For the latest stable version, please use Spring Data Cassandra 4.4.0!spring-doc.cn
Auditing Configuration for Cassandra
To activate auditing functionality, create a configuration as the following example shows:spring-doc.cn
Activating auditing through configuration
@EnableCassandraAuditing
class Config {
  public AuditorAware<AuditableUser> myAuditorProvider() {
      return new AuditorAwareImpl();
  xmlns:cassandra="http://www.springframework.org/schema/data/cassandra"
  xsi:schemaLocation="
    https://www.springframework.org/schema/data/cassandra/spring-cassandra.xsd
    https://www.springframework.org/schema/beans/spring-beans.xsd">
    <cassandra:auditing mapping-context-ref="customMappingContext" auditor-aware-ref="yourAuditorAwareImpl"/>
</beans>
If you expose a bean of type AuditorAware to the ApplicationContext, the auditing infrastructure picks it up automatically and uses it to determine the current user to be set on domain types. If you have multiple implementations registered in the ApplicationContext, you can select the one to be used by explicitly setting the auditorAwareRef attribute of @EnableCassandraAuditing.spring-doc.cn
To enable auditing, leveraging a reactive programming model, use the @EnableReactiveCassandraAuditing annotation.
If you expose a bean of type ReactiveAuditorAware to the ApplicationContext, the auditing infrastructure picks it up automatically and uses it to determine the current user to be set on domain types. If you have multiple implementations registered in the ApplicationContext, you can select the one to be used by explicitly setting the auditorAwareRef attribute of @EnableReactiveCassandraAuditing.spring-doc.cn
Example 1. Activating reactive auditing using JavaConfig
class Config {
  public ReactiveAuditorAware<AuditableUser> myAuditorProvider() {
