此版本仍在开发中,尚未被视为稳定版本。对于最新的稳定版本,请使用 Spring Data MongoDB 4.4.4! |
保存、更新和删除文档
MongoTemplate
/ ReactiveMongoTemplatge
允许您保存、更新和删除域对象,并将这些对象映射到存储在 MongoDB 中的文档。
命令式 API 和反应式 API 的 API 签名基本相同,只是返回类型不同。
虽然同步 API 使用void
单Object
和List
反应式对应物包括Mono<Void>
,Mono<Object>
和Flux
请考虑以下类:
public class Person {
private String id;
private String name;
private int age;
public Person(String name, int age) {
this.name = name;
this.age = age;
public String getId() {
return id;
public String getName() {
return name;
public int getAge() {
return age;
public String toString() {
return "Person [id=" + id + ", name=" + name + ", age=" + age + "]";
鉴于Person
类,您可以保存、更新和删除对象,如下例所示:
Imperative
Reactive
public class MongoApplication {
private static final Log log = LogFactory.getLog(MongoApplication.class);
MongoOperations template = new MongoTemplate(new SimpleMongoClientDbFactory(MongoClients.create(), "database"));
Person p = new Person("Joe", 34);
// Insert is used to initially store the object into the database.
template.insert(p);
log.info("Insert: " + p);
// Find
p = template.findById(p.getId(), Person.class);
log.info("Found: " + p);
// Update
template.updateFirst(query(where("name").is("Joe")), update("age", 35), Person.class);
p = template.findOne(query(where("name").is("Joe")), Person.class);
log.info("Updated: " + p);
// Delete
template.remove(p);
// Check that deletion worked
List<Person> people = template.findAll(Person.class);
log.info("Number of people = : " + people.size());
template.dropCollection(Person.class);
前面的示例将生成以下日志输出(包括来自MongoTemplate
DEBUG apping.MongoPersistentEntityIndexCreator: 80 - Analyzing class class org.spring.example.Person for index information.
DEBUG work.data.mongodb.core.MongoTemplate: 632 - insert Document containing fields: [_class, age, name] in collection: person
INFO org.spring.example.MongoApp: 30 - Insert: Person [id=4ddc6e784ce5b1eba3ceaf5c, name=Joe, age=34]
DEBUG work.data.mongodb.core.MongoTemplate:1246 - findOne using query: { "_id" : { "$oid" : "4ddc6e784ce5b1eba3ceaf5c"}} in db.collection: database.person
INFO org.spring.example.MongoApp: 34 - Found: Person [id=4ddc6e784ce5b1eba3ceaf5c, name=Joe, age=34]
DEBUG work.data.mongodb.core.MongoTemplate: 778 - calling update using query: { "name" : "Joe"} and update: { "$set" : { "age" : 35}} in collection: person
DEBUG work.data.mongodb.core.MongoTemplate:1246 - findOne using query: { "name" : "Joe"} in db.collection: database.person
INFO org.spring.example.MongoApp: 39 - Updated: Person [id=4ddc6e784ce5b1eba3ceaf5c, name=Joe, age=35]
DEBUG work.data.mongodb.core.MongoTemplate: 823 - remove using query: { "id" : "4ddc6e784ce5b1eba3ceaf5c"} in collection: person
INFO org.spring.example.MongoApp: 46 - Number of people = : 0
DEBUG work.data.mongodb.core.MongoTemplate: 376 - Dropped collection [database.person]
public class ReactiveMongoApplication {
private static final Logger log = LoggerFactory.getLogger(ReactiveMongoApplication.class);
public static void main(String[] args) throws Exception {
CountDownLatch latch = new CountDownLatch(1);
ReactiveMongoTemplate template = new ReactiveMongoTemplate(MongoClients.create(), "database");
template.insert(new Person("Joe", 34)).doOnNext(person -> log.info("Insert: " + person))
.flatMap(person -> template.findById(person.getId(), Person.class))
.doOnNext(person -> log.info("Found: " + person))
.zipWith(person -> template.updateFirst(query(where("name").is("Joe")), update("age", 35), Person.class))
.flatMap(tuple -> template.remove(tuple.getT1())).flatMap(deleteResult -> template.findAll(Person.class))
.count().doOnSuccess(count -> {
log.info("Number of people: " + count);
latch.countDown();
.subscribe();
latch.await();
MongoConverter
导致String
以及一个ObjectId
通过识别(通过约定)存储在数据库中的Id
property name 属性。
前面的示例旨在演示如何对MongoTemplate
/ ReactiveMongoTemplate
而不是显示复杂的映射功能。
前面示例中使用的查询语法在 “查询文档” 一节中有更详细的说明。
MongoDB 要求您有一个_id 字段。请参阅 ID 处理部分,了解有关此字段的特殊处理的详细信息。 |
MongoDB 集合可以包含表示各种类型实例的文档。有关详细信息,请参阅类型映射。 |
插入 / 保存
有几种方便的方法MongoTemplate
用于保存和插入对象。
要对转换过程进行更精细的控制,可以使用MappingMongoConverter
— 例如Converter<Person, Document>
和Converter<Document, Person>
插入作和保存作之间的区别在于,如果对象尚不存在,则保存作将执行插入。 |
使用 save作的简单情况是保存一个 POJO。 在这种情况下,集合名称由类的名称(非完全限定)确定。 您还可以使用特定的集合名称调用 save作。您可以使用映射元数据覆盖用于存储对象的集合。
插入或保存时,如果Id
属性,则假设其值将由数据库自动生成。
因此,为了自动生成ObjectId
要成功,需要Id
property 或 field 必须是String
一ObjectId
或BigInteger
以下示例显示如何保存文档并检索其内容:
Imperative
Reactive
import static org.springframework.data.mongodb.core.query.Criteria.where;
import static org.springframework.data.mongodb.core.query.Criteria.query;
template.insert(new Person("Bob", 33));
Person person = template.query(Person.class)
.matching(query(where("age").is(33)))
.oneValue();
Mono<Person> person = mongoTemplate.insert(new Person("Bob", 33))
.then(mongoTemplate.query(Person.class)
.one());
The following insert and save operations are available:
void
save (Object objectToSave)
: Save the object to the default collection.
void
save (Object objectToSave, String collectionName)
: Save the object to the specified collection.
A similar set of insert operations is also available:
void
insert (Object objectToSave)
: Insert the object to the default collection.
void
insert (Object objectToSave, String collectionName)
: Insert the object to the specified collection.
How the _id
Field is Handled in the Mapping Layer
MongoDB requires that you have an _id
field for all documents.
If you do not provide one, the driver assigns an ObjectId
with a generated value without considering your domain model as the server isn’t aware of your identifier type.
When you use the MappingMongoConverter
, certain rules govern how properties from the Java class are mapped to this _id
field:
A property or field annotated with @Id
(org.springframework.data.annotation.Id
) maps to the _id
field.
A property or field without an annotation but named id
maps to the _id
field.
The following outlines what type conversion, if any, is done on the property mapped to the _id
document field when using the MappingMongoConverter
(the default for MongoTemplate
If possible, an id
property or field declared as a String
in the Java class is converted to and stored as an ObjectId
by using a Spring Converter<String, ObjectId>
. Valid conversion rules are delegated to the MongoDB Java driver. If it cannot be converted to an ObjectId
, then the value is stored as a string in the database.
An id
property or field declared as BigInteger
by using a Spring Converter<BigInteger, ObjectId>
If no field or property specified in the previous sets of rules is present in the Java class, an implicit _id
file is generated by the driver but not mapped to a property or field of the Java class.
When querying and updating, MongoTemplate
uses the converter that corresponds to the preceding rules for saving documents so that field names and types used in your queries can match what is in your domain classes.
Some environments require a customized approach to map Id
values such as data stored in MongoDB that did not run through the Spring Data mapping layer. Documents can contain _id
values that can be represented either as ObjectId
or as String
Reading documents from the store back to the domain type works just fine. Querying for documents via their id
can be cumbersome due to the implicit ObjectId
conversion. Therefore documents cannot be retrieved that way.
For those cases @MongoId
provides more control over the actual id mapping attempts.
Example 1. @MongoId
mapping
public class PlainStringId {
@MongoId String id; (1)
public class PlainObjectId {
@MongoId ObjectId id; (2)
public class StringToObjectId {
@MongoId(FieldType.OBJECT_ID) String id; (3)
1
The id is treated as String
without further conversion.
2
The id is treated as ObjectId
3
if the given String
is a valid ObjectId
hex, otherwise as String
. Corresponds to @Id
usage.
Into Which Collection Are My Documents Saved?
There are two ways to manage the collection name that is used for the documents.
The default collection name that is used is the class name changed to start with a lower-case letter.
So a com.test.Person
class is stored in the person
collection.
You can customize this by providing a different collection name with the @Document
annotation.
You can also override the collection name by providing your own collection name as the last parameter for the selected MongoTemplate
method calls.
Inserting or Saving Individual Objects
The MongoDB driver supports inserting a collection of documents in a single operation.
The following methods in the MongoOperations
interface support this functionality:
insert: Inserts an object. If there is an existing document with the same id
, an error is generated.
insertAll: Takes a Collection
of objects as the first parameter. This method inspects each object and inserts it into the appropriate collection, based on the rules specified earlier.
save: Saves the object, overwriting any object that might have the same id
Inserting Several Objects in a Batch
The MongoDB driver supports inserting a collection of documents in one operation.
interface support this functionality via insert
or a dedicated BulkOperations
interface.
Batch Insert
Imperative
Reactive
Collection<Person> inserted = template.insert(List.of(...), Person.class);
Flux<Person> inserted = template.insert(List.of(...), Person.class);
Bulk Insert
Imperative
Reactive
BulkWriteResult result = template.bulkOps(BulkMode.ORDERED, Person.class)
.insert(List.of(...))
.execute();
Mono<BulkWriteResult> result = template.bulkOps(BulkMode.ORDERED, Person.class)
.execute();
Server performance of batch and bulk is identical.
However bulk operations do not publish lifecycle events.
Any @Version
property that has not been set prior to calling insert will be auto initialized with 1
(in case of a simple type like int
) or 0
for wrapper types (eg. Integer
Read more in the see Optimistic Locking section.
Update
For updates, you can update the first document found by using MongoOperation.updateFirst
or you can update all documents that were found to match the query by using the MongoOperation.updateMulti
method or all
on the fluent API.
The following example shows an update of all SAVINGS
accounts where we are adding a one-time $50.00 bonus to the balance by using the $inc
operator:
Updating documents by using the MongoTemplate
Imperative
Reactive
import org.springframework.data.mongodb.core.query.Update;
UpdateResult result = template.update(Account.class)
.matching(where("accounts.accountType").is(Type.SAVINGS))
.apply(new Update().inc("accounts.$.balance", 50.00))
.all();
Mono<UpdateResult> result = template.update(Account.class)
.all();
In addition to the Query
discussed earlier, we provide the update definition by using an Update
object.
The Update
class has methods that match the update modifiers available for MongoDB.
Most methods return the Update
object to provide a fluent style for the API.
@Version
properties if not included in the Update
will be automatically incremented.
Methods for Running Updates for Documents
updateFirst: Updates the first document that matches the query document criteria with the updated document.
updateMulti: Updates all objects that match the query document criteria with the updated document.
updateFirst
does not support ordering. Please use findAndModify to apply Sort
Index hints for the update operation can be provided via Query.withHint(…)
Methods in the Update
Class
You can use a little "'syntax sugar'" with the Update
class, as its methods are meant to be chained together.
Also, you can kick-start the creation of a new Update
instance by using public static Update update(String key, Object value)
and using static imports.
The Update
class contains the following methods:
Update
addToSet (String key, Object value)
Update using the $addToSet
update modifier
Update
currentDate (String key)
Update using the $currentDate
update modifier
Update
currentTimestamp (String key)
update modifier with $type
timestamp
Update
inc (String key, Number inc)
Update using the $inc
update modifier
Update
max (String key, Object max)
Update using the $max
update modifier
Update
min (String key, Object min)
Update using the $min
update modifier
Update
multiply (String key, Number multiplier)
Update using the $mul
update modifier
Update
pop (String key, Update.Position pos)
Update using the $pop
update modifier
Update
pull (String key, Object value)
Update using the $pull
update modifier
Update
pullAll (String key, Object[] values)
Update using the $pullAll
update modifier
Update
push (String key, Object value)
Update using the $push
update modifier
Update
pushAll (String key, Object[] values)
Update using the $pushAll
update modifier
Update
rename (String oldName, String newName)
Update using the $rename
update modifier
Update
set (String key, Object value)
Update using the $set
update modifier
Update
setOnInsert (String key, Object value)
Update using the $setOnInsert
update modifier
Update
unset (String key)
Update using the $unset
update modifier
Some update modifiers, such as $push
and $addToSet
, allow nesting of additional operators.
// { $push : { "category" : { "$each" : [ "spring" , "data" ] } } }
new Update().push("category").each("spring", "data")
// { $push : { "key" : { "$position" : 0 , "$each" : [ "Arya" , "Arry" , "Weasel" ] } } }
new Update().push("key").atPosition(Position.FIRST).each(Arrays.asList("Arya", "Arry", "Weasel"));
// { $push : { "key" : { "$slice" : 5 , "$each" : [ "Arya" , "Arry" , "Weasel" ] } } }
new Update().push("key").slice(5).each(Arrays.asList("Arya", "Arry", "Weasel"));
// { $addToSet : { "values" : { "$each" : [ "spring" , "data" , "mongodb" ] } } }
new Update().addToSet("values").each("spring", "data", "mongodb");
Aggregation Pipeline Updates
Update methods exposed by MongoOperations
and ReactiveMongoOperations
also accept an Aggregation Pipeline via AggregationUpdate
Using AggregationUpdate
allows leveraging MongoDB 4.2 aggregations in an update operation.
Using aggregations in an update allows updating one or more fields by expressing multiple stages and multiple conditions with a single operation.
The update can consist of the following stages:
AggregationUpdate.set(…).toValue(…)
→ $set : { … }
AggregationUpdate.unset(…)
→ $unset : [ … ]
AggregationUpdate.replaceWith(…)
→ $replaceWith : { … }
Example 2. Update Aggregation
AggregationUpdate update = Aggregation.newUpdate()
.set("average").toValue(ArithmeticOperators.valueOf("tests").avg()) (1)
.set("grade").toValue(ConditionalOperators.switchCases( (2)
when(valueOf("average").greaterThanEqualToValue(90)).then("A"),
when(valueOf("average").greaterThanEqualToValue(80)).then("B"),
when(valueOf("average").greaterThanEqualToValue(70)).then("C"),
when(valueOf("average").greaterThanEqualToValue(60)).then("D"))
.defaultTo("F")
template.update(Student.class) (3)
.apply(update)
.all(); (4)
db.students.update( (3)
{ $set: { average : { $avg: "$tests" } } }, (1)
{ $set: { grade: { $switch: { (2)
branches: [
{ case: { $gte: [ "$average", 90 ] }, then: "A" },
{ case: { $gte: [ "$average", 80 ] }, then: "B" },
{ case: { $gte: [ "$average", 70 ] }, then: "C" },
{ case: { $gte: [ "$average", 60 ] }, then: "D" }
default: "F"
{ multi: true } (4)
1
The 1st $set
stage calculates a new field average based on the average of the tests field.
2
The 2nd $set
stage calculates a new field grade based on the average field calculated by the first aggregation stage.
3
The pipeline is run on the students collection and uses Student
for the aggregation field mapping.
4
Apply the update to all matching documents in the collection.
Upsert
Related to performing an updateFirst
operation, you can also perform an upsert
operation, which will perform an insert if no document is found that matches the query.
The document that is inserted is a combination of the query document and the update document.
The following example shows how to use the upsert
method:
Imperative
Reactive
UpdateResult result = template.update(Person.class)
.matching(query(where("ssn").is(1111).and("firstName").is("Joe").and("Fraizer").is("Update"))
.apply(update("address", addr))
.upsert();
Mono<UpdateResult> result = template.update(Person.class)
.upsert();
upsert
@Version
will be automatically initialized.
Replacing Documents in a Collection
The various replace
methods available via MongoTemplate
allow to override the first matching Document.
If no match is found a new one can be upserted (as outlined in the previous section) by providing ReplaceOptions
with according configuration.
Replace one
Person tom = template.insert(new Person("Motte", 21)); (1)
Query query = Query.query(Criteria.where("firstName").is(tom.getFirstName())); (2)
tom.setFirstname("Tom"); (3)
template.replace(query, tom, ReplaceOptions.none()); (4)
1
Insert a new document.
2
The query used to identify the single document to replace.
3
Set up the replacement document which must hold either the same _id
as the existing or no _id
at all.
4
Run the replace operation.
.Replace one with upsert
Person tom = new Person("id-123", "Tom", 21) (1)
template.replace(query, tom, ReplaceOptions.replaceOptions().upsert()); (2)
1
The _id
value needs to be present for upsert, otherwise MongoDB will create a new potentially with the domain type incompatible ObjectId
As MongoDB is not aware of your domain type, any @Field(targetType)
hints are not considered and the resulting ObjectId
might be not compatible with your domain model.
2
Use upsert
to insert a new document if no match is found
It is not possible to change the _id
of existing documents with a replace operation.
On upsert
MongoDB uses 2 ways of determining the new id for the entry:
* The _id
is used within the query as in {"_id" : 1234 }
* The _id
is present in the replacement document.
If no _id
is provided in either way, MongoDB will create a new ObjectId
for the document.
This may lead to mapping and data lookup malfunctions if the used domain types id
property has a different type like e.g. Long
Find and Modify
The findAndModify(…)
method on MongoCollection
can update a document and return either the old or newly updated document in a single operation.
MongoTemplate
provides four findAndModify
overloaded methods that take Query
and Update
classes and converts from Document
to your POJOs:
<T> T findAndModify(Query query, Update update, Class<T> entityClass);
<T> T findAndModify(Query query, Update update, Class<T> entityClass, String collectionName);
<T> T findAndModify(Query query, Update update, FindAndModifyOptions options, Class<T> entityClass);
<T> T findAndModify(Query query, Update update, FindAndModifyOptions options, Class<T> entityClass, String collectionName);
The following example inserts a few Person
objects into the container and performs a findAndUpdate
operation:
template.insert(new Person("Tom", 21));
template.insert(new Person("Dick", 22));
template.insert(new Person("Harry", 23));
Query query = new Query(Criteria.where("firstName").is("Harry"));
Update update = new Update().inc("age", 1);
Person oldValue = template.update(Person.class)
.matching(query)
.apply(update)
.findAndModifyValue(); // oldValue.age == 23
Person newValue = template.query(Person.class)
.matching(query)
.findOneValue(); // newValye.age == 24
Person newestValue = template.update(Person.class)
.matching(query)
.apply(update)
.withOptions(FindAndModifyOptions.options().returnNew(true)) // Now return the newly updated document when updating
.findAndModifyValue(); // newestValue.age == 25
The FindAndModifyOptions
method lets you set the options of returnNew
, upsert
, and remove
An example extending from the previous code snippet follows:
Person upserted = template.update(Person.class)
.matching(new Query(Criteria.where("firstName").is("Mary")))
.apply(update)
.withOptions(FindAndModifyOptions.options().upsert(true).returnNew(true))
@Version
Find and Replace
The most straight forward method of replacing an entire Document
is via its id
using the save
method.
However this might not always be feasible.
findAndReplace
offers an alternative that allows to identify the document to replace via a simple query.
Example 3. Find and Replace Documents
Optional<User> result = template.update(Person.class) (1)
.matching(query(where("firstame").is("Tom"))) (2)
.replaceWith(new Person("Dick"))
.withOptions(FindAndReplaceOptions.options().upsert()) (3)
.as(User.class) (4)
.findAndReplace(); (5)
1
Use the fluent update API with the domain type given for mapping the query and deriving the collection name or just use MongoOperations#findAndReplace
2
The actual match query mapped against the given domain type. Provide sort
, fields
and collation
settings via the query.
3
Additional optional hook to provide options other than the defaults, like upsert
4
An optional projection type used for mapping the operation result. If none given the initial domain type is used.
5
Trigger the actual processing. Use findAndReplaceValue
to obtain the nullable result instead of an Optional
Please note that the replacement must not hold an id
itself as the id
of the existing Document
will be
carried over to the replacement by the store itself. Also keep in mind that findAndReplace
will only replace the first
document matching the query criteria depending on a potentially given sort order.
Delete
You can use one of five overloaded methods to remove an object from the database:
template.remove(tywin, "GOT"); (1)
template.remove(query(where("lastname").is("lannister")), "GOT"); (2)
template.remove(new Query().limit(3), "GOT"); (3)
template.findAllAndRemove(query(where("lastname").is("lannister"), "GOT"); (4)
template.findAllAndRemove(new Query().limit(3), "GOT"); (5)
1
Remove a single entity specified by its _id
from the associated collection.
2
Remove all documents that match the criteria of the query from the GOT
collection.
3
Remove the first three documents in the GOT
collection. Unlike <2>, the documents to remove are identified by their _id
, running the given query, applying sort
, limit
, and skip
options first, and then removing all at once in a separate step.
4
Remove all documents matching the criteria of the query from the GOT
collection. Unlike <3>, documents do not get deleted in a batch but one by one.
5
Optimistic Locking
The @Version
annotation provides syntax similar to that of JPA in the context of MongoDB and makes sure updates are only applied to documents with a matching version.
Therefore, the actual value of the version property is added to the update query in such a way that the update does not have any effect if another operation altered the document in the meantime.
In that case, an OptimisticLockingFailureException
is thrown.
The following example shows these features:
@Document
class Person {
@Id String id;
String firstname;
String lastname;
@Version Long version;
Person daenerys = template.insert(new Person("Daenerys")); (1)
Person tmp = template.findOne(query(where("id").is(daenerys.getId())), Person.class); (2)
daenerys.setLastname("Targaryen");
template.save(daenerys); (3)
template.save(tmp); // throws OptimisticLockingFailureException (4)
1
Intially insert document. version
is set to 0
2
Load the just inserted document. version
is still 0
3
Update the document with version = 0
. Set the lastname
and bump version
to 1
4
Try to update the previously loaded document that still has version = 0
. The operation fails with an OptimisticLockingFailureException
, as the current version
is 1
Only certain CRUD operations on MongoTemplate
do consider and alter version properties. Please consult MongoOperations
java doc for detailed information.
Optimistic Locking requires to set the WriteConcern
to ACKNOWLEDGED
. Otherwise OptimisticLockingFailureException
can be silently swallowed.
As of Version 2.2 MongoOperations
also includes the @Version
property when removing an entity from the database.
To remove a Document
without version check use MongoOperations#remove(Query,…)
instead of MongoOperations#remove(Object)
As of Version 2.2 repositories check for the outcome of acknowledged deletes when removing versioned entities.
An OptimisticLockingFailureException
is raised if a versioned entity cannot be deleted through CrudRepository.delete(Object)
. In such case, the version was changed or the object was deleted in the meantime. Use CrudRepository.deleteById(ID)
to bypass optimistic locking functionality and delete objects regardless of their version.
