This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Data Couchbase 5.4.5!spring-doc.cn
ANSI Joins
This chapter describes hows ANSI joins can be used across entities. Since 5.5 version, Couchbase server provides support for ANSI joins for joining documents using fields. Previous versions allowed index & lookup joins, which were supported in SDC only by querying directly through the SDK.spring-doc.cn
Relationships between entities across repositories can be one to one or one to many. By defining such relationships, a synchronized view of associated entities can be fetched.spring-doc.cn
Configuration
Associated entities can be fetched by annotating the entity’s property reference with @N1qlJoin. The prefix lks refers to left-hand side key space (current entity) and rks refers to the right-hand side key space (associated entity). The required element for @N1qlJoin annotation is the on clause, a boolean expression representing the join condition between the left-hand side (lks) and the right-hand side (rks), which can be fields, constant expressions or any complex N1QL expression. There could also be an optional where clause specified on the annotation for the join, similarly using lks to refer the current entity and rks to refer the associated entity.spring-doc.cn
Example 1. Annotation for ANSI Join
@Document
public class Author {
      @Id
      String id;
      String name;
      @N1qlJoin(on = "lks.name=rks.authorName")
      List<Book> books;
      @N1qlJoin(on = "lks.name=rks.name")
      Address address;
Lazy fetching
Associated entities can be lazily fetched upon the first access of the property, this could save on fetching more data than required when loading the entity. To load the associated entities lazily, @N1qlJoin annotation’s element fetchType has to be set to FetchType.LAZY. The default is FetchType.IMMEDIATE.spring-doc.cn
Example 2. Configuration for lazy fetch
@N1qlJoin(on = "lks.name=rks.authorName", fetchType = FetchType.LAZY)
List<Book> books;
ANSI Join Hints
Use Index Hint
index element on the @N1qlJoin can be used to provided the hint for the lks (current entity) index and rightIndex element can be used to provided the rks (associated entity) index.spring-doc.cn
Hash Join Hint
If the join type is going to be hash join, the hash side can be specified for the rks (associated entity). If the associated entity is on the build side, it can be specified as HashSide.BUILD else HashSide.PROBE.spring-doc.cn
Use Keys Hint
keys element on the @N1qlJoin annotation can be used to specify unique document keys to restrict the join key space.spring-doc.cn
