如需最新的稳定版本,请使用 Spring Data Elasticsearch 5.4.5spring-doc.cadn.net.cn
Elasticsearch 审计
准备实体
为了使审计代码能够确定实体实例是否为新实例,实体必须实现Persistable<ID>接口,定义如下:spring-doc.cadn.net.cn
package org.springframework.data.domain;
import org.springframework.lang.Nullable;
public interface Persistable<ID> {
    @Nullable
    ID getId();
    boolean isNew();
As the existence of an Id is not a sufficient criterion to determine if an enitity is new in Elasticsearch, additional information is necessary. One way is to use the creation-relevant auditing fields for this decision:spring-doc.cadn.net.cn
A Person entity might look as follows - omitting getter and setter methods for brevity:spring-doc.cadn.net.cn
@Document(indexName = "person")
public class Person implements Persistable<Long> {
    @Id private Long id;
    private String lastName;
    private String firstName;
    @CreatedDate
    @Field(type = FieldType.Date, format = DateFormat.basic_date_time)
    private Instant createdDate;
    @CreatedBy
    private String createdBy
    @LastModifiedDate
    private Instant lastModifiedDate;
    @LastModifiedBy
    private String lastModifiedBy;
    public Long getId() {                                                 (1)
        return id;
    public boolean isNew() {
        return id == null || (createdDate == null && createdBy == null);  (2)
1 the getter is the required implementation from the interface
2 an object is new if it either has no id or none of fields containing creation attributes are set.
Activating auditing
After the entities have been set up and providing the AuditorAware - or ReactiveAuditorAware - the Auditing must be activated by setting the @EnableElasticsearchAuditing on a configuration class:spring-doc.cadn.net.cn
@EnableElasticsearchRepositories
class MyConfiguration {
   // configuration code
When using the reactive stack this must be:spring-doc.cadn.net.cn
@EnableReactiveElasticsearchRepositories
@EnableReactiveElasticsearchAuditing
If your code contains more than one AuditorAware bean for different types, you must provide the name of the bean to use as an argument to the auditorAwareRef parameter of the @EnableElasticsearchAuditing annotation.spring-doc.cadn.net.cn
