7. Deployment Platforms
You can configure details of deployment platforms in App Broker configuration properties. These properties are under spring.cloud.appbroker.deployer
. Currently, Spring Cloud App Broker supports only Cloud Foundry as a deployment platform.
To configure a Cloud Foundry deployment platform, use properties under spring.cloud.appbroker.deployer.cloudfoundry
, as follows:
spring:
cloud:
appbroker:
deployer:
cloudfoundry:
api-host: api.sys.example.local
api-port: 443
username: admin
password: adminpass
client-id: EXAMPLE_ID
client-secret: EXAMPLE_SECRET
default-org: test
default-space: development
staging-timeout: 15
deployment-timeout: 10
The two properties, username and password , and the two properties, client-id and client-secret , are mutually exclusive. The client-id and client-secret properties are for use with OAuth 2.0.
