作方法:实施多租户
本指南展示了如何自定义 Spring Authorization Server 以支持多租户托管配置中每个主机的多个颁发者。 本指南的目的是演示为 Spring Authorization Server 构建支持多租户的组件的一般模式,该模式也可以应用于其他组件以满足您的需求。spring-doc.cadn.net.cn
定义租户标识符
OpenID Connect 1.0 提供者配置端点OAuth2 授权服务器元数据端点允许在颁发者标识符值中使用路径组件,从而有效地支持每个主机的多个颁发者。spring-doc.cadn.net.cn
例如,OpenID 提供程序配置请求 “http://localhost:9000/issuer1/.well-known/openid-configuration” 或 Authorization Server 元数据请求 “http://localhost:9000/.well-known/oauth-authorization-server/issuer1” 将返回以下配置元数据:spring-doc.cadn.net.cn
  "issuer": "http://localhost:9000/issuer1",
  "authorization_endpoint": "http://localhost:9000/issuer1/oauth2/authorize",
  "token_endpoint": "http://localhost:9000/issuer1/oauth2/token",
  "jwks_uri": "http://localhost:9000/issuer1/oauth2/jwks",
  "revocation_endpoint": "http://localhost:9000/issuer1/oauth2/revoke",
  "introspection_endpoint": "http://localhost:9000/issuer1/oauth2/introspect",
协议端点的基 URL 是颁发者标识符值。
实质上,带有路径组件的颁发者标识符表示“租户标识符”。spring-doc.cadn.net.cn
启用多个颁发者
默认情况下,对每个主机使用多个颁发者的支持处于禁用状态。 要启用,请添加以下配置:spring-doc.cadn.net.cn
AuthorizationServerSettingsConfig
import org.springframework.security.oauth2.server.authorization.settings.AuthorizationServerSettings;
public class AuthorizationServerSettingsConfig {
	public AuthorizationServerSettings authorizationServerSettings() {
		return AuthorizationServerSettings.builder()
				.multipleIssuersAllowed(true)	(1)
1 Set to true to allow usage of multiple issuers per host.
Create a component registry
We start by building a simple registry for managing the concrete components for each tenant. The registry contains the logic for retrieving a concrete implementation of a particular class using the issuer identifier value.spring-doc.cadn.net.cn
We will use the following class in each of the delegating implementations below:spring-doc.cadn.net.cn
TenantPerIssuerComponentRegistry
import java.util.Map;
import java.util.concurrent.ConcurrentHashMap;
import java.util.concurrent.ConcurrentMap;
import org.springframework.lang.Nullable;
import org.springframework.security.oauth2.server.authorization.context.AuthorizationServerContext;
import org.springframework.security.oauth2.server.authorization.context.AuthorizationServerContextHolder;
import org.springframework.util.Assert;
@Component
public class TenantPerIssuerComponentRegistry {
	private final ConcurrentMap<String, Map<Class<?>, Object>> registry = new ConcurrentHashMap<>();
	public <T> void register(String tenantId, Class<T> componentClass, T component) {	(1)
		Assert.hasText(tenantId, "tenantId cannot be empty");
		Assert.notNull(componentClass, "componentClass cannot be null");
		Assert.notNull(component, "component cannot be null");
		Map<Class<?>, Object> components = this.registry.computeIfAbsent(tenantId, (key) -> new ConcurrentHashMap<>());
		components.put(componentClass, component);
	@Nullable
	public <T> T get(Class<T> componentClass) {
		AuthorizationServerContext context = AuthorizationServerContextHolder.getContext();
		if (context == null || context.getIssuer() == null) {
			return null;
		for (Map.Entry<String, Map<Class<?>, Object>> entry : this.registry.entrySet()) {
			if (context.getIssuer().endsWith(entry.getKey())) {
				return componentClass.cast(entry.getValue().get(componentClass));
		return null;
1 Component registration implicitly enables an allowlist of approved issuers that can be used.
This registry is designed to allow components to be easily registered at startup to support adding tenants statically, but also supports adding tenants dynamically at runtime.
Create multi-tenant components
The components that require multi-tenant capability are:spring-doc.cadn.net.cn
For each of these components, an implementation of a composite can be provided that delegates to the concrete component associated to the "requested" issuer identifier.spring-doc.cadn.net.cn
Let’s step through a scenario of how to customize Spring Authorization Server to support 2x tenants for each multi-tenant capable component.spring-doc.cadn.net.cn
Multi-tenant RegisteredClientRepository
The following example shows a sample implementation of a RegisteredClientRepository that is composed of 2x JdbcRegisteredClientRepository instances, where each instance is mapped to an issuer identifier:spring-doc.cadn.net.cn
RegisteredClientRepositoryConfig
import java.util.UUID;
import javax.sql.DataSource;
import org.springframework.beans.factory.annotation.Qualifier;
import org.springframework.jdbc.core.JdbcTemplate;
import org.springframework.security.oauth2.core.AuthorizationGrantType;
import org.springframework.security.oauth2.core.ClientAuthenticationMethod;
import org.springframework.security.oauth2.server.authorization.client.JdbcRegisteredClientRepository;
import org.springframework.security.oauth2.server.authorization.client.RegisteredClient;
import org.springframework.security.oauth2.server.authorization.client.RegisteredClientRepository;
public class RegisteredClientRepositoryConfig {
	public RegisteredClientRepository registeredClientRepository(
			@Qualifier("issuer1-data-source") DataSource issuer1DataSource,
			@Qualifier("issuer2-data-source") DataSource issuer2DataSource,
			TenantPerIssuerComponentRegistry componentRegistry) {
		JdbcRegisteredClientRepository issuer1RegisteredClientRepository =
				new JdbcRegisteredClientRepository(new JdbcTemplate(issuer1DataSource));	(1)
		issuer1RegisteredClientRepository.save(
				RegisteredClient.withId(UUID.randomUUID().toString())
						.clientId("client-1")
						.clientSecret("{noop}secret")
						.clientAuthenticationMethod(ClientAuthenticationMethod.CLIENT_SECRET_BASIC)
						.authorizationGrantType(AuthorizationGrantType.CLIENT_CREDENTIALS)
						.scope("scope-1")
						.build()
		JdbcRegisteredClientRepository issuer2RegisteredClientRepository =
				new JdbcRegisteredClientRepository(new JdbcTemplate(issuer2DataSource));	(2)
		issuer2RegisteredClientRepository.save(
						.clientId("client-2")
						.scope("scope-2")
						.build()
		componentRegistry.register("issuer1", RegisteredClientRepository.class, issuer1RegisteredClientRepository);
		componentRegistry.register("issuer2", RegisteredClientRepository.class, issuer2RegisteredClientRepository);
		return new DelegatingRegisteredClientRepository(componentRegistry);
	private static class DelegatingRegisteredClientRepository implements RegisteredClientRepository {	(3)
		private final TenantPerIssuerComponentRegistry componentRegistry;
		private DelegatingRegisteredClientRepository(TenantPerIssuerComponentRegistry componentRegistry) {
			this.componentRegistry = componentRegistry;
		public void save(RegisteredClient registeredClient) {
			getRegisteredClientRepository().save(registeredClient);
		public RegisteredClient findById(String id) {
			return getRegisteredClientRepository().findById(id);
		public RegisteredClient findByClientId(String clientId) {
			return getRegisteredClientRepository().findByClientId(clientId);
		private RegisteredClientRepository getRegisteredClientRepository() {
			RegisteredClientRepository registeredClientRepository =
					this.componentRegistry.get(RegisteredClientRepository.class);	(4)
			Assert.state(registeredClientRepository != null,
					"RegisteredClientRepository not found for \"requested\" issuer identifier.");	(5)
			return registeredClientRepository;
Click on the "Expand folded text" icon in the code sample above to display the full example.
1 A JdbcRegisteredClientRepository instance mapped to issuer identifier issuer1 and using a dedicated DataSource.
2 A JdbcRegisteredClientRepository instance mapped to issuer identifier issuer2 and using a dedicated DataSource.
3 A composite implementation of a RegisteredClientRepository that delegates to a JdbcRegisteredClientRepository mapped to the "requested" issuer identifier.
4 Obtain the JdbcRegisteredClientRepository that is mapped to the "requested" issuer identifier indicated by AuthorizationServerContext.getIssuer().
5 If unable to find JdbcRegisteredClientRepository, then error since the "requested" issuer identifier is not in the allowlist of approved issuers.
Explicitly configuring the issuer identifier via AuthorizationServerSettings.builder().issuer("http://localhost:9000") forces to a single-tenant configuration. Avoid explicitly configuring the issuer identifier when using a multi-tenant hosting configuration.
In the preceding example, each of the JdbcRegisteredClientRepository instances are configured with a JdbcTemplate and associated DataSource. This is important in a multi-tenant configuration as a primary requirement is to have the ability to isolate the data from each tenant.spring-doc.cadn.net.cn
Configuring a dedicated DataSource for each component instance provides the flexibility to isolate the data in its own schema within the same database instance or alternatively isolate the data in a separate database instance altogether.spring-doc.cadn.net.cn
The following example shows a sample configuration of 2x DataSource @Bean (one for each tenant) that are used by the multi-tenant capable components:spring-doc.cadn.net.cn
DataSourceConfig
import org.springframework.jdbc.datasource.embedded.EmbeddedDatabase;
import org.springframework.jdbc.datasource.embedded.EmbeddedDatabaseBuilder;
import org.springframework.jdbc.datasource.embedded.EmbeddedDatabaseType;
public class DataSourceConfig {
	@Bean("issuer1-data-source")
	public EmbeddedDatabase issuer1DataSource() {
		return new EmbeddedDatabaseBuilder()
				.setName("issuer1-db")	(1)
				.setType(EmbeddedDatabaseType.H2)
				.setScriptEncoding("UTF-8")
				.addScript("org/springframework/security/oauth2/server/authorization/oauth2-authorization-schema.sql")
				.addScript("org/springframework/security/oauth2/server/authorization/oauth2-authorization-consent-schema.sql")
				.addScript("org/springframework/security/oauth2/server/authorization/client/oauth2-registered-client-schema.sql")
	@Bean("issuer2-data-source")
	public EmbeddedDatabase issuer2DataSource() {
				.setName("issuer2-db")	(2)
1 Use a separate H2 database instance using issuer1-db as the name.
2 Use a separate H2 database instance using issuer2-db as the name.
Multi-tenant OAuth2AuthorizationService
The following example shows a sample implementation of an OAuth2AuthorizationService that is composed of 2x JdbcOAuth2AuthorizationService instances, where each instance is mapped to an issuer identifier:spring-doc.cadn.net.cn
OAuth2AuthorizationServiceConfig
import org.springframework.security.oauth2.server.authorization.JdbcOAuth2AuthorizationService;
import org.springframework.security.oauth2.server.authorization.OAuth2Authorization;
import org.springframework.security.oauth2.server.authorization.OAuth2AuthorizationService;
import org.springframework.security.oauth2.server.authorization.OAuth2TokenType;
public class OAuth2AuthorizationServiceConfig {
	public OAuth2AuthorizationService authorizationService(
			TenantPerIssuerComponentRegistry componentRegistry,
			RegisteredClientRepository registeredClientRepository) {
		componentRegistry.register("issuer1", OAuth2AuthorizationService.class,
				new JdbcOAuth2AuthorizationService(	(1)
						new JdbcTemplate(issuer1DataSource), registeredClientRepository));
		componentRegistry.register("issuer2", OAuth2AuthorizationService.class,
				new JdbcOAuth2AuthorizationService(	(2)
						new JdbcTemplate(issuer2DataSource), registeredClientRepository));
		return new DelegatingOAuth2AuthorizationService(componentRegistry);
	private static class DelegatingOAuth2AuthorizationService implements OAuth2AuthorizationService {	(3)
		private DelegatingOAuth2AuthorizationService(TenantPerIssuerComponentRegistry componentRegistry) {
		public void save(OAuth2Authorization authorization) {
			getAuthorizationService().save(authorization);
		public void remove(OAuth2Authorization authorization) {
			getAuthorizationService().remove(authorization);
		public OAuth2Authorization findById(String id) {
			return getAuthorizationService().findById(id);
		public OAuth2Authorization findByToken(String token, OAuth2TokenType tokenType) {
			return getAuthorizationService().findByToken(token, tokenType);
		private OAuth2AuthorizationService getAuthorizationService() {
			OAuth2AuthorizationService authorizationService =
					this.componentRegistry.get(OAuth2AuthorizationService.class);	(4)
			Assert.state(authorizationService != null,
					"OAuth2AuthorizationService not found for \"requested\" issuer identifier.");	(5)
			return authorizationService;
1 A JdbcOAuth2AuthorizationService instance mapped to issuer identifier issuer1 and using a dedicated DataSource.
2 A JdbcOAuth2AuthorizationService instance mapped to issuer identifier issuer2 and using a dedicated DataSource.
3 A composite implementation of an OAuth2AuthorizationService that delegates to a JdbcOAuth2AuthorizationService mapped to the "requested" issuer identifier.
4 Obtain the JdbcOAuth2AuthorizationService that is mapped to the "requested" issuer identifier indicated by AuthorizationServerContext.getIssuer().
5 If unable to find JdbcOAuth2AuthorizationService, then error since the "requested" issuer identifier is not in the allowlist of approved issuers.
The following example shows a sample implementation of an OAuth2AuthorizationConsentService that is composed of 2x JdbcOAuth2AuthorizationConsentService instances, where each instance is mapped to an issuer identifier:spring-doc.cadn.net.cn
OAuth2AuthorizationConsentServiceConfig
import org.springframework.security.oauth2.server.authorization.JdbcOAuth2AuthorizationConsentService;
import org.springframework.security.oauth2.server.authorization.OAuth2AuthorizationConsent;
import org.springframework.security.oauth2.server.authorization.OAuth2AuthorizationConsentService;
public class OAuth2AuthorizationConsentServiceConfig {
	public OAuth2AuthorizationConsentService authorizationConsentService(
		componentRegistry.register("issuer1", OAuth2AuthorizationConsentService.class,
				new JdbcOAuth2AuthorizationConsentService(	(1)
		componentRegistry.register("issuer2", OAuth2AuthorizationConsentService.class,
				new JdbcOAuth2AuthorizationConsentService(	(2)
		return new DelegatingOAuth2AuthorizationConsentService(componentRegistry);
	private static class DelegatingOAuth2AuthorizationConsentService implements OAuth2AuthorizationConsentService {	(3)
		private DelegatingOAuth2AuthorizationConsentService(TenantPerIssuerComponentRegistry componentRegistry) {
		public void save(OAuth2AuthorizationConsent authorizationConsent) {
			getAuthorizationConsentService().save(authorizationConsent);
		public void remove(OAuth2AuthorizationConsent authorizationConsent) {
			getAuthorizationConsentService().remove(authorizationConsent);
		public OAuth2AuthorizationConsent findById(String registeredClientId, String principalName) {
			return getAuthorizationConsentService().findById(registeredClientId, principalName);
		private OAuth2AuthorizationConsentService getAuthorizationConsentService() {
			OAuth2AuthorizationConsentService authorizationConsentService =
					this.componentRegistry.get(OAuth2AuthorizationConsentService.class);	(4)
			Assert.state(authorizationConsentService != null,
					"OAuth2AuthorizationConsentService not found for \"requested\" issuer identifier.");	(5)
			return authorizationConsentService;
1 A JdbcOAuth2AuthorizationConsentService instance mapped to issuer identifier issuer1 and using a dedicated DataSource.
2 A JdbcOAuth2AuthorizationConsentService instance mapped to issuer identifier issuer2 and using a dedicated DataSource.
3 A composite implementation of an OAuth2AuthorizationConsentService that delegates to a JdbcOAuth2AuthorizationConsentService mapped to the "requested" issuer identifier.
4 Obtain the JdbcOAuth2AuthorizationConsentService that is mapped to the "requested" issuer identifier indicated by AuthorizationServerContext.getIssuer().
5 If unable to find JdbcOAuth2AuthorizationConsentService, then error since the "requested" issuer identifier is not in the allowlist of approved issuers.
Multi-tenant JWKSource
And finally, the following example shows a sample implementation of a JWKSource<SecurityContext> that is composed of 2x JWKSet instances, where each instance is mapped to an issuer identifier:spring-doc.cadn.net.cn
JWKSourceConfig
import java.security.KeyPair;
import java.security.KeyPairGenerator;
import java.security.interfaces.RSAPrivateKey;
import java.security.interfaces.RSAPublicKey;
import java.util.List;
import com.nimbusds.jose.KeySourceException;
import com.nimbusds.jose.jwk.JWK;
import com.nimbusds.jose.jwk.JWKSelector;
import com.nimbusds.jose.jwk.JWKSet;
import com.nimbusds.jose.jwk.RSAKey;
import com.nimbusds.jose.jwk.source.JWKSource;
import com.nimbusds.jose.proc.SecurityContext;
public class JWKSourceConfig {
	public JWKSource<SecurityContext> jwkSource(TenantPerIssuerComponentRegistry componentRegistry) {
		componentRegistry.register("issuer1", JWKSet.class, new JWKSet(generateRSAJwk()));	(1)
		componentRegistry.register("issuer2", JWKSet.class, new JWKSet(generateRSAJwk()));	(2)
		return new DelegatingJWKSource(componentRegistry);
	private static RSAKey generateRSAJwk() {
		KeyPair keyPair;
		try {
			KeyPairGenerator keyPairGenerator = KeyPairGenerator.getInstance("RSA");
			keyPairGenerator.initialize(2048);
			keyPair = keyPairGenerator.generateKeyPair();
		} catch (Exception ex) {
			throw new IllegalStateException(ex);
		RSAPublicKey publicKey = (RSAPublicKey) keyPair.getPublic();
		RSAPrivateKey privateKey = (RSAPrivateKey) keyPair.getPrivate();
		return new RSAKey.Builder(publicKey)
				.privateKey(privateKey)
				.keyID(UUID.randomUUID().toString())
	private static class DelegatingJWKSource implements JWKSource<SecurityContext> {	(3)
		private DelegatingJWKSource(TenantPerIssuerComponentRegistry componentRegistry) {
		public List<JWK> get(JWKSelector jwkSelector, SecurityContext context) throws KeySourceException {
			return jwkSelector.select(getJwkSet());
		private JWKSet getJwkSet() {
			JWKSet jwkSet = this.componentRegistry.get(JWKSet.class);	(4)
			Assert.state(jwkSet != null, "JWKSet not found for \"requested\" issuer identifier.");	(5)
			return jwkSet;
1 A JWKSet instance mapped to issuer identifier issuer1.
2 A JWKSet instance mapped to issuer identifier issuer2.
3 A composite implementation of an JWKSource<SecurityContext> that uses the JWKSet mapped to the "requested" issuer identifier.
4 Obtain the JWKSet that is mapped to the "requested" issuer identifier indicated by AuthorizationServerContext.getIssuer().
5 If unable to find JWKSet, then error since the "requested" issuer identifier is not in the allowlist of approved issuers.
Add Tenants Dynamically
If the number of tenants is dynamic and can change at runtime, defining each DataSource as a @Bean may not be feasible. In this case, the DataSource and corresponding components can be registered through other means at application startup and/or runtime.spring-doc.cadn.net.cn
The following example shows a Spring @Service capable of adding tenants dynamically:spring-doc.cadn.net.cn
TenantService
import org.springframework.stereotype.Service;
@Service
public class TenantService {
	public TenantService(TenantPerIssuerComponentRegistry componentRegistry) {
	public void createTenant(String tenantId) {
		EmbeddedDatabase dataSource = createDataSource(tenantId);
		JdbcTemplate jdbcOperations = new JdbcTemplate(dataSource);
				new JdbcRegisteredClientRepository(jdbcOperations);
		this.componentRegistry.register(tenantId, RegisteredClientRepository.class, registeredClientRepository);
				new JdbcOAuth2AuthorizationService(jdbcOperations, registeredClientRepository);
		this.componentRegistry.register(tenantId, OAuth2AuthorizationService.class, authorizationService);
				new JdbcOAuth2AuthorizationConsentService(jdbcOperations, registeredClientRepository);
		this.componentRegistry.register(tenantId, OAuth2AuthorizationConsentService.class, authorizationConsentService);
		JWKSet jwkSet = new JWKSet(generateRSAJwk());
		this.componentRegistry.register(tenantId, JWKSet.class, jwkSet);
	private EmbeddedDatabase createDataSource(String tenantId) {
				.setName(tenantId)
		KeyPair keyPair;
		try {
