8. Database backends
Vault supports several database secret backends to generate database credentials dynamically based on configured roles. This means services that need to access a database no longer need to configure credentials: they can request them from Vault, and use Vault’s leasing mechanism to more easily roll keys.
Spring Cloud Vault integrates with these backends:
Using a database secret backend requires to enable the backend in the configuration and the spring-cloud-vault-config-databases
dependency.
Vault ships since 0.7.1 with a dedicated database
secret backend that allows database integration via plugins.
You can use that specific backend by using the generic database backend.
Make sure to specify the appropriate backend path, e.g. spring.cloud.vault.mysql.role.backend=database
<dependencies>
<dependency>
<artifactId>spring-cloud-vault-config-databases</artifactId>
<version>3.1.3</version>
</dependency>
</dependencies>
Enabling multiple JDBC-compliant databases will generate credentials and store them by default in the same property keys hence property names for JDBC secrets need to be configured separately. |
8.1. Database
Spring Cloud Vault can obtain credentials for any database listed at
www.vaultproject.io/api/secret/databases/index.html.
The integration can be enabled by setting
spring.cloud.vault.database.enabled=true
(default false
) and providing the role name with spring.cloud.vault.database.role=…
While the database backend is a generic one, spring.cloud.vault.database
specifically targets JDBC databases.
Username and password are available from spring.datasource.username
and spring.datasource.password
properties
so using Spring Boot will pick up the generated credentials for your DataSource
without further configuration.
You can configure the property names by setting
spring.cloud.vault.database.username-property
and
spring.cloud.vault.database.password-property
spring.cloud.vault:
database:
enabled: true
role: readonly
backend: database
username-property: spring.datasource.username
password-property: spring.datasource.password
8.2. Multiple Databases
Sometimes, credentials for a single database isn’t sufficient because an application might connect to two or more databases of the same kind.
Beginning with version 3.0.5, Spring Vault supports the configuration of multiple database secret backends under the spring.cloud.vault.databases.*
namespace.
The configuration accepts multiple database backends to materialize credentials into the specified properties. Make sure to configure username-property
and password-property
appropriately.
spring.cloud.vault:
databases:
primary:
enabled: true
role: readwrite
backend: database
username-property: spring.primary-datasource.username
password-property: spring.primary-datasource.password
other-database:
enabled: true
role: readonly
backend: database
username-property: spring.secondary-datasource.username
password-property: spring.secondary-datasource.password
<name>
descriptive name of the database configuration. -
<name>.enabled
setting this value totrue
enables the Database backend config usage -
<name>.role
sets the role name of the Database role definition -
<name>.backend
sets the path of the Database mount to use -
<name>.username-property
sets the property name in which the Database username is stored. Make sure to use unique property names to avoid property shadowing. -
<name>.password-property
sets the property name in which the Database password is stored Make sure to use unique property names to avoid property shadowing.
Spring Cloud Vault does not support getting new credentials and configuring your DataSource with them when the maximum lease time has been reached.
That is, if max_ttl of the Database role in Vault is set to 24h that means that 24 hours after your application has started it can no longer authenticate with the database.
8.3. Apache Cassandra
The cassandra backend has been deprecated in Vault 0.7.1 and it is recommended to use the database backend and mount it as cassandra .
Spring Cloud Vault can obtain credentials for Apache Cassandra.
spring.cloud.vault.cassandra.enabled=true
(default false
) and providing the role name with spring.cloud.vault.cassandra.role=…
Username and password are available from spring.data.cassandra.username
and spring.data.cassandra.password
properties so using Spring Boot will pick up the generated credentials without further configuration.
spring.cloud.vault.cassandra.username-property
and
spring.cloud.vault.cassandra.password-property
spring.cloud.vault:
cassandra:
enabled: true
role: readonly
backend: cassandra
username-property: spring.data.cassandra.username
password-property: spring.data.cassandra.password
enabled
enables the Cassandra backend config usage -
role
sets the role name of the Cassandra role definition -
backend
sets the path of the Cassandra mount to use -
username-property
sets the property name in which the Cassandra username is stored -
password-property
sets the property name in which the Cassandra password is stored
8.4. Couchbase Database
Spring Cloud Vault can obtain credentials for Couchbase.
spring.cloud.vault.couchbase.enabled=true
(default false
) and providing the role name with spring.cloud.vault.couchbase.role=…
Username and password are available from spring.couchbase.username
and spring.couchbase.password
spring.cloud.vault.couchbase.username-property
and
spring.cloud.vault.couchbase.password-property
spring.cloud.vault:
couchbase:
enabled: true
role: readonly
backend: database
username-property: spring.couchbase.username
password-property: spring.couchbase.password
enabled
enables the Couchbase backend config usage -
role
sets the role name of the Couchbase role definition -
backend
sets the path of the Couchbase mount to use -
username-property
sets the property name in which the Couchbase username is stored -
password-property
sets the property name in which the Couchbase password is stored
See also: Couchbase Database Plugin Documentation
8.5. Elasticsearch
Spring Cloud Vault can obtain since version 3.0 credentials for Elasticsearch.
spring.cloud.vault.elasticsearch.enabled=true
(default false
) and providing the role name with spring.cloud.vault.elasticsearch.role=…
Username and password are available from spring.elasticsearch.rest.username
and spring.elasticsearch.rest.password
spring.cloud.vault.elasticsearch.username-property
and
spring.cloud.vault.elasticsearch.password-property
spring.cloud.vault:
elasticsearch:
enabled: true
role: readonly
backend: mongodb
username-property: spring.elasticsearch.rest.username
password-property: spring.elasticsearch.rest.password
enabled
enables the Elasticsearch database backend config usage -
role
sets the role name of the Elasticsearch role definition -
backend
sets the path of the Elasticsearch mount to use -
username-property
sets the property name in which the Elasticsearch username is stored -
password-property
sets the property name in which the Elasticsearch password is stored
8.6. MongoDB
The mongodb backend has been deprecated in Vault 0.7.1 and it is recommended to use the database backend and mount it as mongodb .
Spring Cloud Vault can obtain credentials for MongoDB.
spring.cloud.vault.mongodb.enabled=true
(default false
) and providing the role name with spring.cloud.vault.mongodb.role=…
Username and password are stored in spring.data.mongodb.username
and spring.data.mongodb.password
spring.cloud.vault.mongodb.username-property
and
spring.cloud.vault.mongodb.password-property
spring.cloud.vault:
mongodb:
enabled: true
role: readonly
backend: mongodb
username-property: spring.data.mongodb.username
password-property: spring.data.mongodb.password
enabled
enables the MongodB backend config usage -
role
sets the role name of the MongoDB role definition -
backend
sets the path of the MongoDB mount to use -
username-property
sets the property name in which the MongoDB username is stored -
password-property
sets the property name in which the MongoDB password is stored
8.7. MySQL
The mysql backend has been deprecated in Vault 0.7.1 and it is recommended to use the database backend and mount it as mysql .
Configuration for spring.cloud.vault.mysql will be removed in a future version.
Spring Cloud Vault can obtain credentials for MySQL.
spring.cloud.vault.mysql.enabled=true
(default false
) and providing the role name with spring.cloud.vault.mysql.role=…
spring.cloud.vault.mysql.username-property
and
spring.cloud.vault.mysql.password-property
spring.cloud.vault:
mysql:
enabled: true
role: readonly
backend: mysql
enabled
enables the MySQL backend config usage -
role
sets the role name of the MySQL role definition -
backend
sets the path of the MySQL mount to use -
username-property
sets the property name in which the MySQL username is stored -
password-property
sets the property name in which the MySQL password is stored
8.8. PostgreSQL
The postgresql backend has been deprecated in Vault 0.7.1 and it is recommended to use the database backend and mount it as postgresql .
Configuration for spring.cloud.vault.postgresql will be removed in a future version.
Spring Cloud Vault can obtain credentials for PostgreSQL.
spring.cloud.vault.postgresql.enabled=true
(default false
) and providing the role name with spring.cloud.vault.postgresql.role=…
spring.cloud.vault.postgresql.username-property
and
spring.cloud.vault.postgresql.password-property
spring.cloud.vault:
postgresql:
enabled: true
role: readonly
backend: postgresql
enabled
enables the PostgreSQL backend config usage -
role
sets the role name of the PostgreSQL role definition -
backend
sets the path of the PostgreSQL mount to use -
username-property
sets the property name in which the PostgreSQL username is stored -
password-property
sets the property name in which the PostgreSQL password is stored
