This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Data Redis 3.4.4!spring-doc.cn
Object-to-Hash Mapping
The Redis Repository support persists Objects to Hashes. This requires an Object-to-Hash conversion which is done by a RedisConverter. The default implementation uses Converter for mapping property values to and from Redis native byte[].spring-doc.cn
Given the Person type from the previous sections, the default mapping looks like the following:spring-doc.cn
_class = org.example.Person                 (1)
id = e2c7dcee-b8cd-4424-883e-736ce564363e
firstname = rand                            (2)
lastname = al’thor
address.city = emond's field                (3)
address.country = andor
1 The _class attribute is included on the root level as well as on any nested interface or abstract types.
2 Simple property values are mapped by path.
3 Properties of complex types are mapped by their dot path.
Data Mapping and Type Conversion
This section explains how types are mapped to and from a Hash representation:spring-doc.cn
Table 1. Default Mapping Rules
Type Sample Mapped Value
Simple Type
(for example, String)spring-doc.cn
String firstname = "rand";spring-doc.cn
firstname = "rand"spring-doc.cn
Byte array (byte[])spring-doc.cn
byte[] image = "rand".getBytes();spring-doc.cn
image = "rand"spring-doc.cn
Complex Type
(for example, Address)spring-doc.cn
Address address = new Address("emond’s field");spring-doc.cn
address.city = "emond’s field"spring-doc.cn
List
of Simple Typespring-doc.cn
List<String> nicknames = asList("dragon reborn", "lews therin");spring-doc.cn
nicknames.[0] = "dragon reborn",
nicknames.[1] = "lews therin"spring-doc.cn
Map
Map<String, String> atts = asMap({"eye-color", "grey"}, {"…​spring-doc.cn
atts.[eye-color] = "grey",
atts.[hair-color] = "…​spring-doc.cn
List
of Complex Typespring-doc.cn
List<Address> addresses = asList(new Address("em…​spring-doc.cn
addresses.[0].city = "emond’s field",
addresses.[1].city = "…​spring-doc.cn
Map
Map<String, Address> addresses = asMap({"home", new Address("em…​spring-doc.cn
addresses.[home].city = "emond’s field",
addresses.[work].city = "…​spring-doc.cn
Due to the flat representation structure, Map keys need to be simple types, such as String or Number.
Mapping behavior can be customized by registering the corresponding Converter in RedisCustomConversions. Those converters can take care of converting from and to a single byte[] as well as Map<String, byte[]>. The first one is suitable for (for example) converting a complex type to (for example) a binary JSON representation that still uses the default mappings hash structure. The second option offers full control over the resulting hash.spring-doc.cn
Writing objects to a Redis hash deletes the content from the hash and re-creates the whole hash, so data that has not been mapped is lost.
The following example shows two sample byte array converters:spring-doc.cn
Example 1. Sample byte[] Converters
@WritingConverter
public class AddressToBytesConverter implements Converter<Address, byte[]> {
  private final Jackson2JsonRedisSerializer<Address> serializer;
  public AddressToBytesConverter() {
    serializer = new Jackson2JsonRedisSerializer<Address>(Address.class);
    serializer.setObjectMapper(new ObjectMapper());
  public byte[] convert(Address value) {
    return serializer.serialize(value);
@ReadingConverter
public class BytesToAddressConverter implements Converter<byte[], Address> {
  public BytesToAddressConverter() {
  public Address convert(byte[] value) {
    return serializer.deserialize(value);
Using the preceding byte array Converter produces output similar to the following:spring-doc.cn
firstname = rand
lastname = al’thor
address = { city : "emond's field", country : "andor" }
The following example shows two examples of Map converters:spring-doc.cn
Example 2. Sample Map<String, byte[]> Converters
@WritingConverter
public class AddressToMapConverter implements Converter<Address, Map<String, byte[]>> {
  public Map<String, byte[]> convert(Address source) {
    return singletonMap("ciudad", source.getCity().getBytes());
@ReadingConverter
public class MapToAddressConverter implements Converter<Map<String, byte[]>, Address> {
  public Address convert(Map<String, byte[]> source) {
    return new Address(new String(source.get("ciudad")));
Using the preceding Map Converter produces output similar to the following:spring-doc.cn
firstname = rand
lastname = al’thor
ciudad = "emond's field"
Custom conversions have no effect on index resolution. Secondary Indexes are still created, even for custom converted types.
Customizing Type Mapping
If you want to avoid writing the entire Java class name as type information and would rather like to use a key, you can use the @TypeAlias annotation on the entity class being persisted. If you need to customize the mapping even more, look at the TypeInformationMapper interface. An instance of that interface can be configured at the DefaultRedisTypeMapper, which can be configured on MappingRedisConverter.spring-doc.cn
The following example shows how to define a type alias for an entity:spring-doc.cn
Example 3. Defining @TypeAlias for an entity
@TypeAlias("pers")
class Person {
The resulting document contains pers as the value in a _class field.spring-doc.cn
Configuring Custom Type Mapping
The following example demonstrates how to configure a custom RedisTypeMapper in MappingRedisConverter:spring-doc.cn
Example 4. Configuring a custom RedisTypeMapper via Spring Java Config
class CustomRedisTypeMapper extends DefaultRedisTypeMapper {
  //implement custom type mapping here
class SampleRedisConfiguration {
  public MappingRedisConverter redisConverter(RedisMappingContext mappingContext,
        RedisCustomConversions customConversions, ReferenceResolver referenceResolver) {
    MappingRedisConverter mappingRedisConverter = new MappingRedisConverter(mappingContext, null, referenceResolver,
            customTypeMapper());
    mappingRedisConverter.setCustomConversions(customConversions);
    return mappingRedisConverter;
  public RedisTypeMapper customTypeMapper() {
    return new CustomRedisTypeMapper();
