For the latest stable version, please use Spring Data JPA 3.4.4!spring-doc.cn
Glossary
AOP
Aspect oriented programmingspring-doc.cn
Commons DBCP
Commons DataBase Connection Pools - a library from the Apache foundation that offers pooling implementations of the DataSource interface.spring-doc.cn
CRUD
Create, Read, Update, Delete - Basic persistence operations.spring-doc.cn
DAO
Data Access Object - Pattern to separate persisting logic from the object to be persistedspring-doc.cn
Dependency Injection
Pattern to hand a component’s dependency to the component from outside, freeing the component to lookup the dependent itself. For more information, see en.wikipedia.org/wiki/Dependency_Injection.spring-doc.cn
EclipseLink
Object relational mapper implementing JPA - www.eclipse.org/eclipselink/spring-doc.cn
Hibernate
Object relational mapper implementing JPA - hibernate.org/spring-doc.cn
JPA
Jakarta Persistence APIspring-doc.cn
Spring
Java application framework - spring.io/projects/spring-frameworkspring-doc.cn
