This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Data Redis 3.4.4!
Connection Modes
Redis can be operated in various setups. Each mode of operation requires specific configuration that is explained in the following sections.
Redis Standalone
The easiest way to get started is by using Redis Standalone with a single Redis server,
Configure LettuceConnectionFactory or JedisConnectionFactory, as shown in the following example:
class RedisStandaloneConfiguration {
   * Lettuce
  public RedisConnectionFactory lettuceConnectionFactory() {
    return new LettuceConnectionFactory(new RedisStandaloneConfiguration("server", 6379));
   * Jedis
  public RedisConnectionFactory jedisConnectionFactory() {
    return new JedisConnectionFactory(new RedisStandaloneConfiguration("server", 6379));
Write to Master, Read from Replica
The Redis Master/Replica setup — without automatic failover (for automatic failover see: Sentinel) — not only allows data to be safely stored at more nodes. It also allows, by using Lettuce, reading data from replicas while pushing writes to the master. You can set the read/write strategy to be used by using LettuceClientConfiguration, as shown in the following example:
class WriteToMasterReadFromReplicaConfiguration {
  public LettuceConnectionFactory redisConnectionFactory() {
    LettuceClientConfiguration clientConfig = LettuceClientConfiguration.builder()
      .readFrom(REPLICA_PREFERRED)
    RedisStandaloneConfiguration serverConfig = new RedisStandaloneConfiguration("server", 6379);
    return new LettuceConnectionFactory(serverConfig, clientConfig);
For environments reporting non-public addresses through the INFO command (for example, when using AWS), use RedisStaticMasterReplicaConfiguration instead of RedisStandaloneConfiguration. Please note that RedisStaticMasterReplicaConfiguration does not support Pub/Sub because of missing Pub/Sub message propagation across individual servers.
Redis Sentinel
For dealing with high-availability Redis, Spring Data Redis has support for Redis Sentinel, using RedisSentinelConfiguration, as shown in the following example:
 * Lettuce
  RedisSentinelConfiguration sentinelConfig = new RedisSentinelConfiguration()
  .master("mymaster")
  .sentinel("127.0.0.1", 26379)
  .sentinel("127.0.0.1", 26380);
  return new LettuceConnectionFactory(sentinelConfig);
 * Jedis
  .master("mymaster")
  return new JedisConnectionFactory(sentinelConfig);
RedisSentinelConfiguration can also be defined through RedisSentinelConfiguration.of(PropertySource), which lets you pick up the following properties:
Configuration Properties
  • spring.redis.sentinel.master: name of the master node.
  • spring.redis.sentinel.nodes: Comma delimited list of host:port pairs.
  • spring.redis.sentinel.username: The username to apply when authenticating with Redis Sentinel (requires Redis 6)
  • spring.redis.sentinel.password: The password to apply when authenticating with Redis Sentinel
  • spring.redis.sentinel.dataNode.username: The username to apply when authenticating with Redis Data Node
  • spring.redis.sentinel.dataNode.password: The password to apply when authenticating with Redis Data Node
  • spring.redis.sentinel.dataNode.database: The database index to apply when authenticating with Redis Data Node
Sometimes, direct interaction with one of the Sentinels is required. Using RedisConnectionFactory.getSentinelConnection() or RedisConnection.getSentinelCommands() gives you access to the first active Sentinel configured.
Redis Cluster
Cluster support is based on the same building blocks as non-clustered communication. RedisClusterConnection, an extension to RedisConnection, handles the communication with the Redis Cluster and translates errors into the Spring DAO exception hierarchy. RedisClusterConnection instances are created with the RedisConnectionFactory, which has to be set up with the associated RedisClusterConfiguration, as shown in the following example:
Example 1. Sample RedisConnectionFactory Configuration for Redis Cluster
@Component
@ConfigurationProperties(prefix = "spring.redis.cluster")
public class ClusterConfigurationProperties {
     * spring.redis.cluster.nodes[0] = 127.0.0.1:7379
     * spring.redis.cluster.nodes[1] = 127.0.0.1:7380
    List<String> nodes;
     * Get initial collection of known cluster nodes in format {@code host:port}.
     * @return
    public List<String> getNodes() {
        return nodes;
    public void setNodes(List<String> nodes) {
        this.nodes = nodes;
public class AppConfig {
     * Type safe representation of application.properties
    @Autowired ClusterConfigurationProperties clusterProperties;
    public @Bean RedisConnectionFactory connectionFactory() {
            new RedisClusterConfiguration(clusterProperties.getNodes()));
RedisClusterConfiguration can also be defined through RedisClusterConfiguration.of(PropertySource), which lets you pick up the following properties:
  • spring.redis.cluster.nodes: Comma-delimited list of host:port pairs.
  • spring.redis.cluster.max-redirects: Number of allowed cluster redirections.
The initial configuration points driver libraries to an initial set of cluster nodes. Changes resulting from live cluster reconfiguration are kept only in the native driver and are not written back to the configuration.
APP信息
