This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Data Redis 3.4.4!
Working with Objects through RedisTemplate
Most users are likely to use RedisTemplate and its corresponding package, org.springframework.data.redis.core or its reactive variant ReactiveRedisTemplate. The template is, in fact, the central class of the Redis module, due to its rich feature set. The template offers a high-level abstraction for Redis interactions. While [Reactive]RedisConnection offers low-level methods that accept and return binary values (byte arrays), the template takes care of serialization and connection management, freeing the user from dealing with such details.
The RedisTemplate class implements the RedisOperations interface and its reactive variant ReactiveRedisTemplate implements ReactiveRedisOperations.
The preferred way to reference operations on a [Reactive]RedisTemplate instance is through the [Reactive]RedisOperations interface.
Moreover, the template provides operations views (following the grouping from the Redis command reference) that offer rich, generified interfaces for working against a certain type or certain key (through the KeyBound interfaces) as described in the following table:
Operational views
Interface Description
Key Type Operations
GeoOperations
Redis geospatial operations, such as GEOADD, GEORADIUS,…​
HashOperations
Redis hash operations
HyperLogLogOperations
Redis HyperLogLog operations, such as PFADD, PFCOUNT,…​
ListOperations
Redis list operations
SetOperations
Redis set operations
ValueOperations
Redis string (or value) operations
ZSetOperations
Redis zset (or sorted set) operations
Key Bound Operations
BoundGeoOperations
Redis key bound geospatial operations
BoundHashOperations
Redis hash key bound operations
BoundKeyOperations
Redis key bound operations
BoundListOperations
Redis list key bound operations
BoundSetOperations
Redis set key bound operations
BoundValueOperations
Redis string (or value) key bound operations
BoundZSetOperations
Redis zset (or sorted set) key bound operations
Once configured, the template is thread-safe and can be reused across multiple instances.
RedisTemplate uses a Java-based serializer for most of its operations. This means that any object written or read by the template is serialized and deserialized through Java.
You can change the serialization mechanism on the template, and the Redis module offers several implementations, which are available in the org.springframework.data.redis.serializer package. See Serializers for more information. You can also set any of the serializers to null and use RedisTemplate with raw byte arrays by setting the enableDefaultSerializer property to false. Note that the template requires all keys to be non-null. However, values can be null as long as the underlying serializer accepts them. Read the Javadoc of each serializer for more information.
For cases where you need a certain template view, declare the view as a dependency and inject the template. The container automatically performs the conversion, eliminating the opsFor[X] calls, as shown in the following example:
Configuring Template API
class MyConfig {
  LettuceConnectionFactory connectionFactory() {
    return new LettuceConnectionFactory();
  RedisTemplate<String, String> redisTemplate(RedisConnectionFactory connectionFactory) {
    RedisTemplate<String, String> template = new RedisTemplate<>();
    template.setConnectionFactory(connectionFactory);
    return template;
Pushing an item to a List using [Reactive]RedisTemplate
public class Example {
  // inject the actual operations
  @Autowired
  private RedisOperations<String, String> operations;
  // inject the template as ListOperations
  @Resource(name="redisTemplate")
  private ListOperations<String, String> listOps;
  public void addLink(String userId, URL url) {
    listOps.leftPush(userId, url.toExternalForm());
String-focused Convenience Classes
Since it is quite common for the keys and values stored in Redis to be java.lang.String, the Redis modules provides two extensions to RedisConnection and RedisTemplate, respectively the StringRedisConnection (and its DefaultStringRedisConnection implementation) and StringRedisTemplate as a convenient one-stop solution for intensive String operations. In addition to being bound to String keys, the template and the connection use the StringRedisSerializer underneath, which means the stored keys and values are human-readable (assuming the same encoding is used both in Redis and your code). The following listings show an example:
class RedisConfiguration {
  LettuceConnectionFactory redisConnectionFactory() {
  StringRedisTemplate stringRedisTemplate(RedisConnectionFactory redisConnectionFactory) {
    StringRedisTemplate template = new StringRedisTemplate();
    template.setConnectionFactory(redisConnectionFactory);
    return template;
  @Autowired
  private StringRedisTemplate redisTemplate;
    redisTemplate.opsForList().leftPush(userId, url.toExternalForm());
As with the other Spring templates, RedisTemplate and StringRedisTemplate let you talk directly to Redis through the RedisCallback interface. This feature gives complete control to you, as it talks directly to the RedisConnection. Note that the callback receives an instance of StringRedisConnection when a StringRedisTemplate is used. The following example shows how to use the RedisCallback interface:
public void useCallback() {
  redisOperations.execute(new RedisCallback<Object>() {
    public Object doInRedis(RedisConnection connection) throws DataAccessException {
      Long size = connection.dbSize();
      // Can cast to StringRedisConnection if using a StringRedisTemplate
      ((StringRedisConnection)connection).set("key", "value");
Serializers
From the framework perspective, the data stored in Redis is only bytes. While Redis itself supports various types, for the most part, these refer to the way the data is stored rather than what it represents. It is up to the user to decide whether the information gets translated into strings or any other objects.
In Spring Data, the conversion between the user (custom) types and raw data (and vice-versa) is handled by Spring Data Redis in the org.springframework.data.redis.serializer package.
This package contains two types of serializers that, as the name implies, take care of the serialization process:
The main difference between these variants is that RedisSerializer primarily serializes to byte[] while readers and writers use ByteBuffer.
Multiple implementations are available (including two that have been already mentioned in this documentation):
However, one can use OxmSerializer for Object/XML mapping through Spring OXM support or Jackson2JsonRedisSerializer or GenericJackson2JsonRedisSerializer for storing data in JSON format.
Do note that the storage format is not limited only to values. It can be used for keys, values, or hashes without any restrictions.
By default, RedisCache and RedisTemplate are configured to use Java native serialization. Java native serialization is known for allowing the running of remote code caused by payloads that exploit vulnerable libraries and classes injecting unverified bytecode. Manipulated input could lead to unwanted code being run in the application during the deserialization step. As a consequence, do not use serialization in untrusted environments. In general, we strongly recommend any other message format (such as JSON) instead.
If you are concerned about security vulnerabilities due to Java serialization, consider the general-purpose serialization filter mechanism at the core JVM level:
APP信息
