对于最新的稳定版本,请使用 Spring Data MongoDB 4.4.5spring-doc.cadn.net.cn
保存、更新和删除文档
MongoTemplate / ReactiveMongoTemplatge允许您保存、更新和删除域对象,并将这些对象映射到存储在 MongoDB 中的文档。 命令式 API 和反应式 API 的 API 签名基本相同,只是返回类型不同。 虽然同步 API 使用voidObjectList反应式对应物包括Mono<Void>,Mono<Object>Flux.spring-doc.cadn.net.cn
请考虑以下类:spring-doc.cadn.net.cn
public class Person {
	private String id;
	private String name;
	private int age;
	public Person(String name, int age) {
		this.name = name;
		this.age = age;
	public String getId() {
		return id;
	public String getName() {
		return name;
	public int getAge() {
		return age;
	public String toString() {
		return "Person [id=" + id + ", name=" + name + ", age=" + age + "]";
鉴于Person类,您可以保存、更新和删除对象,如下例所示:spring-doc.cadn.net.cn
public class MongoApplication {
  private static final Log log = LogFactory.getLog(MongoApplication.class);
    MongoOperations template = new MongoTemplate(new SimpleMongoClientDbFactory(MongoClients.create(), "database"));
    Person p = new Person("Joe", 34);
    // Insert is used to initially store the object into the database.
    template.insert(p);
    log.info("Insert: " + p);
    // Find
    p = template.findById(p.getId(), Person.class);
    log.info("Found: " + p);
    // Update
    template.updateFirst(query(where("name").is("Joe")), update("age", 35), Person.class);
    p = template.findOne(query(where("name").is("Joe")), Person.class);
    log.info("Updated: " + p);
    // Delete
    template.remove(p);
    // Check that deletion worked
    List<Person> people =  template.findAll(Person.class);
    log.info("Number of people = : " + people.size());
    template.dropCollection(Person.class);
前面的示例将生成以下日志输出(包括来自MongoTemplate):spring-doc.cadn.net.cn
DEBUG apping.MongoPersistentEntityIndexCreator:  80 - Analyzing class class org.spring.example.Person for index information.
DEBUG work.data.mongodb.core.MongoTemplate: 632 - insert Document containing fields: [_class, age, name] in collection: person
INFO               org.spring.example.MongoApp:  30 - Insert: Person [id=4ddc6e784ce5b1eba3ceaf5c, name=Joe, age=34]
DEBUG work.data.mongodb.core.MongoTemplate:1246 - findOne using query: { "_id" : { "$oid" : "4ddc6e784ce5b1eba3ceaf5c"}} in db.collection: database.person
INFO               org.spring.example.MongoApp:  34 - Found: Person [id=4ddc6e784ce5b1eba3ceaf5c, name=Joe, age=34]
DEBUG work.data.mongodb.core.MongoTemplate: 778 - calling update using query: { "name" : "Joe"} and update: { "$set" : { "age" : 35}} in collection: person
DEBUG work.data.mongodb.core.MongoTemplate:1246 - findOne using query: { "name" : "Joe"} in db.collection: database.person
INFO               org.spring.example.MongoApp:  39 - Updated: Person [id=4ddc6e784ce5b1eba3ceaf5c, name=Joe, age=35]
DEBUG work.data.mongodb.core.MongoTemplate: 823 - remove using query: { "id" : "4ddc6e784ce5b1eba3ceaf5c"} in collection: person
INFO               org.spring.example.MongoApp:  46 - Number of people = : 0
DEBUG work.data.mongodb.core.MongoTemplate: 376 - Dropped collection [database.person]
public class ReactiveMongoApplication {
  private static final Logger log = LoggerFactory.getLogger(ReactiveMongoApplication.class);
  public static void main(String[] args) throws Exception {
    CountDownLatch latch = new CountDownLatch(1);
    ReactiveMongoTemplate template = new ReactiveMongoTemplate(MongoClients.create(), "database");
    template.insert(new Person("Joe", 34)).doOnNext(person -> log.info("Insert: " + person))
      .flatMap(person -> template.findById(person.getId(), Person.class))
      .doOnNext(person -> log.info("Found: " + person))
      .zipWith(person -> template.updateFirst(query(where("name").is("Joe")), update("age", 35), Person.class))
      .flatMap(tuple -> template.remove(tuple.getT1())).flatMap(deleteResult -> template.findAll(Person.class))
      .count().doOnSuccess(count -> {
        log.info("Number of people: " + count);
        latch.countDown();
      .subscribe();
    latch.await();
MongoConverter导致String以及一个ObjectId通过识别(通过约定)存储在数据库中的Idproperty name 属性。spring-doc.cadn.net.cn
前面的示例旨在演示如何对MongoTemplate / ReactiveMongoTemplate而不是显示复杂的映射功能。 前面示例中使用的查询语法在 “查询文档” 一节中有更详细的说明。spring-doc.cadn.net.cn
MongoDB 要求您有一个_id字段。请参阅 ID 处理部分,了解有关此字段的特殊处理的详细信息。
MongoDB 集合可以包含表示各种类型实例的文档。有关详细信息,请参阅类型映射
插入 / 保存
有几种方便的方法MongoTemplate用于保存和插入对象。 要对转换过程进行更精细的控制,可以使用MappingMongoConverter— 例如Converter<Person, Document>Converter<Document, Person>.spring-doc.cadn.net.cn
插入作和保存作之间的区别在于,如果对象尚不存在,则保存作将执行插入。
使用 save作的简单情况是保存一个 POJO。 在这种情况下,集合名称由类的名称(非完全限定)确定。 您还可以使用特定的集合名称调用 save作。您可以使用映射元数据覆盖用于存储对象的集合。spring-doc.cadn.net.cn
插入或保存时,如果Id属性,则假设其值将由数据库自动生成。 因此,为了自动生成ObjectId要成功,需要Idproperty 或 field 必须是StringObjectIdBigInteger.spring-doc.cadn.net.cn
以下示例显示如何保存文档并检索其内容:spring-doc.cadn.net.cn
使用 MongoTemplate 插入和检索文档
import static org.springframework.data.mongodb.core.query.Criteria.where;
import static org.springframework.data.mongodb.core.query.Criteria.query;
template.insert(new Person("Bob", 33));
Person person = template.query(Person.class)
    .matching(query(where("age").is(33)))
    .oneValue();
Mono<Person> person = mongoTemplate.insert(new Person("Bob", 33))
    .then(mongoTemplate.query(Person.class)
        .one());
The following insert and save operations are available:spring-doc.cadn.net.cn
  • void save (Object objectToSave): Save the object to the default collection.spring-doc.cadn.net.cn
  • void save (Object objectToSave, String collectionName): Save the object to the specified collection.spring-doc.cadn.net.cn
A similar set of insert operations is also available:spring-doc.cadn.net.cn
  • void insert (Object objectToSave): Insert the object to the default collection.spring-doc.cadn.net.cn
  • void insert (Object objectToSave, String collectionName): Insert the object to the specified collection.spring-doc.cadn.net.cn
How the _id Field is Handled in the Mapping Layer
MongoDB requires that you have an _id field for all documents. If you do not provide one, the driver assigns an ObjectId with a generated value without considering your domain model as the server isn’t aware of your identifier type. When you use the MappingMongoConverter, certain rules govern how properties from the Java class are mapped to this _id field:spring-doc.cadn.net.cn
  1. A property or field annotated with @Id (org.springframework.data.annotation.Id) maps to the _id field.spring-doc.cadn.net.cn
  2. A property or field without an annotation but named id maps to the _id field.spring-doc.cadn.net.cn
The following outlines what type conversion, if any, is done on the property mapped to the _id document field when using the MappingMongoConverter (the default for MongoTemplate).spring-doc.cadn.net.cn
  1. If possible, an id property or field declared as a String in the Java class is converted to and stored as an ObjectId by using a Spring Converter<String, ObjectId>. Valid conversion rules are delegated to the MongoDB Java driver. If it cannot be converted to an ObjectId, then the value is stored as a string in the database.spring-doc.cadn.net.cn
  2. An id property or field declared as BigInteger in the Java class is converted to and stored as an ObjectId by using a Spring Converter<BigInteger, ObjectId>.spring-doc.cadn.net.cn
If no field or property specified in the previous sets of rules is present in the Java class, an implicit _id file is generated by the driver but not mapped to a property or field of the Java class.spring-doc.cadn.net.cn
When querying and updating, MongoTemplate uses the converter that corresponds to the preceding rules for saving documents so that field names and types used in your queries can match what is in your domain classes.spring-doc.cadn.net.cn
Some environments require a customized approach to map Id values such as data stored in MongoDB that did not run through the Spring Data mapping layer. Documents can contain _id values that can be represented either as ObjectId or as String. Reading documents from the store back to the domain type works just fine. Querying for documents via their id can be cumbersome due to the implicit ObjectId conversion. Therefore documents cannot be retrieved that way. For those cases @MongoId provides more control over the actual id mapping attempts.spring-doc.cadn.net.cn
Example 1. @MongoId mapping
public class PlainStringId {
  @MongoId String id; (1)
public class PlainObjectId {
  @MongoId ObjectId id; (2)
public class StringToObjectId {
  @MongoId(FieldType.OBJECT_ID) String id; (3)
1 The id is treated as String without further conversion.
2 The id is treated as ObjectId.
3 The id is treated as ObjectId if the given String is a valid ObjectId hex, otherwise as String. Corresponds to @Id usage.
Into Which Collection Are My Documents Saved?
There are two ways to manage the collection name that is used for the documents. The default collection name that is used is the class name changed to start with a lower-case letter. So a com.test.Person class is stored in the person collection. You can customize this by providing a different collection name with the @Document annotation. You can also override the collection name by providing your own collection name as the last parameter for the selected MongoTemplate method calls.spring-doc.cadn.net.cn
Inserting or Saving Individual Objects
The MongoDB driver supports inserting a collection of documents in a single operation. The following methods in the MongoOperations interface support this functionality:spring-doc.cadn.net.cn
  • insert: Inserts an object. If there is an existing document with the same id, an error is generated.spring-doc.cadn.net.cn
  • insertAll: Takes a Collection of objects as the first parameter. This method inspects each object and inserts it into the appropriate collection, based on the rules specified earlier.spring-doc.cadn.net.cn
  • save: Saves the object, overwriting any object that might have the same id.spring-doc.cadn.net.cn
Inserting Several Objects in a Batch
The MongoDB driver supports inserting a collection of documents in one operation. The following methods in the MongoOperations interface support this functionality via insert or a dedicated BulkOperations interface.spring-doc.cadn.net.cn
Batch Insert
Collection<Person> inserted = template.insert(List.of(...), Person.class);
Flux<Person> inserted = template.insert(List.of(...), Person.class);
Bulk Insert
BulkWriteResult result = template.bulkOps(BulkMode.ORDERED, Person.class)
    .insert(List.of(...))
    .execute();
Mono<BulkWriteResult> result = template.bulkOps(BulkMode.ORDERED, Person.class)
    .execute();
Server performance of batch and bulk is identical. However bulk operations do not publish lifecycle events.spring-doc.cadn.net.cn
Any @Version property that has not been set prior to calling insert will be auto initialized with 1 (in case of a simple type like int) or 0 for wrapper types (eg. Integer).
Read more in the see Optimistic Locking section.
Update
For updates, you can update the first document found by using MongoOperation.updateFirst or you can update all documents that were found to match the query by using the MongoOperation.updateMulti method or all on the fluent API. The following example shows an update of all SAVINGS accounts where we are adding a one-time $50.00 bonus to the balance by using the $inc operator:spring-doc.cadn.net.cn
Updating documents by using the MongoTemplate / ReactiveMongoTemplate
import org.springframework.data.mongodb.core.query.Update;
UpdateResult result = template.update(Account.class)
    .matching(where("accounts.accountType").is(Type.SAVINGS))
    .apply(new Update().inc("accounts.$.balance", 50.00))
    .all();
Mono<UpdateResult> result = template.update(Account.class)
    .all();
In addition to the Query discussed earlier, we provide the update definition by using an Update object. The Update class has methods that match the update modifiers available for MongoDB. Most methods return the Update object to provide a fluent style for the API.spring-doc.cadn.net.cn
@Version properties if not included in the Update will be automatically incremented. Read more in the see Optimistic Locking section.spring-doc.cadn.net.cn
Methods for Running Updates for Documents
  • updateFirst: Updates the first document that matches the query document criteria with the updated document.spring-doc.cadn.net.cn
  • updateMulti: Updates all objects that match the query document criteria with the updated document.spring-doc.cadn.net.cn
updateFirst does not support ordering. Please use findAndModify to apply Sort.
Index hints for the update operation can be provided via Query.withHint(…​).
Methods in the Update Class
You can use a little "'syntax sugar'" with the Update class, as its methods are meant to be chained together. Also, you can kick-start the creation of a new Update instance by using public static Update update(String key, Object value) and using static imports.spring-doc.cadn.net.cn
The Update class contains the following methods:spring-doc.cadn.net.cn
Some update modifiers, such as $push and $addToSet, allow nesting of additional operators.spring-doc.cadn.net.cn
// { $push : { "category" : { "$each" : [ "spring" , "data" ] } } }
new Update().push("category").each("spring", "data")
// { $push : { "key" : { "$position" : 0 , "$each" : [ "Arya" , "Arry" , "Weasel" ] } } }
new Update().push("key").atPosition(Position.FIRST).each(Arrays.asList("Arya", "Arry", "Weasel"));
// { $push : { "key" : { "$slice" : 5 , "$each" : [ "Arya" , "Arry" , "Weasel" ] } } }
new Update().push("key").slice(5).each(Arrays.asList("Arya", "Arry", "Weasel"));
// { $addToSet : { "values" : { "$each" : [ "spring" , "data" , "mongodb" ] } } }
new Update().addToSet("values").each("spring", "data", "mongodb");
Aggregation Pipeline Updates
Update methods exposed by MongoOperations and ReactiveMongoOperations also accept an Aggregation Pipeline via AggregationUpdate. Using AggregationUpdate allows leveraging MongoDB 4.2 aggregations in an update operation. Using aggregations in an update allows updating one or more fields by expressing multiple stages and multiple conditions with a single operation.spring-doc.cadn.net.cn
The update can consist of the following stages:spring-doc.cadn.net.cn
Example 2. Update Aggregation
AggregationUpdate update = Aggregation.newUpdate()
    .set("average").toValue(ArithmeticOperators.valueOf("tests").avg())     (1)
    .set("grade").toValue(ConditionalOperators.switchCases(                 (2)
        when(valueOf("average").greaterThanEqualToValue(90)).then("A"),
        when(valueOf("average").greaterThanEqualToValue(80)).then("B"),
        when(valueOf("average").greaterThanEqualToValue(70)).then("C"),
        when(valueOf("average").greaterThanEqualToValue(60)).then("D"))
        .defaultTo("F")
template.update(Student.class)                                              (3)
    .apply(update)
    .all();        (4)
db.students.update(                                                         (3)
     { $set: { average : { $avg: "$tests" } } },                            (1)
     { $set: { grade: { $switch: {                                          (2)
                           branches: [
                               { case: { $gte: [ "$average", 90 ] }, then: "A" },
                               { case: { $gte: [ "$average", 80 ] }, then: "B" },
                               { case: { $gte: [ "$average", 70 ] }, then: "C" },
                               { case: { $gte: [ "$average", 60 ] }, then: "D" }
                           default: "F"
   { multi: true }                                                          (4)
1 The 1st $set stage calculates a new field average based on the average of the tests field.
2 The 2nd $set stage calculates a new field grade based on the average field calculated by the first aggregation stage.
3 The pipeline is run on the students collection and uses Student for the aggregation field mapping.
4 Apply the update to all matching documents in the collection.
Upsert
Related to performing an updateFirst operation, you can also perform an upsert operation, which will perform an insert if no document is found that matches the query. The document that is inserted is a combination of the query document and the update document. The following example shows how to use the upsert method:spring-doc.cadn.net.cn
UpdateResult result = template.update(Person.class)
  .matching(query(where("ssn").is(1111).and("firstName").is("Joe").and("Fraizer").is("Update"))
  .apply(update("address", addr))
  .upsert();
Mono<UpdateResult> result = template.update(Person.class)
  .upsert();
upsert does not support ordering. Please use findAndModify to apply Sort.
@Version properties if not included in the Update will be automatically initialized. Read more in the see Optimistic Locking section.spring-doc.cadn.net.cn
Replacing Documents in a Collection
The various replace methods available via MongoTemplate allow to override the first matching Document. If no match is found a new one can be upserted (as outlined in the previous section) by providing ReplaceOptions with according configuration.spring-doc.cadn.net.cn
Replace one
Person tom = template.insert(new Person("Motte", 21)); (1)
Query query = Query.query(Criteria.where("firstName").is(tom.getFirstName())); (2)
tom.setFirstname("Tom"); (3)
template.replace(query, tom, ReplaceOptions.none()); (4)
1 Insert a new document.
2 The query used to identify the single document to replace.
3 Set up the replacement document which must hold either the same _id as the existing or no _id at all.
4 Run the replace operation. .Replace one with upsert
Person tom = new Person("id-123", "Tom", 21) (1)
template.replace(query, tom, ReplaceOptions.replaceOptions().upsert()); (2)
1 The _id value needs to be present for upsert, otherwise MongoDB will create a new potentially with the domain type incompatible ObjectId. As MongoDB is not aware of your domain type, any @Field(targetType) hints are not considered and the resulting ObjectId might be not compatible with your domain model.
2 Use upsert to insert a new document if no match is found
It is not possible to change the _id of existing documents with a replace operation. On upsert MongoDB uses 2 ways of determining the new id for the entry: * The _id is used within the query as in {"_id" : 1234 } * The _id is present in the replacement document. If no _id is provided in either way, MongoDB will create a new ObjectId for the document. This may lead to mapping and data lookup malfunctions if the used domain types id property has a different type like e.g. Long.spring-doc.cadn.net.cn
Find and Modify
The findAndModify(…) method on MongoCollection can update a document and return either the old or newly updated document in a single operation. MongoTemplate provides four findAndModify overloaded methods that take Query and Update classes and converts from Document to your POJOs:spring-doc.cadn.net.cn
<T> T findAndModify(Query query, Update update, Class<T> entityClass);
<T> T findAndModify(Query query, Update update, Class<T> entityClass, String collectionName);
<T> T findAndModify(Query query, Update update, FindAndModifyOptions options, Class<T> entityClass);
<T> T findAndModify(Query query, Update update, FindAndModifyOptions options, Class<T> entityClass, String collectionName);
The following example inserts a few Person objects into the container and performs a findAndUpdate operation:spring-doc.cadn.net.cn
template.insert(new Person("Tom", 21));
template.insert(new Person("Dick", 22));
template.insert(new Person("Harry", 23));
Query query = new Query(Criteria.where("firstName").is("Harry"));
Update update = new Update().inc("age", 1);
Person oldValue = template.update(Person.class)
  .matching(query)
  .apply(update)
  .findAndModifyValue(); // oldValue.age == 23
Person newValue = template.query(Person.class)
  .matching(query)
  .findOneValue(); // newValye.age == 24
Person newestValue = template.update(Person.class)
  .matching(query)
  .apply(update)
  .withOptions(FindAndModifyOptions.options().returnNew(true)) // Now return the newly updated document when updating
  .findAndModifyValue(); // newestValue.age == 25
The FindAndModifyOptions method lets you set the options of returnNew, upsert, and remove. An example extending from the previous code snippet follows:spring-doc.cadn.net.cn
Person upserted = template.update(Person.class)
  .matching(new Query(Criteria.where("firstName").is("Mary")))
  .apply(update)
  .withOptions(FindAndModifyOptions.options().upsert(true).returnNew(true))
Find and Replace
The most straight forward method of replacing an entire Document is via its id using the save method. However this might not always be feasible. findAndReplace offers an alternative that allows to identify the document to replace via a simple query.spring-doc.cadn.net.cn
Example 3. Find and Replace Documents
Optional<User> result = template.update(Person.class)      (1)
    .matching(query(where("firstame").is("Tom")))          (2)
    .replaceWith(new Person("Dick"))
    .withOptions(FindAndReplaceOptions.options().upsert()) (3)
    .as(User.class)                                        (4)
    .findAndReplace();                                     (5)
1 Use the fluent update API with the domain type given for mapping the query and deriving the collection name or just use MongoOperations#findAndReplace.
2 The actual match query mapped against the given domain type. Provide sort, fields and collation settings via the query.
3 Additional optional hook to provide options other than the defaults, like upsert.
4 An optional projection type used for mapping the operation result. If none given the initial domain type is used.
5 Trigger the actual processing. Use findAndReplaceValue to obtain the nullable result instead of an Optional.
Please note that the replacement must not hold an id itself as the id of the existing Document will be carried over to the replacement by the store itself. Also keep in mind that findAndReplace will only replace the first document matching the query criteria depending on a potentially given sort order.
Delete
You can use one of five overloaded methods to remove an object from the database:spring-doc.cadn.net.cn
template.remove(tywin, "GOT");                                              (1)
template.remove(query(where("lastname").is("lannister")), "GOT");           (2)
template.remove(new Query().limit(3), "GOT");                               (3)
template.findAllAndRemove(query(where("lastname").is("lannister"), "GOT");  (4)
template.findAllAndRemove(new Query().limit(3), "GOT");                     (5)
1 Remove a single entity specified by its _id from the associated collection.
2 Remove all documents that match the criteria of the query from the GOT collection.
3 Remove the first three documents in the GOT collection. Unlike <2>, the documents to remove are identified by their _id, running the given query, applying sort, limit, and skip options first, and then removing all at once in a separate step.
4 Remove all documents matching the criteria of the query from the GOT collection. Unlike <3>, documents do not get deleted in a batch but one by one.
5 Remove the first three documents in the GOT collection. Unlike <3>, documents do not get deleted in a batch but one by one.
Optimistic Locking
The @Version annotation provides syntax similar to that of JPA in the context of MongoDB and makes sure updates are only applied to documents with a matching version. Therefore, the actual value of the version property is added to the update query in such a way that the update does not have any effect if another operation altered the document in the meantime. In that case, an OptimisticLockingFailureException is thrown. The following example shows these features:spring-doc.cadn.net.cn
@Document
class Person {
  @Id String id;
  String firstname;
  String lastname;
  @Version Long version;
Person daenerys = template.insert(new Person("Daenerys"));                            (1)
Person tmp = template.findOne(query(where("id").is(daenerys.getId())), Person.class); (2)
daenerys.setLastname("Targaryen");
template.save(daenerys);                                                              (3)
template.save(tmp); // throws OptimisticLockingFailureException                       (4)
1 Intially insert document. version is set to 0.
2 Load the just inserted document. version is still 0.
3 Update the document with version = 0. Set the lastname and bump version to 1.
4 Try to update the previously loaded document that still has version = 0. The operation fails with an OptimisticLockingFailureException, as the current version is 1.
Only certain CRUD operations on MongoTemplate do consider and alter version properties. Please consult MongoOperations java doc for detailed information.spring-doc.cadn.net.cn
Optimistic Locking requires to set the WriteConcern to ACKNOWLEDGED. Otherwise OptimisticLockingFailureException can be silently swallowed.
As of Version 2.2 MongoOperations also includes the @Version property when removing an entity from the database. To remove a Document without version check use MongoOperations#remove(Query,…​) instead of MongoOperations#remove(Object).
As of Version 2.2 repositories check for the outcome of acknowledged deletes when removing versioned entities. An OptimisticLockingFailureException is raised if a versioned entity cannot be deleted through CrudRepository.delete(Object). In such case, the version was changed or the object was deleted in the meantime. Use CrudRepository.deleteById(ID) to bypass optimistic locking functionality and delete objects regardless of their version.
