For the latest stable version, please use Spring Data MongoDB 4.4.5!spring-doc.cn
Getting Started
An easy way to bootstrap setting up a working environment is to create a Spring-based project via start.spring.io or create a Spring project in Spring Tools.spring-doc.cn
Examples Repository
The GitHub spring-data-examples repository hosts several examples that you can download and play around with to get a feel for how the library works.spring-doc.cn
Hello World
First, you need to set up a running MongoDB server. Refer to the MongoDB Quick Start guide for an explanation on how to startup a MongoDB instance. Once installed, starting MongoDB is typically a matter of running the following command: /bin/mongodspring-doc.cn
Then you can create a Person class to persist:spring-doc.cn
package org.springframework.data.mongodb.example;
public class Person {
	private String id;
	private String name;
	private int age;
	public Person(String name, int age) {
		this.name = name;
		this.age = age;
	public String getId() {
		return id;
	public String getName() {
		return name;
	public int getAge() {
		return age;
	public String toString() {
		return "Person [id=" + id + ", name=" + name + ", age=" + age + "]";
You also need a main application to run:spring-doc.cn
import static org.springframework.data.mongodb.core.query.Criteria.*;
import org.springframework.data.mongodb.core.MongoOperations;
import org.springframework.data.mongodb.core.MongoTemplate;
import com.mongodb.client.MongoClients;
public class MongoApplication {
	public static void main(String[] args) throws Exception {
		MongoOperations mongoOps = new MongoTemplate(MongoClients.create(), "database");
		mongoOps.insert(new Person("Joe", 34));
		System.out.println(mongoOps.query(Person.class).matching(where("name").is("Joe")).firstValue());
		mongoOps.dropCollection("person");
import org.springframework.data.mongodb.core.ReactiveMongoOperations;
import org.springframework.data.mongodb.core.ReactiveMongoTemplate;
import com.mongodb.reactivestreams.client.MongoClients;
public class ReactiveMongoApplication {
		ReactiveMongoOperations mongoOps = new ReactiveMongoTemplate(MongoClients.create(), "database");
			.then(mongoOps.query(Person.class).matching(where("name").is("Joe")).first())
			.doOnNext(System.out::println)
			.block();
		mongoOps.dropCollection("person").block();
When you run the main program, the preceding examples produce the following output:spring-doc.cn
10:01:32,265 DEBUG o.s.data.mongodb.core.MongoTemplate - insert Document containing fields: [_class, age, name] in collection: Person
10:01:32,765 DEBUG o.s.data.mongodb.core.MongoTemplate - findOne using query: { "name" : "Joe"} in db.collection: database.Person
Person [id=4ddbba3c0be56b7e1b210166, name=Joe, age=34]
10:01:32,984 DEBUG o.s.data.mongodb.core.MongoTemplate - Dropped collection [database.person]
Even in this simple example, there are few things to notice:spring-doc.cn
  • You can instantiate the central helper class of Spring Mongo, MongoTemplate, by using the standard or reactive MongoClient object and the name of the database to use.spring-doc.cn
  • The mapper works against standard POJO objects without the need for any additional metadata (though you can optionally provide that information. See here).spring-doc.cn
  • Conventions are used for handling the id field, converting it to be an ObjectId when stored in the database.spring-doc.cn
  • Mapping conventions can use field access. Notice that the Person class has only getters.spring-doc.cn
  • If the constructor argument names match the field names of the stored document, they are used to instantiate the objectspring-doc.cn
