For the latest stable version, please use Spring Data Relational 3.4.5!spring-doc.cn
Null Safety
One of Kotlin’s key features is null safety, which cleanly deals with null values at compile time. This makes applications safer through nullability declarations and the expression of “value or no value” semantics without paying the cost of wrappers, such as Optional. (Kotlin allows using functional constructs with nullable values. See this comprehensive guide to Kotlin null safety.)spring-doc.cn
Although Java does not let you express null safety in its type system, Spring Data API is annotated with JSR-305 tooling friendly annotations declared in the org.springframework.lang package. By default, types from Java APIs used in Kotlin are recognized as platform types, for which null checks are relaxed. Kotlin support for JSR-305 annotations and Spring nullability annotations provide null safety for the whole Spring Data API to Kotlin developers, with the advantage of dealing with null related issues at compile time.spring-doc.cn
See Null Handling of Repository Methods how null safety applies to Spring Data Repositories.spring-doc.cn
You can configure JSR-305 checks by adding the -Xjsr305 compiler flag with the following options: -Xjsr305={strict|warn|ignore}.spring-doc.cn
For Kotlin versions 1.1+, the default behavior is the same as -Xjsr305=warn. The strict value is required take Spring Data API null-safety into account. Kotlin types inferred from Spring API but should be used with the knowledge that Spring API nullability declaration could evolve, even between minor releases and that more checks may be added in the future.spring-doc.cn
Generic type arguments, varargs, and array elements nullability are not supported yet, but should be in an upcoming release.
