This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Data JPA 3.4.5!spring-doc.cn
Configuration
As a starting point for using Spring Data Envers, you need a project with Spring Data JPA on the classpath and an additional spring-data-envers dependency:spring-doc.cn
<dependencies>
  <!-- other dependency elements omitted -->
  <dependency>
    <groupId>org.springframework.data</groupId>
    <artifactId>spring-data-envers</artifactId>
    <version>3.5.0-RC1</version>
  </dependency>
</dependencies>
This also brings hibernate-envers into the project as a transient dependency.spring-doc.cn
To enable Spring Data Envers and Spring Data JPA, we need to configure two beans and a special repositoryFactoryBeanClass:spring-doc.cn
@EnableEnversRepositories
@EnableTransactionManagement
public class EnversDemoConfiguration {
	public DataSource dataSource() {
		EmbeddedDatabaseBuilder builder = new EmbeddedDatabaseBuilder();
		return builder.setType(EmbeddedDatabaseType.HSQL).build();
	public LocalContainerEntityManagerFactoryBean entityManagerFactory() {
		HibernateJpaVendorAdapter vendorAdapter = new HibernateJpaVendorAdapter();
		vendorAdapter.setGenerateDdl(true);
		LocalContainerEntityManagerFactoryBean factory = new LocalContainerEntityManagerFactoryBean();
		factory.setJpaVendorAdapter(vendorAdapter);
		factory.setPackagesToScan("example.springdata.jpa.envers");
		factory.setDataSource(dataSource());
		return factory;
	public PlatformTransactionManager transactionManager(EntityManagerFactory entityManagerFactory) {
		JpaTransactionManager txManager = new JpaTransactionManager();
		txManager.setEntityManagerFactory(entityManagerFactory);
		return txManager;
To actually use Spring Data Envers, make one or more repositories into a RevisionRepository by adding it as an extended interface:spring-doc.cn
interface PersonRepository
    extends CrudRepository<Person, Long>,
    RevisionRepository<Person, Long, Long> (1)
1 The first type parameter (Person) denotes the entity type, the second (Long) denotes the type of the id property, and the last one (Long) is the type of the revision number. For Envers in default configuration, the revision number parameter should be Integer or Long.
The entity for that repository must be an entity with Envers auditing enabled (that is, it must have an @Audited annotation):spring-doc.cn
@Entity
@Audited
class Person {
	@Id @GeneratedValue
	Long id;
	String name;
	@Version Long version;
