此版本仍在开发中,尚未被视为稳定版本。对于最新的稳定版本,请使用 Spring Data JPA 3.4.5spring-doc.cadn.net.cn
用法
您现在可以使用RevisionRepository查询实体的修订版本,如下面的测试用例所示:spring-doc.cadn.net.cn
@ExtendWith(SpringExtension.class)
@Import(EnversDemoConfiguration.class) (1)
class EnversIntegrationTests {
	final PersonRepository repository;
	final TransactionTemplate tx;
	EnversIntegrationTests(@Autowired PersonRepository repository, @Autowired PlatformTransactionManager tm) {
		this.repository = repository;
		this.tx = new TransactionTemplate(tm);
	@Test
	void testRepository() {
		Person updated = preparePersonHistory();
		Revisions<Long, Person> revisions = repository.findRevisions(updated.id);
		Iterator<Revision<Long, Person>> revisionIterator = revisions.iterator();
		checkNextRevision(revisionIterator, "John", RevisionType.INSERT);
		checkNextRevision(revisionIterator, "Jonny", RevisionType.UPDATE);
		checkNextRevision(revisionIterator, null, RevisionType.DELETE);
		assertThat(revisionIterator.hasNext()).isFalse();
    * Checks that the next element in the iterator is a Revision entry referencing a Person
    * with the given name after whatever change brought that Revision into existence.
    * <p>
    * As a side effect the Iterator gets advanced by one element.
    * @param revisionIterator the iterator to be tested.
    * @param name the expected name of the Person referenced by the Revision.
    * @param revisionType the type of the revision denoting if it represents an insert, update or delete.
	private void checkNextRevision(Iterator<Revision<Long, Person>> revisionIterator, String name,
			RevisionType revisionType) {
		assertThat(revisionIterator.hasNext()).isTrue();
		Revision<Long, Person> revision = revisionIterator.next();
		assertThat(revision.getEntity().name).isEqualTo(name);
		assertThat(revision.getMetadata().getRevisionType()).isEqualTo(revisionType);
    * Creates a Person with a couple of changes so it has a non-trivial revision history.
    * @return the created Person.
	private Person preparePersonHistory() {
		Person john = new Person();
		john.setName("John");
		// create
		Person saved = tx.execute(__ -> repository.save(john));
		assertThat(saved).isNotNull();
		saved.setName("Jonny");
		// update
		Person updated = tx.execute(__ -> repository.save(saved));
		assertThat(updated).isNotNull();
		// delete
		tx.executeWithoutResult(__ -> repository.delete(updated));
		return updated;
1 这引用了前面介绍的 application context configuration (在 Configuration 部分中)。
