This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Data Neo4j 7.4.0!
Neo4jClient
Spring Data Neo4j comes with a Neo4j Client, providing a thin layer on top of Neo4j’s Java driver.
While the plain Java driver is a very versatile tool providing an asynchronous API in addition to the imperative and reactive versions, it doesn’t integrate with Spring application level transactions.
SDN uses the driver through the concept of an idiomatic client as directly as possible.
The client has the following main goals
  1. Integrate into Springs transaction management, for both imperative and reactive scenarios
  2. Participate in JTA-Transactions if necessary
  3. Provide a consistent API for both imperative and reactive scenarios
  4. Don’t add any mapping overhead
SDN relies on all those features and uses them to fulfill its entity mapping features.
Have a look at the SDN building blocks for where both the imperative and reactive Neo4 clients are positioned in our stack.
The Neo4j Client comes in two flavors:
  • org.springframework.data.neo4j.core.Neo4jClient
  • org.springframework.data.neo4j.core.ReactiveNeo4jClient
While both versions provide an API using the same vocabulary and syntax, they are not API compatible. Both versions feature the same, fluent API to specify queries, bind parameters and extract results.
Imperative or reactive?
Interactions with a Neo4j Client usually ends with a call to
The imperative version will interact at this moment with the database and get the requested results or summary, wrapped in an Optional<> or a Collection.
The reactive version will in contrast return a publisher of the requested type. Interaction with the database and retrieval of the results will not happen until the publisher is subscribed to. The publisher can only be subscribed once.
Getting an instance of the client
As with most things in SDN, both clients depend on a configured driver instance.
Creating an instance of the imperative Neo4j client
import org.neo4j.driver.AuthTokens;
import org.neo4j.driver.Driver;
import org.neo4j.driver.GraphDatabase;
import org.springframework.data.neo4j.core.Neo4jClient;
public class Demo {
    public static void main(String...args) {
        Driver driver = GraphDatabase
            .driver("neo4j://localhost:7687", AuthTokens.basic("neo4j", "secret"));
        Neo4jClient client = Neo4jClient.create(driver);
The driver can only open a reactive session against a 4.0 database and will fail with an exception on any lower version.
Creating an instance of the reactive Neo4j client
import org.springframework.data.neo4j.core.ReactiveNeo4jClient;
public class Demo {
        ReactiveNeo4jClient client = ReactiveNeo4jClient.create(driver);
Make sure you use the same driver instance for the client as you used for providing a Neo4jTransactionManager or ReactiveNeo4jTransactionManager in case you have enabled transactions. The client won’t be able to synchronize transactions if you use another instance of a driver.
Our Spring Boot starter provide a ready to use bean of the Neo4j Client that fits the environment (imperative or reactive) and you usually don’t have to configure your own instance.
Usage
Selecting the target database
The Neo4j client is well prepared to be used with the multidatabase features of Neo4j 4.0. The client uses the default database unless you specify otherwise. The fluent API of the client allows to specify the target database exactly once, after the declaration of the query to execute. Selecting the target database demonstrates it with the reactive client:
Flux<Map<String, Object>> allActors = client
	.query("MATCH (p:Person) RETURN p")
	.in("neo4j") (1)
	.fetch()
	.all();
1 Select the target database in which the query is to be executed.
Specifying queries
The interaction with the clients starts with a query. A query can be defined by a plain String or a Supplier<String>. The supplier will be evaluated as late as possible and can be provided by any query builder.
Specifying a query
Mono<Map<String, Object>> firstActor = client
	.query(() -> "MATCH (p:Person) RETURN p")
	.fetch()
	.first();
Retrieving results
As the previous listings shows, the interaction with the client always ends with a call to fetch and how many results shall be received. Both reactive and imperative client offer
one()
Expect exactly one result from the query
first()
Expect results and return the first record
all()
Retrieve all records returned
The imperative client returns Optional<T> and Collection<T> respectively, while the reactive client returns Mono<T> and Flux<T>, the later one being executed only if subscribed to.
If you don’t expect any results from your query, then use run() after specifying the query.
Retrieving result summaries in a reactive way
Mono<ResultSummary> summary = reactiveClient
    .query("MATCH (m:Movie) where m.title = 'Aeon Flux' DETACH DELETE m")
    .run();
summary
    .map(ResultSummary::counters)
    .subscribe(counters ->
        System.out.println(counters.nodesDeleted() + " nodes have been deleted")
    ); (1)
1 The actual query is triggered here by subscribing to the publisher.
Please take a moment to compare both listings and understand the difference when the actual query is triggered.
Retrieving result summaries in an imperative way
ResultSummary resultSummary = imperativeClient
	.run(); (1)
SummaryCounters counters = resultSummary.counters();
1 Here the query is immediately triggered.
Mapping parameters
Queries can contain named parameters ($someName) and the Neo4j client makes it easy to bind values to them.
The client doesn’t check whether all parameters are bound or whether there are too many values. That is left to the driver. However, the client prevents you from using a parameter name twice.
You can either bind simple types that the Java driver understands without conversion or complex classes. For complex classes you need to provide a binder function as shown in this listing. Please have a look at the drivers manual, to see which simple types are supported.
Mapping simple types
Map<String, Object> parameters = new HashMap<>();
parameters.put("name", "Li.*");
Flux<Map<String, Object>> directorAndMovies = client
	.query(
		"MATCH (p:Person) - [:DIRECTED] -> (m:Movie {title: $title}), (p) - [:WROTE] -> (om:Movie) " +
			"WHERE p.name =~ $name " +
			"  AND p.born < $someDate.year " +
			"RETURN p, om"
	.bind("The Matrix").to("title") (1)
	.bind(LocalDate.of(1979, 9, 21)).to("someDate")
	.bindAll(parameters) (2)
	.fetch()
	.all();
1 There’s a fluent API for binding simple types.
2 Alternatively parameters can be bound via a map of named parameters.
SDN does a lot of complex mapping and it uses the same API that you can use from the client.
You can provide a Function<T, Map<String, Object>> for any given domain object like an owner of bicycles in Example of a domain type to the Neo4j Client to map those domain objects to parameters the driver can understand.
public class Director {
    private final String name;
    private final List<Movie> movies;
    Director(String name, List<Movie> movies) {
        this.name = name;
        this.movies = new ArrayList<>(movies);
    public String getName() {
        return name;
    public List<Movie> getMovies() {
        return Collections.unmodifiableList(movies);
public class Movie {
    private final String title;
    public Movie(String title) {
        this.title = title;
    public String getTitle() {
        return title;
The mapping function has to fill in all named parameters that might occur in the query like Using a mapping function for binding domain objects shows:
Director joseph = new Director("Joseph Kosinski",
        Arrays.asList(new Movie("Tron Legacy"), new Movie("Top Gun: Maverick")));
Mono<ResultSummary> summary = client
    .query(""
        + "MERGE (p:Person {name: $name}) "
        + "WITH p UNWIND $movies as movie "
        + "MERGE (m:Movie {title: movie}) "
        + "MERGE (p) - [o:DIRECTED] -> (m) "
    .bind(joseph).with(director -> { (1)
        Map<String, Object> mappedValues = new HashMap<>();
        List<String> movies = director.getMovies().stream()
            .map(Movie::getTitle).collect(Collectors.toList());
        mappedValues.put("name", director.getName());
        mappedValues.put("movies", movies);
        return mappedValues;
    .run();
1 The with method allows for specifying the binder function.
Working with result objects
Both clients return collections or publishers of maps (Map<String, Object>). Those maps correspond exactly with the records that a query might have produced.
In addition, you can plug in your own BiFunction<TypeSystem, Record, T> through fetchAs to reproduce your domain object.
Using a mapping function for reading domain objects
Mono<Director> lily = client
    .query(""
        + " MATCH (p:Person {name: $name}) - [:DIRECTED] -> (m:Movie)"
        + "RETURN p, collect(m) as movies")
    .bind("Lilly Wachowski").to("name")
    .fetchAs(Director.class).mappedBy((TypeSystem t, Record record) -> {
        List<Movie> movies = record.get("movies")
            .asList(v -> new Movie((v.get("title").asString())));
        return new Director(record.get("name").asString(), movies);
    .one();
TypeSystem gives access to the types the underlying Java driver used to fill the record.
Using domain-aware mapping functions
If you know that the result of the query will contain nodes that have entity definitions in your application, you can use the injectable MappingContext to retrieve their mapping functions and apply them during the mapping.
Using an existing mapping function
BiFunction<TypeSystem, MapAccessor, Movie> mappingFunction = neo4jMappingContext.getRequiredMappingFunctionFor(Movie.class);
    .query(""
            .asList(movie -> mappingFunction.apply(t, movie));
    .one();
Interacting directly with the driver while using managed transactions
In case you don’t want or don’t like the opinionated "client" approach of the Neo4jClient or the ReactiveNeo4jClient, you can have the client delegate all interactions with the database to your code. The interaction after the delegation is slightly different with the imperative and reactive versions of the client.
The imperative version takes in a Function<StatementRunner, Optional<T>> as a callback. Returning an empty optional is ok.
Delegate database interaction to an imperative StatementRunner
Optional<Long> result = client
    .delegateTo((StatementRunner runner) -> {
        // Do as many interactions as you want
        long numberOfNodes = runner.run("MATCH (n) RETURN count(n) as cnt")
            .single().get("cnt").asLong();
        return Optional.of(numberOfNodes);
    // .in("aDatabase") (1)
    .run();
1 The database selection as described in Selecting the target database is optional.
The reactive version receives a RxStatementRunner.
Delegate database interaction to a reactive RxStatementRunner
Mono<Integer> result = client
    .delegateTo((RxStatementRunner runner) ->
        Mono.from(runner.run("MATCH (n:Unused) DELETE n").summary())
            .map(SummaryCounters::nodesDeleted))
    .run();
1 Optional selection of the target database.
Note that in both Delegate database interaction to an imperative StatementRunner and Delegate database interaction to a reactive RxStatementRunner the types of the runner have only been stated to provide more clarity to reader of this manual.
APP信息
