This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Data Redis 3.4.4!spring-doc.cn
Getting Started
An easy way to bootstrap setting up a working environment is to create a Spring-based project via start.spring.io or create a Spring project in Spring Tools.spring-doc.cn
Examples Repository
The GitHub spring-data-examples repository hosts several examples that you can download and play around with to get a feel for how the library works.spring-doc.cn
Hello World
First, you need to set up a running Redis server. Spring Data Redis requires Redis 2.6 or above and Spring Data Redis integrates with Lettuce and Jedis, two popular open-source Java libraries for Redis.spring-doc.cn
Now you can create a simple Java application that stores and reads a value to and from Redis.spring-doc.cn
Create the main application to run, as the following example shows:spring-doc.cn
import org.apache.commons.logging.Log;
import org.apache.commons.logging.LogFactory;
import org.springframework.data.redis.connection.lettuce.LettuceConnectionFactory;
import org.springframework.data.redis.core.RedisTemplate;
import org.springframework.data.redis.serializer.StringRedisSerializer;
public class RedisApplication {
	private static final Log LOG = LogFactory.getLog(RedisApplication.class);
		LettuceConnectionFactory connectionFactory = new LettuceConnectionFactory();
		connectionFactory.afterPropertiesSet();
		RedisTemplate<String, String> template = new RedisTemplate<>();
		template.setConnectionFactory(connectionFactory);
		template.setDefaultSerializer(StringRedisSerializer.UTF_8);
		template.afterPropertiesSet();
		template.opsForValue().set("foo", "bar");
		LOG.info("Value at foo:" + template.opsForValue().get("foo"));
		connectionFactory.destroy();
import reactor.core.publisher.Mono;
import java.time.Duration;
import org.springframework.data.redis.core.ReactiveRedisTemplate;
import org.springframework.data.redis.serializer.RedisSerializationContext;
public class ReactiveRedisApplication {
	private static final Log LOG = LogFactory.getLog(ReactiveRedisApplication.class);
		ReactiveRedisTemplate<String, String> template = new ReactiveRedisTemplate<>(connectionFactory,
				RedisSerializationContext.string());
		Mono<Boolean> set = template.opsForValue().set("foo", "bar");
		set.block(Duration.ofSeconds(10));
		LOG.info("Value at foo:" + template.opsForValue().get("foo").block(Duration.ofSeconds(10)));
Even in this simple example, there are a few notable things to point out:spring-doc.cn
