This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Data Couchbase 5.4.5! |
Defining Query Methods
The repository proxy has two ways to derive a store-specific query from the method name:
By deriving the query from the method name directly.
By using a manually defined query.
Available options depend on the actual store. However, there must be a strategy that decides what actual query is created. The next section describes the available options.
Query Lookup Strategies
The following strategies are available for the repository infrastructure to resolve the query.
With XML configuration, you can configure the strategy at the namespace through the query-lookup-strategy
attribute.
For Java configuration, you can use the queryLookupStrategy
attribute of the EnableCouchbaseRepositories
annotation.
Some strategies may not be supported for particular datastores.
CREATE
attempts to construct a store-specific query from the query method name. The general approach is to remove a given set of well known prefixes from the method name and parse the rest of the method. You can read more about query construction in “Query Creation”. -
USE_DECLARED_QUERY
tries to find a declared query and throws an exception if it cannot find one. The query can be defined by an annotation somewhere or declared by other means. See the documentation of the specific store to find available options for that store. If the repository infrastructure does not find a declared query for the method at bootstrap time, it fails. -
CREATE_IF_NOT_FOUND
(the default) combinesCREATE
andUSE_DECLARED_QUERY
. It looks up a declared query first, and, if no declared query is found, it creates a custom method name-based query. This is the default lookup strategy and, thus, is used if you do not configure anything explicitly. It allows quick query definition by method names but also custom-tuning of these queries by introducing declared queries as needed.
Query Creation
The query builder mechanism built into the Spring Data repository infrastructure is useful for building constraining queries over entities of the repository.
The following example shows how to create a number of queries:
interface PersonRepository extends Repository<Person, Long> {
List<Person> findByEmailAddressAndLastname(EmailAddress emailAddress, String lastname);
// Enables the distinct flag for the query
List<Person> findDistinctPeopleByLastnameOrFirstname(String lastname, String firstname);
List<Person> findPeopleDistinctByLastnameOrFirstname(String lastname, String firstname);
// Enabling ignoring case for an individual property
List<Person> findByLastnameIgnoreCase(String lastname);
// Enabling ignoring case for all suitable properties
List<Person> findByLastnameAndFirstnameAllIgnoreCase(String lastname, String firstname);
// Enabling static ORDER BY for a query
List<Person> findByLastnameOrderByFirstnameAsc(String lastname);
List<Person> findByLastnameOrderByFirstnameDesc(String lastname);
Parsing query method names is divided into subject and predicate.
The first part (find…By
, exists…By
) defines the subject of the query, the second part forms the predicate.
The introducing clause (subject) can contain further expressions.
Any text between find
(or other introducing keywords) and By
is considered to be descriptive unless using one of the result-limiting keywords such as a Distinct
to set a distinct flag on the query to be created or Top
/First
to limit query results.
The appendix contains the full list of query method subject keywords and query method predicate keywords including sorting and letter-casing modifiers.
However, the first By
acts as a delimiter to indicate the start of the actual criteria predicate.
At a very basic level, you can define conditions on entity properties and concatenate them with And
and Or
The actual result of parsing the method depends on the persistence store for which you create the query. However, there are some general things to notice:
The expressions are usually property traversals combined with operators that can be concatenated. You can combine property expressions with
AND
andOR
. You also get support for operators such asBetween
,LessThan
,GreaterThan
, andLike
for the property expressions. The supported operators can vary by datastore, so consult the appropriate part of your reference documentation. -
The method parser supports setting an
IgnoreCase
flag for individual properties (for example,findByLastnameIgnoreCase(…)
) or for all properties of a type that supports ignoring case (usuallyString
instances — for example,findByLastnameAndFirstnameAllIgnoreCase(…)
). Whether ignoring cases is supported may vary by store, so consult the relevant sections in the reference documentation for the store-specific query method. -
You can apply static ordering by appending an
OrderBy
clause to the query method that references a property and by providing a sorting direction (Asc
orDesc
). To create a query method that supports dynamic sorting, see “Paging, Iterating Large Results, Sorting & Limiting”.
Reserved Method Names
While derived repository methods bind to properties by name, there are a few exceptions to this rule when it comes to certain method names inherited from the base repository targeting the identifier property.
Those reserved methods like CrudRepository#findById
(or just findById
) are targeting the identifier property regardless of the actual property name used in the declared method.
Consider the following domain type holding a property pk
marked as the identifier via @Id
and a property called id
In this case you need to pay close attention to the naming of your lookup methods as they may collide with predefined signatures:
class User {
@Id Long pk; (1)
Long id; (2)
Optional<User> findById(Long id); (3)
Optional<User> findByPk(Long pk); (4)
Optional<User> findUserById(Long id); (5)
1 | The identifier property (primary key). |
2 | A property named id , but not the identifier. |
3 | Targets the pk property (the one marked with @Id which is considered to be the identifier) as it refers to a CrudRepository base repository method.
Therefore, it is not a derived query using of id as the property name would suggest because it is one of the reserved methods. |
4 | Targets the pk property by name as it is a derived query. |
5 | Targets the id property by using the descriptive token between find and by to avoid collisions with reserved methods. |
This special behaviour not only targets lookup methods but also applies to the exits
and delete
ones.
Please refer to the “Repository query keywords” for the list of methods.
Property Expressions
Property expressions can refer only to a direct property of the managed entity, as shown in the preceding example. At query creation time, you already make sure that the parsed property is a property of the managed domain class. However, you can also define constraints by traversing nested properties. Consider the following method signature:
List<Person> findByAddressZipCode(ZipCode zipCode);
Assume a Person
has an Address
with a ZipCode
In that case, the method creates the x.address.zipCode
property traversal.
The resolution algorithm starts by interpreting the entire part (AddressZipCode
) as the property and checks the domain class for a property with that name (uncapitalized).
If the algorithm succeeds, it uses that property.
If not, the algorithm splits up the source at the camel-case parts from the right side into a head and a tail and tries to find the corresponding property — in our example, AddressZip
and Code
If the algorithm finds a property with that head, it takes the tail and continues building the tree down from there, splitting the tail up in the way just described.
If the first split does not match, the algorithm moves the split point to the left (Address
, ZipCode
) and continues.
Although this should work for most cases, it is possible for the algorithm to select the wrong property.
Suppose the Person
class has an addressZip
property as well.
The algorithm would match in the first split round already, choose the wrong property, and fail (as the type of addressZip
probably has no code
property).
To resolve this ambiguity you can use _
inside your method name to manually define traversal points.
So our method name would be as follows:
List<Person> findByAddress_ZipCode(ZipCode zipCode);
Because we treat underscores ( |
Field Names starting with underscore:
Field names may start with underscores like Upper Case Field Names:
Field names that are all uppercase can be used as such.
Nested paths if applicable require splitting via Field Names with 2nd uppercase letter:
Field names that consist of a starting lower case letter followed by an uppercase one like Path Ambiguities:
In the following sample the arrangement of properties
Since a direct match on a property is considered first, any potential nested paths will not be considered and the algorithm picks the |
Repository Methods Returning Collections or Iterables
Query methods that return multiple results can use standard Java Iterable
, List
, and Set
Beyond that, we support returning Spring Data’s Streamable
, a custom extension of Iterable
, as well as collection types provided by Vavr.
Refer to the appendix explaining all possible query method return types.
Using Streamable as Query Method Return Type
You can use Streamable
as alternative to Iterable
or any collection type.
It provides convenience methods to access a non-parallel Stream
(missing from Iterable
) and the ability to directly ….filter(…)
and ….map(…)
over the elements and concatenate the Streamable
to others:
Streamable<Person> findByFirstnameContaining(String firstname);
Streamable<Person> findByLastnameContaining(String lastname);
Streamable<Person> result = repository.findByFirstnameContaining("av")
.and(repository.findByLastnameContaining("ea"));
Returning Custom Streamable Wrapper Types
Providing dedicated wrapper types for collections is a commonly used pattern to provide an API for a query result that returns multiple elements. Usually, these types are used by invoking a repository method returning a collection-like type and creating an instance of the wrapper type manually. You can avoid that additional step as Spring Data lets you use these wrapper types as query method return types if they meet the following criteria:
The type implements
Streamable
The type exposes either a constructor or a static factory method named
of(…)
orvalueOf(…)
that takesStreamable
as an argument.
The following listing shows an example:
class Product { (1)
MonetaryAmount getPrice() { … }
@RequiredArgsConstructor(staticName = "of")
class Products implements Streamable<Product> { (2)
private final Streamable<Product> streamable;
public MonetaryAmount getTotal() { (3)
return streamable.stream()
.map(Product::getPrice)
.reduce(Money.of(0), MonetaryAmount::add);
public Iterator<Product> iterator() { (4)
return streamable.iterator();
interface ProductRepository implements Repository<Product, Long> {
Products findAllByDescriptionContaining(String text); (5)
1 | A Product entity that exposes API to access the product’s price. |
2 | A wrapper type for a Streamable<Product> that can be constructed by using Products.of(…) (factory method created with the Lombok annotation).
A standard constructor taking the Streamable<Product> will do as well. |
3 | The wrapper type exposes an additional API, calculating new values on the Streamable<Product> . |
4 | Implement the Streamable interface and delegate to the actual result. |
5 | That wrapper type Products can be used directly as a query method return type.
You do not need to return Streamable<Product> and manually wrap it after the query in the repository client. |
Support for Vavr Collections
Vavr is a library that embraces functional programming concepts in Java. It ships with a custom set of collection types that you can use as query method return types, as the following table shows:
Vavr collection type | Used Vavr implementation type | Valid Java source types |
You can use the types in the first column (or subtypes thereof) as query method return types and get the types in the second column used as implementation type, depending on the Java type of the actual query result (third column).
Alternatively, you can declare Traversable
(the Vavr Iterable
equivalent), and we then derive the implementation class from the actual return value.
That is, a java.util.List
is turned into a Vavr List
or Seq
, a java.util.Set
becomes a Vavr LinkedHashSet
Set
, and so on.
Streaming Query Results
You can process the results of query methods incrementally by using a Java 8 Stream<T>
as the return type.
Instead of wrapping the query results in a Stream
, data store-specific methods are used to perform the streaming, as shown in the following example:
Stream<T>
@Query("select u from User u")
Stream<User> findAllByCustomQueryAndStream();
Stream<User> readAllByFirstnameNotNull();
Stream<User> streamAllPaged(Pageable pageable);
A Stream potentially wraps underlying data store-specific resources and must, therefore, be closed after usage.
You can either manually close the Stream by using the close() method or by using a Java 7 try-with-resources block, as shown in the following example:
Stream<T>
result in a try-with-resources
blocktry (Stream<User> stream = repository.findAllByCustomQueryAndStream()) {
stream.forEach(…);
Not all Spring Data modules currently support Stream<T> as a return type.
Asynchronous Query Results
You can run repository queries asynchronously by using Spring’s asynchronous method running capability.
This means the method returns immediately upon invocation while the actual query occurs in a task that has been submitted to a Spring TaskExecutor
Asynchronous queries differ from reactive queries and should not be mixed.
See the store-specific documentation for more details on reactive support.
The following example shows a number of asynchronous queries:
@Async
Future<User> findByFirstname(String firstname); (1)
@Async
CompletableFuture<User> findOneByFirstname(String firstname); (2)
1 | Use java.util.concurrent.Future as the return type. |
2 | Use a Java 8 java.util.concurrent.CompletableFuture as the return type. |
To handle parameters in your query, define method parameters as already seen in the preceding examples.
Besides that, the infrastructure recognizes certain specific types like Pageable
, Sort
and Limit
, to apply pagination, sorting and limiting to your queries dynamically.
The following example demonstrates these features:
Pageable
, Slice
, Sort
and Limit
in query methodsPage<User> findByLastname(String lastname, Pageable pageable);
Slice<User> findByLastname(String lastname, Pageable pageable);
List<User> findByLastname(String lastname, Sort sort);
List<User> findByLastname(String lastname, Sort sort, Limit limit);
List<User> findByLastname(String lastname, Pageable pageable);
APIs taking Sort , Pageable and Limit expect non-null values to be handed into methods.
If you do not want to apply any sorting or pagination, use Sort.unsorted() , Pageable.unpaged() and Limit.unlimited() .
The first method lets you pass an org.springframework.data.domain.Pageable
instance to the query method to dynamically add paging to your statically defined query.
A Page
knows about the total number of elements and pages available.
It does so by the infrastructure triggering a count query to calculate the overall number.
As this might be expensive (depending on the store used), you can instead return a Slice
A Slice
knows only about whether a next Slice
is available, which might be sufficient when walking through a larger result set.
Sorting options are handled through the Pageable
instance, too.
If you need only sorting, add an org.springframework.data.domain.Sort
parameter to your method.
As you can see, returning a List
is also possible.
In this case, the additional metadata required to build the actual Page
instance is not created (which, in turn, means that the additional count query that would have been necessary is not issued).
Rather, it restricts the query to look up only the given range of entities.
To find out how many pages you get for an entire query, you have to trigger an additional count query. By default, this query is derived from the query you actually trigger. |
Special parameters may only be used once within a query method.
The |
Which Method is Appropriate?
The value provided by the Spring Data abstractions is perhaps best shown by the possible query method return types outlined in the following table below. The table shows which types you can return from a query method
Method | Amount of Data Fetched | Query Structure | Constraints |
All results. |
Single query. |
Query results can exhaust all memory. Fetching all data can be time-intensive. |
All results. |
Single query. |
Chunked (one-by-one or in batches) depending on |
Single query using typically cursors. |
Streams must be closed after usage to avoid resource leaks. |
Store module must provide reactive infrastructure. |
One to many queries fetching data starting at |
A
One to many queries starting at |
Often times,
Paging and Sorting
You can define simple sorting expressions by using property names. You can concatenate expressions to collect multiple criteria into one expression.
Sort sort = Sort.by("firstname").ascending()
.and(Sort.by("lastname").descending());
For a more type-safe way to define sort expressions, start with the type for which to define the sort expression and use method references to define the properties on which to sort.
TypedSort<Person> person = Sort.sort(Person.class);
Sort sort = person.by(Person::getFirstname).ascending()
.and(person.by(Person::getLastname).descending());
TypedSort.by(…) makes use of runtime proxies by (typically) using CGlib, which may interfere with native image compilation when using tools such as Graal VM Native.
If your store implementation supports Querydsl, you can also use the generated metamodel types to define sort expressions:
QSort sort = QSort.by(QPerson.firstname.asc())
.and(QSort.by(QPerson.lastname.desc()));
Limiting Query Results
In addition to paging it is possible to limit the result size using a dedicated Limit
parameter.
You can also limit the results of query methods by using the First
or Top
keywords, which you can use interchangeably but may not be mixed with a Limit
parameter.
You can append an optional numeric value to Top
or First
to specify the maximum result size to be returned.
If the number is left out, a result size of 1 is assumed.
The following example shows how to limit the query size:
Top
and First
List<User> findByLastname(Limit limit);
User findFirstByOrderByLastnameAsc();
User findTopByLastnameOrderByAgeDesc(String lastname);
Page<User> queryFirst10ByLastname(String lastname, Pageable pageable);
Slice<User> findTop3By(Pageable pageable);
List<User> findFirst10ByLastname(String lastname, Sort sort);
List<User> findTop10ByLastname(String lastname, Pageable pageable);
The limiting expressions also support the Distinct
keyword for datastores that support distinct queries.
Also, for the queries that limit the result set to one instance, wrapping the result into with the Optional
keyword is supported.
If pagination or slicing is applied to a limiting query pagination (and the calculation of the number of available pages), it is applied within the limited result.
Limiting the results in combination with dynamic sorting by using a Sort parameter lets you express query methods for the 'K' smallest as well as for the 'K' biggest elements.
