For the latest stable version, please use Spring-Cloud-CircuitBreaker 3.2.0!spring-doc.cn
Default Configuration
To provide a default configuration for all of your circuit breakers create a Customizer bean that is passed a Resilience4JCircuitBreakerFactory or ReactiveResilience4JCircuitBreakerFactory. The configureDefault method can be used to provide a default configuration.spring-doc.cn
public Customizer<Resilience4JCircuitBreakerFactory> defaultCustomizer() {
	return factory -> factory.configureDefault(id -> new Resilience4JConfigBuilder(id)
			.timeLimiterConfig(TimeLimiterConfig.custom().timeoutDuration(Duration.ofSeconds(4)).build())
			.circuitBreakerConfig(CircuitBreakerConfig.ofDefaults())
			.build());
Reactive Example
public Customizer<ReactiveResilience4JCircuitBreakerFactory> defaultCustomizer() {
			.timeLimiterConfig(TimeLimiterConfig.custom().timeoutDuration(Duration.ofSeconds(4)).build()).build());
Customizing The ExecutorService
If you would like to configure the ExecutorService which executes the circuit breaker you can do so using the Resilience4JCircuitBreakerFactory.spring-doc.cn
For example if you would like to use a context aware ExecutorService you could do the following.spring-doc.cn
	return factory -> {
		ContextAwareScheduledThreadPoolExecutor executor = ContextAwareScheduledThreadPoolExecutor.newScheduledThreadPool().corePoolSize(5)
		factory.configureExecutorService(executor);
