3. 广告服务
Service Broker 目录提供了一组元数据,用于描述可用服务以及成本和功能等属性。 该目录通过 Service Broker 提供给平台的服务市场/v2/catalog端点。spring-doc.cadn.net.cn
Service Broker 可以提供Catalog或实施服务CatalogService.spring-doc.cadn.net.cn
3.1. 提供目录 Bean
您可以通过创建 Spring Bean 并将其贡献给 Spring 来公开 Service Broker 目录 应用程序上下文。 您可以在 Spring 中执行此作@Configuration类,如下所示:spring-doc.cadn.net.cn
package com.example.servicebroker;
import org.springframework.cloud.servicebroker.model.catalog.Catalog;
import org.springframework.cloud.servicebroker.model.catalog.Plan;
import org.springframework.cloud.servicebroker.model.catalog.ServiceDefinition;
public class ExampleCatalogConfiguration {
	public Catalog catalog() {
		Plan plan = Plan.builder()
				.id("simple-plan")
				.name("standard")
				.description("A simple plan")
				.free(true)
		ServiceDefinition serviceDefinition = ServiceDefinition.builder()
				.id("example-service")
				.name("example")
				.description("A simple example")
				.bindable(true)
				.tags("example", "tags")
				.plans(plan)
		return Catalog.builder()
		  .serviceDefinitions(serviceDefinition)
3.2. Providing a Catalog by Using Properties
You can configure a catalog with Spring Boot externalized configuration within a Java properties file or a YAML file. The catalog is parsed and made available as a Catalog bean during autoconfiguration.spring-doc.cadn.net.cn
The following YAML file configures a catalog:spring-doc.cadn.net.cn
# Example Spring Boot YAML configuration
spring:
  cloud:
    openservicebroker:
      catalog:
        services:
        - id: example-service
          description: A simple example
          bindable: true
          tags:
          - example
          - tags
          plans:
          - id: simple-plan
            description: A simple plan
The following properties file configures a catalog:spring-doc.cadn.net.cn
# Example Spring Boot properties configuration
spring.cloud.openservicebroker.catalog.services[0].id=example-service
spring.cloud.openservicebroker.catalog.services[0].name=example
spring.cloud.openservicebroker.catalog.services[0].description=A simple example
spring.cloud.openservicebroker.catalog.services[0].bindable=true
spring.cloud.openservicebroker.catalog.services[0].tags[0]=example
spring.cloud.openservicebroker.catalog.services[0].tags[1]=tags
spring.cloud.openservicebroker.catalog.services[0].plans[0].id=simple-plan
spring.cloud.openservicebroker.catalog.services[0].plans[0].name=standard
spring.cloud.openservicebroker.catalog.services[0].plans[0].description=A simple plan
3.3. Implementing a Catalog Service
A service broker can take more control over the catalog by implementing the CatalogService interface. This might be required if some details of the catalog metadata need to be read from the environment or from an external data source.spring-doc.cadn.net.cn
The following example implements the CatalogService interface:spring-doc.cadn.net.cn
import reactor.core.publisher.Mono;
import org.springframework.cloud.servicebroker.service.CatalogService;
import org.springframework.http.HttpHeaders;
import org.springframework.http.ResponseEntity;
import org.springframework.stereotype.Service;
@Service
public class ExampleCatalogService implements CatalogService {
	public Mono<Catalog> getCatalog() {
		return getServiceDefinition("example-service")
				.map(serviceDefinition -> Catalog.builder()
						.build());
	public Mono<ServiceDefinition> getServiceDefinition(String serviceId) {
		return Mono.just(ServiceDefinition.builder()
				.id(serviceId)
				.name("example")
				.bindable(true)
				.plans(getPlan())
				.build());
	public Mono<ResponseEntity<Catalog>> getResponseEntityCatalog(HttpHeaders httpHeaders) {
		// Use this method to handle catalog caching and ETag support.
		// The example below is a basic ETag comparison and response.
		if ("useful-etag-value".equals(httpHeaders.getIfNoneMatch())) {
			return Mono.just(ResponseEntity
					.status(304)
					.eTag("useful-etag-value")
					.build());
		else {
			return getCatalog()
					.map(catalog -> ResponseEntity
							.status(200)
							.eTag("different-etag-value")
							.body(catalog));
	private Plan getPlan() {
		return Plan.builder()
				.id("simple-plan")
				.name("standard")
				.free(true)
