This version is still in development and is not considered stable yet. For the latest stable version, please use Spring-Cloud-CircuitBreaker 3.2.0!
Circuit Breaker Properties Configuration
You can configure CircuitBreaker and TimeLimiter configs or instances in your application’s configuration properties file. Property configuration has higher priority than Java Customizer configuration.
Descending priority from top to bottom.
ReactiveResilience4JCircuitBreakerFactory.create(String id, String groupName)
Global Default Properties Configuration
resilience4j.circuitbreaker:
    configs:
        default:
            registerHealthIndicator: true
            slidingWindowSize: 50
resilience4j.timelimiter:
    configs:
        default:
            timeoutDuration: 5s
            cancelRunningFuture: true
Configs Properties Configuration
    configs:
        groupA:
            slidingWindowSize: 200
    configs:
        groupC:
            timeoutDuration: 3s
Instances Properties Configuration
 instances:
     backendA:
         slidingWindowSize: 100
     backendB:
         permittedNumberOfCallsInHalfOpenState: 3
         slidingWindowType: TIME_BASED
         recordFailurePredicate: io.github.robwin.exception.RecordFailurePredicate
 instances:
     backendA:
         timeoutDuration: 2s
     backendB:
         timeoutDuration: 1s
         cancelRunningFuture: false
  • ReactiveResilience4JCircuitBreakerFactory.create("backendA") or Resilience4JCircuitBreakerFactory.create("backendA") will apply instances backendA properties
  • ReactiveResilience4JCircuitBreakerFactory.create("backendA", "groupA") or Resilience4JCircuitBreakerFactory.create("backendA", "groupA") will apply instances backendA properties
  • ReactiveResilience4JCircuitBreakerFactory.create("backendC") or Resilience4JCircuitBreakerFactory.create("backendC") will apply global default properties
  • ReactiveResilience4JCircuitBreakerFactory.create("backendC", "groupC") or Resilience4JCircuitBreakerFactory.create("backendC", "groupC") will apply global default CircuitBreaker properties and config groupC TimeLimiter properties
For more information on Resilience4j property configuration, see Resilience4J Spring Boot 2 Configuration.
Disabling the TimeLimiter
By default, the TimeLimiter is enabled and every execution is backed by a time limit. This time limit is either defined explicitly or the default time limit (provided by io.github.resilience4j.timelimiter.TimeLimiterConfig#ofDefaults) is used.
The TimeLimiter can be globally disabled by setting the property spring.cloud.circuitbreaker.resilience4j.disable-time-limiter to true.
spring:
	cloud:
		circuitbreaker:
			resilience4j:
				disable-time-limiter: true
TimeLimiter can also be disabled for specific group or instances using spring.cloud.circuitbreaker.resilience4j.disable-time-limiter-map as below:
spring:
	cloud:
		circuitbreaker:
			resilience4j:
				disable-time-limiter-map:
					group1: true
					instanceA: false
					instanceB: true
These options for disabling TimeLimit are provided within spring-cloud-circuitbreaker and applies to both basic and reactive circuitbreaker implementation.
Priority order of disabling is : instance > group > global. Based on above configuration, instanceB and group1 have TimeLimiter disabled but instanceA has enabled. For all other instances and groups, it will fall back to globally set value of spring.cloud.circuitbreaker.resilience4j.disable-time-limiter If spring.cloud.circuitbreaker.resilience4j.disable-time-limiter is not set, by default, TimeLimit is enabled for remaining circuitbreaker instances and groups.
APP信息
