This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Data Neo4j 7.4.0!
Spatial types
Spring Data Neo4j supports the following spatial types
Supported conversions
Derived finder keywords
If you are using the native Neo4j Java driver org.neo4j.driver.types.Point type, you can make use of the following keywords and parameter types in derived finder methods.
Query inside an area:
  • findBy[…​]Within(org.springframework.data.geo.Circle circle)
  • findBy[…​]Within(org.springframework.data.geo.Box box)
  • findBy[…​]Within(org.springframework.data.neo4j.repository.query.BoundingBox boundingBox)
You could also use a org.springframework.data.geo.Polygon but would need to pass it into a BoundingBox by calling BoundingBox#of.
Query near a certain point:
  • findBy[…​]Near(org.neo4j.driver.types.Point point) - returns result sorted by distance to the given point ascending
  • findBy[…​]Near(Point point, org.springframework.data.geo.Distance max)
  • findBy[…​]Near(Point point, org.springframework.data.domain.Range<Distance> between)
  • findBy[…​]Near(Range<Distance> between, Point p)
APP信息
