Embedding the Config Server
The Config Server runs best as a standalone application.
However, if need be, you can embed it in another application.
To do so, use the @EnableConfigServer
annotation.
An optional property named spring.cloud.config.server.bootstrap
can be useful in this case.
It is a flag to indicate whether the server should configure itself from its own remote repository.
By default, the flag is off, because it can delay startup.
However, when embedded in another application, it makes sense to initialize the same way as any other application.
When setting spring.cloud.config.server.bootstrap
to true
you must also use a composite environment repository configuration.
For example
spring:
application:
profiles:
active: composite
cloud:
config:
server:
composite:
- type: native
search-locations: ${HOME}/Desktop/config
bootstrap: true
If you use the bootstrap flag, the config server needs to have its name and repository URI configured in bootstrap.yml .
To change the location of the server endpoints, you can (optionally) set spring.cloud.config.server.prefix
(for example, /config
), to serve the resources under a prefix.
The prefix should start but not end with a /
It is applied to the @RequestMappings
in the Config Server (that is, underneath the Spring Boot server.servletPath
and server.contextPath
prefixes).
If you want to read the configuration for an application directly from the backend repository (instead of from the config server), you
basically want an embedded config server with no endpoints.
You can switch off the endpoints entirely by not using the @EnableConfigServer
annotation (set spring.cloud.config.server.bootstrap=true
