For the latest stable version, please use Spring Data JPA 3.4.4!spring-doc.cn
Locking
To specify the lock mode to be used, you can use the @Lock annotation on query methods, as shown in the following example:spring-doc.cn
Example 1. Defining lock metadata on query methods
  // Plain query method
  @Lock(LockModeType.READ)
  List<User> findByLastname(String lastname);
This method declaration causes the query being triggered to be equipped with a LockModeType of READ. You can also define locking for CRUD methods by redeclaring them in your repository interface and adding the @Lock annotation, as shown in the following example:spring-doc.cn
Example 2. Defining lock metadata on CRUD methods
  // Redeclaration of a CRUD method
  List<User> findAll();
