For the latest stable version, please use Spring-Cloud-CircuitBreaker 3.2.0!spring-doc.cn
Circuit Breaker Properties Configuration
You can configure CircuitBreaker and TimeLimiter configs or instances in your application’s configuration properties file. Property configuration has higher priority than Java Customizer configuration.spring-doc.cn
Descending priority from top to bottom.spring-doc.cn
ReactiveResilience4JCircuitBreakerFactory.create(String id, String groupName)
Global Default Properties Configuration
resilience4j.circuitbreaker:
    configs:
        default:
            registerHealthIndicator: true
            slidingWindowSize: 50
resilience4j.timelimiter:
    configs:
        default:
            timeoutDuration: 5s
            cancelRunningFuture: true
Configs Properties Configuration
    configs:
        groupA:
            slidingWindowSize: 200
    configs:
        groupC:
            timeoutDuration: 3s
Instances Properties Configuration
 instances:
     backendA:
         slidingWindowSize: 100
     backendB:
         permittedNumberOfCallsInHalfOpenState: 3
         slidingWindowType: TIME_BASED
         recordFailurePredicate: io.github.robwin.exception.RecordFailurePredicate
 instances:
     backendA:
         timeoutDuration: 2s
     backendB:
         timeoutDuration: 1s
         cancelRunningFuture: false
  • ReactiveResilience4JCircuitBreakerFactory.create("backendA") or Resilience4JCircuitBreakerFactory.create("backendA") will apply instances backendA propertiesspring-doc.cn
  • ReactiveResilience4JCircuitBreakerFactory.create("backendA", "groupA") or Resilience4JCircuitBreakerFactory.create("backendA", "groupA") will apply instances backendA propertiesspring-doc.cn
  • ReactiveResilience4JCircuitBreakerFactory.create("backendC") or Resilience4JCircuitBreakerFactory.create("backendC") will apply global default propertiesspring-doc.cn
  • ReactiveResilience4JCircuitBreakerFactory.create("backendC", "groupC") or Resilience4JCircuitBreakerFactory.create("backendC", "groupC") will apply global default CircuitBreaker properties and config groupC TimeLimiter propertiesspring-doc.cn
For more information on Resilience4j property configuration, see Resilience4J Spring Boot 2 Configuration.spring-doc.cn
Disabling the TimeLimiter
By default, the TimeLimiter is enabled and every execution is backed by a time limit. This time limit is either defined explicitly or the default time limit (provided by io.github.resilience4j.timelimiter.TimeLimiterConfig#ofDefaults) is used.spring-doc.cn
The TimeLimiter can be globally disabled by setting the property spring.cloud.circuitbreaker.resilience4j.disable-time-limiter to true.spring-doc.cn
spring:
	cloud:
		circuitbreaker:
			resilience4j:
				disable-time-limiter: true
TimeLimiter can also be disabled for specific group or instances using spring.cloud.circuitbreaker.resilience4j.disable-time-limiter-map as below:spring-doc.cn
spring:
	cloud:
		circuitbreaker:
			resilience4j:
				disable-time-limiter-map:
					group1: true
					instanceA: false
					instanceB: true
These options for disabling TimeLimit are provided within spring-cloud-circuitbreaker and applies to both basic and reactive circuitbreaker implementation.spring-doc.cn
Priority order of disabling is : instance > group > global. Based on above configuration, instanceB and group1 have TimeLimiter disabled but instanceA has enabled. For all other instances and groups, it will fall back to globally set value of spring.cloud.circuitbreaker.resilience4j.disable-time-limiter If spring.cloud.circuitbreaker.resilience4j.disable-time-limiter is not set, by default, TimeLimit is enabled for remaining circuitbreaker instances and groups.spring-doc.cn
