9. Resource handling
The Spring Framework provides a org.springframework.core.io.ResourceLoader
abstraction to load files from the filesystem,
servlet context and the classpath. Spring Cloud AWS adds support for the Amazon S3 service
to load and write resources with the resource loader and the s3
protocol.
The resource loader is part of the context module, therefore no additional dependencies are necessary to use the resource handling support.
9.1. Configuring the resource loader
Spring Cloud AWS does not modify the default resource loader unless it encounters an explicit configuration with an XML namespace element. The configuration consists of one element for the whole application context that is shown below:
<beans xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:aws-context="http://www.springframework.org/schema/cloud/aws/context"
xsi:schemaLocation="http://www.springframework.org/schema/cloud/aws/context
http://www.springframework.org/schema/cloud/aws/context/spring-cloud-aws-context.xsd">
<aws-context:context-credentials>
</aws-context:context-credentials>
<aws-context:context-resource-loader/>
</beans>
9.2. Downloading files
Downloading files can be done by using the s3
protocol to reference Amazon S3 buckets and objects inside their bucket. The
typical pattern is s3://<bucket>/<object>
where bucket is the global and unique bucket name and object is a valid object
name inside the bucket. The object name can be a file in the root folder of a bucket or a nested file within a directory
inside a bucket.
The next example demonstrates the use of the resource loader to load different resources.
public class SimpleResourceLoadingBean {
@Autowired
private ResourceLoader resourceLoader;
public void resourceLoadingMethod() throws IOException {
Resource resource = this.resourceLoader.getResource("s3://myBucket/rootFile.log");
Resource secondResource = this.resourceLoader.getResource("s3://myBucket/rootFolder/subFile");
InputStream inputStream = resource.getInputStream();
//read file
9.3. Uploading files
Since Spring Framework 3.1 the resource loader can also be used to upload files with the org.springframework.core.io.WritableResource
interface which is a specialization of the org.springframework.core.io.ResourceLoader
interface. Clients can upload files
using the WritableResource
interface. The next example demonstrates an upload of a resource using the resource loader.
@Autowired
public void writeResource() throws IOException {
WritableResource writableResource = (WritableResource) resource;
try (OutputStream outputStream = writableResource.getOutputStream()) {
outputStream.write("test".getBytes());
9.3.1. Uploading multi-part files
Amazon S3 supports multi-part uploads to
increase the general throughput while uploading. Spring Cloud AWS by default only uses one thread to upload the files and
therefore does not provide parallel upload support. Users can configure a custom org.springframework.core.task.TaskExecutor
for the resource loader. The resource loader will queue multiple threads at the same time to use parallel multi-part uploads.
The configuration for a resource loader that uploads with 10 Threads looks like the following
<beans ...>
<aws-context:context-resource-loader task-executor="executor" />
<task:executor id="executor" pool-size="10" queue-capacity="0" rejection-policy="CALLER_RUNS" />
</beans>
Spring Cloud AWS consumes up to 5 MB (at a minimum) of memory per thread. Therefore each parallel thread will incur
a memory footprint of 5 MB in the heap, and a thread size of 10 will consume therefore up to 50 mb of heap space. Spring Cloud
AWS releases the memory as soon as possible. Also, the example above shows that there is no |
9.3.2. Uploading with the TransferManager
The Amazon SDK also provides a high-level abstraction that is useful to upload files, also with multiple threads using
the multi-part functionality. A com.amazonaws.services.s3.transfer.TransferManager
can be easily created in the application
code and injected with the pre-configured com.amazonaws.services.s3.AmazonS3
client that is already created
with the Spring Cloud AWS resource loader configuration.
This example shows the use of the transferManager
within an application to upload files from the hard-drive.
@Autowired
private AmazonS3 amazonS3;
public void withTransferManager() {
TransferManager transferManager = new TransferManager(this.amazonS3);
transferManager.upload("myBucket","filename",new File("someFile"));
9.4. Searching resources
The Spring resource loader also supports collecting resources based on an Ant-style path specification. Spring Cloud AWS offers the same support to resolve resources within a bucket and even throughout buckets. The actual resource loader needs to be wrapped with the Spring Cloud AWS one in order to search for s3 buckets, in case of non s3 bucket the resource loader will fall back to the original one. The next example shows the resource resolution by using different patterns.
private ResourcePatternResolver resourcePatternResolver;
@Autowired
public void setupResolver(ApplicationContext applicationContext, AmazonS3 amazonS3){
this.resourcePatternResolver = new PathMatchingSimpleStorageResourcePatternResolver(amazonS3, applicationContext);
public void resolveAndLoad() throws IOException {
Resource[] allTxtFilesInFolder = this.resourcePatternResolver.getResources("s3://bucket/name/*.txt");
Resource[] allTxtFilesInBucket = this.resourcePatternResolver.getResources("s3://bucket/**/*.txt");
Resource[] allTxtFilesGlobally = this.resourcePatternResolver.getResources("s3://**/*.txt");
Resolving resources throughout all buckets can be very time consuming depending on the number of buckets a user owns. |
9.5. Using CloudFormation
CloudFormation also allows to create buckets during stack creation. These buckets will typically have a generated name
that must be used as the bucket name. In order to allow application developers to define static names inside their
configuration, Spring Cloud AWS provides support to resolve the generated bucket names.
Application developers can use the org.springframework.cloud.aws.core.env.ResourceIdResolver
interface to resolve the
physical names that are generated based on the logical names.
The next example shows a bucket definition inside a CloudFormation stack template. The bucket will be created with a name like integrationteststack-sampleBucket-23qysofs62tc2
"Resources": {
"sampleBucket": {
"Type": "AWS::S3::Bucket"
Application developers can resolve that name and use it to load resources as shown in the next example below.
private final ResourceLoader loader;
private final ResourceIdResolver idResolver;
@Autowired
public SimpleResourceLoadingBean(ResourceLoader loader, ResourceIdResolver idResolver) {
this.loader = loader;
this.idResolver = idResolver;
public void resolveAndLoad() {
String sampleBucketName = this.idResolver.
resolveToPhysicalResourceId("sampleBucket");
Resource resource = this.loader.
getResource("s3://" + sampleBucketName + "/test");
