如需最新的稳定版本,请使用 Spring Data Elasticsearch 5.4.5spring-doc.cadn.net.cn
Elasticsearch 客户端
本章说明了受支持的 Elasticsearch 客户端实现的配置和使用。spring-doc.cadn.net.cn
Spring Data Elasticsearch 在连接到单个 Elasticsearch 节点或集群的 Elasticsearch 客户端(由 Elasticsearch 客户端库提供)上运行。 尽管 Elasticsearch 客户端可以直接用于处理集群,但使用 Spring Data Elasticsearch 的应用程序通常使用 Elasticsearch OperationsElasticsearch 存储库的更高级别抽象。spring-doc.cadn.net.cn
命令式 REST 客户端
要使用命令式(非反应式)客户端,必须像这样配置配置 Bean:spring-doc.cadn.net.cn
import org.springframework.data.elasticsearch.client.elc.ElasticsearchConfiguration;
public class MyClientConfig extends ElasticsearchConfiguration {
	public ClientConfiguration clientConfiguration() {
		return ClientConfiguration.builder()           (1)
			.connectedTo("localhost:9200")
1 for a detailed description of the builder methods see Client Configuration
The ElasticsearchConfiguration] class allows further configuration by overriding for example the jsonpMapper() or transportOptions() methods.spring-doc.cadn.net.cn
The following beans can then be injected in other Spring components:spring-doc.cadn.net.cn
import org.springframework.beans.factory.annotation.Autowired;@Autowired
ElasticsearchOperations operations;      (1)
@Autowired
ElasticsearchClient elasticsearchClient; (2)
@Autowired
RestClient restClient;                   (3)
@Autowired
JsonpMapper jsonpMapper;                 (4)
1 an implementation of ElasticsearchOperations
2 the co.elastic.clients.elasticsearch.ElasticsearchClient that is used.
3 the low level RestClient from the Elasticsearch libraries
4 the JsonpMapper user by the Elasticsearch Transport
Basically one should just use the ElasticsearchOperations to interact with the Elasticsearch cluster. When using repositories, this instance is used under the hood as well.spring-doc.cadn.net.cn
Reactive Rest Client
When working with the reactive stack, the configuration must be derived from a different class:spring-doc.cadn.net.cn
import org.springframework.data.elasticsearch.client.elc.ReactiveElasticsearchConfiguration;
public class MyClientConfig extends ReactiveElasticsearchConfiguration {
The ReactiveElasticsearchConfiguration class allows further configuration by overriding for example the jsonpMapper() or transportOptions() methods.spring-doc.cadn.net.cn
@Autowired
ReactiveElasticsearchOperations operations;      (1)
@Autowired
ReactiveElasticsearchClient elasticsearchClient; (2)
@Autowired
@Autowired
the following can be injected:spring-doc.cadn.net.cn
1 an implementation of ReactiveElasticsearchOperations
2 the org.springframework.data.elasticsearch.client.elc.ReactiveElasticsearchClient that is used. This is a reactive implementation based on the Elasticsearch client implementation.
Basically one should just use the ReactiveElasticsearchOperations to interact with the Elasticsearch cluster. When using repositories, this instance is used under the hood as well.spring-doc.cadn.net.cn
Client behaviour can be changed via the ClientConfiguration that allows to set options for SSL, connect and socket timeouts, headers and other parameters.spring-doc.cadn.net.cn
Example 1. Client Configuration
import org.springframework.data.elasticsearch.client.ClientConfiguration;
import org.springframework.data.elasticsearch.support.HttpHeaders;
import static org.springframework.data.elasticsearch.client.elc.ElasticsearchClients.*;
HttpHeaders httpHeaders = new HttpHeaders();
httpHeaders.add("some-header", "on every request")                      (1)
ClientConfiguration clientConfiguration = ClientConfiguration.builder()
  .connectedTo("localhost:9200", "localhost:9291")                      (2)
  .usingSsl()                                                           (3)
  .withProxy("localhost:8888")                                          (4)
  .withPathPrefix("ela")                                                (5)
  .withConnectTimeout(Duration.ofSeconds(5))                            (6)
  .withSocketTimeout(Duration.ofSeconds(3))                             (7)
  .withDefaultHeaders(defaultHeaders)                                   (8)
  .withBasicAuth(username, password)                                    (9)
  .withHeaders(() -> {                                                  (10)
    HttpHeaders headers = new HttpHeaders();
    headers.add("currentTime", LocalDateTime.now().format(DateTimeFormatter.ISO_LOCAL_DATE_TIME));
    return headers;
  .withClientConfigurer(                                                (11)
    ElasticsearchHttpClientConfigurationCallback.from(clientBuilder -> {
      return clientBuilder;
  . // ... other options
1 Define default headers, if they need to be customized
2 Use the builder to provide cluster addresses, set default HttpHeaders or enable SSL.
3 Optionally enable SSL.There exist overloads of this function that can take a SSLContext or as an alternative the fingerprint of the certificate as it is output by Elasticsearch 8 on startup.
4 Optionally set a proxy.
5 Optionally set a path prefix, mostly used when different clusters a behind some reverse proxy.
6 Set the connection timeout.
7 Set the socket timeout.
8 Optionally set headers.
9 Add basic authentication.
10 A Supplier<HttpHeaders> function can be specified which is called every time before a request is sent to Elasticsearch - here, as an example, the current time is written in a header.
11 a function to configure the created client (see Client configuration callbacks), can be added multiple times.
Adding a Header supplier as shown in above example allows to inject headers that may change over the time, like authentication JWT tokens. If this is used in the reactive setup, the supplier function must not block!
The ClientConfiguration class offers the most common parameters to configure the client. In the case this is not enough, the user can add callback functions by using the withClientConfigurer(ClientConfigurationCallback<?>) method.spring-doc.cadn.net.cn
The following callbacks are provided:spring-doc.cadn.net.cn
Configuration of the low level Elasticsearch RestClient:
This callback provides a org.elasticsearch.client.RestClientBuilder that can be used to configure the Elasticsearch RestClient:spring-doc.cadn.net.cn
    .withClientConfigurer(ElasticsearchClients.ElasticsearchRestClientConfigurationCallback.from(restClientBuilder -> {
        // configure the Elasticsearch RestClient
        return restClientBuilder;
Configuration of the HttpAsyncClient used by the low level Elasticsearch RestClient:
This callback provides a org.apache.http.impl.nio.client.HttpAsyncClientBuilder to configure the HttpCLient that is used by the RestClient.spring-doc.cadn.net.cn
    .withClientConfigurer(ElasticsearchClients.ElasticsearchHttpClientConfigurationCallback.from(httpAsyncClientBuilder -> {
        // configure the HttpAsyncClient
        return httpAsyncClientBuilder;
Client Logging
To see what is actually sent to and received from the server Request / Response logging on the transport level needs to be turned on as outlined in the snippet below. This can be enabled in the Elasticsearch client by setting the level of the tracer package to "trace" (see www.elastic.co/guide/en/elasticsearch/client/java-api-client/current/java-rest-low-usage-logging.html)spring-doc.cadn.net.cn
Enable transport layer logging
<logger name="tracer" level="trace"/>
