Using Skipper
This section is the "'three-hour tour'" of Skipper. It describes how to configure and use the main feature set of Skipper in detail. We will cover the shell, platforms, packages, and repositories.spring-doc.cn
Feel free to ask questions on Stack Overflow. Issues can be filed on Github issues.spring-doc.cn
12. Skipper Shell
The shell is based on the Spring Shell project. Two of the shell’s best features are tab-completion and colorization of commands. Use the 'help' command or the --help argument when starting the shell to get help information. The output of using the --help argument follows:spring-doc.cn
Skipper Options:
  --spring.cloud.skipper.client.serverUri=<uri>                        Address of the Skipper Server [default: http://localhost:7577].
  --spring.cloud.skipper.client.username=<USER>                        Username of the Skipper Server [no default].
  --spring.cloud.skipper.client.password=<PASSWORD>                    Password of the Skipper Server [no default].
  --spring.cloud.skipper.client.credentials-provider-command=<COMMAND> Runs an external command, which must return an OAuth Access Token [no default].
  --spring.cloud.skipper.client.skip-ssl-validation=<true|false>       Accept any SSL certificate (even self-signed) [default: no].
  --spring.shell.historySize=<SIZE>                 Default size of the shell log file [default: 3000].
  --spring.shell.commandFile=<FILE>                 Skipper Shell read commands read from the file(s) and then exits.
  --help                                            This message.
12.1. Shell Modes
The shell can be started in either interactive or non-interactive mode. In the case of the non-interactive mode, command line arguments are run as Skipper commands, and then the shell exits. If there are any arguments that do not have the prefix spring.cloud.skipper.client, they are considered as skipper commands to run.spring-doc.cn
Consider the following example:spring-doc.cn
java -jar spring-cloud-skipper-shell-2.11.5.jar --spring.cloud.skipper.client.serverUri=http://localhost:9123/api
The preceding example brings up the interactive shell and connects to localhost:9123/api. Now consider the following command:spring-doc.cn
$ java -jar spring-cloud-skipper-shell-2.11.5.jar --spring.cloud.skipper.client.serverUri=http://localhost:9123/api search
The preceding command connects to localhost:9123/api, runs the search command, and then exits.spring-doc.cn
A more common use case would be to update a package from within a CI job — for example, in a Jenkins Stage, as shown in the following example:spring-doc.cn
stage ('Build') {
    steps {
        checkout([
            $class: 'GitSCM',
            branches: [
                [name: "*/master"]
            userRemoteConfigs: [
                [url: "https://github.com/markpollack/skipper-samples.git"]
        sh '''
            VERSION="1.0.0.M1-$(date +%Y%m%d_%H%M%S)-VERSION"
            mvn org.codehaus.mojo:versions-maven-plugin:2.3:set -DnewVersion="${VERSION}"
            mvn install
            java -jar /home/mpollack/software/skipper.jar upgrade --package-name helloworld --release-name helloworld-jenkins --properties version=${VERSION}
13. Platforms
Skipper supports deploying to multiple platforms. The platforms included are Local, Cloud Foundry, and Kubernetes. For each platform, you can configure multiple accounts. Each account name must be globally unique across all platforms.spring-doc.cn
Usually, different accounts correspond to different orgs or spaces for Cloud Foundry and to different namespaces for a single Kubernetes cluster.spring-doc.cn
Platforms are defined by using Spring Boot’s Externalized Configuration feature. To simplify the getting started experience, if a local platform account is not defined in your configuration, Skipper creates a local deployer implementation named default.spring-doc.cn
You can make use of the Encryption and Decryption features of Spring Cloud Config as one way to secure credentials.spring-doc.cn
Distinct from where Skipper deploys the application, you can also run the Skipper server itself on a platform. Installation on other platforms is covered in the Installation section.spring-doc.cn
The following example YAML file shows configuration of all three platforms:spring-doc.cn
spring:
  cloud:
    skipper:
      server:
        platform:
          local:
            accounts:
              localDevDebug:
                javaOpts: "-Xdebug"
          cloudfoundry:
            accounts:
              cf-dev:
                connection:
                  url: https://api.run.pivotal.io
                  org: scdf-ci
                  space: space-mark
                  domain: cfapps.io
                  username: <your-username>
                  password: <your-password>
                  skipSslValidation: false
                deployment:
                  deleteRoutes: false
          kubernetes:
            accounts:
              minikube:
                namespace: default
The properties available for each platform can be found in the following classes:spring-doc.cn
14. Packages
Packages contain all the necessary information to install your application or group of applications. The approach to describing the applications is to use a YAML file that provides all the necessary information to help facilitate searching for your application hosted in a Package Registry and to install your application to a platform.spring-doc.cn
To make it easy to customize a package, the YAML files are templated. The final version of the YAML file, with all values substituted, is known as the release manifest. Skipper currently understands how to deploy applications based off a YAML file that contains the information needed for a Spring Cloud Deployer or Cloud Foundry implementation to deploy an application. It describes where to find the application (an HTTP, Maven or Docker location), application properties (think Spring Boot @ConfigurationProperties), and deployment properties (such as how much memory to use).spring-doc.cn
14.1. Package Format
A package is a collection of YAML files that are zipped up into a file with the following naming convention: [PackageName]-[PackageVersion].zip (for example: mypackage-1.0.0.zip).spring-doc.cn
A package can define a single application or a group of applications.spring-doc.cn
14.1.1. Single Application
The single application package file, mypackage-1.0.0.zip, when unzipped, should have the following directory structure:spring-doc.cn
mypackage-1.0.0
├── package.yml
├── templates
│   └── template.yml
└── values.yml
The package.yml file contains metadata about the package and is used to support Skipper’s search functionality. The template.yml file contains placeholders for values that are specified in the values.yml file. When installing a package, placeholder values can also be specified, and they would override the values in the values.yml file. The templating engine that Skipper uses is JMustache. The YAML files can have either .yml or .yaml extensions.spring-doc.cn
The helloworld-1.0.0.zip or helloworld-docker-1.0.0.zip files are good examples to use as a basis to create your own package "'by hand'".spring-doc.cn
The source code for the helloworld sample can be found here.spring-doc.cn
14.1.2. Multiple Applications
A package can contain a group of applications bundled in it. In those cases, the structure of the package would resemble the following:spring-doc.cn
mypackagegroup-1.0.0
├── package.yml
├── packages
│   ├── app1
│   │   ├── package.yml
│   │   ├── templates
│   │   │   └── log.yml
│   │   └── values.yml
│   └── app2
│       ├── package.yml
│       ├── templates
│       │   └── time.yml
│       └── values.yml
└── values.yml
In the preceding example, the mypackagegroup still has its own package.yml and values.yml to specify the package metadata and the values to override. All the applications inside the mypackagegroup are considered to be sub-packages and follow a package structure similar to the individual packages. These sub packages need to be specified inside the packages directory of the root package, mypackagegroup.spring-doc.cn
The ticktock-1.0.0.zip file is a good example to use as a basis for creating your own package 'by-hand'.spring-doc.cn
Packages with template kind CloudFoundryApplication currently doesn’t support multiple applications format.spring-doc.cn
14.2. Package Metadata
The package.yml file specifies the package metadata. A sample package metadata would resemble the following:spring-doc.cn
# Required Fields
apiVersion: skipper.spring.io/v1
kind: SkipperPackageMetadata
version: 1.0.0
# Optional Fields
packageSourceUrl: https://github.com/some-mypackage-project/v1.0.0.RELEASE
packageHomeUrl: https://some-mypackage-project/
tags: skipper, mypackage, sample
maintainer: https://github.com/maintainer
description: This is a mypackage sample.
Required Fields:spring-doc.cn
Currently only supported kind is SkipperPackageMetadata.spring-doc.cn
Optional Fields:spring-doc.cn
  • packageSourceUrl: The location of the source code for this package.spring-doc.cn
  • packageHomeUrl: The home page of the package.spring-doc.cn
  • tags: A comma-separated list of tags to be used for searching.spring-doc.cn
  • maintainer: Who maintains this package.spring-doc.cn
  • description: Free-form text describing the functionality of the package — generally shown in search results.spring-doc.cn
  • sha256: The hash of the package binary (not yet enforced).spring-doc.cn
  • iconUrl: The URL for an icon to show for this package.spring-doc.cn
  • origin: Free-form text describing the origin of this package — for example, your company name.spring-doc.cn
Currently, the package search functionality is only a wildcard match against the name of the package.spring-doc.cn
A Package Repository exposes an index.yml file that contains multiple metadata documents and that uses the standard three dash notation --- to separate the documents — for example, index.yml.spring-doc.cn
14.3. Package Templates
Currently, two type of applications are supported. One having SpringCloudDeployerApplication kind, which means the applications can be deployed into the target platforms only by using their corresponding Spring Cloud Deployer implementations (CF, Kubernetes Deployer, and so on). Other is having CloudFoundryApplication kind, which means the applications are directly deployed into Cloud Foundry using its manifest support.spring-doc.cn
14.3.1. Spring Cloud Deployer
The template.yml file has a package structure similar to that of the following example:spring-doc.cn
mypackage-1.0.0
├── package.yml
├── templates
│   └── template.yml
└── values.yml
Actual template file name doesn’t matter and you can have multiple template files. These just need to be inside of a templates directory.spring-doc.cn
# template.yml
kind: SpringCloudDeployerApplication
metadata:
  type: sample
spec:
  resource: maven://org.mysample:mypackage
  resourceMetadata:  maven://org.mysample:mypackage:jar:metadata:{{spec.version}}
  version: {{spec.version}}
  applicationProperties:
    {{#spec.applicationProperties.entrySet}}
    {{key}}: {{value}}
    {{/spec.applicationProperties.entrySet}}
  deploymentProperties:
    {{#spec.deploymentProperties.entrySet}}
    {{key}}: {{value}}
    {{/spec.deploymentProperties.entrySet}}
The apiVersion, kind, and spec.resource are required.spring-doc.cn
The spec.resource and spec.version define where the application executable is located. The spec.resourceMetadata field defines where a Spring Boot Configuration metadata jar is located that contains the configuration properties of the application. This is either a Spring Boot uber jar hosted under a HTTP endpoint or a Maven or Docker repository. The template placeholder {{spec.version}} exists so that the version of a specific application can be easily upgraded without having to create a new package .zip file.spring-doc.cn
The resource is based on http:// or maven:// or docker:. The format for specifying a resource follows documented types in Resources.spring-doc.cn
14.3.2. Cloud Foundry
mypackage-1.0.0
├── package.yml
├── templates
│   └── template.yml
└── values.yml
template.yml commonly has content similar to the following:spring-doc.cn
# template.yml
kind: CloudFoundryApplication
spec:
  manifest:
    {{#spec.manifest.entrySet}}
    {{key}}: {{value}}
    {{/spec.manifest.entrySet}}
Where values could for example be something like:spring-doc.cn
# values.yml
spec:
  version: 1.0.0
  manifest:
    memory: 1024
    disk-quota: 1024
Possible values of a spec.manifest are:spring-doc.cn
Key Value Notes
buildpackspring-doc.cn
(String)spring-doc.cn
buildpack attribute as is.spring-doc.cn
commandspring-doc.cn
command attribute as is.spring-doc.cn
memoryspring-doc.cn
(String or Integer)spring-doc.cn
memory attribute as is if type is Integer, String is converted using same format in a CF, like 1024M or 2G. 1024 and 1024M are equivalent.spring-doc.cn
disk-quotaspring-doc.cn
disk_quota attribute as is if type is Integer, String is converted using same format in a CF, like 1024M or 2G. 1024 and 1024M are equivalent.spring-doc.cn
timeoutspring-doc.cn
(Integer)spring-doc.cn
timeout attribute as is.spring-doc.cn
instancesspring-doc.cn
instances attribute as is.spring-doc.cn
no-hostnamespring-doc.cn
(Boolean)spring-doc.cn
no-hostname attribute as is.spring-doc.cn
no-routespring-doc.cn
no-route attribute as is.spring-doc.cn
random-routespring-doc.cn
random-route attribute as is.spring-doc.cn
health-check-typespring-doc.cn
health-check-type having possible values of port, process or http.spring-doc.cn
health-check-http-endpointspring-doc.cn
health-check-http-endpoint attribute as is.spring-doc.cn
stackspring-doc.cn
stack attribute as is.spring-doc.cn
servicesspring-doc.cn
(List<String>)spring-doc.cn
services attribute as is.spring-doc.cn
domainsspring-doc.cn
domains attribute as is.spring-doc.cn
hostsspring-doc.cn
hosts attribute as is.spring-doc.cn
envspring-doc.cn
(Map<String,Object>)spring-doc.cn
env attribute as is.spring-doc.cn
Remember that when a value is given from a command-line, replacement happens as is defined in a template. Using a template format {{#spec.manifest.entrySet}} shown above, List would be given in format spec.manifest.services=[service1, service2] and Map would be given in format spec.manifest.env={key1: value1, key2: value2}.spring-doc.cn
14.3.3. Resources
This section contains resource types currently supported.spring-doc.cn
HTTP Resources
The following example shows a typical spec for HTTP:spring-doc.cn
spec:
  resource: https://example.com/app/hello-world
  version: 1.0.0.RELEASE
There is a naming convention that must be followed for HTTP-based resources so that Skipper can assemble a full URL from the resource and version field and also parse the version number given the URL. The preceding spec references a URL at example.com/app/hello-world-1.0.0.RELEASE.jar. The resource and version fields should not have any numbers after the - character.spring-doc.cn
Docker Resources
The following example shows a typical spec for Docker:spring-doc.cn
spec:
  resource: docker:springcloud/spring-cloud-skipper-samples-helloworld
The mapping to docker registry names follows:spring-doc.cn
spec:
  resource: docker:<user>/<repo>
  version: <tag>
Maven Resources
The following example shows a typical spec for Maven:spring-doc.cn
spec:
  resource: maven://org.springframework.cloud.samples:spring-cloud-skipper-samples-helloworld:1.0.0.RELEASE
The mapping to Maven artifact names followsspring-doc.cn
spec:
  resource: maven://<maven-group-name>:<maven-artifact-name>
  version:<maven-version>
There is only one setting to specify with Maven repositories to search. This setting applies across all platform accounts. By default, the following configuration is used:spring-doc.cn
maven:
  remoteRepositories:
    springRepo: https://repo.spring.io/snapshot
You can specify other entries and also specify proxy properties. This is currently best documented here. Essentially, this needs to be set as a property in your launch properties or manifest.yml (when pushing to PCF), as follows:spring-doc.cn
# manifest.yml
env:
    SPRING_APPLICATION_JSON: '{"maven": { "remote-repositories": { "springRepo": { "url": "https://repo.spring.io/snapshot"} } } }'
The metadata section is used to help search for applications after they have been installed. This feature will be made available in a future release.spring-doc.cn
The spec contains the resource specification and the properties for the package.spring-doc.cn
The resource represents the resource URI to download the application from. This would typically be a Maven co-ordinate or a Docker image URL.spring-doc.cn
The SpringCloudDeployerApplication kind of application can have applicationProperties and deploymentProperties as the configuration properties.spring-doc.cn
The application properties correspond to the properties for the application itself.spring-doc.cn
The deployment properties correspond to the properties for the deployment operation performed by Spring Cloud Deployer implementations.spring-doc.cn
The name of the template file can be anything, as all the files under templates directory are loaded to apply the template configurations.spring-doc.cn
14.4. Package Values
The values.yml file contains the default values for any of the keys specified in the template files.spring-doc.cn
For instance, in a package that defines one application, the format is as follows:spring-doc.cn
spec:
    server.port: 9090
If the package defines multiple applications, provide the name of the package in the top-level YML section to scope the spec section. Consider the example of a multiple application package with the following layout:spring-doc.cn
ticktock-1.0.0/
├── packages
│   ├── log
│   │   ├── package.yml
│   │   └── values.yml
│   └── time
│       ├── package.yml
│       └── values.yml
├── package.yml
└── values.yml
The top-level values.yml file might resemble the following:spring-doc.cn
#values.yml
hello: world
time:
  appVersion: 1.3.0.M1
  deployment:
      log.level: WARN
      trigger.fixed-delay: 1
log:
  deployment:
    count: 2
      log.level: WARN
      log.name: skipperlogger
The preceding values.yml file sets hello as a variable available to be used as a placeholder in the packages\log\values.yml file and the packages\time\values.yml. However, the YML section under time: is applied only to the packages\time\values.yml file and the YML section under log: is applied only to the packages\log\values.yml file.spring-doc.cn
14.5. Package Upload
After creating the package in the structure shown in the previous section, we can compress it in a zip file with the following naming scheme: [PackageName]-[PackageVersion].zip (for example, mypackage-1.0.0.zip).spring-doc.cn
For instance, the package directory would resemble the following before compression:spring-doc.cn
mypackage-1.0.0
├── package.yml
├── templates
│   └── template.yml
└── values.yml
The zip file can be uploaded into one of the local repositories of the Skipper server. By default, the Skipper server has a local repository with the name, local.spring-doc.cn
By using the Skipper shell, we can upload the package zip file into the Skipper server’s local repository, as follows:spring-doc.cn
skipper:>package upload --path /path-to-package/mypackage-1.0.0.zip
Package uploaded successfully:[mypackage:1.0.0]
If no --repo-name is set, the upload command uses local as the repository to upload.spring-doc.cn
We can then use the package list or package search command to see that our package has been uploaded, as shown (with its output) in the following example:spring-doc.cn
skipper:>package list
║      Name       │Version│                                  Description                                   ║
║helloworld       │1.0.0  │The app has two endpoints, /about and /greeting in English.  Maven resource.    ║
║helloworld       │1.0.1  │The app has two endpoints, /about and /greeting in Portuguese.  Maven resource. ║
║helloworld-docker│1.0.0  │The app has two endpoints, /about and /greeting in English.  Docker resource.   ║
║helloworld-docker│1.0.1  │The app has two endpoints, /about and /greeting in Portuguese.  Docker resource.║
║mypackage        │1.0.0  │This is a mypackage sample                                                      ║
14.6. Creating Your Own Package
In this section, we create a package that can be deployed by using Spring Cloud Deployer implementations.spring-doc.cn
For this package, we are going to create a simple package and upload it to our local machine.spring-doc.cn
To get started creating your own package, create a folder following a naming convention of [package-name]-[package-version]. In our case, the folder name is demo-1.0.0. In this directory, create empty files named values.yml and package.yml and create a templates directory. In the templates directory, create an empty file named template.yml.spring-doc.cn
Go into the package.yml where we are going to specify the package metadata. For this app, we fill only the minimum values possible, as shown in the following example:spring-doc.cn
# package.yml
version: 1.0.0
description: Greets the world!
Ensure that your name and version matches the name and version in your folder name, or you get an error.
Next, open up your templates/template.yml file. Here, we are going to specify the actual information about your package and, most importantly, set default values. In the template.yml, copy the template for the kind SpringCloudDeployerApplication from the preceding sample. Your resulting template.yml file should resemble the following:spring-doc.cn
# templates/template.yml
metadata:
spec:
  version: {{version}}
    {{key}}: {{value}}
    {{key}}: {{value}}
The preceding example file specifies that our application name is demo and finds our package in Maven. Now we can specify the version, applicationProperties, and deploymentProperties in our values.yml, as follows:spring-doc.cn
# values.yml
# This is a YAML-formatted file.
# Declare variables to be passed into your templates
spec:
    server.port: 8100
The preceding example sets the version to 1.0.0.RELEASE and also sets the server.port=8100 as one of the application properties. When the Skipper Package reader resolves these values by merging the values.yml against the template, the resolved values resemble the following:spring-doc.cn
# hypothetical template.yml
metadata:
spec:
    server.port: 8100
The reason to use values.yml instead of entering the values directly is that it lets you overwrite the values at run time by using the --file or --properties flags.spring-doc.cn
We have finished making our file. Now we have to zip it up. The easiest way to do is by using the zip -r command on the command line, as follows:spring-doc.cn
$ zip -r demo-1.0.0.zip demo-1.0.0/
  adding: demo-1.0.0/ (stored 0%)
  adding: demo-1.0.0/package.yml (deflated 14%)
  adding: demo-1.0.0/templates/ (stored 0%)
  adding: demo-1.0.0/templates/template.yml (deflated 55%)
  adding: demo-1.0.0/values.yml (deflated 4%)
Armed with our zipped file and the path to it, we can head to Skipper and use the upload command, as follows:spring-doc.cn
skipper:>package upload --path /Users/path-to-your-zip/demo-1.0.0.zip
Package uploaded successfully:[demo:1.0.0]
Now you can search for it as shown previously and then install it, as followsspring-doc.cn
skipper:>package install --package-name demo --package-version 1.0.0 --release-name demo
Released demo. Now at version v1.
Congratulations! You have now created, packaged, uploaded, and installed your own Skipper package!spring-doc.cn
15. Repositories
Repositories store package metadata and host package .zip files. Repositores can be local or remote, were local means backed by Skipper’s relational database and remote means a filesystem exposed over HTTP.spring-doc.cn
When registering a remote registry (for example, the experimental one that is currently not defined by default in addition to one named local`), use the following format:spring-doc.cn
spring
  cloud:
    skipper:
      server:
        package-repositories:
          experimental:
            url: https://skipper-repository.cfapps.io/repository/experimental
            description: Experimental Skipper Repository
            repoOrder: 0
          local:
            url: http://${spring.cloud.client.hostname}:7577
            local: true
            description: Default local database backed repository
            repoOrder: 1
For Skipper 2.x, spring.cloud.skipper.server.package-repositories structure has been changed from a list to a map where key is the repository name. Having a map format makes it easier to define and override configuration values.
The repoOrder determines which repository serves up a package if one with the same name is registered in two or more repositories.spring-doc.cn
The directory structure assumed for a remote repository is the registered url value followed by the package name and then the zip file name (for example, skipper-repository.cfapps.io/repository/experimental/helloworld/helloworld-1.0.0.zip for the package helloworld with a version of 1.0.0). A file named index.yml is expected to be directly under the registered url — for example, skipper-repository.cfapps.io/repository/experimental/index.yml. This file contains the package metadata for all the packages hosted by the repository.spring-doc.cn
It is up to you to update the index.yml file "'by hand'" for remote repositories.spring-doc.cn
'Local' repositories are backed by Skipper’s database. In the Skipper 1.0 release, they do not expose the index.yml or the .zip files under a filesystem-like URL structure as with remote repositories. This feature will be provided in the next version. However, you can upload packages to a local repository and do not need to maintain an index file. See the “Skipper Commands” section for information on creating local repositories.spring-doc.cn
A good example that shows using a Spring Boot web application with static resources to host a Repository can be found here. This application is currently running under skipper-repository.cfapps.io/repository/experimental.spring-doc.cn
