For the latest stable version, please use Spring Data Cassandra 4.4.0!spring-doc.cn
Schema Management
Apache Cassandra is a data store that requires a schema definition prior to any data interaction. Spring Data for Apache Cassandra can support you with schema creation.spring-doc.cn
Keyspaces and Lifecycle Scripts
The first thing to start with is a Cassandra keyspace. A keyspace is a logical grouping of tables that share the same replication factor and replication strategy. Keyspace management is located in the CqlSession configuration, which has the KeyspaceSpecification and startup and shutdown CQL script execution.spring-doc.cn
Declaring a keyspace with a specification allows creating and dropping of the Keyspace. It derives CQL from the specification so that you need not write CQL yourself. The following example specifies a Cassandra keyspace by using XML:spring-doc.cn
Example 1. Specifying a Cassandra keyspace
Java
public class CreateKeyspaceConfiguration extends AbstractCassandraConfiguration implements BeanClassLoaderAware {
	protected List<CreateKeyspaceSpecification> getKeyspaceCreations() {
		CreateKeyspaceSpecification specification = CreateKeyspaceSpecification.createKeyspace("my_keyspace")
				.with(KeyspaceOption.DURABLE_WRITES, true)
				.withNetworkReplication(DataCenterReplication.of("foo", 1), DataCenterReplication.of("bar", 2));
		return Arrays.asList(specification);
	protected List<DropKeyspaceSpecification> getKeyspaceDrops() {
		return Arrays.asList(DropKeyspaceSpecification.dropKeyspace("my_keyspace"));
XML
  xmlns:cassandra="http://www.springframework.org/schema/data/cassandra"
  xsi:schemaLocation="
    https://www.springframework.org/schema/data/cassandra/spring-cassandra.xsd
    https://www.springframework.org/schema/beans/spring-beans.xsd">
    <cassandra:session>
        <cassandra:keyspace action="CREATE_DROP" durable-writes="true" name="my_keyspace">
            <cassandra:replication class="NETWORK_TOPOLOGY_STRATEGY">
              <cassandra:data-center name="foo" replication-factor="1" />
              <cassandra:data-center name="bar" replication-factor="2" />
            </cassandra:replication>
      </cassandra:keyspace>
    </cassandra:session>
</beans>
Keyspace creation allows rapid bootstrapping without the need of external keyspace management. This can be useful for certain scenarios but should be used with care. Dropping a keyspace on application shutdown removes the keyspace and all data from the tables in the keyspace.
Initializing a SessionFactory
The org.springframework.data.cassandra.core.cql.session.init package provides support for initializing an existing SessionFactory. You may sometimes need to initialize a keyspace that runs on a server somewhere.spring-doc.cn
Initializing a Keyspace
You can provide arbitrary CQL that is executed on CqlSession initialization and shutdown in the configured keyspace, as the following Java configuration example shows:spring-doc.cn
Java
public class KeyspacePopulatorConfiguration extends AbstractCassandraConfiguration {
	@Nullable
	protected KeyspacePopulator keyspacePopulator() {
		return new ResourceKeyspacePopulator(new ClassPathResource("com/foo/cql/db-schema.cql"),
				new ClassPathResource("com/foo/cql/db-test-data.cql"));
	@Nullable
	protected KeyspacePopulator keyspaceCleaner() {
		return new ResourceKeyspacePopulator(scriptOf("DROP TABLE my_table;"));
XML
<cassandra:initialize-keyspace session-factory-ref="cassandraSessionFactory">
    <cassandra:script location="classpath:com/foo/cql/db-schema.cql"/>
    <cassandra:script location="classpath:com/foo/cql/db-test-data.cql"/>
</cassandra:initialize-keyspace>
The preceding example runs the two specified scripts against the keyspace. The first script creates a schema, and the second populates tables with a test data set. The script locations can also be patterns with wildcards in the usual Ant style used for resources in Spring (for example, classpath*:/com/foo/**/cql/*-data.cql). If you use a pattern, the scripts are run in the lexical order of their URL or filename.spring-doc.cn
The default behavior of the keyspace initializer is to unconditionally run the provided scripts. This may not always be what you want — for instance, if you run the scripts against a keyspace that already has test data in it. The likelihood of accidentally deleting data is reduced by following the common pattern (shown earlier) of creating the tables first and then inserting the data. The first step fails if the tables already exist.spring-doc.cn
However, to gain more control over the creation and deletion of existing data, the XML namespace provides a few additional options. The first is a flag to switch the initialization on and off. You can set this according to the environment (such as pulling a boolean value from system properties or from an environment bean). The following example gets a value from a system property:spring-doc.cn
    enabled="#{systemProperties.INITIALIZE_KEYSPACE}">    (1)
    <cassandra:script location="..."/>
</cassandra:initialize-database>
1 Get the value for enabled from a system property called INITIALIZE_KEYSPACE.
The second option to control what happens with existing data is to be more tolerant of failures. To this end, you can control the ability of the initializer to ignore certain errors in the CQL it executes from the scripts, as the following example shows:spring-doc.cn
Java
public class KeyspacePopulatorFailureConfiguration extends AbstractCassandraConfiguration {
	@Nullable
		ResourceKeyspacePopulator populator = new ResourceKeyspacePopulator(
				new ClassPathResource("com/foo/cql/db-schema.cql"));
		populator.setIgnoreFailedDrops(true);
		return populator;
XML
<cassandra:initialize-keyspace session-factory-ref="cassandraSessionFactory" ignore-failures="DROPS">
In the preceding example, we are saying that we expect that, sometimes, the scripts are run against an empty keyspace, and there are some DROP statements in the scripts that would, therefore, fail. So failed CQL DROP statements will be ignored, but other failures will cause an exception. This is useful if you don’t want tu use support DROP …​ IF EXISTS (or similar) but you want to unconditionally remove all test data before re-creating it. In that case the first script is usually a set of DROP statements, followed by a set of CREATE statements.spring-doc.cn
The ignore-failures option can be set to NONE (the default), DROPS (ignore failed drops), or ALL (ignore all failures).spring-doc.cn
Each statement should be separated by ; or a new line if the ; character is not present at all in the script. You can control that globally or script by script, as the following example shows:spring-doc.cn
Java
public class SessionFactoryInitializerConfiguration extends AbstractCassandraConfiguration {
	SessionFactoryInitializer sessionFactoryInitializer(SessionFactory sessionFactory) {
		SessionFactoryInitializer initializer = new SessionFactoryInitializer();
		initializer.setSessionFactory(sessionFactory);
		ResourceKeyspacePopulator populator1 = new ResourceKeyspacePopulator();
		populator1.setSeparator(";");
		populator1.setScripts(new ClassPathResource("com/myapp/cql/db-schema.cql"));
		ResourceKeyspacePopulator populator2 = new ResourceKeyspacePopulator();
		populator2.setSeparator("@@");
		populator2.setScripts(new ClassPathResource("classpath:com/myapp/cql/db-test-data-1.cql"), //
				new ClassPathResource("classpath:com/myapp/cql/db-test-data-2.cql"));
		initializer.setKeyspacePopulator(new CompositeKeyspacePopulator(populator1, populator2));
		return initializer;
XML
<cassandra:initialize-keyspace session-factory-ref="cassandraSessionFactory" separator="@@">
    <cassandra:script location="classpath:com/myapp/cql/db-schema.cql" separator=";"/>
    <cassandra:script location="classpath:com/myapp/cql/db-test-data-1.cql"/>
    <cassandra:script location="classpath:com/myapp/cql/db-test-data-2.cql"/>
In this example, the two test-data scripts use @@ as statement separator and only the db-schema.cql uses ;. This configuration specifies that the default separator is @@ and overrides that default for the db-schema script.spring-doc.cn
If you need more control than you get from the XML namespace, you can use the SessionFactoryInitializer directly and define it as a component in your application.spring-doc.cn
Initialization of Other Components that Depend on the Keyspace
A large class of applications (those that do not use the database until after the Spring context has started) can use the database initializer with no further complications. If your application is not one of those, you might need to read the rest of this section.spring-doc.cn
The database initializer depends on a SessionFactory instance and runs the scripts provided in its initialization callback (analogous to an init-method in an XML bean definition, a @PostConstruct method in a component, or the afterPropertiesSet() method in a component that implements InitializingBean). If other beans depend on the same data source and use the session factory in an initialization callback, there might be a problem because the data has not yet been initialized. A common example of this is a cache that initializes eagerly and loads data from the database on application startup.spring-doc.cn
To get around this issue, you have two options: change your cache initialization strategy to a later phase or ensure that the keyspace initializer is initialized first.spring-doc.cn
Changing your cache initialization strategy might be easy if the application is in your control and not otherwise. Some suggestions for how to implement this include:spring-doc.cn
  • Make the cache initialize lazily on first usage, which improves application startup time.spring-doc.cn
  • Have your cache or a separate component that initializes the cache implement Lifecycle or SmartLifecycle. When the application context starts, you can automatically start a SmartLifecycle by setting its autoStartup flag, and you can manually start a Lifecycle by calling ConfigurableApplicationContext.start() on the enclosing context.spring-doc.cn
  • Use a Spring ApplicationEvent or similar custom observer mechanism to trigger the cache initialization. ContextRefreshedEvent is always published by the context when it is ready for use (after all beans have been initialized), so that is often a useful hook (this is how the SmartLifecycle works by default).spring-doc.cn
Ensuring that the keyspace initializer is initialized first can also be easy. Some suggestions on how to implement this include:spring-doc.cn
  • Rely on the default behavior of the Spring BeanFactory, which is that beans are initialized in registration order. You can easily arrange that by adopting the common practice of a set of <import/> elements in XML configuration that order your application modules and ensuring that the database and database initialization are listed first.spring-doc.cn
  • Separate the SessionFactory and the business components that use it and control their startup order by putting them in separate ApplicationContext instances (for example, the parent context contains the SessionFactory, and the child context contains the business components). This structure is common in Spring web applications but can be more generally applied.spring-doc.cn
  • Use the Schema management for Tables and User-defined Types to initialize the keyspace using Spring Data Cassandra’s built-in schema generator.spring-doc.cn
Spring Data for Apache Cassandra approaches data access with mapped entity classes that fit your data model. You can use these entity classes to create Cassandra table specifications and user type definitions.spring-doc.cn
Schema creation is tied to CqlSession initialization by SchemaAction. The following actions are supported:spring-doc.cn
  • SchemaAction.NONE: No tables or types are created or dropped. This is the default setting.spring-doc.cn
  • SchemaAction.CREATE: Create tables, indexes, and user-defined types from entities annotated with @Table and types annotated with @UserDefinedType. Existing tables or types cause an error if you tried to create the type.spring-doc.cn
  • SchemaAction.CREATE_IF_NOT_EXISTS: Like SchemaAction.CREATE but with IF NOT EXISTS applied. Existing tables or types do not cause any errors but may remain stale.spring-doc.cn
  • SchemaAction.RECREATE: Drops and recreates existing tables and types that are known to be used. Tables and types that are not configured in the application are not dropped.spring-doc.cn
  • SchemaAction.RECREATE_DROP_UNUSED: Drops all tables and types and recreates only known tables and types.spring-doc.cn
SchemaAction.RECREATE and SchemaAction.RECREATE_DROP_UNUSED drop your tables and lose all data. RECREATE_DROP_UNUSED also drops tables and types that are not known to the application.
Enabling Tables and User-Defined Types for Schema Management
Metadata-based Mapping explains object mapping with conventions and annotations. To prevent unwanted classes from being created as a table or a type, schema management is only active for entities annotated with @Table and user-defined types annotated with @UserDefinedType. Entities are discovered by scanning the classpath. Entity scanning requires one or more base packages. Tuple-typed columns that use TupleValue do not provide any typing details. Consequently, you must annotate such column properties with @CassandraType(type = TUPLE, typeArguments = …) to specify the desired column type.spring-doc.cn
The following example shows how to specify entity base packages in XML configuration:spring-doc.cn
Example 2. Specifying entity base packages
Java
public class EntityBasePackagesConfiguration extends AbstractCassandraConfiguration {
	public String[] getEntityBasePackages() {
		return new String[] { "com.foo", "com.bar" };
XML
    <cassandra:mapping entity-base-packages="com.foo,com.bar"/>
</beans>
