For the latest stable version, please use Spring Data MongoDB 4.4.5!spring-doc.cn
Property Converters
While type-based conversion already offers ways to influence the conversion and representation of certain types within the target store, it has limitations when only certain values or properties of a particular type should be considered for conversion. Property-based converters allow configuring conversion rules on a per-property basis, either declaratively (via @ValueConverter) or programmatically (by registering a PropertyValueConverter for a specific property).spring-doc.cn
A PropertyValueConverter can transform a given value into its store representation (write) and back (read) as the following listing shows. The additional ValueConversionContext provides additional information, such as mapping metadata and direct read and write methods.spring-doc.cn
Example 1. A simple PropertyValueConverter
class ReversingValueConverter implements PropertyValueConverter<String, String, ValueConversionContext> {
  public String read(String value, ValueConversionContext context) {
    return reverse(value);
  public String write(String value, ValueConversionContext context) {
You can obtain PropertyValueConverter instances from CustomConversions#getPropertyValueConverter(…) by delegating to PropertyValueConversions, typically by using a PropertyValueConverterFactory to provide the actual converter. Depending on your application’s needs, you can chain or decorate multiple instances of PropertyValueConverterFactory — for example, to apply caching. By default, Spring Data MongoDB uses a caching implementation that can serve types with a default constructor or enum values. A set of predefined factories is available through the factory methods in PropertyValueConverterFactory. You can use PropertyValueConverterFactory.beanFactoryAware(…) to obtain a PropertyValueConverter instance from an ApplicationContext.spring-doc.cn
You can change the default behavior through ConverterConfiguration.spring-doc.cn
Declarative Value Converter
The most straight forward usage of a PropertyValueConverter is by annotating properties with the @ValueConverter annotation that defines the converter type:spring-doc.cn
Example 2. Declarative PropertyValueConverter
class Person {
  @ValueConverter(ReversingValueConverter.class)
  String ssn;
Programmatic Value Converter Registration
Programmatic registration registers PropertyValueConverter instances for properties within an entity model by using a PropertyValueConverterRegistrar, as the following example shows. The difference between declarative registration and programmatic registration is that programmatic registration happens entirely outside of the entity model. Such an approach is useful if you cannot or do not want to annotate the entity model.spring-doc.cn
Example 3. Programmatic PropertyValueConverter registration
PropertyValueConverterRegistrar registrar = new PropertyValueConverterRegistrar();
registrar.registerConverter(Address.class, "street", new PropertyValueConverter() { … }); (1)
// type safe registration
registrar.registerConverter(Person.class, Person::getSsn())                               (2)
  .writing(value -> encrypt(value))
  .reading(value -> decrypt(value));
1 Register a converter for the field identified by its name.
2 Type safe variant that allows to register a converter and its conversion functions. This method uses class proxies to determine the property. Make sure that neither the class nor the accessors are final as otherwise this approach doesn’t work.
Dot notation (such as registerConverter(Person.class, "address.street", …)) for nagivating across properties into subdocuments is not supported when registering converters.
MongoValueConverter offers a pre-typed PropertyValueConverter interface that uses MongoConversionContext.
MongoCustomConversions configuration
By default, MongoCustomConversions can handle declarative value converters, depending on the configured PropertyValueConverterFactory. MongoConverterConfigurationAdapter helps to set up programmatic value conversions or define the PropertyValueConverterFactory to be used.spring-doc.cn
Example 4. Configuration Sample
MongoCustomConversions.create(configurationAdapter -> {
    SimplePropertyValueConversions valueConversions = new SimplePropertyValueConversions();
    valueConversions.setConverterFactory(…);
    valueConversions.setValueConverterRegistry(new PropertyValueConverterRegistrar()
        .registerConverter(…)
        .buildRegistry());
    configurationAdapter.setPropertyValueConversions(valueConversions);
