6. API 版本验证
平台需要在每次调用 Open Service Broker API 时提供 HTTP 标头,以指示平台支持的 API 规范版本。 您可以配置 Spring Cloud Open Service Broker 以验证平台在每次调用 Service Broker 时提供的版本。 默认情况下,此版本验证配置为允许任何 API 版本。spring-doc.cadn.net.cn
要自定义版本验证,请将apiVersion指定 Service Broker 所需的 API 版本的属性,如下所示:spring-doc.cadn.net.cn
spring.cloud.openservicebroker.apiVersion=2.13
或者,您也可以提供BrokerApiVersionSpring bean 中,如下所示:spring-doc.cadn.net.cn
package com.example.servicebroker;
import org.springframework.cloud.servicebroker.model.BrokerApiVersion;
public class ExampleApiVersionConfiguration {
	public BrokerApiVersion brokerApiVersion() {
		return new BrokerApiVersion("2.13");
In the case of both a Spring Bean and a property being configured, the Spring Bean takes precedence over the property.spring-doc.cadn.net.cn
If an API version is specified and the platform provides a different version in the X-Broker-API-Version header, the framework returns a 412 Precondition Failed error to the platform.spring-doc.cadn.net.cn
As mentioned earlier, the default version verification is configured to allow any API version. However, to disable version verification entirely, you can set the api-version-check-endabled property to false, as follows:spring-doc.cadn.net.cn
spring.cloud.openservicebroker.api-version-check-enabled = false
