This version is still in development and is not considered stable yet. For the latest stable version, please use Spring Data Couchbase 5.4.5!spring-doc.cn
Projections
Spring Data query methods usually return one or multiple instances of the aggregate root managed by the repository. However, it might sometimes be desirable to create projections based on certain attributes of those types. Spring Data allows modeling dedicated return types, to more selectively retrieve partial views of the managed aggregates.spring-doc.cn
Imagine a repository and aggregate root type such as the following example:spring-doc.cn
A sample aggregate and repository
class Person {
  @Id UUID id;
  String firstname, lastname;
  Address address;
  static class Address {
    String zipCode, city, street;
interface PersonRepository extends Repository<Person, UUID> {
  Collection<Person> findByLastname(String lastname);
Now imagine that we want to retrieve the person’s name attributes only. What means does Spring Data offer to achieve this? The rest of this chapter answers that question.spring-doc.cn
Projection types are types residing outside the entity’s type hierarchy. Superclasses and interfaces implemented by the entity are inside the type hierarchy hence returning a supertype (or implemented interface) returns an instance of the fully materialized entity.
Interface-based Projections
The easiest way to limit the result of the queries to only the name attributes is by declaring an interface that exposes accessor methods for the properties to be read, as shown in the following example:spring-doc.cn
A projection interface to retrieve a subset of attributes
interface NamesOnly {
  String getFirstname();
  String getLastname();
The important bit here is that the properties defined here exactly match properties in the aggregate root. Doing so lets a query method be added as follows:spring-doc.cn
A repository using an interface based projection with a query method
  Collection<NamesOnly> findByLastname(String lastname);
The query execution engine creates proxy instances of that interface at runtime for each element returned and forwards calls to the exposed methods to the target object.spring-doc.cn
Declaring a method in your Repository that overrides a base method (e.g. declared in CrudRepository, a store-specific repository interface, or the Simple…Repository) results in a call to the base method regardless of the declared return type. Make sure to use a compatible return type as base methods cannot be used for projections. Some store modules support @Query annotations to turn an overridden base method into a query method that then can be used to return projections.
Projections can be used recursively. If you want to include some of the Address information as well, create a projection interface for that and return that interface from the declaration of getAddress(), as shown in the following example:spring-doc.cn
interface PersonSummary {
  AddressSummary getAddress();
  interface AddressSummary {
    String getCity();
On method invocation, the address property of the target instance is obtained and wrapped into a projecting proxy in turn.spring-doc.cn
Closed Projections
A projection interface whose accessor methods all match properties of the target aggregate is considered to be a closed projection. The following example (which we used earlier in this chapter, too) is a closed projection:spring-doc.cn
A closed projection
If you use a closed projection, Spring Data can optimize the query execution, because we know about all the attributes that are needed to back the projection proxy. For more details on that, see the module-specific part of the reference documentation.spring-doc.cn
Open Projections
Accessor methods in projection interfaces can also be used to compute new values by using the @Value annotation, as shown in the following example:spring-doc.cn
An Open Projection
  @Value("#{target.firstname + ' ' + target.lastname}")
  String getFullName();
The aggregate root backing the projection is available in the target variable. A projection interface using @Value is an open projection. Spring Data cannot apply query execution optimizations in this case, because the SpEL expression could use any attribute of the aggregate root.spring-doc.cn
The expressions used in @Value should not be too complex — you want to avoid programming in String variables. For very simple expressions, one option might be to resort to default methods (introduced in Java 8), as shown in the following example:spring-doc.cn
A projection interface using a default method for custom logic
  default String getFullName() {
    return getFirstname().concat(" ").concat(getLastname());
This approach requires you to be able to implement logic purely based on the other accessor methods exposed on the projection interface. A second, more flexible, option is to implement the custom logic in a Spring bean and then invoke that from the SpEL expression, as shown in the following example:spring-doc.cn
Sample Person object
@Component
class MyBean {
  String getFullName(Person person) {
  @Value("#{@myBean.getFullName(target)}")
Notice how the SpEL expression refers to myBean and invokes the getFullName(…) method and forwards the projection target as a method parameter. Methods backed by SpEL expression evaluation can also use method parameters, which can then be referred to from the expression. The method parameters are available through an Object array named args. The following example shows how to get a method parameter from the args array:spring-doc.cn
  @Value("#{args[0] + ' ' + target.firstname + '!'}")
  String getSalutation(String prefix);
Again, for more complex expressions, you should use a Spring bean and let the expression invoke a method, as described earlier.spring-doc.cn
Nullable Wrappers
Getters in projection interfaces can make use of nullable wrappers for improved null-safety. Currently supported wrapper types are:spring-doc.cn
A projection interface using nullable wrappers
  Optional<String> getFirstname();
If the underlying projection value is not null, then values are returned using the present-representation of the wrapper type. In case the backing value is null, then the getter method returns the empty representation of the used wrapper type.spring-doc.cn
Class-based Projections (DTOs)
Another way of defining projections is by using value type DTOs (Data Transfer Objects) that hold properties for the fields that are supposed to be retrieved. These DTO types can be used in exactly the same way projection interfaces are used, except that no proxying happens and no nested projections can be applied.spring-doc.cn
If the store optimizes the query execution by limiting the fields to be loaded, the fields to be loaded are determined from the parameter names of the constructor that is exposed.spring-doc.cn
The following example shows a projecting DTO:spring-doc.cn
A projecting DTO
record NamesOnly(String firstname, String lastname) {
Java Records are ideal to define DTO types since they adhere to value semantics: All fields are private final and equals(…)/hashCode()/toString() methods are created automatically. Alternatively, you can use any class that defines the properties you want to project.spring-doc.cn
Dynamic Projections
So far, we have used the projection type as the return type or element type of a collection. However, you might want to select the type to be used at invocation time (which makes it dynamic). To apply dynamic projections, use a query method such as the one shown in the following example:spring-doc.cn
A repository using a dynamic projection parameter
  <T> Collection<T> findByLastname(String lastname, Class<T> type);
This way, the method can be used to obtain the aggregates as is or with a projection applied, as shown in the following example:spring-doc.cn
Using a repository with dynamic projections
void someMethod(PersonRepository people) {
  Collection<Person> aggregates =
    people.findByLastname("Matthews", Person.class);
  Collection<NamesOnly> aggregates =
    people.findByLastname("Matthews", NamesOnly.class);
Query parameters of type Class are inspected whether they qualify as dynamic projection parameter. If the actual return type of the query equals the generic parameter type of the Class parameter, then the matching Class parameter is not available for usage within the query or SpEL expressions. If you want to use a Class parameter as query argument then make sure to use a different generic parameter, for example Class<?>.
When using Class-based projection, types must declare a single constructor so that Spring Data can determine their input properties. If your class defines more than one constructor, then you cannot use the type without further hints for DTO projections. In such a case annotate the desired constructor with @PersistenceCreator as outlined below so that Spring Data can determine which properties to select:spring-doc.cn
public class NamesOnly {
  private final String firstname;
  private final String lastname;
  protected NamesOnly() { }
  @PersistenceCreator
  public NamesOnly(String firstname, String lastname) {
      this.firstname = firstname;
      this.lastname = lastname;
