcTemplate(dataSource); (3)
1 | Annotate the class with @Repository . |
2 | Annotate the DataSource setter method with @Autowired . |
3 | Create a new JdbcTemplate with the DataSource . |
@Repository (1)
class JdbcCorporateEventDao(dataSource: DataSource) : CorporateEventDao { (2)
private val jdbcTemplate = JdbcTemplate(dataSource) (3)
2 | Constructor injection of the DataSource . |
<!-- Scans within the base package of the application for @Component classes to configure as beans -->
<context:component-scan base-package="org.springframework.docs.test" />
</bean>
</beans>
If you use Spring’s JdbcDaoSupport
class and your various JDBC-backed DAO classes
extend from it, your sub-class inherits a setDataSource(..)
method from the
JdbcDaoSupport
class. You can choose whether to inherit from this class. The
JdbcDaoSupport
class is provided as a convenience only.
Regardless of which of the above template initialization styles you choose to use (or
not), it is seldom necessary to create a new instance of a JdbcTemplate
class each
time you want to run SQL. Once configured, a JdbcTemplate
instance is thread-safe.
If your application accesses multiple
databases, you may want multiple JdbcTemplate
instances, which requires multiple DataSources
and, subsequently, multiple differently
configured JdbcTemplate
instances.
3.3.2. Using NamedParameterJdbcTemplate
The NamedParameterJdbcTemplate
class adds support for programming JDBC statements
by using named parameters, as opposed to programming JDBC statements using only classic
placeholder ( '?'
) arguments. The NamedParameterJdbcTemplate
class wraps a
JdbcTemplate
and delegates to the wrapped JdbcTemplate
to do much of its work. This
section describes only those areas of the NamedParameterJdbcTemplate
class that differ
from the JdbcTemplate
itself — namely, programming JDBC statements by using named
parameters. The following example shows how to use NamedParameterJdbcTemplate
// some JDBC-backed DAO class...
private NamedParameterJdbcTemplate namedParameterJdbcTemplate;
this.namedParameterJdbcTemplate = new NamedParameterJdbcTemplate(dataSource);
public int countOfActorsByFirstName(String firstName) {
String sql = "select count(*) from t_actor where first_name = :first_name";
SqlParameterSource namedParameters = new MapSqlParameterSource("first_name", firstName);
return this.namedParameterJdbcTemplate.queryForObject(sql, namedParameters, Integer.class);
private val namedParameterJdbcTemplate = NamedParameterJdbcTemplate(dataSource)
fun countOfActorsByFirstName(firstName: String): Int {
val sql = "select count(*) from t_actor where first_name = :first_name"
val namedParameters = MapSqlParameterSource("first_name", firstName)
return namedParameterJdbcTemplate.queryForObject(sql, namedParameters, Int::class.java)!!
Notice the use of the named parameter notation in the value assigned to the sql
variable and the corresponding value that is plugged into the namedParameters
variable (of type MapSqlParameterSource
Alternatively, you can pass along named parameters and their corresponding values to a
instance by using the Map
-based style. The remaining
methods exposed by the NamedParameterJdbcOperations
and implemented by the
class follow a similar pattern and are not covered here.
The following example shows the use of the Map
-based style:
Map<String, String> namedParameters = Collections.singletonMap("first_name", firstName);
val namedParameters = mapOf("first_name" to firstName)
One nice feature related to the NamedParameterJdbcTemplate
(and existing in the same
Java package) is the SqlParameterSource
interface. You have already seen an example of
an implementation of this interface in one of the previous code snippets (the
class). An SqlParameterSource
is a source of named parameter
values to a NamedParameterJdbcTemplate
. The MapSqlParameterSource
class is a
simple implementation that is an adapter around a java.util.Map
, where the keys
are the parameter names and the values are the parameter values.
Another SqlParameterSource
implementation is the BeanPropertySqlParameterSource
class. This class wraps an arbitrary JavaBean (that is, an instance of a class that
adheres to the
JavaBean conventions) and uses the properties of the wrapped JavaBean as the source
of named parameter values.
The following example shows a typical JavaBean:
public class Actor {
private Long id;
private String firstName;
private String lastName;
public String getFirstName() {
return this.firstName;
public String getLastName() {
return this.lastName;
public Long getId() {
return this.id;
// setters omitted...
data class Actor(val id: Long, val firstName: String, val lastName: String)
The following example uses a NamedParameterJdbcTemplate
to return the count of the
members of the class shown in the preceding example:
public int countOfActors(Actor exampleActor) {
// notice how the named parameters match the properties of the above 'Actor' class
String sql = "select count(*) from t_actor where first_name = :firstName and last_name = :lastName";
SqlParameterSource namedParameters = new BeanPropertySqlParameterSource(exampleActor);
fun countOfActors(exampleActor: Actor): Int {
val sql = "select count(*) from t_actor where first_name = :firstName and last_name = :lastName"
val namedParameters = BeanPropertySqlParameterSource(exampleActor)
Remember that the NamedParameterJdbcTemplate
class wraps a classic JdbcTemplate
template. If you need access to the wrapped JdbcTemplate
instance to access
functionality that is present only in the JdbcTemplate
class, you can use the
getJdbcOperations()
method to access the wrapped JdbcTemplate
through the
JdbcOperations
interface.
See also JdbcTemplate
Best Practices for guidelines on using the
class in the context of an application.
3.3.3. Using SQLExceptionTranslator
is an interface to be implemented by classes that can translate
between SQLException
s and Spring’s own org.springframework.dao.DataAccessException
which is agnostic in regard to data access strategy. Implementations can be generic (for
example, using SQLState codes for JDBC) or proprietary (for example, using Oracle error
codes) for greater precision. This exception translation mechanism is used behind the
the common JdbcTemplate
and JdbcTransactionManager
entry points which do not
propagate SQLException
but rather DataAccessException
SQLErrorCodeSQLExceptionTranslator
is the implementation of SQLExceptionTranslator
that is used by default. This implementation uses specific vendor codes. It is more
precise than the SQLState
implementation. The error code translations are based on
codes held in a JavaBean type class called SQLErrorCodes
. This class is created and
populated by an SQLErrorCodesFactory
, which (as the name suggests) is a factory for
creating SQLErrorCodes
based on the contents of a configuration file named
sql-error-codes.xml
. This file is populated with vendor codes and based on the
DatabaseProductName
taken from DatabaseMetaData
. The codes for the actual
database you are using are used.
The SQLErrorCodeSQLExceptionTranslator
applies matching rules in the following sequence:
Any custom translation implemented by a subclass. Normally, the provided concrete
is used, so this rule does not apply. It applies only if you have actually provided a subclass implementation. -
Any custom implementation of the
interface that is provided as thecustomSqlExceptionTranslator
property of theSQLErrorCodes
class. -
The list of instances of the
CustomSQLErrorCodesTranslation
class (provided for thecustomTranslations
class) are searched for a match. -
Error code matching is applied.
Use the fallback translator.
SQLExceptionSubclassTranslator
is the default fallback translator. If this translation is not available, the next fallback translator is theSQLStateSQLExceptionTranslator
The SQLErrorCodesFactory is used by default to define error codes and custom
exception translations. They are looked up in a file named sql-error-codes.xml from the
classpath, and the matching SQLErrorCodes instance is located based on the database
name from the database metadata of the database in use.
You can extend SQLErrorCodeSQLExceptionTranslator
, as the following example shows:
public class CustomSQLErrorCodesTranslator extends SQLErrorCodeSQLExceptionTranslator {
protected DataAccessException customTranslate(String task, String sql, SQLException sqlEx) {
if (sqlEx.getErrorCode() == -12345) {
return new DeadlockLoserDataAccessException(task, sqlEx);
return null;
class CustomSQLErrorCodesTranslator : SQLErrorCodeSQLExceptionTranslator() {
override fun customTranslate(task: String, sql: String?, sqlEx: SQLException): DataAccessException? {
if (sqlEx.errorCode == -12345) {
return DeadlockLoserDataAccessException(task, sqlEx)
return null
In the preceding example, the specific error code (-12345
) is translated while
other errors are left to be translated by the default translator implementation.
To use this custom translator, you must pass it to the JdbcTemplate
through the
method setExceptionTranslator
, and you must use this JdbcTemplate
for all of the
data access processing where this translator is needed. The following example shows
how you can use this custom translator:
// create a JdbcTemplate and set data source
this.jdbcTemplate = new JdbcTemplate();
this.jdbcTemplate.setDataSource(dataSource);
// create a custom translator and set the DataSource for the default translation lookup
CustomSQLErrorCodesTranslator tr = new CustomSQLErrorCodesTranslator();
tr.setDataSource(dataSource);
this.jdbcTemplate.setExceptionTranslator(tr);
public void updateShippingCharge(long orderId, long pct) {
// use the prepared JdbcTemplate for this update
this.jdbcTemplate.update("update orders" +
" set shipping_charge = shipping_charge * ? / 100" +
" where id = ?", pct, orderId);
private val jdbcTemplate = JdbcTemplate(dataSource).apply {
exceptionTranslator = CustomSQLErrorCodesTranslator().apply {
this.dataSource = dataSource
fun updateShippingCharge(orderId: Long, pct: Long) {
this.jdbcTemplate!!.update("update orders" +
The custom translator is passed a data source in order to look up the error codes in
sql-error-codes.xml
3.3.4. Running Statements
Running an SQL statement requires very little code. You need a DataSource
and a
JdbcTemplate
, including the convenience methods that are provided with the
JdbcTemplate
. The following example shows what you need to include for a minimal but
fully functional class that creates a new table:
import javax.sql.DataSource;
import org.springframework.jdbc.core.JdbcTemplate;
public class ExecuteAStatement {
public void doExecute() {
class ExecuteAStatement(dataSource: DataSource) {
fun doExecute() {
3.3.5. Running Queries
Some query methods return a single value. To retrieve a count or a specific value from
one row, use queryForObject(..)
. The latter converts the returned JDBC Type
to the
Java class that is passed in as an argument. If the type conversion is invalid, an
InvalidDataAccessApiUsageException
is thrown. The following example contains two
query methods, one for an int
and one that queries for a String
public class RunAQuery {
public int getCount() {
return this.jdbcTemplate.queryForObject("select count(*) from mytable", Integer.class);
public String getName() {
return this.jdbcTemplate.queryForObject("select name from mytable", String.class);
class RunAQuery(dataSource: DataSource) {
val count: Int
get() = jdbcTemplate.queryForObject("select count(*) from mytable")!!
val name: String?
get() = jdbcTemplate.queryForObject("select name from mytable")
In addition to the single result query methods, several methods return a list with an
entry for each row that the query returned. The most generic method is queryForList(..)
which returns a List
where each element is a Map
containing one entry for each column,
using the column name as the key. If you add a method to the preceding example to retrieve a
list of all the rows, it might be as follows:
public List<Map<String, Object>> getList() {
return this.jdbcTemplate.queryForList("select * from mytable");
fun getList(): List<Map<String, Any>> {
return jdbcTemplate.queryForList("select * from mytable")
The returned list would resemble the following:
[{name=Bob, id=1}, {name=Mary, id=2}]
3.3.6. Updating the Database
The following example updates a column for a certain primary key:
public class ExecuteAnUpdate {
public void setName(int id, String name) {
this.jdbcTemplate.update("update mytable set name = ? where id = ?", name, id);
class ExecuteAnUpdate(dataSource: DataSource) {
fun setName(id: Int, name: String) {
In the preceding example, an SQL statement has placeholders for row parameters. You can pass the parameter values in as varargs or, alternatively, as an array of objects. Thus, you should explicitly wrap primitives in the primitive wrapper classes, or you should use auto-boxing.
3.3.7. Retrieving Auto-generated Keys
An update()
convenience method supports the retrieval of primary keys generated by the
database. This support is part of the JDBC 3.0 standard. See Chapter 13.6 of the
specification for details. The method takes a PreparedStatementCreator
as its first
argument, and this is the way the required insert statement is specified. The other
argument is a KeyHolder
, which contains the generated key on successful return from the
update. There is no standard single way to create an appropriate PreparedStatement
(which explains why the method signature is the way it is). The following example works
on Oracle but may not work on other platforms:
final String INSERT_SQL = "insert into my_test (name) values(?)";
final String name = "Rob";
KeyHolder keyHolder = new GeneratedKeyHolder();
jdbcTemplate.update(connection -> {
PreparedStatement ps = connection.prepareStatement(INSERT_SQL, new String[] { "id" });
ps.setString(1, name);
return ps;
}, keyHolder);
// keyHolder.getKey() now contains the generated key
val INSERT_SQL = "insert into my_test (name) values(?)"
val name = "Rob"
val keyHolder = GeneratedKeyHolder()
jdbcTemplate.update({
it.prepareStatement (INSERT_SQL, arrayOf("id")).apply { setString(1, name) }
}, keyHolder)
3.4. Controlling Database Connections
This section covers:
3.4.1. Using DataSource
Spring obtains a connection to the database through a DataSource
. A DataSource
is
part of the JDBC specification and is a generalized connection factory. It lets a
container or a framework hide connection pooling and transaction management issues
from the application code. As a developer, you need not know details about how to
connect to the database. That is the responsibility of the administrator who sets up
the datasource. You most likely fill both roles as you develop and test code, but you
do not necessarily have to know how the production data source is configured.
When you use Spring’s JDBC layer, you can obtain a data source from JNDI, or you can
configure your own with a connection pool implementation provided by a third party.
Traditional choices are Apache Commons DBCP and C3P0 with bean-style DataSource
classes;
for a modern JDBC connection pool, consider HikariCP with its builder-style API instead.
You should use the DriverManagerDataSource and SimpleDriverDataSource classes
(as included in the Spring distribution) only for testing purposes! Those variants do not
provide pooling and perform poorly when multiple requests for a connection are made.
The following section uses Spring’s DriverManagerDataSource
implementation.
Several other DataSource
variants are covered later.
To configure a DriverManagerDataSource
Obtain a connection with
as you typically obtain a JDBC connection. -
Specify the fully qualified classname of the JDBC driver so that the
DriverManager
can load the driver class. -
Provide a URL that varies between JDBC drivers. (See the documentation for your driver for the correct value.)
Provide a username and a password to connect to the database.
The following example shows how to configure a DriverManagerDataSource
in Java:
DriverManagerDataSource dataSource = new DriverManagerDataSource();
dataSource.setDriverClassName("org.hsqldb.jdbcDriver");
dataSource.setUrl("jdbc:hsqldb:hsql://localhost:");
dataSource.setUsername("sa");
dataSource.setPassword("");
val dataSource = DriverManagerDataSource().apply {
url = "jdbc:hsqldb:hsql://localhost:"
username = "sa"
password = ""
<bean id="dataSource" class="org.springframework.jdbc.datasource.DriverManagerDataSource">
</bean>
The next two examples show the basic connectivity and configuration for DBCP and C3P0. To learn about more options that help control the pooling features, see the product documentation for the respective connection pooling implementations.
The following example shows DBCP configuration:
</bean>
The following example shows C3P0 configuration:
<bean id="dataSource" class="com.mchange.v2.c3p0.ComboPooledDataSource" destroy-method="close">
<property name="driverClass" value="${jdbc.driverClassName}"/>
<property name="jdbcUrl" value="${jdbc.url}"/>
<property name="user" value="${jdbc.username}"/>
</bean>
3.4.2. Using DataSourceUtils
The DataSourceUtils
class is a convenient and powerful helper class that provides
static
methods to obtain connections from JNDI and close connections if necessary.
It supports a thread-bound JDBC Connection
with DataSourceTransactionManager
but
also with JtaTransactionManager
and JpaTransactionManager
Note that JdbcTemplate
implies DataSourceUtils
connection access, using it
behind every JDBC operation, implicitly participating in an ongoing transaction.
3.4.3. Implementing SmartDataSource
The SmartDataSource
interface should be implemented by classes that can provide a
connection to a relational database. It extends the DataSource
interface to let
classes that use it query whether the connection should be closed after a given
operation. This usage is efficient when you know that you need to reuse a connection.
3.4.4. Extending AbstractDataSource
AbstractDataSource
is an abstract
base class for Spring’s DataSource
implementations. It implements code that is common to all DataSource
implementations.
You should extend the AbstractDataSource
class if you write your own DataSource
implementation.
3.4.5. Using SingleConnectionDataSource
The SingleConnectionDataSource
class is an implementation of the SmartDataSource
interface that wraps a single Connection
that is not closed after each use.
This is not multi-threading capable.
If any client code calls close
on the assumption of a pooled connection (as when using
persistence tools), you should set the suppressClose
property to true
. This setting
returns a close-suppressing proxy that wraps the physical connection. Note that you can
no longer cast this to a native Oracle Connection
or a similar object.
is primarily a test class. It typically enables easy testing
of code outside an application server, in conjunction with a simple JNDI environment.
In contrast to DriverManagerDataSource
, it reuses the same connection all the time,
avoiding excessive creation of physical connections.
3.4.6. Using DriverManagerDataSource
The DriverManagerDataSource
class is an implementation of the standard DataSource
interface that configures a plain JDBC driver through bean properties and returns a new
Connection
every time.
This implementation is useful for test and stand-alone environments outside of a Java EE
container, either as a DataSource
bean in a Spring IoC container or in conjunction
with a simple JNDI environment. Pool-assuming Connection.close()
calls
close the connection, so any DataSource
-aware persistence code should work. However,
using JavaBean-style connection pools (such as commons-dbcp
) is so easy, even in a test
environment, that it is almost always preferable to use such a connection pool over
3.4.7. Using TransactionAwareDataSourceProxy
is a proxy for a target DataSource
. The proxy wraps that
target DataSource
to add awareness of Spring-managed transactions. In this respect, it
is similar to a transactional JNDI DataSource
, as provided by a Java EE server.
It is rarely desirable to use this class, except when already existing code must be
called and passed a standard JDBC DataSource interface implementation. In this case,
you can still have this code be usable and, at the same time, have this code
participating in Spring managed transactions. It is generally preferable to write your
own new code by using the higher level abstractions for resource management, such as
JdbcTemplate or DataSourceUtils .
See the TransactionAwareDataSourceProxy
javadoc for more details.
3.4.8. Using DataSourceTransactionManager
/ JdbcTransactionManager
The DataSourceTransactionManager
class is a PlatformTransactionManager
implementation for a single JDBC DataSource
. It binds a JDBC Connection
from the specified DataSource
to the currently executing thread, potentially
allowing for one thread-bound Connection
per DataSource
Application code is required to retrieve the JDBC Connection
through
DataSourceUtils.getConnection(DataSource)
instead of Java EE’s standard
DataSource.getConnection
. It throws unchecked org.springframework.dao
exceptions
instead of checked SQLExceptions
. All framework classes (such as JdbcTemplate
) use
this strategy implicitly. If not used with a transaction manager, the lookup strategy
behaves exactly like DataSource.getConnection
and can therefore be used in any case.
class supports savepoints (PROPAGATION_NESTED
custom isolation levels, and timeouts that get applied as appropriate JDBC statement
query timeouts. To support the latter, application code must either use JdbcTemplate
or
call the DataSourceUtils.applyTransactionTimeout(..)
method for each created statement.
You can use DataSourceTransactionManager
instead of JtaTransactionManager
in the
single-resource case, as it does not require the container to support a JTA transaction
coordinator. Switching between these transaction managers is just a matter of configuration,
provided you stick to the required connection lookup pattern. Note that JTA does not support
savepoints or custom isolation levels and has a different timeout mechanism but otherwise
exposes similar behavior in terms of JDBC resources and JDBC commit/rollback management.
As of 5.3, Spring provides an extended In terms of exception behavior, |
3.5. JDBC Batch Operations
Most JDBC drivers provide improved performance if you batch multiple calls to the same prepared statement. By grouping updates into batches, you limit the number of round trips to the database.
3.5.1. Basic Batch Operations with JdbcTemplate
You accomplish JdbcTemplate
batch processing by implementing two methods of a special interface,
BatchPreparedStatementSetter
, and passing that implementation in as the second parameter
in your batchUpdate
method call. You can use the getBatchSize
method to provide the size of
the current batch. You can use the setValues
method to set the values for the parameters of
the prepared statement. This method is called the number of times that you specified in the
getBatchSize
call. The following example updates the t_actor
table based on entries in a list,
and the entire list is used as the batch:
public class JdbcActorDao implements ActorDao {
public int[] batchUpdate(final List<Actor> actors) {
return this.jdbcTemplate.batchUpdate(
"update t_actor set first_name = ?, last_name = ? where id = ?",
new BatchPreparedStatementSetter() {
public void setValues(PreparedStatement ps, int i) throws SQLException {
Actor actor = actors.get(i);
ps.setString(1, actor.getFirstName());
ps.setString(2, actor.getLastName());
ps.setLong(3, actor.getId().longValue());
public int getBatchSize() {
return actors.size();
// ... additional methods
class JdbcActorDao(dataSource: DataSource) : ActorDao {
fun batchUpdate(actors: List<Actor>): IntArray {
return jdbcTemplate.batchUpdate(
object: BatchPreparedStatementSetter {
override fun setValues(ps: PreparedStatement, i: Int) {
ps.setString(1, actors[i].firstName)
ps.setString(2, actors[i].lastName)
ps.setLong(3, actors[i].id)
override fun getBatchSize() = actors.size
If you process a stream of updates or reading from a file, you might have a
preferred batch size, but the last batch might not have that number of entries. In this
case, you can use the InterruptibleBatchPreparedStatementSetter
interface, which lets
you interrupt a batch once the input source is exhausted. The isBatchExhausted
method
lets you signal the end of the batch.
3.5.2. Batch Operations with a List of Objects
Both the JdbcTemplate
and the NamedParameterJdbcTemplate
provides an alternate way
of providing the batch update. Instead of implementing a special batch interface, you
provide all parameter values in the call as a list. The framework loops over these
values and uses an internal prepared statement setter. The API varies, depending on
whether you use named parameters. For the named parameters, you provide an array of
SqlParameterSource
, one entry for each member of the batch. You can use the
SqlParameterSourceUtils.createBatch
convenience methods to create this array, passing
in an array of bean-style objects (with getter methods corresponding to parameters),
String
-keyed Map
instances (containing the corresponding parameters as values), or a mix of both.
The following example shows a batch update using named parameters:
private NamedParameterTemplate namedParameterJdbcTemplate;
public int[] batchUpdate(List<Actor> actors) {
return this.namedParameterJdbcTemplate.batchUpdate(
"update t_actor set first_name = :firstName, last_name = :lastName where id = :id",
SqlParameterSourceUtils.createBatch(actors));
For an SQL statement that uses the classic ?
placeholders, you pass in a list
containing an object array with the update values. This object array must have one entry
for each placeholder in the SQL statement, and they must be in the same order as they are
defined in the SQL statement.
The following example is the same as the preceding example, except that it uses classic
JDBC ?
placeholders:
List<Object[]> batch = new ArrayList<Object[]>();
for (Actor actor : actors) {
Object[] values = new Object[] {
actor.getFirstName(), actor.getLastName(), actor.getId()};
batch.add(values);
batch);
val batch = mutableListOf<Array<Any>>()
for (actor in actors) {
batch.add(arrayOf(actor.firstName, actor.lastName, actor.id))
"update t_actor set first_name = ?, last_name = ? where id = ?", batch)
All of the batch update methods that we described earlier return an int
array
containing the number of affected rows for each batch entry. This count is reported by
the JDBC driver. If the count is not available, the JDBC driver returns a value of -2
In such a scenario, with automatic setting of values on an underlying Alternatively, you might consider specifying the corresponding JDBC types explicitly,
either through a |
3.5.3. Batch Operations with Multiple Batches
The preceding example of a batch update deals with batches that are so large that you want to
break them up into several smaller batches. You can do this with the methods
mentioned earlier by making multiple calls to the batchUpdate
method, but there is now a
more convenient method. This method takes, in addition to the SQL statement, a
Collection
of objects that contain the parameters, the number of updates to make for each
batch, and a ParameterizedPreparedStatementSetter
of the prepared statement. The framework loops over the provided values and breaks the
update calls into batches of the size specified.
The following example shows a batch update that uses a batch size of 100:
public int[][] batchUpdate(final Collection<Actor> actors) {
int[][] updateCounts = jdbcTemplate.batchUpdate(
actors,
100,
(PreparedStatement ps, Actor actor) -> {
return updateCounts;
fun batchUpdate(actors: List<Actor>): Array<IntArray> {
actors, 100) { ps, argument ->
ps.setString(1, argument.firstName)
ps.setString(2, argument.lastName)
ps.setLong(3, argument.id)
The batch update method for this call returns an array of int
arrays that contains an
array entry for each batch with an array of the number of affected rows for each update.
The top-level array’s length indicates the number of batches run, and the second level
array’s length indicates the number of updates in that batch. The number of updates in
each batch should be the batch size provided for all batches (except that the last one
that might be less), depending on the total number of update objects provided. The update
count for each update statement is the one reported by the JDBC driver. If the count is
3.6. Simplifying JDBC Operations with the SimpleJdbc
Classes
The SimpleJdbcInsert
and SimpleJdbcCall
classes provide a simplified configuration
by taking advantage of database metadata that can be retrieved through the JDBC driver.
This means that you have less to configure up front, although you can override or turn off
the metadata processing if you prefer to provide all the details in your code.
3.6.1. Inserting Data by Using SimpleJdbcInsert
We start by looking at the SimpleJdbcInsert
class with the minimal amount of
configuration options. You should instantiate the SimpleJdbcInsert
in the data access
layer’s initialization method. For this example, the initializing method is the
setDataSource
method. You do not need to subclass the SimpleJdbcInsert
class. Instead,
you can create a new instance and set the table name by using the withTableName
method.
Configuration methods for this class follow the fluid
style that returns the instance
of the SimpleJdbcInsert
, which lets you chain all configuration methods. The following
example uses only one configuration method (we show examples of multiple methods later):
private SimpleJdbcInsert insertActor;
this.insertActor = new SimpleJdbcInsert(dataSource).withTableName("t_actor");
public void add(Actor actor) {
Map<String, Object> parameters = new HashMap<String, Object>(3);
parameters.put("id", actor.getId());
parameters.put("first_name", actor.getFirstName());
parameters.put("last_name", actor.getLastName());
insertActor.execute(parameters);
private val insertActor = SimpleJdbcInsert(dataSource).withTableName("t_actor")
fun add(actor: Actor) {
val parameters = mutableMapOf<String, Any>()
parameters["id"] = actor.id
parameters["first_name"] = actor.firstName
parameters["last_name"] = actor.lastName
The execute
method used here takes a plain java.util.Map
as its only parameter. The
important thing to note here is that the keys used for the Map
must match the column
names of the table, as defined in the database. This is because we read the metadata
to construct the actual insert statement.
3.6.2. Retrieving Auto-generated Keys by Using SimpleJdbcInsert
The next example uses the same insert as the preceding example, but, instead of passing in the id
, it
retrieves the auto-generated key and sets it on the new Actor
object. When it creates
, in addition to specifying the table name, it specifies the name
of the generated key column with the usingGeneratedKeyColumns
method. The following
listing shows how it works:
.usingGeneratedKeyColumns("id");
Map<String, Object> parameters = new HashMap<String, Object>(2);
Number newId = insertActor.executeAndReturnKey(parameters);
actor.setId(newId.longValue());
.withTableName("t_actor").usingGeneratedKeyColumns("id")
fun add(actor: Actor): Actor {
val parameters = mapOf(
"first_name" to actor.firstName,
"last_name" to actor.lastName)
val newId = insertActor.executeAndReturnKey(parameters);
return actor.copy(id = newId.toLong())
The main difference when you run the insert by using this second approach is that you do not
add the id
to the Map
, and you call the executeAndReturnKey
method. This returns a
java.lang.Number
object with which you can create an instance of the numerical type that
is used in your domain class. You cannot rely on all databases to return a specific Java
class here. java.lang.Number
is the base class that you can rely on. If you have
multiple auto-generated columns or the generated values are non-numeric, you can
use a KeyHolder
that is returned from the executeAndReturnKeyHolder
method.
3.6.3. Specifying Columns for a SimpleJdbcInsert
You can limit the columns for an insert by specifying a list of column names with the
usingColumns
method, as the following example shows:
.usingColumns("first_name", "last_name")
The execution of the insert is the same as if you had relied on the metadata to determine which columns to use.
3.6.4. Using SqlParameterSource
to Provide Parameter Values
Using a Map
to provide parameter values works fine, but it is not the most convenient
class to use. Spring provides a couple of implementations of the SqlParameterSource
interface that you can use instead. The first one is BeanPropertySqlParameterSource
which is a very convenient class if you have a JavaBean-compliant class that contains
your values. It uses the corresponding getter method to extract the parameter
values. The following example shows how to use BeanPropertySqlParameterSource
SqlParameterSource parameters = new BeanPropertySqlParameterSource(actor);
val parameters = BeanPropertySqlParameterSource(actor)
Another option is the MapSqlParameterSource
that resembles a Map
but provides a more
convenient addValue
method that can be chained. The following example shows how to use it:
SqlParameterSource parameters = new MapSqlParameterSource()
.addValue("first_name", actor.getFirstName())
.addValue("last_name", actor.getLastName());
val parameters = MapSqlParameterSource()
.addValue("first_name", actor.firstName)
.addValue("last_name", actor.lastName)
As you can see, the configuration is the same. Only the executing code has to change to use these alternative input classes.
3.6.5. Calling a Stored Procedure with SimpleJdbcCall
The SimpleJdbcCall
class uses metadata in the database to look up names of in
and out
parameters so that you do not have to explicitly declare them. You can
declare parameters if you prefer to do that or if you have parameters (such as ARRAY
or STRUCT
) that do not have an automatic mapping to a Java class. The first example
shows a simple procedure that returns only scalar values in VARCHAR
and DATE
format
from a MySQL database. The example procedure reads a specified actor entry and returns
first_name
, last_name
, and birth_date
columns in the form of out
parameters.
The following listing shows the first example:
CREATE PROCEDURE read_actor (
IN in_id INTEGER,
OUT out_first_name VARCHAR(100),
OUT out_last_name VARCHAR(100),
OUT out_birth_date DATE)
BEGIN
SELECT first_name, last_name, birth_date
INTO out_first_name, out_last_name, out_birth_date
FROM t_actor where id = in_id;
END;
The in_id
parameter contains the id
of the actor that you are looking up. The out
parameters return the data read from the table.
You can declare SimpleJdbcCall
in a manner similar to declaring SimpleJdbcInsert
. You
should instantiate and configure the class in the initialization method of your data-access
layer. Compared to the StoredProcedure
class, you need not create a subclass
and you need not to declare parameters that can be looked up in the database metadata.
The following example of a SimpleJdbcCall
configuration uses the preceding stored
procedure (the only configuration option, in addition to the DataSource
, is the name
of the stored procedure):
private SimpleJdbcCall procReadActor;
this.procReadActor = new SimpleJdbcCall(dataSource)
.withProcedureName("read_actor");
public Actor readActor(Long id) {
SqlParameterSource in = new MapSqlParameterSource()
.addValue("in_id", id);
Map out = procReadActor.execute(in);
actor.setId(id);
actor.setFirstName((String) out.get("out_first_name"));
actor.setLastName((String) out.get("out_last_name"));
actor.setBirthDate((Date) out.get("out_birth_date"));
return actor;
private val procReadActor = SimpleJdbcCall(dataSource)
fun readActor(id: Long): Actor {
val source = MapSqlParameterSource().addValue("in_id", id)
val output = procReadActor.execute(source)
return Actor(
id,
output["out_first_name"] as String,
output["out_last_name"] as String,
output["out_birth_date"] as Date)
The code you write for the execution of the call involves creating an SqlParameterSource
containing the IN parameter. You must match the name provided for the input value
with that of the parameter name declared in the stored procedure. The case does not have
to match because you use metadata to determine how database objects should be referred to
in a stored procedure. What is specified in the source for the stored procedure is not
necessarily the way it is stored in the database. Some databases transform names to all
upper case, while others use lower case or use the case as specified.
The execute
method takes the IN parameters and returns a Map
that contains any out
parameters keyed by the name, as specified in the stored procedure. In this case, they are
out_first_name
, out_last_name
, and out_birth_date
The last part of the execute
method creates an Actor
instance to use to return the
data retrieved. Again, it is important to use the names of the out
parameters as they
are declared in the stored procedure. Also, the case in the names of the out
parameters stored in the results map matches that of the out
parameter names in the
database, which could vary between databases. To make your code more portable, you should
do a case-insensitive lookup or instruct Spring to use a LinkedCaseInsensitiveMap
To do the latter, you can create your own JdbcTemplate
and set the setResultsMapCaseInsensitive
property to true
. Then you can pass this customized JdbcTemplate
instance into
the constructor of your SimpleJdbcCall
. The following example shows this configuration:
JdbcTemplate jdbcTemplate = new JdbcTemplate(dataSource);
jdbcTemplate.setResultsMapCaseInsensitive(true);
this.procReadActor = new SimpleJdbcCall(jdbcTemplate)
private var procReadActor = SimpleJdbcCall(JdbcTemplate(dataSource).apply {
isResultsMapCaseInsensitive = true
}).withProcedureName("read_actor")
By taking this action, you avoid conflicts in the case used for the names of your
returned out
parameters.
3.6.6. Explicitly Declaring Parameters to Use for a SimpleJdbcCall
Earlier in this chapter, we described how parameters are deduced from metadata, but you can declare them
explicitly if you wish. You can do so by creating and configuring SimpleJdbcCall
with
the declareParameters
method, which takes a variable number of SqlParameter
objects
as input. See the next section for details on how to define an SqlParameter
Explicit declarations are necessary if the database you use is not a Spring-supported database. Currently, Spring supports metadata lookup of stored procedure calls for the following databases: Apache Derby, DB2, MySQL, Microsoft SQL Server, Oracle, and Sybase. We also support metadata lookup of stored functions for MySQL, Microsoft SQL Server, and Oracle. |
You can opt to explicitly declare one, some, or all of the parameters. The parameter
metadata is still used where you do not explicitly declare parameters. To bypass all
processing of metadata lookups for potential parameters and use only the declared
parameters, you can call the method withoutProcedureColumnMetaDataAccess
as part of the
declaration. Suppose that you have two or more different call signatures declared for a
database function. In this case, you call useInParameterNames
to specify the list
of IN parameter names to include for a given signature.
The following example shows a fully declared procedure call and uses the information from the preceding example:
.withoutProcedureColumnMetaDataAccess()
.useInParameterNames("in_id")
.declareParameters(
new SqlParameter("in_id", Types.NUMERIC),
new SqlOutParameter("out_first_name", Types.VARCHAR),
new SqlOutParameter("out_last_name", Types.VARCHAR),
new SqlOutParameter("out_birth_date", Types.DATE)
private val procReadActor = SimpleJdbcCall(JdbcTemplate(dataSource).apply {
.declareParameters(
The execution and end results of the two examples are the same. The second example specifies all details explicitly rather than relying on metadata.
3.6.7. How to Define SqlParameters
To define a parameter for the SimpleJdbc
classes and also for the RDBMS operations
classes (covered in Modeling JDBC Operations as Java Objects) you can use SqlParameter
or one of its subclasses.
To do so, you typically specify the parameter name and SQL type in the constructor. The SQL type
is specified by using the java.sql.Types
constants. Earlier in this chapter, we saw declarations
similar to the following:
The first line with the SqlParameter
declares an IN parameter. You can use IN parameters
for both stored procedure calls and for queries by using the SqlQuery
and its
subclasses (covered in Understanding SqlQuery
The second line (with the SqlOutParameter
) declares an out
parameter to be used in a
stored procedure call. There is also an SqlInOutParameter
for InOut
parameters
(parameters that provide an IN value to the procedure and that also return a value).
Only parameters declared as SqlParameter and SqlInOutParameter are used to
provide input values. This is different from the StoredProcedure class, which (for
backwards compatibility reasons) lets input values be provided for parameters
declared as SqlOutParameter .
For IN parameters, in addition to the name and the SQL type, you can specify a scale for
numeric data or a type name for custom database types. For out
parameters, you can
provide a RowMapper
to handle mapping of rows returned from a REF
cursor. Another
option is to specify an SqlReturnType
that provides an opportunity to define
customized handling of the return values.
3.6.8. Calling a Stored Function by Using SimpleJdbcCall
You can call a stored function in almost the same way as you call a stored procedure, except
that you provide a function name rather than a procedure name. You use the
withFunctionName
method as part of the configuration to indicate that you want to make
a call to a function, and the corresponding string for a function call is generated. A
specialized call (executeFunction
) is used to run the function, and it
returns the function return value as an object of a specified type, which means you do
not have to retrieve the return value from the results map. A similar convenience method
(named executeObject
) is also available for stored procedures that have only one out
parameter. The following example (for MySQL) is based on a stored function named get_actor_name
that returns an actor’s full name:
CREATE FUNCTION get_actor_name (in_id INTEGER)
RETURNS VARCHAR(200) READS SQL DATA
BEGIN
DECLARE out_name VARCHAR(200);
SELECT concat(first_name, ' ', last_name)
INTO out_name
RETURN out_name;
END;
To call this function, we again create a SimpleJdbcCall
in the initialization method,
private SimpleJdbcCall funcGetActorName;
this.funcGetActorName = new SimpleJdbcCall(jdbcTemplate)
.withFunctionName("get_actor_name");
public String getActorName(Long id) {
String name = funcGetActorName.executeFunction(String.class, in);
return name;
private val funcGetActorName = SimpleJdbcCall(jdbcTemplate)
fun getActorName(id: Long): String {
return funcGetActorName.executeFunction(String::class.java, source)
The executeFunction
method used returns a String
that contains the return value from the
function call.
3.6.9. Returning a ResultSet
or REF Cursor from a SimpleJdbcCall
Calling a stored procedure or function that returns a result set is a bit tricky. Some
databases return result sets during the JDBC results processing, while others require an
explicitly registered out
parameter of a specific type. Both approaches need
additional processing to loop over the result set and process the returned rows. With
the SimpleJdbcCall
, you can use the returningResultSet
method and declare a RowMapper
implementation to be used for a specific parameter. If the result set is
returned during the results processing, there are no names defined, so the returned
results must match the order in which you declare the RowMapper
implementations. The name specified is still used to store the processed list of results
in the results map that is returned from the execute
statement.
The next example (for MySQL) uses a stored procedure that takes no IN parameters and returns
all rows from the t_actor
table:
CREATE PROCEDURE read_all_actors()
BEGIN
SELECT a.id, a.first_name, a.last_name, a.birth_date FROM t_actor a;
END;
To call this procedure, you can declare the RowMapper
. Because the class to which you want
to map follows the JavaBean rules, you can use a BeanPropertyRowMapper
that is created by
passing in the required class to map to in the newInstance
method.
private SimpleJdbcCall procReadAllActors;
this.procReadAllActors = new SimpleJdbcCall(jdbcTemplate)
.withProcedureName("read_all_actors")
.returningResultSet("actors",
BeanPropertyRowMapper.newInstance(Actor.class));
public List getActorsList() {
Map m = procReadAllActors.execute(new HashMap<String, Object>(0));
return (List) m.get("actors");
private val procReadAllActors = SimpleJdbcCall(JdbcTemplate(dataSource).apply {
}).withProcedureName("read_all_actors")
BeanPropertyRowMapper.newInstance(Actor::class.java))
fun getActorsList(): List<Actor> {
val m = procReadAllActors.execute(mapOf<String, Any>())
return m["actors"] as List<Actor>
The execute
call passes in an empty Map
, because this call does not take any parameters.
The list of actors is then retrieved from the results map and returned to the caller.
3.7. Modeling JDBC Operations as Java Objects
The org.springframework.jdbc.object
package contains classes that let you access
the database in a more object-oriented manner. As an example, you can run queries
and get the results back as a list that contains business objects with the relational
column data mapped to the properties of the business object. You can also run stored
procedures and run update, delete, and insert statements.
Many Spring developers believe that the various RDBMS operation classes described below
(with the exception of the However, if you are getting measurable value from using the RDBMS operation classes, you should continue to use these classes. |
3.7.1. Understanding SqlQuery
SqlQuery
is a reusable, thread-safe class that encapsulates an SQL query. Subclasses
must implement the newRowMapper(..)
method to provide a RowMapper
instance that can
create one object per row obtained from iterating over the ResultSet
that is created
during the execution of the query. The SqlQuery
class is rarely used directly, because
the MappingSqlQuery
subclass provides a much more convenient implementation for
mapping rows to Java classes. Other implementations that extend SqlQuery
are
MappingSqlQueryWithParameters
and UpdatableSqlQuery
3.7.2. Using MappingSqlQuery
MappingSqlQuery
is a reusable query in which concrete subclasses must implement the
abstract mapRow(..)
method to convert each row of the supplied ResultSet
into an
object of the type specified. The following example shows a custom query that maps the
data from the t_actor
relation to an instance of the Actor
class:
public class ActorMappingQuery extends MappingSqlQuery<Actor> {
public ActorMappingQuery(DataSource ds) {
super(ds, "select id, first_name, last_name from t_actor where id = ?");
declareParameter(new SqlParameter("id", Types.INTEGER));
compile();
protected Actor mapRow(ResultSet rs, int rowNumber) throws SQLException {
actor.setId(rs.getLong("id"));
actor.setFirstName(rs.getString("first_name"));
actor.setLastName(rs.getString("last_name"));
return actor;
class ActorMappingQuery(ds: DataSource) : MappingSqlQuery<Actor>(ds, "select id, first_name, last_name from t_actor where id = ?") {
init {
declareParameter(SqlParameter("id", Types.INTEGER))
compile()
override fun mapRow(rs: ResultSet, rowNumber: Int) = Actor(
rs.getLong("id"),
The class extends MappingSqlQuery
parameterized with the Actor
type. The constructor
for this customer query takes a DataSource
as the only parameter. In this
constructor, you can call the constructor on the superclass with the DataSource
and the SQL
that should be run to retrieve the rows for this query. This SQL is used to
create a PreparedStatement
, so it may contain placeholders for any parameters to be
passed in during execution. You must declare each parameter by using the declareParameter
method passing in an SqlParameter
. The SqlParameter
takes a name, and the JDBC type
as defined in java.sql.Types
. After you define all parameters, you can call the
compile()
method so that the statement can be prepared and later run. This class is
thread-safe after it is compiled, so, as long as these instances are created when the DAO
is initialized, they can be kept as instance variables and be reused. The following
example shows how to define such a class:
private ActorMappingQuery actorMappingQuery;
@Autowired
this.actorMappingQuery = new ActorMappingQuery(dataSource);
public Customer getCustomer(Long id) {
return actorMappingQuery.findObject(id);
private val actorMappingQuery = ActorMappingQuery(dataSource)
fun getCustomer(id: Long) = actorMappingQuery.findObject(id)
The method in the preceding example retrieves the customer with the id
that is passed in as the
only parameter. Since we want only one object to be returned, we call the findObject
convenience
method with the id
as the parameter. If we had instead a query that returned a
list of objects and took additional parameters, we would use one of the execute
methods that takes an array of parameter values passed in as varargs. The following
example shows such a method:
public List<Actor> searchForActors(int age, String namePattern) {
List<Actor> actors = actorSearchMappingQuery.execute(age, namePattern);
return actors;
fun searchForActors(age: Int, namePattern: String) =
3.7.3. Using SqlUpdate
The SqlUpdate
class encapsulates an SQL update. As with a query, an update object is
reusable, and, as with all RdbmsOperation
classes, an update can have parameters and is
defined in SQL. This class provides a number of update(..)
methods analogous to the
execute(..)
methods of query objects. The SqlUpdate
class is concrete. It can be
subclassed — for example, to add a custom update method.
However, you do not have to subclass the SqlUpdate
class, since it can easily be parameterized by setting SQL and declaring parameters.
The following example creates a custom update method named execute
import java.sql.Types;
import org.springframework.jdbc.core.SqlParameter;
import org.springframework.jdbc.object.SqlUpdate;
public class UpdateCreditRating extends SqlUpdate {
public UpdateCreditRating(DataSource ds) {
setDataSource(ds);
setSql("update customer set credit_rating = ? where id = ?");
declareParameter(new SqlParameter("creditRating", Types.NUMERIC));
declareParameter(new SqlParameter("id", Types.NUMERIC));
compile();
* @param id for the Customer to be updated
* @param rating the new value for credit rating
* @return number of rows updated
public int execute(int id, int rating) {
return update(rating, id);
.SqlUpdate
class UpdateCreditRating(ds: DataSource) : SqlUpdate() {
init {
setDataSource(ds)
sql = "update customer set credit_rating = ? where id = ?"
declareParameter(SqlParameter("creditRating", Types.NUMERIC))
declareParameter(SqlParameter("id", Types.NUMERIC))
compile()
fun execute(id: Int, rating: Int): Int {
3.7.4. Using StoredProcedure
The StoredProcedure
class is an abstract
superclass for object abstractions of RDBMS
stored procedures.
The inherited sql
property is the name of the stored procedure in the RDBMS.
To define a parameter for the StoredProcedure
class, you can use an SqlParameter
or one
of its subclasses. You must specify the parameter name and SQL type in the constructor,
as the following code snippet shows:
The SQL type is specified using the java.sql.Types
constants.
The first line (with the SqlParameter
) declares an IN parameter. You can use IN parameters
both for stored procedure calls and for queries using the SqlQuery
and its
) declares an out
parameter to be used in the
for InOut
parameters
(parameters that provide an in
For in
scale for numeric data or a type name for custom database types. For out
parameters,
you can provide a RowMapper
cursor.
Another option is to specify an SqlReturnType
that lets you define customized
The next example of a simple DAO uses a StoredProcedure
to call a function
(sysdate()
), which comes with any Oracle database. To use the stored procedure
functionality, you have to create a class that extends StoredProcedure
. In this
example, the StoredProcedure
class is an inner class. However, if you need to reuse the
StoredProcedure
, you can declare it as a top-level class. This example has no input
parameters, but an output parameter is declared as a date type by using the
SqlOutParameter
class. The execute()
method runs the procedure and extracts the
returned date from the results Map
. The results Map
has an entry for each declared
output parameter (in this case, only one) by using the parameter name as the key.
The following listing shows our custom StoredProcedure class:
import java.util.Date;
import java.util.HashMap;
import java.util.Map;
import org.springframework.beans.factory.annotation.Autowired;
import org.springframework.jdbc.core.SqlOutParameter;
import org.springframework.jdbc.object.StoredProcedure;
public class StoredProcedureDao {
private GetSysdateProcedure getSysdate;
@Autowired
public void init(DataSource dataSource) {
this.getSysdate = new GetSysdateProcedure(dataSource);
public Date getSysdate() {
return getSysdate.execute();
private class GetSysdateProcedure extends StoredProcedure {
private static final String SQL = "sysdate";
public GetSysdateProcedure(DataSource dataSource) {
setFunction(true);
setSql(SQL);
declareParameter(new SqlOutParameter("date", Types.DATE));
compile();
public Date execute() {
// the 'sysdate' sproc has no input parameters, so an empty Map is supplied...
Map<String, Object> results = execute(new HashMap<String, Object>());
Date sysdate = (Date) results.get("date");
return sysdate;
class StoredProcedureDao(dataSource: DataSource) {
private val SQL = "sysdate"
private val getSysdate = GetSysdateProcedure(dataSource)
val sysdate: Date
get() = getSysdate.execute()
private inner class GetSysdateProcedure(dataSource: DataSource) : StoredProcedure() {
init {
isFunction = true
sql = SQL
declareParameter(SqlOutParameter("date", Types.DATE))
compile()
fun execute(): Date {
val results = execute(mutableMapOf<String, Any>())
return results["date"] as Date
The following example of a StoredProcedure
has two output parameters (in this case,
Oracle REF cursors):
import oracle.jdbc.OracleTypes;
public class TitlesAndGenresStoredProcedure extends StoredProcedure {
private static final String SPROC_NAME = "AllTitlesAndGenres";
public TitlesAndGenresStoredProcedure(DataSource dataSource) {
super(dataSource, SPROC_NAME);
declareParameter(new SqlOutParameter("titles", OracleTypes.CURSOR, new TitleMapper()));
declareParameter(new SqlOutParameter("genres", OracleTypes.CURSOR, new GenreMapper()));
compile();
public Map<String, Object> execute() {
// again, this sproc has no input parameters, so an empty Map is supplied
return super.execute(new HashMap<String, Object>());
.StoredProcedure
class TitlesAndGenresStoredProcedure(dataSource: DataSource) : StoredProcedure(dataSource, SPROC_NAME) {
companion object {
private const val SPROC_NAME = "AllTitlesAndGenres"
init {
declareParameter(SqlOutParameter("titles", OracleTypes.CURSOR, TitleMapper()))
declareParameter(SqlOutParameter("genres", OracleTypes.CURSOR, GenreMapper()))
compile()
fun execute(): Map<String, Any> {
return super.execute(HashMap<String, Any>())
Notice how the overloaded variants of the declareParameter(..)
method that have been
used in the TitlesAndGenresStoredProcedure
constructor are passed RowMapper
implementation instances. This is a very convenient and powerful way to reuse existing
functionality. The next two examples provide code for the two RowMapper
implementations.
The TitleMapper
class maps a ResultSet
to a Title
domain object for each row in
, as follows:
import java.sql.ResultSet;
import java.sql.SQLException;
import com.foo.domain.Title;
import org.springframework.jdbc.core.RowMapper;
public final class TitleMapper implements RowMapper<Title> {
public Title mapRow(ResultSet rs, int rowNum) throws SQLException {
Title title = new Title();
title.setId(rs.getLong("id"));
title.setName(rs.getString("name"));
return title;
class TitleMapper : RowMapper<Title> {
override fun mapRow(rs: ResultSet, rowNum: Int) =
Title(rs.getLong("id"), rs.getString("name"))
The GenreMapper
to a Genre
, as follows:
import com.foo.domain.Genre;
public final class GenreMapper implements RowMapper<Genre> {
public Genre mapRow(ResultSet rs, int rowNum) throws SQLException {
return new Genre(rs.getString("name"));
class GenreMapper : RowMapper<Genre> {
override fun mapRow(rs: ResultSet, rowNum: Int): Genre {
return Genre(rs.getString("name"))
To pass parameters to a stored procedure that has one or more input parameters in its
definition in the RDBMS, you can code a strongly typed execute(..)
method that would
delegate to the untyped execute(Map)
method in the superclass, as the following example shows:
public class TitlesAfterDateStoredProcedure extends StoredProcedure {
private static final String SPROC_NAME = "TitlesAfterDate";
private static final String CUTOFF_DATE_PARAM = "cutoffDate";
public TitlesAfterDateStoredProcedure(DataSource dataSource) {
declareParameter(new SqlParameter(CUTOFF_DATE_PARAM, Types.DATE);
compile();
public Map<String, Object> execute(Date cutoffDate) {
Map<String, Object> inputs = new HashMap<String, Object>();
inputs.put(CUTOFF_DATE_PARAM, cutoffDate);
return super.execute(inputs);
.StoredProcedure
class TitlesAfterDateStoredProcedure(dataSource: DataSource) : StoredProcedure(dataSource, SPROC_NAME) {
companion object {
private const val SPROC_NAME = "TitlesAfterDate"
private const val CUTOFF_DATE_PARAM = "cutoffDate"
init {
declareParameter(SqlParameter(CUTOFF_DATE_PARAM, Types.DATE))
compile()
fun execute(cutoffDate: Date) = super.execute(
mapOf<String, Any>(CUTOFF_DATE_PARAM to cutoffDate))
3.8. Common Problems with Parameter and Data Value Handling
Common problems with parameters and data values exist in the different approaches provided by Spring Framework’s JDBC support. This section covers how to address them.
3.8.1. Providing SQL Type Information for Parameters
Usually, Spring determines the SQL type of the parameters based on the type of parameter
passed in. It is possible to explicitly provide the SQL type to be used when setting
parameter values. This is sometimes necessary to correctly set NULL
values.
You can provide SQL type information in several ways:
Many update and query methods of the
JdbcTemplate
take an additional parameter in the form of anint
array. This array is used to indicate the SQL type of the corresponding parameter by using constant values from thejava.sql.Types
class. Provide one entry for each parameter. -
You can use the
SqlParameterValue
class to wrap the parameter value that needs this additional information. To do so, create a new instance for each value and pass in the SQL type and the parameter value in the constructor. You can also provide an optional scale parameter for numeric values. -
For methods that work with named parameters, you can use the
SqlParameterSource
classes,BeanPropertySqlParameterSource
orMapSqlParameterSource
. They both have methods for registering the SQL type for any of the named parameter values.
3.8.2. Handling BLOB and CLOB objects
You can store images, other binary data, and large chunks of text in the database. These
large objects are called BLOBs (Binary Large OBject) for binary data and CLOBs (Character
Large OBject) for character data. In Spring, you can handle these large objects by using
the JdbcTemplate
directly and also when using the higher abstractions provided by RDBMS
Objects and the SimpleJdbc
classes. All of these approaches use an implementation of
the LobHandler
interface for the actual management of the LOB (Large OBject) data.
LobHandler
provides access to a LobCreator
class, through the getLobCreator
method,
that is used for creating new LOB objects to be inserted.
LobCreator
and LobHandler
provide the following support for LOB input and output:
BLOB
byte[]
:getBlobAsBytes
andsetBlobAsBytes
InputStream
:getBlobAsBinaryStream
andsetBlobAsBinaryStream
CLOB
String
:getClobAsString
andsetClobAsString
InputStream
:getClobAsAsciiStream
andsetClobAsAsciiStream
Reader
:getClobAsCharacterStream
andsetClobAsCharacterStream
The next example shows how to create and insert a BLOB. Later we show how to read it back from the database.
This example uses a JdbcTemplate
and an implementation of the
AbstractLobCreatingPreparedStatementCallback
. It implements one method,
setValues
. This method provides a LobCreator
that we use to set the values for the
LOB columns in your SQL insert statement.
For this example, we assume that there is a variable, lobHandler
, that is already
set to an instance of a DefaultLobHandler
. You typically set this value through
dependency injection.
The following example shows how to create and insert a BLOB:
final File blobIn = new File("spring2004.jpg");
final InputStream blobIs = new FileInputStream(blobIn);
final File clobIn = new File("large.txt");
final InputStream clobIs = new FileInputStream(clobIn);
final InputStreamReader clobReader = new InputStreamReader(clobIs);
jdbcTemplate.execute(
"INSERT INTO lob_table (id, a_clob, a_blob) VALUES (?, ?, ?)",
new AbstractLobCreatingPreparedStatementCallback(lobHandler) { (1)
protected void setValues(PreparedStatement ps, LobCreator lobCreator) throws SQLException {
ps.setLong(1, 1L);
lobCreator.setClobAsCharacterStream(ps, 2, clobReader, (int)clobIn.length()); (2)
lobCreator.setBlobAsBinaryStream(ps, 3, blobIs, (int)blobIn.length()); (3)
blobIs.close();
clobReader.close();
1 | Pass in the lobHandler that (in this example) is a plain DefaultLobHandler . |
2 | Using the method setClobAsCharacterStream to pass in the contents of the CLOB. |
3 | Using the method setBlobAsBinaryStream to pass in the contents of the BLOB. |
val blobIn = File("spring2004.jpg")
val blobIs = FileInputStream(blobIn)
val clobIn = File("large.txt")
val clobIs = FileInputStream(clobIn)
val clobReader = InputStreamReader(clobIs)
object: AbstractLobCreatingPreparedStatementCallback(lobHandler) { (1)
override fun setValues(ps: PreparedStatement, lobCreator: LobCreator) {
ps.setLong(1, 1L)
lobCreator.setClobAsCharacterStream(ps, 2, clobReader, clobIn.length().toInt()) (2)
lobCreator.setBlobAsBinaryStream(ps, 3, blobIs, blobIn.length().toInt()) (3)
blobIs.close()
clobReader.close()
If you invoke the See the documentation for the JDBC driver you use to verify that it supports streaming a LOB without providing the content length. |
Now it is time to read the LOB data from the database. Again, you use a JdbcTemplate
with the same instance variable lobHandler
and a reference to a DefaultLobHandler
The following example shows how to do so:
List<Map<String, Object>> l = jdbcTemplate.query("select id, a_clob, a_blob from lob_table",
new RowMapper<Map<String, Object>>() {
public Map<String, Object> mapRow(ResultSet rs, int i) throws SQLException {
Map<String, Object> results = new HashMap<String, Object>();
String clobText = lobHandler.getClobAsString(rs, "a_clob"); (1)
results.put("CLOB", clobText);
byte[] blobBytes = lobHandler.getBlobAsBytes(rs, "a_blob"); (2)
results.put("BLOB", blobBytes);
return results;
1 | Using the method getClobAsString to retrieve the contents of the CLOB. |
2 | Using the method getBlobAsBytes to retrieve the contents of the BLOB. |
val l = jdbcTemplate.query("select id, a_clob, a_blob from lob_table") { rs, _ ->
val clobText = lobHandler.getClobAsString(rs, "a_clob") (1)
val blobBytes = lobHandler.getBlobAsBytes(rs, "a_blob") (2)
mapOf("CLOB" to clobText, "BLOB" to blobBytes)
3.8.3. Passing in Lists of Values for IN Clause
The SQL standard allows for selecting rows based on an expression that includes a
variable list of values. A typical example would be select * from t_actor where id in
(1, 2, 3)
. This variable list is not directly supported for prepared statements by the
JDBC standard. You cannot declare a variable number of placeholders. You need a number
of variations with the desired number of placeholders prepared, or you need to generate
the SQL string dynamically once you know how many placeholders are required. The named
parameter support provided in the NamedParameterJdbcTemplate
takes the latter approach.
You can pass in the values as a java.util.List
(or any Iterable
) of simple values.
This list is used to insert the required placeholders into the actual SQL statement
and pass in the values during statement execution.
Be careful when passing in many values. The JDBC standard does not guarantee that
you can use more than 100 values for an IN expression list. Various databases exceed
this number, but they usually have a hard limit for how many values are allowed.
For example, Oracle’s limit is 1000.
In addition to the primitive values in the value list, you can create a java.util.List
of object arrays. This list can support multiple expressions being defined for the in
clause, such as select * from t_actor where (id, last_name) in ((1, 'Johnson'), (2,
'Harrop'))
. This, of course, requires that your database supports this syntax.
3.8.4. Handling Complex Types for Stored Procedure Calls
When you call stored procedures, you can sometimes use complex types specific to the
database. To accommodate these types, Spring provides a SqlReturnType
for handling
them when they are returned from the stored procedure call and SqlTypeValue
when they
are passed in as a parameter to the stored procedure.
The SqlReturnType
interface has a single method (named getTypeValue
) that must be
implemented. This interface is used as part of the declaration of an SqlOutParameter
The following example shows returning the value of an Oracle STRUCT
object of the user
declared type ITEM_TYPE
public class TestItemStoredProcedure extends StoredProcedure {
public TestItemStoredProcedure(DataSource dataSource) {
declareParameter(new SqlOutParameter("item", OracleTypes.STRUCT, "ITEM_TYPE",
(CallableStatement cs, int colIndx, int sqlType, String typeName) -> {
STRUCT struct = (STRUCT) cs.getObject(colIndx);
Object[] attr = struct.getAttributes();
TestItem item = new TestItem();
item.setId(((Number) attr[0]).longValue());
item.setDescription((String) attr[1]);
item.setExpirationDate((java.util.Date) attr[2]);
return item;
class TestItemStoredProcedure(dataSource: DataSource) : StoredProcedure() {
init {
declareParameter(SqlOutParameter("item", OracleTypes.STRUCT, "ITEM_TYPE") { cs, colIndx, sqlType, typeName ->
val struct = cs.getObject(colIndx) as STRUCT
val attr = struct.getAttributes()
TestItem((attr[0] as Long, attr[1] as String, attr[2] as Date)
You can use SqlTypeValue
to pass the value of a Java object (such as TestItem
) to a
stored procedure. The SqlTypeValue
createTypeValue
) that you must implement. The active connection is passed in, and you
can use it to create database-specific objects, such as StructDescriptor
instances
or ArrayDescriptor
instances. The following example creates a StructDescriptor
instance:
final TestItem testItem = new TestItem(123L, "A test item",
new SimpleDateFormat("yyyy-M-d").parse("2010-12-31"));
SqlTypeValue value = new AbstractSqlTypeValue() {
protected Object createTypeValue(Connection conn, int sqlType, String typeName) throws SQLException {
StructDescriptor itemDescriptor = new StructDescriptor(typeName, conn);
Struct item = new STRUCT(itemDescriptor, conn,
new Object[] {
testItem.getId(),
testItem.getDescription(),
new java.sql.Date(testItem.getExpirationDate().getTime())
return item;
val (id, description, expirationDate) = TestItem(123L, "A test item",
val value = object : AbstractSqlTypeValue() {
override fun createTypeValue(conn: Connection, sqlType: Int, typeName: String?): Any {
val itemDescriptor = StructDescriptor(typeName, conn)
return STRUCT(itemDescriptor, conn,
arrayOf(id, description, java.sql.Date(expirationDate.time)))
You can now add this SqlTypeValue
to the Map
that contains the input parameters for the
execute
call of the stored procedure.
Another use for the SqlTypeValue
is passing in an array of values to an Oracle stored
procedure. Oracle has its own internal ARRAY
class that must be used in this case, and
you can use the SqlTypeValue
to create an instance of the Oracle ARRAY
and populate
it with values from the Java ARRAY
final Long[] ids = new Long[] {1L, 2L};
ArrayDescriptor arrayDescriptor = new ArrayDescriptor(typeName, conn);
ARRAY idArray = new ARRAY(arrayDescriptor, conn, ids);
return idArray;
init {
val ids = arrayOf(1L, 2L)
val arrayDescriptor = ArrayDescriptor(typeName, conn)
return ARRAY(arrayDescriptor, conn, ids)
3.9. Embedded Database Support
The org.springframework.jdbc.datasource.embedded
package provides support for embedded
Java database engines. Support for HSQL,
H2, and Derby is provided
natively. You can also use an extensible API to plug in new embedded database types and
DataSource
implementations.
3.9.1. Why Use an Embedded Database?
An embedded database can be useful during the development phase of a project because of its lightweight nature. Benefits include ease of configuration, quick startup time, testability, and the ability to rapidly evolve your SQL during development.
3.9.2. Creating an Embedded Database by Using Spring XML
If you want to expose an embedded database instance as a bean in a Spring
ApplicationContext
, you can use the embedded-database
tag in the spring-jdbc
namespace:
<jdbc:embedded-database id="dataSource" generate-name="true">
<jdbc:script location="classpath:schema.sql"/>
<jdbc:script location="classpath:test-data.sql"/>
</jdbc:embedded-database>
The preceding configuration creates an embedded HSQL database that is populated with SQL from
the schema.sql
and test-data.sql
resources in the root of the classpath. In addition, as
a best practice, the embedded database is assigned a uniquely generated name. The
embedded database is made available to the Spring container as a bean of type
that can then be injected into data access objects as needed.
3.9.3. Creating an Embedded Database Programmatically
The EmbeddedDatabaseBuilder
class provides a fluent API for constructing an embedded
database programmatically. You can use this when you need to create an embedded database in a
stand-alone environment or in a stand-alone integration test, as in the following example:
EmbeddedDatabase db = new EmbeddedDatabaseBuilder()
.generateUniqueName(true)
.setType(H2)
.setScriptEncoding("UTF-8")
.ignoreFailedDrops(true)
.addScript("schema.sql")
.addScripts("user_data.sql", "country_data.sql")
// perform actions against the db (EmbeddedDatabase extends javax.sql.DataSource)
db.shutdown()
val db = EmbeddedDatabaseBuilder()
.setType(H2)
.build()
db.shutdown()
See the javadoc for EmbeddedDatabaseBuilder
for further details on all supported options.
You can also use the EmbeddedDatabaseBuilder
to create an embedded database by using Java
configuration, as the following example shows:
public class DataSourceConfig {
public DataSource dataSource() {
return new EmbeddedDatabaseBuilder()
.setType(H2)
fun dataSource(): DataSource {
return EmbeddedDatabaseBuilder()
.setType(H2)
.build()
3.9.4. Selecting the Embedded Database Type
This section covers how to select one of the three embedded databases that Spring supports. It includes the following topics:
Using HSQL
Spring supports HSQL 1.8.0 and above. HSQL is the default embedded database if no type is
explicitly specified. To specify HSQL explicitly, set the type
attribute of the
embedded-database
tag to HSQL
. If you use the builder API, call the
setType(EmbeddedDatabaseType)
method with EmbeddedDatabaseType.HSQL
3.9.5. Testing Data Access Logic with an Embedded Database
Embedded databases provide a lightweight way to test data access code. The next example is a
data access integration test template that uses an embedded database. Using such a template
can be useful for one-offs when the embedded database does not need to be reused across test
classes. However, if you wish to create an embedded database that is shared within a test suite,
consider using the Spring TestContext Framework and
configuring the embedded database as a bean in the Spring ApplicationContext
as described
in Creating an Embedded Database by Using Spring XML and Creating an Embedded Database Programmatically. The following listing
shows the test template:
public class DataAccessIntegrationTestTemplate {
private EmbeddedDatabase db;
@BeforeEach
public void setUp() {
// creates an HSQL in-memory database populated from default scripts
// classpath:schema.sql and classpath:data.sql
.addDefaultScripts()
@Test
public void testDataAccess() {
JdbcTemplate template = new JdbcTemplate(db);
template.query( /* ... */ );
@AfterEach
public void tearDown() {
db.shutdown();
private lateinit var db: EmbeddedDatabase
@BeforeEach
fun setUp() {
.build()
@Test
fun testDataAccess() {
val template = JdbcTemplate(db)
template.query( /* ... */)
@AfterEach
fun tearDown() {
db.shutdown()
3.9.6. Generating Unique Names for Embedded Databases
Development teams often encounter errors with embedded databases if their test suite
inadvertently attempts to recreate additional instances of the same database. This can
happen quite easily if an XML configuration file or @Configuration
class is responsible
for creating an embedded database and the corresponding configuration is then reused
across multiple testing scenarios within the same test suite (that is, within the same JVM
process) — for example, integration tests against embedded databases whose
ApplicationContext
configuration differs only with regard to which bean definition
profiles are active.
The root cause of such errors is the fact that Spring’s EmbeddedDatabaseFactory
(used
internally by both the <jdbc:embedded-database>
XML namespace element and the
for Java configuration) sets the name of the embedded database to
testdb
if not otherwise specified. For the case of <jdbc:embedded-database>
, the
embedded database is typically assigned a name equal to the bean’s id
(often,
something like dataSource
). Thus, subsequent attempts to create an embedded database
do not result in a new database. Instead, the same JDBC connection URL is reused,
and attempts to create a new embedded database actually point to an existing
embedded database created from the same configuration.
To address this common issue, Spring Framework 4.2 provides support for generating unique names for embedded databases. To enable the use of generated names, use one of the following options.
EmbeddedDatabaseFactory.setGenerateUniqueDatabaseName()
EmbeddedDatabaseBuilder.generateUniqueName()
<jdbc:embedded-database generate-name="true" … >
3.9.7. Extending the Embedded Database Support
You can extend Spring JDBC embedded database support in two ways:
Implement
EmbeddedDatabaseConfigurer
to support a new embedded database type. -
Implement
DataSourceFactory
to support a newDataSource
implementation, such as a connection pool to manage embedded database connections.
We encourage you to contribute extensions to the Spring community at GitHub Issues.
3.10. Initializing a DataSource
The org.springframework.jdbc.datasource.init
package provides support for initializing
an existing DataSource
. The embedded database support provides one option for creating
and initializing a DataSource
for an application. However, you may sometimes need to initialize
an instance that runs on a server somewhere.
3.10.1. Initializing a Database by Using Spring XML
If you want to initialize a database and you can provide a reference to a DataSource
bean, you can use the initialize-database
namespace:
<jdbc:initialize-database data-source="dataSource">
<jdbc:script location="classpath:com/foo/sql/db-schema.sql"/>
<jdbc:script location="classpath:com/foo/sql/db-test-data.sql"/>
</jdbc:initialize-database>
The preceding example runs the two specified scripts against the database. The first
script creates a schema, and the second populates tables with a test data set. The script
locations can also be patterns with wildcards in the usual Ant style used for resources
in Spring (for example,
classpath*:/com/foo/**/sql/*-data.sql
). If you use a
pattern, the scripts are run in the lexical order of their URL or filename.
The default behavior of the database initializer is to unconditionally run the provided scripts. This may not always be what you want — for instance, if you run the scripts against a database that already has test data in it. The likelihood of accidentally deleting data is reduced by following the common pattern (shown earlier) of creating the tables first and then inserting the data. The first step fails if the tables already exist.
However, to gain more control over the creation and deletion of existing data, the XML namespace provides a few additional options. The first is a flag to switch the initialization on and off. You can set this according to the environment (such as pulling a boolean value from system properties or from an environment bean). The following example gets a value from a system property:
enabled="#{systemProperties.INITIALIZE_DATABASE}"> (1)
<jdbc:script location="..."/>
1 | Get the value for enabled from a system property called INITIALIZE_DATABASE . |
The second option to control what happens with existing data is to be more tolerant of failures. To this end, you can control the ability of the initializer to ignore certain errors in the SQL it runs from the scripts, as the following example shows:
<jdbc:initialize-database data-source="dataSource" ignore-failures="DROPS">
In the preceding example, we are saying that we expect that, sometimes, the scripts are run
against an empty database, and there are some DROP
statements in the scripts that
would, therefore, fail. So failed SQL DROP
statements will be ignored, but other failures
will cause an exception. This is useful if your SQL dialect doesn’t support DROP … IF
EXISTS
(or similar) but you want to unconditionally remove all test data before
re-creating it. In that case the first script is usually a set of DROP
statements,
followed by a set of CREATE
statements.
The ignore-failures
option can be set to NONE
(the default), DROPS
(ignore failed
drops), or ALL
(ignore all failures).
Each statement should be separated by ;
or a new line if the ;
character is not
present at all in the script. You can control that globally or script by script, as the
<jdbc:initialize-database data-source="dataSource" separator="@@"> (1)
<jdbc:script location="classpath:com/myapp/sql/db-schema.sql" separator=";"/> (2)
<jdbc:script location="classpath:com/myapp/sql/db-test-data-1.sql"/>
<jdbc:script location="classpath:com/myapp/sql/db-test-data-2.sql"/>
1 | Set the separator scripts to @@ . |
2 | Set the separator for db-schema.sql to ; . |
In this example, the two test-data
scripts use @@
as statement separator and only
the db-schema.sql
uses ;
. This configuration specifies that the default separator
is @@
and overrides that default for the db-schema
script.
If you need more control than you get from the XML namespace, you can use the
DataSourceInitializer
directly and define it as a component in your application.
Initialization of Other Components that Depend on the Database
A large class of applications (those that do not use the database until after the Spring context has started) can use the database initializer with no further complications. If your application is not one of those, you might need to read the rest of this section.
The database initializer depends on a DataSource
instance and runs the scripts
provided in its initialization callback (analogous to an init-method
in an XML bean
definition, a @PostConstruct
method in a component, or the afterPropertiesSet()
method in a component that implements InitializingBean
). If other beans depend on the
same data source and use the data source in an initialization callback, there
might be a problem because the data has not yet been initialized. A common example of
this is a cache that initializes eagerly and loads data from the database on application
startup.
To get around this issue, you have two options: change your cache initialization strategy to a later phase or ensure that the database initializer is initialized first.
Changing your cache initialization strategy might be easy if the application is in your control and not otherwise. Some suggestions for how to implement this include:
Make the cache initialize lazily on first usage, which improves application startup time.
Have your cache or a separate component that initializes the cache implement
Lifecycle
orSmartLifecycle
. When the application context starts, you can automatically start aSmartLifecycle
by setting itsautoStartup
flag, and you can manually start aLifecycle
by callingConfigurableApplicationContext.start()
on the enclosing context. -
Use a Spring
ApplicationEvent
or similar custom observer mechanism to trigger the cache initialization.ContextRefreshedEvent
is always published by the context when it is ready for use (after all beans have been initialized), so that is often a useful hook (this is how theSmartLifecycle
works by default).
Ensuring that the database initializer is initialized first can also be easy. Some suggestions on how to implement this include:
Rely on the default behavior of the Spring
BeanFactory
, which is that beans are initialized in registration order. You can easily arrange that by adopting the common practice of a set of<import/>
elements in XML configuration that order your application modules and ensuring that the database and database initialization are listed first. -
Separate the
DataSource
and the business components that use it and control their startup order by putting them in separateApplicationContext
instances (for example, the parent context contains theDataSource
, and the child context contains the business components). This structure is common in Spring web applications but can be more generally applied.
4. Data Access with R2DBC
R2DBC ("Reactive Relational Database Connectivity") is a community-driven specification effort to standardize access to SQL databases using reactive patterns.
4.1. Package Hierarchy
The Spring Framework’s R2DBC abstraction framework consists of two different packages:
core
: Theorg.springframework.r2dbc.core
package contains theDatabaseClient
class plus a variety of related classes. See Using the R2DBC Core Classes to Control Basic R2DBC Processing and Error Handling. -
connection
: Theorg.springframework.r2dbc.connection
package contains a utility class for easyConnectionFactory
access and various simpleConnectionFactory
implementations that you can use for testing and running unmodified R2DBC. See Controlling Database Connections.
4.2. Using the R2DBC Core Classes to Control Basic R2DBC Processing and Error Handling
This section covers how to use the R2DBC core classes to control basic R2DBC processing, including error handling. It includes the following topics:
4.2.1. Using DatabaseClient
DatabaseClient
is the central class in the R2DBC core package. It handles the
creation and release of resources, which helps to avoid common errors, such as
forgetting to close the connection. It performs the basic tasks of the core R2DBC
workflow (such as statement creation and execution), leaving application code to provide
SQL and extract results. The DatabaseClient
class:
Runs SQL queries
Update statements and stored procedure calls
Performs iteration over
Result
instances -
Catches R2DBC exceptions and translates them to the generic, more informative, exception hierarchy defined in the
org.springframework.dao
package. (See Consistent Exception Hierarchy.)
The client has a functional, fluent API using reactive types for declarative composition.
When you use the DatabaseClient
for your code, you need only to implement
java.util.function
interfaces, giving them a clearly defined contract.
Given a Connection
provided by the DatabaseClient
class, a Function
callback creates a Publisher
. The same is true for mapping functions that
extract a Row
result.
You can use DatabaseClient
within a DAO implementation through direct instantiation
with a ConnectionFactory
reference, or you can configure it in a Spring IoC container
and give it to DAOs as a bean reference.
The simplest way to create a DatabaseClient
object is through a static factory method, as follows:
DatabaseClient client = DatabaseClient.create(connectionFactory);
val client = DatabaseClient.create(connectionFactory)
The ConnectionFactory should always be configured as a bean in the Spring IoC
container.
The preceding method creates a DatabaseClient
with default settings.
You can also obtain a Builder
instance from DatabaseClient.builder()
You can customize the client by calling the following methods:
….bindMarkers(…)
: Supply a specificBindMarkersFactory
to configure named parameter to database bind marker translation. -
….executeFunction(…)
: Set theExecuteFunction
howStatement
objects get run. -
….namedParameters(false)
: Disable named parameter expansion. Enabled by default.
Dialects are resolved by BindMarkersFactoryResolver
from a ConnectionFactory , typically by inspecting ConnectionFactoryMetadata .
You can let Spring auto-discover your BindMarkersFactory by registering a
class that implements org.springframework.r2dbc.core.binding.BindMarkersFactoryResolver$BindMarkerFactoryProvider
through META-INF/spring.factories .
BindMarkersFactoryResolver discovers bind marker provider implementations from
the class path using Spring’s SpringFactoriesLoader .
Currently supported databases are:
H2
MariaDB
MySQL
Postgres
All SQL issued by this class is logged at the DEBUG
level under the category
corresponding to the fully qualified class name of the client instance (typically
DefaultDatabaseClient
). Additionally, each execution registers a checkpoint in
the reactive sequence to aid debugging.
The following sections provide some examples of DatabaseClient
usage. These examples
are not an exhaustive list of all of the functionality exposed by the DatabaseClient
See the attendant javadoc for that.
Executing Statements
DatabaseClient
provides the basic functionality of running a statement.
The following example shows what you need to include for minimal but fully functional
code that creates a new table:
Mono<Void> completion = client.sql("CREATE TABLE person (id VARCHAR(255) PRIMARY KEY, name VARCHAR(255), age INTEGER);")
.then();
.await()
DatabaseClient
is designed for convenient, fluent usage.
It exposes intermediate, continuation, and terminal methods at each stage of the
execution specification. The preceding example above uses then()
to return a completion
Publisher
that completes as soon as the query (or queries, if the SQL query contains
multiple statements) completes.
execute(…) accepts either the SQL query string or a query Supplier<String>
to defer the actual query creation until execution.
Querying (SELECT
SQL queries can return values through Row
objects or the number of affected rows.
DatabaseClient
can return the number of updated rows or the rows themselves,
depending on the issued query.
The following query gets the id
and name
columns from a table:
Mono<Map<String, Object>> first = client.sql("SELECT id, name FROM person")
.fetch().first();
val first = client.sql("SELECT id, name FROM person")
.fetch().awaitSingle()
The following query uses a bind variable:
Mono<Map<String, Object>> first = client.sql("SELECT id, name FROM person WHERE first_name = :fn")
.bind("fn", "Joe")
.fetch().first();
val first = client.sql("SELECT id, name FROM person WHERE WHERE first_name = :fn")
.bind("fn", "Joe")
You might have noticed the use of fetch()
in the example above. fetch()
is a
continuation operator that lets you specify how much data you want to consume.
Calling first()
returns the first row from the result and discards remaining rows.
You can consume data with the following operators:
first()
return the first row of the entire result. Its Kotlin Coroutine variant is namedawaitSingle()
for non-nullable return values andawaitSingleOrNull()
if the value is optional. -
one()
returns exactly one result and fails if the result contains more rows. Using Kotlin Coroutines,awaitOne()
for exactly one value orawaitOneOrNull()
if the value may benull
all()
returns all rows of the result. When using Kotlin Coroutines, useflow()
rowsUpdated()
returns the number of affected rows (INSERT
/UPDATE
/DELETE
count). Its Kotlin Coroutine variant is namedawaitRowsUpdated()
Without specifying further mapping details, queries return tabular results
as Map
whose keys are case-insensitive column names that map to their column value.
You can take control over result mapping by supplying a Function<Row, T>
that gets
called for each Row
so it can can return arbitrary values (singular values,
collections and maps, and objects).
The following example extracts the name
column and emits its value:
Flux<String> names = client.sql("SELECT name FROM person")
.map(row -> row.get("name", String.class))
.all();
val names = client.sql("SELECT name FROM person")
.map{ row: Row -> row.get("name", String.class) }
.flow()
Updating (INSERT
, UPDATE
, and DELETE
) with DatabaseClient
The only difference of modifying statements is that these statements typically
do not return tabular data so you use rowsUpdated()
to consume results.
The following example shows an UPDATE
statement that returns the number
of updated rows:
Mono<Integer> affectedRows = client.sql("UPDATE person SET first_name = :fn")
.bind("fn", "Joe")
.fetch().rowsUpdated();
val affectedRows = client.sql("UPDATE person SET first_name = :fn")
.bind("fn", "Joe")
.fetch().awaitRowsUpdated()
Binding Values to Queries
A typical application requires parameterized SQL statements to select or
update rows according to some input. These are typically SELECT
statements
constrained by a WHERE
clause or INSERT
and UPDATE
statements that accept
input parameters. Parameterized statements bear the risk of SQL injection if
parameters are not escaped properly. DatabaseClient
leverages R2DBC’s
bind
API to eliminate the risk of SQL injection for query parameters.
You can provide a parameterized SQL statement with the execute(…)
operator
and bind parameters to the actual Statement
. Your R2DBC driver then runs
the statement by using prepared statements and parameter substitution.
Parameter binding supports two binding strategies:
By Index, using zero-based parameter indexes.
By Name, using the placeholder name.
The following example shows parameter binding for a query:
db.sql("INSERT INTO person (id, name, age) VALUES(:id, :name, :age)")
.bind("id", "joe")
.bind("name", "Joe")
.bind("age", 34);
The query-preprocessor unrolls named Collection
parameters into a series of bind
markers to remove the need of dynamic query creation based on the number of arguments.
Nested object arrays are expanded to allow usage of (for example) select lists.
Consider the following query:
SELECT id, name, state FROM table WHERE (name, age) IN (('John', 35), ('Ann', 50))
The preceding query can be parametrized and run as follows:
List<Object[]> tuples = new ArrayList<>();
tuples.add(new Object[] {"John", 35});
tuples.add(new Object[] {"Ann", 50});
client.sql("SELECT id, name, state FROM table WHERE (name, age) IN (:tuples)")
.bind("tuples", tuples);
val tuples: MutableList<Array<Any>> = ArrayList()
tuples.add(arrayOf("John", 35))
tuples.add(arrayOf("Ann", 50))
Usage of select lists is vendor-dependent. |
The following example shows a simpler variant using IN
predicates:
client.sql("SELECT id, name, state FROM table WHERE age IN (:ages)")
.bind("ages", Arrays.asList(35, 50));
.bind("tuples", arrayOf(35, 50))
R2DBC itself does not support Collection-like values. Nevertheless,
expanding a given List in the example above works for named parameters
in Spring’s R2DBC support, e.g. for use in IN clauses as shown above.
However, inserting or updating array-typed columns (e.g. in Postgres)
requires an array type that is supported by the underlying R2DBC driver:
typically a Java array, e.g. String[] to update a text[] column.
Do not pass Collection<String> or the like as an array parameter.
Statement Filters
Sometimes it you need to fine-tune options on the actual Statement
before it gets run. Register a Statement
filter
(StatementFilterFunction
) through DatabaseClient
to intercept and
modify statements in their execution, as the following example shows:
client.sql("INSERT INTO table (name, state) VALUES(:name, :state)")
.filter((s, next) -> next.execute(s.returnGeneratedValues("id")))
.bind("name", …)
.bind("state", …);
.filter { s: Statement, next: ExecuteFunction -> next.execute(s.returnGeneratedValues("id")) }
.bind("name", …)
.bind("state", …)
DatabaseClient
exposes also simplified filter(…)
overload accepting Function<Statement, Statement>
.filter(statement -> s.returnGeneratedValues("id"));
client.sql("SELECT id, name, state FROM table")
.filter(statement -> s.fetchSize(25));
.filter { statement -> s.returnGeneratedValues("id") }
.filter { statement -> s.fetchSize(25) }
implementations allow filtering of the
Statement
and filtering of Result
objects.
DatabaseClient
Best Practices
Instances of the DatabaseClient
class are thread-safe, once configured. This is
important because it means that you can configure a single instance of a DatabaseClient
and then safely inject this shared reference into multiple DAOs (or repositories).
The DatabaseClient
is stateful, in that it maintains a reference to a ConnectionFactory
but this state is not conversational state.
A common practice when using the DatabaseClient
class is to configure a ConnectionFactory
in your Spring configuration file and then dependency-inject
that shared ConnectionFactory
bean into your DAO classes. The DatabaseClient
is created in
the setter for the ConnectionFactory
. This leads to DAOs that resemble the following:
public class R2dbcCorporateEventDao implements CorporateEventDao {
private DatabaseClient databaseClient;
public void setConnectionFactory(ConnectionFactory connectionFactory) {
this.databaseClient = DatabaseClient.create(connectionFactory);
// R2DBC-backed implementations of the methods on the CorporateEventDao follow...
class R2dbcCorporateEventDao(connectionFactory: ConnectionFactory) : CorporateEventDao {
private val databaseClient = DatabaseClient.create(connectionFactory)
An alternative to explicit configuration is to use component-scanning and annotation
support for dependency injection. In this case, you can annotate the class with @Component
(which makes it a candidate for component-scanning) and annotate the ConnectionFactory
setter
method with @Autowired
. The following example shows how to do so:
@Component (1)
@Autowired (2)
this.databaseClient = DatabaseClient.create(connectionFactory); (3)
1 | Annotate the class with @Component . |
2 | Annotate the ConnectionFactory setter method with @Autowired . |
3 | Create a new DatabaseClient with the ConnectionFactory . |
@Component (1)
class R2dbcCorporateEventDao(connectionFactory: ConnectionFactory) : CorporateEventDao { (2)
private val databaseClient = DatabaseClient(connectionFactory) (3)
2 | Constructor injection of the ConnectionFactory . |
Regardless of which of the above template initialization styles you choose to use (or
not), it is seldom necessary to create a new instance of a DatabaseClient
class each
time you want to run SQL. Once configured, a DatabaseClient
instance is thread-safe.
If your application accesses multiple
databases, you may want multiple DatabaseClient
instances, which requires multiple
ConnectionFactory
and, subsequently, multiple differently configured DatabaseClient
instances.
4.3. Retrieving Auto-generated Keys
INSERT
statements may generate keys when inserting rows into a table
that defines an auto-increment or identity column. To get full control over
the column name to generate, simply register a StatementFilterFunction
that
requests the generated key for the desired column.
Mono<Integer> generatedId = client.sql("INSERT INTO table (name, state) VALUES(:name, :state)")
.map(row -> row.get("id", Integer.class))
.first();
// generatedId emits the generated key once the INSERT statement has finished
val generatedId = client.sql("INSERT INTO table (name, state) VALUES(:name, :state)")
.map { row -> row.get("id", Integer.class) }
.awaitOne()
4.4. Controlling Database Connections
This section covers:
4.4.1. Using ConnectionFactory
Spring obtains an R2DBC connection to the database through a ConnectionFactory
A ConnectionFactory
is part of the R2DBC specification and is a common entry-point
for drivers. It lets a container or a framework hide connection pooling
and transaction management issues from the application code. As a developer,
you need not know details about how to connect to the database. That is the
responsibility of the administrator who sets up the ConnectionFactory
. You
most likely fill both roles as you develop and test code, but you do not
necessarily have to know how the production data source is configured.
When you use Spring’s R2DBC layer, you can can configure your own with a
connection pool implementation provided by a third party. A popular
implementation is R2DBC Pool (r2dbc-pool
). Implementations in the Spring
distribution are meant only for testing purposes and do not provide pooling.
To configure a ConnectionFactory
Obtain a connection with
ConnectionFactory
as you typically obtain an R2DBCConnectionFactory
Provide an R2DBC URL (See the documentation for your driver for the correct value).
The following example shows how to configure a ConnectionFactory
ConnectionFactory factory = ConnectionFactories.get("r2dbc:h2:mem:///test?options=DB_CLOSE_DELAY=-1;DB_CLOSE_ON_EXIT=FALSE");
val factory = ConnectionFactories.get("r2dbc:h2:mem:///test?options=DB_CLOSE_DELAY=-1;DB_CLOSE_ON_EXIT=FALSE");
4.4.2. Using ConnectionFactoryUtils
The ConnectionFactoryUtils
class is a convenient and powerful helper class
that provides static
methods to obtain connections from ConnectionFactory
and close connections (if necessary).
It supports subscriber Context
-bound connections with, for example
R2dbcTransactionManager
4.4.3. Using SingleConnectionFactory
The SingleConnectionFactory
class is an implementation of DelegatingConnectionFactory
interface that wraps a single Connection
that is not closed after each use.
If any client code calls close
on the assumption of a pooled connection (as when using
persistence tools), you should set the suppressClose
property to true
. This setting
returns a close-suppressing proxy that wraps the physical connection. Note that you can
no longer cast this to a native Connection
or a similar object.
is primarily a test class and may be used for specific requirements
such as pipelining if your R2DBC driver permits for such use.
In contrast to a pooled ConnectionFactory
, it reuses the same connection all the time, avoiding
excessive creation of physical connections.
4.4.4. Using TransactionAwareConnectionFactoryProxy
is a proxy for a target ConnectionFactory
The proxy wraps that target ConnectionFactory
to add awareness of Spring-managed transactions.
Using this class is required if you use a R2DBC client that is not integrated otherwise
with Spring’s R2DBC support. In this case, you can still use this client and, at
the same time, have this client participating in Spring managed transactions. It is generally
preferable to integrate a R2DBC client with proper access to ConnectionFactoryUtils
for resource management.
See the TransactionAwareConnectionFactoryProxy
javadoc for more details.
4.4.5. Using R2dbcTransactionManager
The R2dbcTransactionManager
class is a ReactiveTransactionManager
implementation for
a single R2DBC ConnectionFactory
. It binds an R2DBC Connection
from the specified
ConnectionFactory
to the subscriber Context
, potentially allowing for one subscriber
Connection
for each ConnectionFactory
Application code is required to retrieve the R2DBC Connection
through
ConnectionFactoryUtils.getConnection(ConnectionFactory)
, instead of R2DBC’s standard
ConnectionFactory.create()
. All framework classes (such as DatabaseClient
) use this
strategy implicitly. If not used with a transaction manager, the lookup strategy behaves
exactly like ConnectionFactory.create()
and can therefore be used in any case.
5. Object Relational Mapping (ORM) Data Access
This section covers data access when you use Object Relational Mapping (ORM).
5.1. Introduction to ORM with Spring
The Spring Framework supports integration with the Java Persistence API (JPA) and supports native Hibernate for resource management, data access object (DAO) implementations, and transaction strategies. For example, for Hibernate, there is first-class support with several convenient IoC features that address many typical Hibernate integration issues. You can configure all of the supported features for OR (object relational) mapping tools through Dependency Injection. They can participate in Spring’s resource and transaction management, and they comply with Spring’s generic transaction and DAO exception hierarchies. The recommended integration style is to code DAOs against plain Hibernate or JPA APIs.
Spring adds significant enhancements to the ORM layer of your choice when you create data access applications. You can leverage as much of the integration support as you wish, and you should compare this integration effort with the cost and risk of building a similar infrastructure in-house. You can use much of the ORM support as you would a library, regardless of technology, because everything is designed as a set of reusable JavaBeans. ORM in a Spring IoC container facilitates configuration and deployment. Thus, most examples in this section show configuration inside a Spring container.
The benefits of using the Spring Framework to create your ORM DAOs include:
Easier testing. Spring’s IoC approach makes it easy to swap the implementations and configuration locations of Hibernate
SessionFactory
instances, JDBCDataSource
instances, transaction managers, and mapped object implementations (if needed). This in turn makes it much easier to test each piece of persistence-related code in isolation. -
Common data access exceptions. Spring can wrap exceptions from your ORM tool, converting them from proprietary (potentially checked) exceptions to a common runtime
DataAccessException
hierarchy. This feature lets you handle most persistence exceptions, which are non-recoverable, only in the appropriate layers, without annoying boilerplate catches, throws, and exception declarations. You can still trap and handle exceptions as necessary. Remember that JDBC exceptions (including DB-specific dialects) are also converted to the same hierarchy, meaning that you can perform some operations with JDBC within a consistent programming model. -
General resource management. Spring application contexts can handle the location and configuration of Hibernate
SessionFactory
instances, JPAEntityManagerFactory
instances, and other related resources. This makes these values easy to manage and change. Spring offers efficient, easy, and safe handling of persistence resources. For example, related code that uses Hibernate generally needs to use the same HibernateSession
to ensure efficiency and proper transaction handling. Spring makes it easy to create and bind aSession
to the current thread transparently, by exposing a currentSession
through the HibernateSessionFactory
. Thus, Spring solves many chronic problems of typical Hibernate usage, for any local or JTA transaction environment. -
Integrated transaction management. You can wrap your ORM code with a declarative, aspect-oriented programming (AOP) style method interceptor either through the
@Transactional
annotation or by explicitly configuring the transaction AOP advice in an XML configuration file. In both cases, transaction semantics and exception handling (rollback and so on) are handled for you. As discussed in Resource and Transaction Management, you can also swap various transaction managers, without affecting your ORM-related code. For example, you can swap between local transactions and JTA, with the same full services (such as declarative transactions) available in both scenarios. Additionally, JDBC-related code can fully integrate transactionally with the code you use to do ORM. This is useful for data access that is not suitable for ORM (such as batch processing and BLOB streaming) but that still needs to share common transactions with ORM operations.
For more comprehensive ORM support, including support for alternative database technologies such as MongoDB, you might want to check out the Spring Data suite of projects. If you are a JPA user, the Getting Started Accessing Data with JPA guide from https://spring.io provides a great introduction. |
5.2. General ORM Integration Considerations
This section highlights considerations that apply to all ORM technologies. The Hibernate section provides more details and also show these features and configurations in a concrete context.
The major goal of Spring’s ORM integration is clear application layering (with any data access and transaction technology) and for loose coupling of application objects — no more business service dependencies on the data access or transaction strategy, no more hard-coded resource lookups, no more hard-to-replace singletons, no more custom service registries. The goal is to have one simple and consistent approach to wiring up application objects, keeping them as reusable and free from container dependencies as possible. All the individual data access features are usable on their own but integrate nicely with Spring’s application context concept, providing XML-based configuration and cross-referencing of plain JavaBean instances that need not be Spring-aware. In a typical Spring application, many important objects are JavaBeans: data access templates, data access objects, transaction managers, business services that use the data access objects and transaction managers, web view resolvers, web controllers that use the business services, and so on.
5.2.1. Resource and Transaction Management
Typical business applications are cluttered with repetitive resource management code. Many projects try to invent their own solutions, sometimes sacrificing proper handling of failures for programming convenience. Spring advocates simple solutions for proper resource handling, namely IoC through templating in the case of JDBC and applying AOP interceptors for the ORM technologies.
The infrastructure provides proper resource handling and appropriate conversion of
specific API exceptions to an unchecked infrastructure exception hierarchy. Spring
introduces a DAO exception hierarchy, applicable to any data access strategy. For direct
JDBC, the JdbcTemplate
class mentioned in a previous section
provides connection handling and proper conversion of SQLException
to the
DataAccessException
hierarchy, including translation of database-specific SQL error
codes to meaningful exception classes. For ORM technologies, see the
next section for how to get the same exception
translation benefits.
When it comes to transaction management, the JdbcTemplate
class hooks in to the Spring
transaction support and supports both JTA and JDBC transactions, through respective
Spring transaction managers. For the supported ORM technologies, Spring offers Hibernate
and JPA support through the Hibernate and JPA transaction managers as well as JTA support.
For details on transaction support, see the Transaction Management chapter.
5.2.2. Exception Translation
When you use Hibernate or JPA in a DAO, you must decide how to handle the persistence
technology’s native exception classes. The DAO throws a subclass of a HibernateException
or PersistenceException
, depending on the technology. These exceptions are all runtime
exceptions and do not have to be declared or caught. You may also have to deal with
IllegalArgumentException
and IllegalStateException
. This means that callers can only
treat exceptions as being generally fatal, unless they want to depend on the persistence
technology’s own exception structure. Catching specific causes (such as an optimistic
locking failure) is not possible without tying the caller to the implementation strategy.
This trade-off might be acceptable to applications that are strongly ORM-based or
do not need any special exception treatment (or both). However, Spring lets exception
translation be applied transparently through the @Repository
annotation. The following
examples (one for Java configuration and one for XML configuration) show how to do so:
@Repository
public class ProductDaoImpl implements ProductDao {
// class body here...
@Repository
class ProductDaoImpl : ProductDao {
<beans>
<!-- Exception translation bean post processor -->
<bean class="org.springframework.dao.annotation.PersistenceExceptionTranslationPostProcessor"/>
<bean id="myProductDao" class="product.ProductDaoImpl"/>
</beans>
The postprocessor automatically looks for all exception translators (implementations of
the PersistenceExceptionTranslator
interface) and advises all beans marked with the
@Repository
annotation so that the discovered translators can intercept and apply the
appropriate translation on the thrown exceptions.
In summary, you can implement DAOs based on the plain persistence technology’s API and annotations while still benefiting from Spring-managed transactions, dependency injection, and transparent exception conversion (if desired) to Spring’s custom exception hierarchies.
5.3. Hibernate
We start with a coverage of Hibernate 5 in a Spring environment, using it to demonstrate the approach that Spring takes towards integrating OR mappers. This section covers many issues in detail and shows different variations of DAO implementations and transaction demarcation. Most of these patterns can be directly translated to all other supported ORM tools. The later sections in this chapter then cover the other ORM technologies and show brief examples.
As of Spring Framework 5.3, Spring requires Hibernate ORM 5.2+ for Spring’s
HibernateJpaVendorAdapter as well as for a native Hibernate SessionFactory setup.
It is strongly recommended to go with Hibernate ORM 5.4 for a newly started application.
For use with HibernateJpaVendorAdapter , Hibernate Search needs to be upgraded to 5.11.6.
5.3.1. SessionFactory
Setup in a Spring Container
To avoid tying application objects to hard-coded resource lookups, you can define
resources (such as a JDBC DataSource
or a Hibernate SessionFactory
) as beans in the
Spring container. Application objects that need to access resources receive references
to such predefined instances through bean references, as illustrated in the DAO
definition in the next section.
The following excerpt from an XML application context definition shows how to set up a
JDBC DataSource
and a Hibernate SessionFactory
on top of it:
<beans>
<bean id="myDataSource" class="org.apache.commons.dbcp.BasicDataSource" destroy-method="close">
<property name="driverClassName" value="org.hsqldb.jdbcDriver"/>
<property name="url" value="jdbc:hsqldb:hsql://localhost:9001"/>
<property name="username" value="sa"/>
<property name="password" value=""/>
</bean>
<bean id="mySessionFactory" class="org.springframework.orm.hibernate5.LocalSessionFactoryBean">
<property name="dataSource" ref="myDataSource"/>
<property name="mappingResources">
<list>
<value>product.hbm.xml</value>
</list>
</property>
<property name="hibernateProperties">
<value>
hibernate.dialect=org.hibernate.dialect.HSQLDialect
</value>
</property>
</bean>
</beans>
Switching from a local Jakarta Commons DBCP BasicDataSource
to a JNDI-located
DataSource
(usually managed by an application server) is only a matter of
<beans>
<jee:jndi-lookup id="myDataSource" jndi-name="java:comp/env/jdbc/myds"/>
</beans>
You can also access a JNDI-located SessionFactory
, using Spring’s
JndiObjectFactoryBean
/ <jee:jndi-lookup>
to retrieve and expose it.
However, that is typically not common outside of an EJB context.
Spring also provides a Both As of Spring Framework 5.1, such a native Hibernate setup can also expose a JPA
5.3.2. Implementing DAOs Based on the Plain Hibernate API
Hibernate has a feature called contextual sessions, wherein Hibernate itself manages
one current Session
per transaction. This is roughly equivalent to Spring’s
synchronization of one Hibernate Session
per transaction. A corresponding DAO
implementation resembles the following example, based on the plain Hibernate API:
private SessionFactory sessionFactory;
public void setSessionFactory(SessionFactory sessionFactory) {
this.sessionFactory = sessionFactory;
public Collection loadProductsByCategory(String category) {
return this.sessionFactory.getCurrentSession()
.createQuery("from test.Product product where product.category=?")
.setParameter(0, category)
.list();
class ProductDaoImpl(private val sessionFactory: SessionFactory) : ProductDao {
fun loadProductsByCategory(category: String): Collection<*> {
return sessionFactory.currentSession
.list()
This style is similar to that of the Hibernate reference documentation and examples,
except for holding the SessionFactory
in an instance variable. We strongly recommend
such an instance-based setup over the old-school static
HibernateUtil
class from
Hibernate’s CaveatEmptor sample application. (In general, do not keep any resources in
static
variables unless absolutely necessary.)
The preceding DAO example follows the dependency injection pattern. It fits nicely into a Spring IoC
container, as it would if coded against Spring’s HibernateTemplate
You can also set up such a DAO in plain Java (for example, in unit tests). To do so,
instantiate it and call setSessionFactory(..)
with the desired factory reference. As a
Spring bean definition, the DAO would resemble the following:
<beans>
<bean id="myProductDao" class="product.ProductDaoImpl">
<property name="sessionFactory" ref="mySessionFactory"/>
</bean>
</beans>
The main advantage of this DAO style is that it depends on Hibernate API only. No import of any Spring class is required. This is appealing from a non-invasiveness perspective and may feel more natural to Hibernate developers.
However, the DAO throws plain HibernateException
(which is unchecked, so it does not have
to be declared or caught), which means that callers can treat exceptions only as being
generally fatal — unless they want to depend on Hibernate’s own exception hierarchy.
Catching specific causes (such as an optimistic locking failure) is not possible without
tying the caller to the implementation strategy. This trade off might be acceptable to
applications that are strongly Hibernate-based, do not need any special exception
treatment, or both.
Fortunately, Spring’s LocalSessionFactoryBean
supports Hibernate’s
SessionFactory.getCurrentSession()
method for any Spring transaction strategy,
returning the current Spring-managed transactional Session
, even with
HibernateTransactionManager
. The standard behavior of that method remains
to return the current Session
associated with the ongoing JTA transaction, if any.
This behavior applies regardless of whether you use Spring’s
JtaTransactionManager
, EJB container managed transactions (CMTs), or JTA.
In summary, you can implement DAOs based on the plain Hibernate API, while still being able to participate in Spring-managed transactions.
5.3.3. Declarative Transaction Demarcation
We recommend that you use Spring’s declarative transaction support, which lets you replace explicit transaction demarcation API calls in your Java code with an AOP transaction interceptor. You can configure this transaction interceptor in a Spring container by using either Java annotations or XML. This declarative transaction capability lets you keep business services free of repetitive transaction demarcation code and focus on adding business logic, which is the real value of your application.
Before you continue, we are strongly encourage you to read Declarative Transaction Management if you have not already done so. |
You can annotate the service layer with @Transactional
annotations and instruct the
Spring container to find these annotations and provide transactional semantics for
these annotated methods. The following example shows how to do so:
public class ProductServiceImpl implements ProductService {
private ProductDao productDao;
public void setProductDao(ProductDao productDao) {
this.productDao = productDao;
@Transactional
public void increasePriceOfAllProductsInCategory(final String category) {
List productsToChange = this.productDao.loadProductsByCategory(category);
@Transactional(readOnly = true)
public List<Product> findAllProducts() {
return this.productDao.findAllProducts();
class ProductServiceImpl(private val productDao: ProductDao) : ProductService {
@Transactional
fun increasePriceOfAllProductsInCategory(category: String) {
val productsToChange = productDao.loadProductsByCategory(category)
fun findAllProducts() = productDao.findAllProducts()
In the container, you need to set up the PlatformTransactionManager
implementation
(as a bean) and a <tx:annotation-driven/>
entry, opting into @Transactional
processing at runtime. The following example shows how to do so:
xmlns:aop="http://www.springframework.org/schema/aop"
xmlns:tx="http://www.springframework.org/schema/tx"
xsi:schemaLocation="
https://www.springframework.org/schema/tx/spring-tx.xsd
https://www.springframework.org/schema/aop/spring-aop.xsd">
<!-- SessionFactory, DataSource, etc. omitted -->
<bean id="transactionManager"
class="org.springframework.orm.hibernate5.HibernateTransactionManager">
<property name="sessionFactory" ref="sessionFactory"/>
</bean>
<bean id="myProductService" class="product.SimpleProductService">
<property name="productDao" ref="myProductDao"/>
</bean>
</beans>
5.3.4. Programmatic Transaction Demarcation
You can demarcate transactions in a higher level of the application, on top of
lower-level data access services that span any number of operations. Nor do restrictions
exist on the implementation of the surrounding business service. It needs only a Spring
. Again, the latter can come from anywhere, but preferably
as a bean reference through a setTransactionManager(..)
method. Also, the
productDAO
should be set by a setProductDao(..)
method. The following pair of snippets show
a transaction manager and a business service definition in a Spring application context
and an example for a business method implementation:
<beans>
<bean id="myTxManager" class="org.springframework.orm.hibernate5.HibernateTransactionManager">
</bean>
<bean id="myProductService" class="product.ProductServiceImpl">
<property name="transactionManager" ref="myTxManager"/>
</bean>
</beans>
private TransactionTemplate transactionTemplate;
public void setTransactionManager(PlatformTransactionManager transactionManager) {
this.transactionTemplate = new TransactionTemplate(transactionManager);
this.transactionTemplate.execute(new TransactionCallbackWithoutResult() {
public void doInTransactionWithoutResult(TransactionStatus status) {
// do the price increase...
class ProductServiceImpl(transactionManager: PlatformTransactionManager,
private val transactionTemplate = TransactionTemplate(transactionManager)
transactionTemplate.execute {
Spring’s TransactionInterceptor
lets any checked application exception be thrown
with the callback code, while TransactionTemplate
is restricted to unchecked
exceptions within the callback. TransactionTemplate
triggers a rollback in case of
an unchecked application exception or if the transaction is marked rollback-only by
the application (by setting TransactionStatus
). By default, TransactionInterceptor
behaves the same way but allows configurable rollback policies per method.
5.3.5. Transaction Management Strategies
Both TransactionTemplate
and TransactionInterceptor
delegate the actual transaction
handling to a PlatformTransactionManager
instance (which can be a
(for a single Hibernate SessionFactory
) by using a
ThreadLocal
Session
under the hood) or a JtaTransactionManager
(delegating to the
JTA subsystem of the container) for Hibernate applications. You can even use a custom
implementation. Switching from native Hibernate transaction
management to JTA (such as when facing distributed transaction requirements for certain
deployments of your application) is only a matter of configuration. You can replace
the Hibernate transaction manager with Spring’s JTA transaction implementation. Both
transaction demarcation and data access code work without changes, because they
use the generic transaction management APIs.
For distributed transactions across multiple Hibernate session factories, you can combine
as a transaction strategy with multiple
definitions. Each DAO then gets one specific SessionFactory
reference passed into its corresponding bean property. If all underlying JDBC data
sources are transactional container ones, a business service can demarcate transactions
across any number of DAOs and any number of session factories without special regard, as
long as it uses JtaTransactionManager
as the strategy.
Both HibernateTransactionManager
and JtaTransactionManager
allow for proper
JVM-level cache handling with Hibernate, without container-specific transaction manager
lookup or a JCA connector (if you do not use EJB to initiate transactions).
can export the Hibernate JDBC Connection
to plain JDBC
access code for a specific DataSource
. This ability allows for high-level
transaction demarcation with mixed Hibernate and JDBC data access completely without
JTA, provided you access only one database. HibernateTransactionManager
automatically
exposes the Hibernate transaction as a JDBC transaction if you have set up the passed-in
SessionFactory
with a DataSource
through the dataSource
property of the
class. Alternatively, you can specify explicitly the
DataSource
for which the transactions are supposed to be exposed through the
dataSource
property of the HibernateTransactionManager
class.
5.3.6. Comparing Container-managed and Locally Defined Resources
You can switch between a container-managed JNDI SessionFactory
and a locally defined
one without having to change a single line of application code. Whether to keep
resource definitions in the container or locally within the application is mainly a
matter of the transaction strategy that you use. Compared to a Spring-defined local
SessionFactory
, a manually registered JNDI SessionFactory
does not provide any
benefits. Deploying a SessionFactory
through Hibernate’s JCA connector provides the
added value of participating in the Java EE server’s management infrastructure, but does
not add actual value beyond that.
Spring’s transaction support is not bound to a container. When configured with any strategy
other than JTA, transaction support also works in a stand-alone or test environment.
Especially in the typical case of single-database transactions, Spring’s single-resource
local transaction support is a lightweight and powerful alternative to JTA. When you use
local EJB stateless session beans to drive transactions, you depend both on an EJB
container and on JTA, even if you access only a single database and use only stateless
session beans to provide declarative transactions through container-managed
transactions. Direct use of JTA programmatically also requires a Java EE environment.
JTA does not involve only container dependencies in terms of JTA itself and of
JNDI DataSource
instances. For non-Spring, JTA-driven Hibernate transactions, you have
to use the Hibernate JCA connector or extra Hibernate transaction code with the
TransactionManagerLookup
configured for proper JVM-level caching.
Spring-driven transactions can work as well with a locally defined Hibernate
SessionFactory
as they do with a local JDBC DataSource
, provided they access a
single database. Thus, you need only use Spring’s JTA transaction strategy when you
have distributed transaction requirements. A JCA connector requires container-specific
deployment steps, and (obviously) JCA support in the first place. This configuration
requires more work than deploying a simple web application with local resource
definitions and Spring-driven transactions. Also, you often need the Enterprise Edition
of your container if you use, for example, WebLogic Express, which does not
provide JCA. A Spring application with local resources and transactions that span one
single database works in any Java EE web container (without JTA, JCA, or EJB), such as
Tomcat, Resin, or even plain Jetty. Additionally, you can easily reuse such a middle
tier in desktop applications or test suites.
All things considered, if you do not use EJBs, stick with local SessionFactory
setup
and Spring’s HibernateTransactionManager
or JtaTransactionManager
. You get all of
the benefits, including proper transactional JVM-level caching and distributed
transactions, without the inconvenience of container deployment. JNDI registration of a
through the JCA connector adds value only when used in
conjunction with EJBs.
5.3.7. Spurious Application Server Warnings with Hibernate
In some JTA environments with very strict XADataSource
implementations (currently
some WebLogic Server and WebSphere versions), when Hibernate is configured without
regard to the JTA transaction manager for that environment, spurious warnings or
exceptions can show up in the application server log. These warnings or exceptions
indicate that the connection being accessed is no longer valid or JDBC access is no
longer valid, possibly because the transaction is no longer active. As an example,
here is an actual exception from WebLogic:
java.sql.SQLException: The transaction is no longer active - status: 'Committed'. No further JDBC access is allowed within this transaction.
Another common problem is a connection leak after JTA transactions, with Hibernate sessions (and potentially underlying JDBC connections) not getting closed properly.
You can resolve such issues by making Hibernate aware of the JTA transaction manager, to which it synchronizes (along with Spring). You have two options for doing this:
Pass your Spring
bean to your Hibernate setup. The easiest way is a bean reference into thejtaTransactionManager
property for yourLocalSessionFactoryBean
bean (see Hibernate Transaction Setup). Spring then makes the corresponding JTA strategies available to Hibernate. -
You may also configure Hibernate’s JTA-related properties explicitly, in particular "hibernate.transaction.coordinator_class", "hibernate.connection.handling_mode" and potentially "hibernate.transaction.jta.platform" in your "hibernateProperties" on
(see Hibernate’s manual for details on those properties).
The remainder of this section describes the sequence of events that occur with and
without Hibernate’s awareness of the JTA PlatformTransactionManager
When Hibernate is not configured with any awareness of the JTA transaction manager, the following events occur when a JTA transaction commits:
The JTA transaction commits.
Spring’s
is synchronized to the JTA transaction, so it is called back through anafterCompletion
callback by the JTA transaction manager. -
Among other activities, this synchronization can trigger a callback by Spring to Hibernate, through Hibernate’s
afterTransactionCompletion
callback (used to clear the Hibernate cache), followed by an explicitclose()
call on the Hibernate session, which causes Hibernate to attempt toclose()
the JDBC Connection. -
In some environments, this
Connection.close()
call then triggers the warning or error, as the application server no longer considers theConnection
to be usable, because the transaction has already been committed.
When Hibernate is configured with awareness of the JTA transaction manager, the following events occur when a JTA transaction commits:
The JTA transaction is ready to commit.
Spring’s
is synchronized to the JTA transaction, so the transaction is called back through abeforeCompletion
Spring is aware that Hibernate itself is synchronized to the JTA transaction and behaves differently than in the previous scenario. In particular, it aligns with Hibernate’s transactional resource management.
Hibernate is synchronized to the JTA transaction, so the transaction is called back through an
afterCompletion
callback by the JTA transaction manager and can properly clear its cache.
5.4. JPA
The Spring JPA, available under the org.springframework.orm.jpa
package, offers
comprehensive support for the
Java Persistence
API in a manner similar to the integration with Hibernate while being aware of
the underlying implementation in order to provide additional features.
5.4.1. Three Options for JPA Setup in a Spring Environment
The Spring JPA support offers three ways of setting up the JPA EntityManagerFactory
that is used by the application to obtain an entity manager.
Using LocalEntityManagerFactoryBean
You can use this option only in simple deployment environments such as stand-alone applications and integration tests.
The LocalEntityManagerFactoryBean
creates an EntityManagerFactory
suitable for
simple deployment environments where the application uses only JPA for data access.
The factory bean uses the JPA PersistenceProvider
auto-detection mechanism (according
to JPA’s Java SE bootstrapping) and, in most cases, requires you to specify only the
persistence unit name. The following XML example configures such a bean:
<beans>
<bean id="myEmf" class="org.springframework.orm.jpa.LocalEntityManagerFactoryBean">
<property name="persistenceUnitName" value="myPersistenceUnit"/>
</bean>
</beans>
This form of JPA deployment is the simplest and the most limited. You cannot refer to an
existing JDBC DataSource
bean definition, and no support for global transactions
exists. Furthermore, weaving (byte-code transformation) of persistent classes is
provider-specific, often requiring a specific JVM agent to be specified on startup. This
option is sufficient only for stand-alone applications and test environments, for which
the JPA specification is designed.
Obtaining an EntityManagerFactory from JNDI
You can use this option when deploying to a Java EE server. Check your server’s documentation on how to deploy a custom JPA provider into your server, allowing for a different provider than the server’s default.
from JNDI (for example in a Java EE environment),
is a matter of changing the XML configuration, as the following example shows:
<beans>
<jee:jndi-lookup id="myEmf" jndi-name="persistence/myPersistenceUnit"/>
</beans>
This action assumes standard Java EE bootstrapping. The Java EE server auto-detects
persistence units (in effect, META-INF/persistence.xml
files in application jars) and
persistence-unit-ref
entries in the Java EE deployment descriptor (for example,
web.xml
) and defines environment naming context locations for those persistence units.
In such a scenario, the entire persistence unit deployment, including the weaving
(byte-code transformation) of persistent classes, is up to the Java EE server. The JDBC
DataSource
is defined through a JNDI location in the META-INF/persistence.xml
file.
EntityManager
transactions are integrated with the server’s JTA subsystem. Spring merely
uses the obtained EntityManagerFactory
, passing it on to application objects through
dependency injection and managing transactions for the persistence unit (typically
through JtaTransactionManager
If you use multiple persistence units in the same application, the bean names of such
JNDI-retrieved persistence units should match the persistence unit names that the
application uses to refer to them (for example, in @PersistenceUnit
and
@PersistenceContext
annotations).
Using LocalContainerEntityManagerFactoryBean
You can use this option for full JPA capabilities in a Spring-based application environment. This includes web containers such as Tomcat, stand-alone applications, and integration tests with sophisticated persistence requirements.
If you want to specifically configure a Hibernate setup, an immediate alternative
is to set up a native Hibernate LocalSessionFactoryBean instead of a plain JPA
LocalContainerEntityManagerFactoryBean , letting it interact with JPA access code
as well as native Hibernate access code.
See Native Hibernate setup for JPA interaction for details.
The LocalContainerEntityManagerFactoryBean
gives full control over
configuration and is appropriate for environments where
fine-grained customization is required. The LocalContainerEntityManagerFactoryBean
creates a PersistenceUnitInfo
instance based on the persistence.xml
file, the
supplied dataSourceLookup
strategy, and the specified loadTimeWeaver
. It is, thus,
possible to work with custom data sources outside of JNDI and to control the weaving
process. The following example shows a typical bean definition for a
<beans>
<bean id="myEmf" class="org.springframework.orm.jpa.LocalContainerEntityManagerFactoryBean">
<property name="dataSource" ref="someDataSource"/>
<property name="loadTimeWeaver">
<bean class="org.springframework.instrument.classloading.InstrumentationLoadTimeWeaver"/>
</property>
</bean>
</beans>
The following example shows a typical persistence.xml
file:
<persistence xmlns="http://java.sun.com/xml/ns/persistence" version="1.0">
<persistence-unit name="myUnit" transaction-type="RESOURCE_LOCAL">
<mapping-file>META-INF/orm.xml</mapping-file>
<exclude-unlisted-classes/>
</persistence-unit>
</persistence>
The <exclude-unlisted-classes/> shortcut indicates that no scanning for
annotated entity classes is supposed to occur. An explicit 'true' value
(<exclude-unlisted-classes>true</exclude-unlisted-classes/> ) also means no scan.
<exclude-unlisted-classes>false</exclude-unlisted-classes/> does trigger a scan.
However, we recommend omitting the exclude-unlisted-classes element
if you want entity class scanning to occur.
Using the LocalContainerEntityManagerFactoryBean
is the most powerful JPA setup
option, allowing for flexible local configuration within the application. It supports
links to an existing JDBC DataSource
, supports both local and global transactions, and
so on. However, it also imposes requirements on the runtime environment, such as the
availability of a weaving-capable class loader if the persistence provider demands
byte-code transformation.
This option may conflict with the built-in JPA capabilities of a Java EE server. In a
full Java EE environment, consider obtaining your EntityManagerFactory
from JNDI.
Alternatively, specify a custom persistenceXmlLocation
on your
definition (for example,
META-INF/my-persistence.xml) and include only a descriptor with that name in your
application jar files. Because the Java EE server looks only for default
files, it ignores such custom persistence units and, hence,
avoids conflicts with a Spring-driven JPA setup upfront. (This applies to Resin 3.1, for
example.)
The LoadTimeWeaver
interface is a Spring-provided class that lets JPA
ClassTransformer
instances be plugged in a specific manner, depending on whether the
environment is a web container or application server. Hooking ClassTransformers
through an
agent
is typically not efficient. The agents work against the entire virtual machine and
inspect every class that is loaded, which is usually undesirable in a production
server environment.
Spring provides a number of LoadTimeWeaver
implementations for various environments,
letting ClassTransformer
instances be applied only for each class loader and not
for each VM.
See the Spring configuration in the AOP chapter for
more insight regarding the LoadTimeWeaver
implementations and their setup, either
generic or customized to various platforms (such as Tomcat, JBoss and WebSphere).
As described in Spring configuration, you can configure
a context-wide LoadTimeWeaver
by using the @EnableLoadTimeWeaving
annotation or the
context:load-time-weaver
XML element. Such a global weaver is automatically picked up
by all JPA LocalContainerEntityManagerFactoryBean
instances. The following example
shows the preferred way of setting up a load-time weaver, delivering auto-detection
of the platform (e.g. Tomcat’s weaving-capable class loader or Spring’s JVM agent)
and automatic propagation of the weaver to all weaver-aware beans:
<context:load-time-weaver/>
<bean id="emf" class="org.springframework.orm.jpa.LocalContainerEntityManagerFactoryBean">
</bean>
However, you can, if needed, manually specify a dedicated weaver through the
loadTimeWeaver
property, as the following example shows:
<bean class="org.springframework.instrument.classloading.ReflectiveLoadTimeWeaver"/>
</property>
</bean>
No matter how the LTW is configured, by using this technique, JPA applications relying on instrumentation can run in the target platform (for example, Tomcat) without needing an agent. This is especially important when the hosting applications rely on different JPA implementations, because the JPA transformers are applied only at the class-loader level and are, thus, isolated from each other.
Dealing with Multiple Persistence Units
For applications that rely on multiple persistence units locations (stored in various
JARS in the classpath, for example), Spring offers the PersistenceUnitManager
to act as
a central repository and to avoid the persistence units discovery process, which can be
expensive. The default implementation lets multiple locations be specified. These locations are
parsed and later retrieved through the persistence unit name. (By default, the classpath
is searched for META-INF/persistence.xml
files.) The following example configures
multiple locations:
<bean id="pum" class="org.springframework.orm.jpa.persistenceunit.DefaultPersistenceUnitManager">
<property name="persistenceXmlLocations">
<list>
<value>org/springframework/orm/jpa/domain/persistence-multi.xml</value>
<value>classpath:/my/package/**/custom-persistence.xml</value>
<value>classpath*:META-INF/persistence.xml</value>
</list>
</property>
<property name="dataSources">
<map>
<entry key="localDataSource" value-ref="local-db"/>
<entry key="remoteDataSource" value-ref="remote-db"/>
</map>
</property>
<!-- if no datasource is specified, use this one -->
<property name="defaultDataSource" ref="remoteDataSource"/>
</bean>
<property name="persistenceUnitManager" ref="pum"/>
<property name="persistenceUnitName" value="myCustomUnit"/>
</bean>
The default implementation allows customization of the PersistenceUnitInfo
instances
(before they are fed to the JPA provider) either declaratively (through its properties, which
affect all hosted units) or programmatically (through the
PersistenceUnitPostProcessor
, which allows persistence unit selection). If no
is specified, one is created and used internally by
Background Bootstrapping
supports background bootstrapping through
the bootstrapExecutor
<property name="bootstrapExecutor">
<bean class="org.springframework.core.task.SimpleAsyncTaskExecutor"/>
</property>
</bean>
The actual JPA provider bootstrapping is handed off to the specified executor and then,
running in parallel, to the application bootstrap thread. The exposed EntityManagerFactory
proxy can be injected into other application components and is even able to respond to
EntityManagerFactoryInfo
configuration inspection. However, once the actual JPA provider
is being accessed by other components (for example, calling createEntityManager
), those calls
block until the background bootstrapping has completed. In particular, when you use
Spring Data JPA, make sure to set up deferred bootstrapping for its repositories as well.
5.4.2. Implementing DAOs Based on JPA: EntityManagerFactory
and EntityManager
Although EntityManagerFactory instances are thread-safe, EntityManager instances are
not. The injected JPA EntityManager behaves like an EntityManager fetched from an
application server’s JNDI environment, as defined by the JPA specification. It delegates
all calls to the current transactional EntityManager , if any. Otherwise, it falls back
to a newly created EntityManager per operation, in effect making its usage thread-safe.
It is possible to write code against the plain JPA without any Spring dependencies, by
using an injected EntityManagerFactory
or EntityManager
. Spring can understand the
@PersistenceUnit
and @PersistenceContext
annotations both at the field and the method level
if a PersistenceAnnotationBeanPostProcessor
is enabled. The following example shows a plain JPA DAO implementation
that uses the @PersistenceUnit
annotation:
private EntityManagerFactory emf;
@PersistenceUnit
public void setEntityManagerFactory(EntityManagerFactory emf) {
this.emf = emf;
EntityManager em = this.emf.createEntityManager();
try {
Query query = em.createQuery("from Product as p where p.category = ?1");
query.setParameter(1, category);
return query.getResultList();
finally {
if (em != null) {
em.close();
private lateinit var emf: EntityManagerFactory
@PersistenceUnit
fun setEntityManagerFactory(emf: EntityManagerFactory) {
this.emf = emf
val em = this.emf.createEntityManager()
val query = em.createQuery("from Product as p where p.category = ?1");
return query.resultList;
The preceding DAO has no dependency on Spring and still fits nicely into a Spring
application context. Moreover, the DAO takes advantage of annotations to require the
injection of the default EntityManagerFactory
, as the following example bean definition shows:
<beans>
<!-- bean post-processor for JPA annotations -->
<bean class="org.springframework.orm.jpa.support.PersistenceAnnotationBeanPostProcessor"/>
</beans>
As an alternative to explicitly defining a PersistenceAnnotationBeanPostProcessor
consider using the Spring context:annotation-config
XML element in your application
context configuration. Doing so automatically registers all Spring standard
post-processors for annotation-based configuration, including
CommonAnnotationBeanPostProcessor
and so on.
Consider the following example:
<beans>
<!-- post-processors for all standard config annotations -->
<context:annotation-config/>
</beans>
The main problem with such a DAO is that it always creates a new EntityManager
through
the factory. You can avoid this by requesting a transactional EntityManager
(also
called a “shared EntityManager” because it is a shared, thread-safe proxy for the actual
transactional EntityManager) to be injected instead of the factory. The following example shows how to do so:
@PersistenceContext
private EntityManager em;
Query query = em.createQuery("from Product as p where p.category = :category");
query.setParameter("category", category);
@PersistenceContext
private lateinit var em: EntityManager
val query = em.createQuery("from Product as p where p.category = :category")
The @PersistenceContext
annotation has an optional attribute called type
, which defaults to
PersistenceContextType.TRANSACTION
. You can use this default to receive a shared
EntityManager
proxy. The alternative, PersistenceContextType.EXTENDED
, is a completely
different affair. This results in a so-called extended EntityManager
, which is not
thread-safe and, hence, must not be used in a concurrently accessed component, such as a
Spring-managed singleton bean. Extended EntityManager
instances are only supposed to be used in
stateful components that, for example, reside in a session, with the lifecycle of the
EntityManager
not tied to a current transaction but rather being completely up to the
application.
The injected EntityManager
is Spring-managed (aware of the ongoing transaction).
Even though the new DAO implementation uses method-level
injection of an EntityManager
instead of an EntityManagerFactory
, no change is
required in the application context XML, due to annotation usage.
The main advantage of this DAO style is that it depends only on the Java Persistence API. No import of any Spring class is required. Moreover, as the JPA annotations are understood, the injections are applied automatically by the Spring container. This is appealing from a non-invasiveness perspective and can feel more natural to JPA developers.
5.4.3. Spring-driven JPA transactions
We strongly encourage you to read Declarative Transaction Management, if you have not already done so, to get more detailed coverage of Spring’s declarative transaction support. |
The recommended strategy for JPA is local transactions through JPA’s native transaction
support. Spring’s JpaTransactionManager
provides many capabilities known from local
JDBC transactions (such as transaction-specific isolation levels and resource-level
read-only optimizations) against any regular JDBC connection pool (no XA requirement).
Spring JPA also lets a configured JpaTransactionManager
expose a JPA transaction
to JDBC access code that accesses the same DataSource
, provided that the registered
JpaDialect
supports retrieval of the underlying JDBC Connection
Spring provides dialects for the EclipseLink and Hibernate JPA implementations.
See the next section for details on the JpaDialect
mechanism.
As an immediate alternative, Spring’s native HibernateTransactionManager is capable
of interacting with JPA access code, adapting to several Hibernate specifics and providing
JDBC interaction. This makes particular sense in combination with LocalSessionFactoryBean
setup. See Native Hibernate Setup for JPA Interaction for details.
5.4.4. Understanding JpaDialect
and JpaVendorAdapter
As an advanced feature, JpaTransactionManager
and subclasses of
AbstractEntityManagerFactoryBean
allow a custom JpaDialect
to be passed into the
jpaDialect
bean property. A JpaDialect
implementation can enable the following advanced
features supported by Spring, usually in a vendor-specific manner:
Applying specific transaction semantics (such as custom isolation level or transaction timeout)
Retrieving the transactional JDBC
Connection
(for exposure to JDBC-based DAOs) -
Advanced translation of
to Spring’sDataAccessException
This is particularly valuable for special transaction semantics and for advanced
translation of exception. The default implementation (DefaultJpaDialect
) does
not provide any special abilities and, if the features listed earlier are required, you have
to specify the appropriate dialect.
As an even broader provider adaptation facility primarily for Spring’s full-featured
LocalContainerEntityManagerFactoryBean setup, JpaVendorAdapter combines the
capabilities of JpaDialect with other provider-specific defaults. Specifying a
HibernateJpaVendorAdapter or EclipseLinkJpaVendorAdapter is the most convenient
way of auto-configuring an EntityManagerFactory setup for Hibernate or EclipseLink,
respectively. Note that those provider adapters are primarily designed for use with
Spring-driven transaction management (that is, for use with JpaTransactionManager ).
See the JpaDialect
and
JpaVendorAdapter
javadoc for
more details of its operations and how they are used within Spring’s JPA support.
5.4.5. Setting up JPA with JTA Transaction Management
As an alternative to JpaTransactionManager
, Spring also allows for multi-resource
transaction coordination through JTA, either in a Java EE environment or with a
stand-alone transaction coordinator, such as Atomikos. Aside from choosing Spring’s
instead of JpaTransactionManager
, you need to take few further
steps:
The underlying JDBC connection pools need to be XA-capable and be integrated with your transaction coordinator. This is usually straightforward in a Java EE environment, exposing a different kind of
DataSource
through JNDI. See your application server documentation for details. Analogously, a standalone transaction coordinator usually comes with special XA-integratedDataSource
variants. Again, check its documentation. -
The JPA
setup needs to be configured for JTA. This is provider-specific, typically through special properties to be specified asjpaProperties
onLocalContainerEntityManagerFactoryBean
. In the case of Hibernate, these properties are even version-specific. See your Hibernate documentation for details. -
Spring’s
enforces certain Spring-oriented defaults, such as the connection release mode,on-close
, which matches Hibernate’s own default in Hibernate 5.0 but not any more in Hibernate 5.1+. For a JTA setup, make sure to declare your persistence unit transaction type as "JTA". Alternatively, set Hibernate 5.2’shibernate.connection.handling_mode
property toDELAYED_ACQUISITION_AND_RELEASE_AFTER_STATEMENT
to restore Hibernate’s own default. See Spurious Application Server Warnings with Hibernate for related notes. -
Alternatively, consider obtaining the
from your application server itself (that is, through a JNDI lookup instead of a locally declaredLocalContainerEntityManagerFactoryBean
). A server-providedEntityManagerFactory
might require special definitions in your server configuration (making the deployment less portable) but is set up for the server’s JTA environment.
5.4.6. Native Hibernate Setup and Native Hibernate Transactions for JPA Interaction
A native LocalSessionFactoryBean
setup in combination with HibernateTransactionManager
allows for interaction with @PersistenceContext
and other JPA access code. A Hibernate
SessionFactory
natively implements JPA’s EntityManagerFactory
interface now
handle natively is a JPA EntityManager
Spring’s JPA support facilities automatically detect native Hibernate sessions.
Such native Hibernate setup can, therefore, serve as a replacement for a standard JPA
and JpaTransactionManager
combination
in many scenarios, allowing for interaction with SessionFactory.getCurrentSession()
(and also HibernateTemplate
) next to @PersistenceContext EntityManager
within
the same local transaction. Such a setup also provides stronger Hibernate integration
and more configuration flexibility, because it is not constrained by JPA bootstrap contracts.
You do not need HibernateJpaVendorAdapter
configuration in such a scenario,
since Spring’s native Hibernate setup provides even more features
(for example, custom Hibernate Integrator setup, Hibernate 5.3 bean container integration,
and stronger optimizations for read-only transactions). Last but not least, you can also
express native Hibernate setup through LocalSessionFactoryBuilder
seamlessly integrating with @Bean
style configuration (no FactoryBean
involved).
On |
6. Marshalling XML by Using Object-XML Mappers
6.1. Introduction
This chapter, describes Spring’s Object-XML Mapping support. Object-XML Mapping (O-X mapping for short) is the act of converting an XML document to and from an object. This conversion process is also known as XML Marshalling, or XML Serialization. This chapter uses these terms interchangeably.
Within the field of O-X mapping, a marshaller is responsible for serializing an object (graph) to XML. In similar fashion, an unmarshaller deserializes the XML to an object graph. This XML can take the form of a DOM document, an input or output stream, or a SAX handler.
Some of the benefits of using Spring for your O/X mapping needs are:
6.1.1. Ease of configuration
Spring’s bean factory makes it easy to configure marshallers, without needing to construct JAXB context, JiBX binding factories, and so on. You can configure the marshallers as you would any other bean in your application context. Additionally, XML namespace-based configuration is available for a number of marshallers, making the configuration even simpler.
6.1.2. Consistent Interfaces
Spring’s O-X mapping operates through two global interfaces: Marshaller
and
Unmarshaller
. These abstractions let you switch O-X mapping frameworks
with relative ease, with little or no change required on the classes that do the
marshalling. This approach has the additional benefit of making it possible to do XML
marshalling with a mix-and-match approach (for example, some marshalling performed using JAXB
and some by XStream) in a non-intrusive fashion, letting you use the strength of each
technology.
6.2. Marshaller
and Unmarshaller
As stated in the introduction, a marshaller serializes an object to XML, and an unmarshaller deserializes XML stream to an object. This section describes the two Spring interfaces used for this purpose.
6.2.1. Understanding Marshaller
Spring abstracts all marshalling operations behind the
org.springframework.oxm.Marshaller
interface, the main method of which follows:
public interface Marshaller {
* Marshal the object graph with the given root into the provided Result.
void marshal(Object graph, Result result) throws XmlMappingException, IOException;
The Marshaller
interface has one main method, which marshals the given object to a
given javax.xml.transform.Result
. The result is a tagging interface that basically
represents an XML output abstraction. Concrete implementations wrap various XML
representations, as the following table indicates:
Result implementation | Wraps XML representation |
Although the marshal() method accepts a plain object as its first parameter, most
Marshaller implementations cannot handle arbitrary objects. Instead, an object class
must be mapped in a mapping file, be marked with an annotation, be registered with the
marshaller, or have a common base class. Refer to the later sections in this chapter
to determine how your O-X technology manages this.
6.2.2. Understanding Unmarshaller
Similar to the Marshaller
, we have the org.springframework.oxm.Unmarshaller
interface, which the following listing shows:
public interface Unmarshaller {
* Unmarshal the given provided Source into an object graph.
Object unmarshal(Source source) throws XmlMappingException, IOException;
This interface also has one method, which reads from the given
javax.xml.transform.Source
(an XML input abstraction) and returns the object read. As
with Result
, Source
is a tagging interface that has three concrete implementations. Each
wraps a different XML representation, as the following table indicates:
Source implementation | Wraps XML representation |
Even though there are two separate marshalling interfaces (Marshaller
and
Unmarshaller
), all implementations in Spring-WS implement both in one class.
This means that you can wire up one marshaller class and refer to it both as a
marshaller and as an unmarshaller in your applicationContext.xml
6.2.3. Understanding XmlMappingException
Spring converts exceptions from the underlying O-X mapping tool to its own exception
hierarchy with the XmlMappingException
as the root exception.
These runtime exceptions wrap the original exception so that no information will be lost.
Additionally, the MarshallingFailureException
and UnmarshallingFailureException
provide a distinction between marshalling and unmarshalling operations, even though the
underlying O-X mapping tool does not do so.
The O-X Mapping exception hierarchy is shown in the following figure:
6.3. Using Marshaller
and Unmarshaller
You can use Spring’s OXM for a wide variety of situations. In the following example, we use it to marshal the settings of a Spring-managed application as an XML file. In the following example, we use a simple JavaBean to represent the settings:
public class Settings {
private boolean fooEnabled;
public boolean isFooEnabled() {
return fooEnabled;
public void setFooEnabled(boolean fooEnabled) {
this.fooEnabled = fooEnabled;
class Settings {
var isFooEnabled: Boolean = false
The application class uses this bean to store its settings. Besides a main method, the
class has two methods: saveSettings()
saves the settings bean to a file named
settings.xml
, and loadSettings()
loads these settings again. The following main()
method
constructs a Spring application context and calls these two methods:
import java.io.FileInputStream;
import java.io.FileOutputStream;
import java.io.IOException;
import javax.xml.transform.stream.StreamResult;
import javax.xml.transform.stream.StreamSource;
import org.springframework.context.ApplicationContext;
import org.springframework.context.support.ClassPathXmlApplicationContext;
import org.springframework.oxm.Marshaller;
import org.springframework.oxm.Unmarshaller;
public class Application {
private static final String FILE_NAME = "settings.xml";
private Settings settings = new Settings();
private Marshaller marshaller;
private Unmarshaller unmarshaller;
public void setMarshaller(Marshaller marshaller) {
this.marshaller = marshaller;
public void setUnmarshaller(Unmarshaller unmarshaller) {
this.unmarshaller = unmarshaller;
public void saveSettings() throws IOException {
try (FileOutputStream os = new FileOutputStream(FILE_NAME)) {
this.marshaller.marshal(settings, new StreamResult(os));
public void loadSettings() throws IOException {
try (FileInputStream is = new FileInputStream(FILE_NAME)) {
this.settings = (Settings) this.unmarshaller.unmarshal(new StreamSource(is));
public static void main(String[] args) throws IOException {
ApplicationContext appContext =
new ClassPathXmlApplicationContext("applicationContext.xml");
Application application = (Application) appContext.getBean("application");
application.saveSettings();
application.loadSettings();
class Application {
lateinit var marshaller: Marshaller
lateinit var unmarshaller: Unmarshaller
fun saveSettings() {
FileOutputStream(FILE_NAME).use { outputStream -> marshaller.marshal(settings, StreamResult(outputStream)) }
fun loadSettings() {
FileInputStream(FILE_NAME).use { inputStream -> settings = unmarshaller.unmarshal(StreamSource(inputStream)) as Settings }
private const val FILE_NAME = "settings.xml"
fun main(args: Array<String>) {
val appContext = ClassPathXmlApplicationContext("applicationContext.xml")
val application = appContext.getBean("application") as Application
The Application
requires both a marshaller
and an unmarshaller
property to be set. We
can do so by using the following applicationContext.xml
<beans>
<bean id="application" class="Application">
<property name="marshaller" ref="xstreamMarshaller" />
<property name="unmarshaller" ref="xstreamMarshaller" />
</bean>
<bean id="xstreamMarshaller" class="org.springframework.oxm.xstream.XStreamMarshaller"/>
</beans>
This application context uses XStream, but we could have used any of the other marshaller
instances described later in this chapter. Note that, by default, XStream does not require
any further configuration, so the bean definition is rather simple. Also note that the
XStreamMarshaller
implements both Marshaller
and Unmarshaller
, so we can refer to the
xstreamMarshaller
bean in both the marshaller
and unmarshaller
property of the
application.
This sample application produces the following settings.xml
file:
<settings foo-enabled="false"/>
6.4. XML Configuration Namespace
You can configure marshallers more concisely by using tags from the OXM namespace. To make these tags available, you must first reference the appropriate schema in the preamble of the XML configuration file. The following example shows how to do so:
xmlns:oxm="http://www.springframework.org/schema/oxm" (1)
http://www.springframework.org/schema/oxm https://www.springframework.org/schema/oxm/spring-oxm.xsd"> (2)
1 | Reference the oxm schema. |
2 | Specify the oxm schema location. |
The schema makes the following elements available:
Each tag is explained in its respective marshaller’s section. As an example, though, the configuration of a JAXB2 marshaller might resemble the following:
<oxm:jaxb2-marshaller id="marshaller" contextPath="org.springframework.ws.samples.airline.schema"/>
6.5. JAXB
The JAXB binding compiler translates a W3C XML Schema into one or more Java classes, a
jaxb.properties
file, and possibly some resource files. JAXB also offers a way to
generate a schema from annotated Java classes.
Spring supports the JAXB 2.0 API as XML marshalling strategies, following the
Marshaller
and Unmarshaller
interfaces described in Marshaller
and Unmarshaller
The corresponding integration classes reside in the org.springframework.oxm.jaxb
package.
6.5.1. Using Jaxb2Marshaller
The Jaxb2Marshaller
class implements both of Spring’s Marshaller
and Unmarshaller
interfaces. It requires a context path to operate. You can set the context path by setting the
contextPath
property. The context path is a list of colon-separated Java package
names that contain schema derived classes. It also offers a classesToBeBound
property,
which allows you to set an array of classes to be supported by the marshaller. Schema
validation is performed by specifying one or more schema resources to the bean, as the following example shows:
<beans>
<bean id="jaxb2Marshaller" class="org.springframework.oxm.jaxb.Jaxb2Marshaller">
<property name="classesToBeBound">
<list>
<value>org.springframework.oxm.jaxb.Flight</value>
<value>org.springframework.oxm.jaxb.Flights</value>
</list>
</property>
<property name="schema" value="classpath:org/springframework/oxm/schema.xsd"/>
</bean>
</beans>
The jaxb2-marshaller
element configures a org.springframework.oxm.jaxb.Jaxb2Marshaller
Alternatively, you can provide the list of classes to bind to the marshaller by using the
class-to-be-bound
child element:
<oxm:jaxb2-marshaller id="marshaller">
<oxm:class-to-be-bound name="org.springframework.ws.samples.airline.schema.Airport"/>
<oxm:class-to-be-bound name="org.springframework.ws.samples.airline.schema.Flight"/>
</oxm:jaxb2-marshaller>
The following table describes the available attributes:
Attribute | Description | Required |
The ID of the marshaller |
No |
The JAXB Context path |
No |
6.6. JiBX
The JiBX framework offers a solution similar to that which Hibernate provides for ORM: A binding definition defines the rules for how your Java objects are converted to or from XML. After preparing the binding and compiling the classes, a JiBX binding compiler enhances the class files and adds code to handle converting instances of the classes from or to XML.
For more information on JiBX, see the JiBX web
site. The Spring integration classes reside in the org.springframework.oxm.jibx
package.
6.6.1. Using JibxMarshaller
The JibxMarshaller
class implements both the Marshaller
and Unmarshaller
interface. To operate, it requires the name of the class to marshal in, which you can
set using the targetClass
property. Optionally, you can set the binding name by setting the
bindingName
property. In the following example, we bind the Flights
class:
<beans>
<bean id="jibxFlightsMarshaller" class="org.springframework.oxm.jibx.JibxMarshaller">
<property name="targetClass">org.springframework.oxm.jibx.Flights</property>
</bean>
</beans>
A JibxMarshaller
is configured for a single class. If you want to marshal multiple
classes, you have to configure multiple JibxMarshaller
instances with different targetClass
property values.
The jibx-marshaller
tag configures a org.springframework.oxm.jibx.JibxMarshaller
<oxm:jibx-marshaller id="marshaller" target-class="org.springframework.ws.samples.airline.schema.Flight"/>
No |
The target class for this marshaller |
Yes |
The binding name used by this marshaller |
No |
6.7. XStream
XStream is a simple library to serialize objects to XML and back again. It does not require any mapping and generates clean XML.
For more information on XStream, see the XStream
web site. The Spring integration classes reside in the
package.
6.7.1. Using XStreamMarshaller
The XStreamMarshaller
does not require any configuration and can be configured in an
application context directly. To further customize the XML, you can set an alias map,
which consists of string aliases mapped to classes, as the following example shows:
<beans>
<bean id="xstreamMarshaller" class="org.springframework.oxm.xstream.XStreamMarshaller">
<property name="aliases">
<props>
<prop key="Flight">org.springframework.oxm.xstream.Flight</prop>
</props>
</property>
</bean>
</beans>
By default, XStream lets arbitrary classes be unmarshalled, which can lead to
unsafe Java serialization effects. As such, we do not recommend using the
If you choose to use the
Doing so ensures that only the registered classes are eligible for unmarshalling. Additionally, you can register
custom
converters to make sure that only your supported classes can be unmarshalled. You might
want to add a |
Note that XStream is an XML serialization library, not a data binding library. Therefore, it has limited namespace support. As a result, it is rather unsuitable for usage within Web Services. |
7. Appendix
7.1. XML Schemas
This part of the appendix lists XML schemas for data access, including the following:
7.1.1. The tx
Schema
The tx
tags deal with configuring all of those beans in Spring’s comprehensive support
for transactions. These tags are covered in the chapter entitled
Transaction Management.
We strongly encourage you to look at the 'spring-tx.xsd' file that ships with the
Spring distribution. This file contains the XML Schema for Spring’s transaction
configuration and covers all of the various elements in the tx namespace, including
attribute defaults and similar information. This file is documented inline, and, thus,
the information is not repeated here in the interests of adhering to the DRY (Don’t
Repeat Yourself) principle.
In the interest of completeness, to use the elements in the tx
schema, you need to have
the following preamble at the top of your Spring XML configuration file. The text in the
following snippet references the correct schema so that the tags in the tx
namespace
are available to you:
xmlns:tx="http://www.springframework.org/schema/tx" (1)
http://www.springframework.org/schema/beans https://www.springframework.org/schema/beans/spring-beans.xsd
http://www.springframework.org/schema/tx https://www.springframework.org/schema/tx/spring-tx.xsd (2)
http://www.springframework.org/schema/aop https://www.springframework.org/schema/aop/spring-aop.xsd">
<!-- bean definitions here -->
</beans>
1 | Declare usage of the tx namespace. |
2 | Specify the location (with other schema locations). |
Often, when you use the elements in the tx namespace, you are also using the
elements from the aop namespace (since the declarative transaction support in Spring is
implemented by using AOP). The preceding XML snippet contains the relevant lines needed
to reference the aop schema so that the elements in the aop namespace are available
to you.
7.1.2. The jdbc
Schema
The jdbc
elements let you quickly configure an embedded database or initialize an
existing data source. These elements are documented in
Embedded Database Support and
Initializing a DataSource, respectively.
To use the elements in the jdbc
schema, you need to have the following preamble at the
top of your Spring XML configuration file. The text in the following snippet references
the correct schema so that the elements in the jdbc
namespace are available to you:
xmlns:jdbc="http://www.springframework.org/schema/jdbc" (1)
http://www.springframework.org/schema/jdbc https://www.springframework.org/schema/jdbc/spring-jdbc.xsd"> (2)
</beans>
1 | Declare usage of the jdbc namespace. |
