6. 服务绑定
默认情况下,Spring Cloud App Broker 不包含用于管理与其服务实例的绑定的功能。App Broker 提供了 Service Broker 作者可以实施的接口来控制服务绑定。
6.1. 创建 Service Binding
Service Broker 应用程序可以实现CreateServiceInstanceAppBindingWorkflow
接口。或者,Service Broker 应用程序也可以实现ServiceInstanceBindingService
接口。请参阅 Spring Cloud Open Service Broker 文档中的服务绑定。
6.2. 删除服务绑定
Service Broker 应用程序可以实现DeleteServiceInstanceBindingWorkflow
6.3. 持久化服务实例绑定状态
Spring Cloud App Broker 提供了ServiceInstanceBindingStateRepository
用于持久化服务实例绑定状态的接口。默认实现为InMemoryServiceInstanceBindingStateRepository
,它使用内存中的Map
保存状态,并提供轻松的入门体验。为了使用适当的数据库来持久化状态,实现ServiceInstanceBindingStateRepository
在您的应用程序中。
这InMemoryServiceInstanceBindingStateRepository 仅用于演示和测试目的。它不适合生产应用! |
6.3.1. 示例实现
以下示例显示了服务实例绑定状态存储库实现:
package com.example.appbroker;
class ExampleServiceInstanceBindingStateRepository implements ServiceInstanceBindingStateRepository {
private final ServiceInstanceBindingStateCrudRepository serviceInstanceBindingStateCrudRepository;
ExampleServiceInstanceBindingStateRepository(
ServiceInstanceBindingStateCrudRepository serviceInstanceBindingStateCrudRepository) {
this.serviceInstanceBindingStateCrudRepository = serviceInstanceBindingStateCrudRepository;
public Mono<ServiceInstanceState> saveState(String serviceInstanceId, String bindingId, OperationState state,
String description) {
return serviceInstanceBindingStateCrudRepository
.findByServiceInstanceIdAndBindingId(serviceInstanceId, bindingId)
.switchIfEmpty(Mono.just(new ServiceInstanceBinding()))
.flatMap(binding -> {
binding.setServiceInstanceId(serviceInstanceId);
binding.setBindingId(bindingId);
binding.setOperationState(state);
binding.setDescription(description);
return Mono.just(binding);
.flatMap(serviceInstanceBindingStateCrudRepository::save)
.map(ExampleServiceInstanceBindingStateRepository::toServiceInstanceState);
public Mono<ServiceInstanceState> getState(String serviceInstanceId, String bindingId) {
.switchIfEmpty(Mono.error(new IllegalArgumentException(
"Unknown binding: serviceInstanceId=" + serviceInstanceId + ", bindingId=" + bindingId)))
public Mono<ServiceInstanceState> removeState(String serviceInstanceId, String bindingId) {
return getState(serviceInstanceId, bindingId)
.doOnNext(serviceInstanceState -> serviceInstanceBindingStateCrudRepository
.deleteByServiceInstanceIdAndBindingId(serviceInstanceId, bindingId));
private static ServiceInstanceState toServiceInstanceState(ServiceInstanceBinding binding) {
return new ServiceInstanceState(binding.getOperationState(), binding.getDescription(), null);
持久化服务实例绑定状态的一种方法是使用 Spring DataCrudRepository
.以下示例显示了ReactiveCrudRepository
实现:
interface ServiceInstanceBindingStateCrudRepository extends ReactiveCrudRepository<ServiceInstanceBinding, Long> {
@Query("select * from service_instance_binding " +
"where service_instance_id = :service_instance_id " +
"and binding_id = :binding_id")
Mono<ServiceInstanceBinding> findByServiceInstanceIdAndBindingId(
@Param("service_instance_id") String serviceInstanceId,
@Param("binding_id") String bindingId);
@Query("delete from service_instance_binding " +
Mono<Void> deleteByServiceInstanceIdAndBindingId(
模型对象对于使用CrudRepository
.以下示例显示了ServiceInstanceBinding
型:
class ServiceInstanceBinding {
@Id
private Long id;
private String bindingId;
private String serviceInstanceId;
private String description;
private OperationState operationState;
public ServiceInstanceBinding() {
public ServiceInstanceBinding(String bindingId, String serviceInstanceId, String description,
OperationState operationState) {
this.bindingId = bindingId;
this.serviceInstanceId = serviceInstanceId;
this.description = description;
this.operationState = operationState;
public Long getId() {
return id;
public void setId(Long id) {
this.id = id;
public String getBindingId() {
return bindingId;
public void setBindingId(String bindingId) {
public String getServiceInstanceId() {
return serviceInstanceId;
public void setServiceInstanceId(String serviceInstanceId) {
public String getDescription() {
return description;
public void setDescription(String description) {
public OperationState getOperationState() {
return operationState;
public void setOperationState(OperationState operationState) {
